S-19518AY2A-V9T1U4
S-19518AY2A-V9T1U4
    ABLIC(艾普凌科)
    TO-252-9
    IC REG LIN 3.3V 250MA TO252-9S
S-19518AY2A-V9T1U4 数据手册
S-19518 Series www.ablic.com AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 © ABLIC Inc., 2019-2023 The S-19518 Series, developed by using high-withstand voltage CMOS technology, is a low dropout positive voltage regulator with the window watchdog timer and the reset function, which has high-withstand voltage. The monitoring time of watchdog timer can be adjusted by an external capacitor. Moreover, a voltage detection circuit which monitors the output voltage is also prepared. ABLIC Inc. offers a "thermal simulation service" which supports the thermal design in conditions when our power management ICs are in use by customers. Our thermal simulation service will contribute to reducing the risk in the thermal design at customers' development stage. ABLIC Inc. also offers FIT rate calculated based on actual customer usage conditions in order to support customer functional safety design. Contact our sales representatives for details. Caution This product can be used in vehicle equipment and in-vehicle equipment. Before using the product for these purposes, it is imperative to contact our sales representatives.  Features Regulator block • Output voltage: • Input voltage: • Output voltage accuracy: • Dropout voltage: • Output current: • Input and output capacitors: • Built-in overcurrent protection circuit: • Built-in thermal shutdown circuit: • Built-in ON / OFF circuit: 3.3 V, 5.0 V 3.0 V to 36.0 V ±2.0% (Tj = −40°C to +150°C) 100 mV typ. (5.0 V output product, IOUT = 100 mA) Possible to output 250 mA (VIN = VOUT(S) + 1.0 V)*1 A ceramic capacitor of 1.0 μF or more can be used. Limits overcurrent of output transistor. Detection temperature 170°C typ. Ensures long battery life. Detector block • Detection voltage: • Detection voltage accuracy: • Hysteresis width: • Release delay time is adjustable*2: 2.6 V to 4.7 V, selectable in 0.1 V step ±2.0% (Tj = −40°C to +150°C) 0.12 V min. 20 ms typ. (CDLY = 10 nF) Watchdog timer block • Watchdog activation current: • Watchdog trigger time is adjustable*2: • Autonomous watchdog operation function: • Watchdog mode: 1.5 mA typ. 46 ms typ. (CDLY = 10 nF) Watchdog timer operates due to detection of load current. Window mode Overall • Current consumption: • Operation temperature range: • Lead-free (Sn 100%), halogen-free • Withstand 45 V load dump • AEC-Q100 qualified*3 *1. *2. *3. 3.2 μA typ. (During regulator operation, during watchdog timer deactivation) 0.1 μA typ. (During regulator stop) Ta = −40°C to +125°C Please make sure that the loss of the IC will not exceed the power dissipation when the output current is large. The release delay time and the watchdog trigger time can be adjusted by connecting CDLY to the DLY pin. Contact our sales representatives for details.  Applications • Constant-voltage power supply for automotive electric component, monitoring of microcontroller  Packages • TO-252-9S • HSOP-8A 1 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00  Block Diagram VIN VOUT Thermal shutdown circuit Overcurrent protection circuit Reference voltage circuit EN ON / OFF circuit + − *1 WI WDT circuit WEN + − Reference voltage circuit WO / RO Voltage detection circuit VSS *1. The ON / OFF circuit controls the internal circuit and the output transistor. Figure 1 2 DLY AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series  AEC-Q100 Qualified This IC supports AEC-Q100 for the operation temperature grade 1. Contact our sales representatives for details of AEC-Q100 reliability specification.  Product Name Structure 1. Product name S-19518 A x x A - xxxx U 4 Environmental code U: Lead-free (Sn 100%), halogen-free Package abbreviation and IC packing specifications*1 V9T1: TO-252-9S, Tape E8T1: HSOP-8A, Tape Operation temperature A: Ta = −40°C to +125°C Detection voltage*2 J to Z, 0 to 5 Output voltage*2 F, Y *1. *2. 2. Refer to the tape drawing. Refer to "2. Product option list". Product option list Table 1 Output Voltage Set Output Symbol Voltage 5.0 V 3.3 V F Y Table 2 Set Detection Voltage Symbol 4.7 V 4.6 V 4.5 V 4.4 V 4.3 V 4.2 V 4.1 V 4.0 V 3.9 V 3.8 V 3.7 V Remark Set output voltage ≥ Set detection voltage + 0.3 V J K L M N P Q R S T U Detection Voltage Set Detection Voltage 3.6 V 3.5 V 3.4 V 3.3 V 3.2 V 3.1 V 3.0 V 2.9 V 2.8 V 2.7 V 2.6 V Symbol V W X Y Z 0 1 2 3 4 5 3 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00 3. Packages Table 3 Package Name TO-252-9S HSOP-8A 4. Dimension VA009-A-P-SD FH008-A-P-SD Package Drawing Codes Tape VA009-A-C-SD FH008-A-C-SD Reel VA009-A-R-SD FH008-A-R-SD Land VA009-A-L-SD FH008-A-L-SD Product name list Table 4 Output Voltage (VOUT) Detection Voltage (−VDET) TO-252-9S HSOP-8A 3.3 V ± 2.0% 3.3 V ± 2.0% 3.3 V ± 2.0% 5.0 V ± 2.0% 5.0 V ± 2.0% 2.8 V ± 2.0% 2.9 V ± 2.0% 3.0 V ± 2.0% 4.2 V ± 2.0% 4.6 V ± 2.0% S-19518AY3A-V9T1U4 S-19518AY2A-V9T1U4 S-19518AY1A-V9T1U4 S-19518AFPA-V9T1U4 S-19518AFKA-V9T1U4 S-19518AY3A-E8T1U4 S-19518AY2A-E8T1U4 S-19518AY1A-E8T1U4 S-19518AFPA-E8T1U4 S-19518AFKA-E8T1U4 Remark 4 Please contact our sales representatives for products other than the above. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series  Pin Configurations 1. TO-252-9S Table 5 Top view Pin No. 5 1 2 3 4 6 7 8 9 Figure 2 *1. *2. 2. Symbol Description 1 VOUT Voltage output pin (Regulator block) 2 WEN 3 DLY Watchdog enable pin Connection pin for release delay time and monitoring time adjustment capacitor 4 NC*1 No connection 5 VSS GND pin 6 WO / RO*2 7 WI Watchdog input pin 8 EN Enable pin 9 VIN Voltage input pin (Regulator block) WO Watchdog output pin RO Reset output pin The NC pin is electrically open. The NC pin can be connected to the VIN pin or the VSS pin. The WO / RO pin combines the watchdog output pin and the reset output pin. HSOP-8A Table 6 Top view Pin No. 1 8 2 7 3 6 4 5 Bottom view 8 1 7 2 6 3 5 4 Symbol Description 1 VOUT Voltage output pin (Regulator block) 2 WEN Watchdog enable pin 3 VSS 4 DLY 5 WO / RO*2 GND pin Connection pin for release delay time and monitoring time adjustment capacitor Watchdog output pin WO 6 WI Reset output pin RO Watchdog input pin 7 EN Enable pin 8 VIN Voltage input pin (Regulator block) *1 Figure 3 *1. *2. Connect the heat sink of backside at shadowed area to the board, and set electric potential GND. However, do not use it as the function of electrode. The WO / RO pin combines the watchdog output pin and the reset output pin. 5 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00  Absolute Maximum Ratings Table 7 (Tj = −40°C to +150°C unless otherwise specified) Item VIN pin voltage EN pin voltage VOUT pin voltage DLY pin voltage WEN pin voltage WI pin voltage WO / RO pin voltage Output current Junction temperature Operation ambient temperature Storage temperature Caution Symbol VIN VEN VOUT VDLY VWEN VWI VWO / RO IOUT IWO / RO Tj Topr Tstg Absolute Maximum Rating VSS − 0.3 to VSS + 45.0 VSS − 0.3 to VSS + 45.0 VSS − 0.3 to VIN + 0.3 ≤ VSS + 7.0 VSS − 0.3 to VOUT + 0.3 ≤ VSS + 7.0 VSS − 0.3 to VSS + 7.0 VSS − 0.3 to VOUT + 0.3 ≤ VSS + 7.0 VSS − 0.3 to VOUT + 0.3 ≤ VSS + 7.0 325 30 −40 to +150 −40 to +125 −40 to +150 Unit V V V V V V V mA mA °C °C °C The absolute maximum ratings are rated values exceeding which the product could suffer physical damage. These values must therefore not be exceeded under any conditions.  Thermal Resistance Value Table 8 Item Symbol Condition TO-252-9S Max. Unit °C/W − 84 − − − °C/W − − − °C/W Board B Board C − − − °C/W Board E Board A − − 24 °C/W °C/W Board B − 105 − − − − °C/W Board C − − − °C/W Board D − − − °C/W Board E Test environment: compliance with JEDEC STANDARD JESD51-2A Measurement values when this IC is mounted on each board − 31 − °C/W θJA HSOP-8A Remark 6 Typ. − Board D Junction-to-ambient thermal resistance1, *2 *1. *2. Min. Board A Refer to " Power Dissipation" and "Test Board" for details. AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series  Recommended Operation Conditions Item Symbol VIN pin voltage VIN EN pin voltage WEN pin voltage WI pin voltage Watchdog input "H" time*2 Watchdog input "L" time*2 Watchdog input frequency*2 Input capacitance Output capacitance Equivalent series resistance Release delay time and monitoring time adjustment capacitance*3 External pull-up resistance for output pin VEN VWEN VWI thigh tIow fWI CIN CL RESR Table 9 Condition − Autonomous watchdog operation function*1 − − − − − Duty ratio 50% − − Output capacitor (CL) − CDLY RextR Connected to WO / RO pin Min. Typ. − Max. Unit 36.0 V − 36.0 V − − − − − − − − − VIN VOUT VOUT − − 0.2 − − 100 V V V μs μs MHz μF μF Ω 1 10 − nF 3 − − kΩ 3.0 VOUT(S) + 1.0 0 0 0 5.0 5.0 − 1.0 1.0 − *1. Refer to "3. Watchdog timer block" in " Operation" for the autonomous watchdog operation function. *2. When inputting a rising edge that satisfies the condition of Figure 4 to the WI pin, the watchdog timer detects a trigger. The signal input from the monitored object by the watchdog timer should satisfy the condition of Figure 4. *3. Refer to "2. Release delay time and monitoring time adjustment capacitor (CDLY)" in " Selection of External Parts" for the details. VWI thigh tlow VSH,WI VSL,WI 1 / fWI t Figure 4 Caution Generally a series regulator may cause oscillation, depending on the selection of external parts. Confirm that no oscillation occurs in the actual application using capacitors that meet the above CIN, CL, and RESR. 7 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00  Electrical Characteristics 1. Regulator block Table 10 (VIN = 13.5 V, Tj = −40°C to +150°C unless otherwise specified) Item Symbol Condition Output voltage*1 VOUT(E) VOUT(S) + 1.0 V ≤ VIN ≤ 18.0 V, 1 mA ≤ IOUT ≤ 100 mA Output current*2 IOUT VIN ≥ VOUT(S) + 1.0 V IOUT = 100 mA Dropout voltage*3 Vdrop IOUT = 250 mA Min. Typ. Max. Unit Test Circuit VOUT(S) − 2.0% VOUT(S) VOUT(S) + 2.0% V 1 250*7 − − mA 2 VOUT(S) = 3.3 V − 120 240 mV 1 VOUT(S) = 5.0 V − 100 200 mV 1 VOUT(S) = 3.3 V − 300 600 mV 1 VOUT(S) = 5.0 V − 250 500 mV 1 Line regulation*4 ΔVOUT1 ΔVIN • VOUT VOUT(S) + 1.0 V ≤ VIN ≤ 36.0 V, IOUT = 1 mA − 0.01 0.02 %/V 1 Load regulation*5 ΔVOUT2 VIN = VOUT(S) + 1.0 V, 1 mA ≤ IOUT ≤ 250 mA, Ta = +25°C − 10 50 mV 1 Input voltage VIN − 3.0 − 36.0 V − EN pin input voltage "H" VSH,EN − 2 − − V 4 EN pin input voltage "L" VSL,EN − − − 0.8 V 4 EN pin input current "H" ISH,EN VEN = VIN − − 1 μA 4 EN pin input current "L" ISL,EN VEN = 0 V VIN = 13.5 V, IOUT = 30 mA, f = 100 Hz, ΔVrip = 1.0 Vp-p − − 0.1 μA 4 VOUT(S) = 3.3 V − 65 − dB 3 VOUT(S) = 5.0 V − 60 − dB 3 Ripple rejection Limit current*6 Short-circuit current Thermal shutdown detection temperature Thermal shutdown release temperature |RR| ILIM VIN = VOUT(S) + 1.0 V, Ta = +25°C 250 450 650 mA 2 Ishort VIN = 13.5 V, VOUT = 0 V, Ta = +25°C 40 80 120 mA 2 TSD Junction temperature − 170 − °C − TSR Junction temperature − 135 − °C − *1. The accuracy is guaranteed when the input voltage, output current, and temperature satisfy the conditions listed above. VOUT(S): Set output voltage VOUT(E): Actual output voltage *2. The output current when increasing the output current gradually until the output voltage has reached the value of 95% of VOUT(E). *3. The difference between input voltage (VIN1) and the output voltage when decreasing input voltage (VIN) gradually until the output voltage has dropped out to the value of 98% of output voltage (VOUT3). Vdrop: VIN1 − (VOUT3 × 0.98) VOUT3: Output voltage when VIN = VOUT(S) + 1.0 V *4. The dependency of the output voltage against the input voltage. The value shows how much the output voltage changes due to a change in the input voltage while keeping output current constant. *5. The dependency of the output voltage against the output current. The value shows how much the output voltage changes due to a change in the output current while keeping input voltage constant. *6. The current limited by overcurrent protection circuit. *7. Due to limitation of the power dissipation, this value may not be satisfied. Attention should be paid to the power dissipation when the output current is large. This specification is guaranteed by design. 8 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series 2. Detector block Table 11 (Tj = −40°C to +150°C unless otherwise specified) Item Symbol Condition Min. Typ. Max. Unit Test Circuit −VDET(S) − 2.0% −VDET(S) −VDET(S) + 2.0% V 5 Detection voltage*1 −VDET − Hysteresis width*2 VHYS − 120 150 180 mV 5 − VOUT(S) × 0.9 − − V 5 Reset output voltage "H" VROH Reset output voltage "L" VROL VOUT ≥ 1.0 V, RextR ≥ 3 kΩ, Connected to VOUT pin − 0.2 0.4 V 5 Reset pull-up resistance RRO VOUT pin internal resistance, VOUT ≥ +VDET 20 30 45 kΩ − Reset output current IRO Release delay time*3 trd Reset reaction time*4 trr VRO = 0.4 V, VOUT = −VDET(S) × 0.95 CDLY = 10 nF − 3.0 − − mA 6 16 20 24 ms 5 200 μs 5 − − *1. The VOUT pin voltage at which the output of the RO pin switches from "H" to "L". −VDET(S): Set detection voltage −VDET: Actual detection voltage *2. The voltage difference between the detection voltage (−VDET) and the release voltage (+VDET). The relation between the actual output voltage (VOUT(E)) of the regulator block and the actual release voltage (+VDET = −VDET + VHYS) of the detector block is as follows. VOUT(E) > +VDET *3. The time from when VOUT exceeds +VDET to when the RO pin output inverts (Refer to Figure 5). This value changes according to the release delay time and monitoring time adjustment capacitor (CDLY). *4. The time from when VOUT falls below −VDET to when the RO pin output inverts (Refer to Figure 6). V VOUT(S) V VOUT(S) VOUT +VDET −VDET(S) ×0.95 VRO −VDET VOUT −VDET(S) ×0.95 VOUT / 2 VOUT / 2 VRO t t trd Figure 5 Release Delay Time trr Figure 6 Reset Reaction Time 9 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00 3. Watchdog timer block Table 12 Item (VIN = 13.5 V, Tj = −40°C to +150°C unless otherwise specified) Test Condition Min. Typ. Max. Unit Circuit Symbol Watchdog activation threshold current Watchdog deactivation threshold current IO,WDact − − 1.5 1.9 mA 9 IO,WDdeact − 0.85 1.25 − mA 9 WI pin input voltage "H" VSH,WI − VOUT(S) × 0.7 − − V 7 WI pin input voltage "L" VSL,WI − − − VOUT(S) × 0.3 V 7 WI pin input current "H" ISH,WI VWI = VOUT(S) − − 1 μA 7 WI pin input current "L" ISL,WI VWI = 0 V WEN pin input voltage "H" VSH,WEN WEN pin input voltage "L" WEN pin input curernt "H" − − 0.1 μA 7 − 2 − − V 8 VSL,WEN − − − 0.8 V 8 ISH,WEN VWEN = VOUT(S) − − 1 μA 8 WEN pin input current "L" Watchdog output "L" time*1 ISL,WEN tWD,L − − 0.1 μA 8 CDLY = 10 nF 9.2 11.5 13.8 ms 9 Watchdog trigger time*2 tWI,tr CDLY = 10 nF 39.1 46 52.9 ms 9 VWEN = 0 V Watchdog double-pulse tWI,dp CDLY = 10 nF 9.2 11.5 13.8 ms 9 detection time*3 *1. The time when the WO / RO pin continues "L" after the watchdog timer detects a time-out or double-pulse (Refer to Figure 7). This value changes according to CDLY. *2. The time from when the watchdog timer initiates the detection of a trigger signal to when a time-out is detected and the WO / RO pin output changes to "L" (Refer to Figure 7). This value changes according to CDLY. *3. The time from when the watchdog timer initiates the detection of a trigger signal to when a trigger is detected again before tWI,dp elapses and the WO / RO pin output changes to "L" (Refer to Figure 8). This value changes according to CDLY. VWI VWI t VWO/RO tWI,dp Figure 8 IO,WDact, "L": IOUT < IO,WDdeact 23 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00 3. 4 Watchdog input circuit By inputting a rising edge to the WI pin, the watchdog timer detects a trigger. Refer to " Recommended Operation Conditions" for the input conditions of the signal to be input from the watchdog timer monitored object to the WI pin. The WI pin is pulled down internally by a constant current source. For this reason, if the WI pin is used in a floating status, the WI pin sets to "L". Note that if any voltage other than "L" or "H" is input to the WI pin, the current consumption increases. Triggers are detected only when the WO pin is outputting "H" and CDLY charge-discharge operation is being carried out while the watchdog timer is carrying out monitoring operation. Caution 3. 5 Under a noisy environment, the watchdog input circuit may detect the noise as a trigger signal. Sufficiently evaluate with the actual application to confirm that a trigger is detected only in the intended signal. Watchdog output circuit Since the WO pin has a built-in resistor to pull up to the VOUT pin internally, the WO pin can output a signal without an external pull-up resistor Do not connect to the pin other than VOUT pin when connecting an external pull-up resistor. In the S-19518 Series, the reset output pin and the watchdog output pin are prepared as the WO / RO pin. The output level of the WO / RO pin is applied by the AND logic of the reset output pin and the watchdog output pin. Example: When the WO pin is "L" and the RO pin is "H", the WO / RO pin is "L". Caution Define the external pull-up resistance by sufficient evaluation including the temperature characteristics under the actual usage conditions. 24 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series  Timing Chart Power supply start-up WDT: ON Low voltage detection Voltage restoration WO output "L" release WDT: OFF Regulator: OFF VIN EN VOUT Output current (IOUT) WEN WI DLY WO / RO Reset release Trigger detection WDT abnormal detection WDT: ON Figure 29 25 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00  Precautions • Wiring patterns for the VIN pin, the VOUT pin and GND should be designed so that the impedance is low. When mounting an output capacitor between the VOUT pin and the VSS pin (CL) and an input capacitor between the VIN pin and the VSS pin (CIN), the distance from the capacitors to these pins should be as short as possible. • Note that generally the output voltage may increase when a series regulator is used at low load current (0.1 mA or less). • Note that generally the output voltage may increase due to the leakage current from an output transistor when a series regulator is used at high temperature. • Generally a series regulator may cause oscillation, depending on the selection of external parts. The following conditions are recommended for the S-19518 Series. However, be sure to perform sufficient evaluation under the actual usage conditions for selection, including evaluation of temperature characteristics. Refer to "5. Example of equivalent series resistance vs. Output current characteristics (Ta = −40°C to +125°C)" in " Reference Data" for the equivalent series resistance (RESR) of the output capacitor. Input capacitor (CIN): Output capacitor (CL): 1.0 μF or more 1.0 μF or more • In a series regulator, generally the values of overshoot and undershoot in the output voltage vary depending on the variation factors of power-on, power supply fluctuation and load fluctuation, or output capacitance. Determine the conditions of the output capacitor after sufficiently evaluating the temperature characteristics of overshoot or undershoot in the output voltage with the actual device. • The voltage regulator may oscillate when the impedance of the power supply is high and the input capacitance is small or an input capacitor is not connected. • Overshoot may occur in the output voltage momentarily if the voltage is rapidly raised at power-on or when the power supply fluctuates. Sufficiently evaluate the output voltage at that time with the actual device. • If the VOUT pin is steeply shorted with GND, a negative voltage exceeding the absolute maximum ratings may occur to the VOUT pin due to resonance of the wiring inductance and the output capacitance in the application. The negative voltage can be limited by inserting a protection diode between the VOUT pin and the VSS pin or inserting a series resistor to the output capacitor. • The application conditions for the input voltage, the output voltage, and the load current should not exceed the power dissipation. • Do not apply an electrostatic discharge to this IC that exceeds the performance ratings of the built-in electrostatic protection circuit. • In determining the output current, attention should be paid to the output current value specified in Table 10 in " Electrical Characteristics" and footnote *7 of the table. • ABLIC Inc. claims no responsibility for any disputes arising out of or in connection with any infringement by products including this IC of patents owned by a third party. 26 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series  Characteristics (Typical Data) 1. Regulator block 1. 1 Output voltage vs. Output current (When load current increases) (Ta = +25°C) 1. 1. 1 VOUT = 3.3 V 4.0 1. 1. 2 6.0 5.0 3.0 2.0 VOUT [V] VOUT [V] VIN = 3.8 V VIN = 13.5 V VIN = 4.3 V 1.0 100 200 300 400 IOUT [mA] 500 200 300 400 IOUT [mA] 500 600 1. 2. 2 VOUT = 5.0 V 6.0 5.0 VOUT [V] 2.0 IOUT = 1 mA IOUT = 10 mA IOUT = 100 mA 0.0 0 2 4 6 4.0 3.0 IOUT = 1 mA IOUT = 10 mA IOUT = 100 mA 2.0 1.0 0.0 8 10 12 14 16 18 VIN [V] 0 2 4 6 8 10 12 14 16 18 VIN [V] Dropout voltage vs. Output current VOUT = 3.3 V 1. 3. 2 500 Tj = +150°C 400 Tj = +125°C Tj = +25°C 300 200 100 0 50 100 150 IOUT [mA] 200 Tj = +150°C Tj = +125°C 300 Tj = +25°C 200 100 Tj = −40°C 0 VOUT = 5.0 V 400 Vdrop [mV] 1. 3. 1 500 Tj = −40°C 0 250 0 50 100 150 IOUT [mA] 200 250 Dropout voltage vs. Junction temperature 1. 4. 1 500 VOUT = 3.3 V 400 IOUT = 250 mA 300 IOUT = 100 mA 200 100 0 −40 −25 1. 4. 2 500 VOUT = 5.0 V 400 Vdrop [mV] VOUT [V] 100 Output voltage vs. Input voltage (Ta = +25°C) 1.0 Vdrop [mV] VIN = 6.0 V 0 3.0 Vdrop [mV] VIN = 13.5 V 2.0 600 1. 2. 1 VOUT = 3.3 V 4.0 1. 4 VIN = 5.5 V 3.0 0.0 0 1. 3 4.0 1.0 0.0 1. 2 VOUT = 5.0 V IOUT = 250 mA 300 IOUT = 100 mA 200 100 0 25 50 75 100 125 150 Tj [°C] 0 −40 −25 0 25 50 75 100 125 150 Tj [°C] 27 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00 1. 5 Output voltage vs. Junction temperature 1. 5. 1 VOUT = 3.3 V 3.5 5.2 3.4 5.1 3.3 3.2 3.1 5.0 4.9 4.8 3.0 −40 −25 0 25 4.7 −40 −25 50 75 100 125 150 Tj [°C] 0 25 50 75 100 125 150 Tj [°C] Ripple rejection (Ta = +25°C) 1. 6. 2 VOUT = 3.3 V VIN = 13.5 V, CL = 1.0 μF 100 IOUT = 100 mA 80 IOUT = 30 mA 60 40 IOUT = 1 mA 20 0 10 100 1k 10k 100k VOUT = 5.0 V VIN = 13.5 V, CL = 1.0 μF 100 Ripple Rejection [dB] 1. 6. 1 Ripple Rejection [dB] VIN = 13.5 V 5.3 VOUT [V] VOUT [V] 3.6 1. 6 VOUT = 5.0 V 1. 5. 2 VIN = 13.5 V IOUT = 100 mA 80 IOUT = 30 mA 60 40 IOUT = 1 mA 20 0 10 1M 100 Frequency [Hz] 1k 10k 100k 1M Frequency [Hz] 2. Detector block Detection voltage, Release voltage vs. Junction temperature −VDET, +VDET [V] 2. 1. 1 3.2 −VDET = 2.6 V 3.0 +VDET 2.8 2.6 2.4 −VDET 2.2 −40 −25 2. 2 0 25 5.1 +VDET 4.9 4.7 4.5 −VDET 4.3 −40 −25 50 75 100 125 150 Tj [°C] −VDET = 2.6 V 2. 2. 2 300 250 200 200 VHYS [mV] 250 150 100 50 0 −40 −25 28 −VDET = 4.7 V 0 25 50 75 100 125 150 Tj [°C] Hysteresis width vs. Junction temperature 2. 2. 1 300 VHYS [mV] 2. 1. 2 5.3 −VDET, +VDET [V] 2. 1 −VDET = 4.7 V 150 100 50 0 25 50 75 100 125 150 Tj [°C] 0 −40 −25 0 25 50 75 100 125 150 Tj [°C] AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series Reset output current vs. VDS 2. 3. 1 100 −VDET = 2.6 V IRO [mA] 80 2. 3. 2 −VDET = 4.7 V 200 60 Ta = −40°C 40 Ta = +125°C 0 0.0 0.5 1.0 1.5 2.0 VDS [V] 3.0 0 2. 4. 2 1 2 3 VDS [V] 4 5 Ta = −40°C 5 0.0 0.5 1.0 1.5 2.0 VOUT [V] 2.5 Ta = +25°C 20 Ta = −40°C 15 10 5 Ta = +125°C 0 VDS = 0.4 V 25 Ta = +25°C 10 −VDET = 4.7 V 30 IRO [mA] IRO [mA] 2.5 VDS = 0.4 V 15 Ta = +125°C 0 3.0 0 1 2 3 VOUT [V] 4 5 RO pin voltage vs. Output voltage 2. 5. 1 −VDET = 2.6 V 2. 5. 2 VDS = 0.4 V, Rext = 3 kΩ 4 VDS = 0.4 V, Rext = 3 kΩ 5 Tj = +150°C 1 0 0.0 0.5 1.0 VRO [V] 2 −VDET = 4.7 V 6 3 VRO [V] Ta = +125°C 0 −VDET = 2.6 V 20 Remark 80 Reset output current vs. Output voltage 2. 4. 1 2. 5 Ta = −40°C 120 40 20 2. 4 Ta = +25°C 160 Ta = +25°C IRO [mA] 2. 3 Tj = +125°C Tj = +25°C Tj = −40°C 1.5 2.0 VOUT [V] 4 3 Tj = +150°C Tj = +125°C Tj = +25°C Tj = −40°C 2 1 0 2.5 3.0 0 1 2 3 VOUT [V] 4 5 IRO: Nch transistor output current VRO: Nch transistor output voltage VDS: Drain-to-source voltage of Nch transistor 29 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00 2. 6 Release delay time vs. Junction temperature −VDET = 2.6 V 2. 6. 1 25 25 20 20 15 10 5 15 10 5 0 −40 −25 0 25 0 −40 −25 50 75 100 125 150 Tj [°C] 0 25 −VDET = 2.6 V °C °C 100 + 10 − + 1000 trd [ms] + −VDET = 4.7 V 2. 7. 2 10000 + 1000 °C + °C + 10 °C − 10 100 1000 1 °C 10 CDLY [nF] 100 1000 CDLY [nF] Reset reaction time vs. Junction temperature 2. 8. 1 200 −VDET = 2.6 V 2. 8. 2 200 160 160 120 120 trr [μs] trr [μs] °C 1 1 80 40 0 −40 −25 30 °C 100 1 2. 8 50 75 100 125 150 Tj [°C] Release delay time vs. Release delay time and monitoring time adjustment capacitance 2. 7. 1 10000 trd [ms] CDLY = 10 nF 30 trd [ms] trd [ms] 30 2. 7 −VDET = 4.7 V 2. 6. 2 CDLY = 10 nF −VDET = 4.7 V 80 40 0 25 50 75 100 125 150 Tj [°C] 0 −40 −25 0 25 50 75 100 125 150 Tj [°C] AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series 3. Watchdog timer block 3. 1 Watchdog activation threshold current, watchdog deactivation threshold current vs. Junction temperature 3. 1. 1 3. 1. 2 VOUT = 3.3 V VIN = 13.5 V 2.5 IO,WDact, IO,WDdeact [mA] IO,WDact, IO,WDdeact [mA] 3.0 IO,WDact 2.0 1.5 1.0 0.5 IO,WDdeact 0.0 −40 −25 3. 2 0 25 50 75 100 125 150 Tj [°C] VIN = 13.5 V IO,WDact 2.0 1.5 1.0 0.5 IO,WDdeact 0.0 −40 −25 0 25 50 75 100 125 150 Tj [°C] 50 50 40 40 30 20 VOUT = 5.0 V VIN = 13.5 V 60 tWI,tr [ms] tWI,tr [ms] 2.5 3. 2. 2 VOUT = 3.3 V 60 10 30 20 10 0 −40 −25 0 25 0 −40 −25 50 75 100 125 150 Tj [°C] 0 25 50 75 100 125 150 Tj [°C] Watchdog trigger time vs. Release delay time and monitoring time adjustment capacitance 3. 3. 1 3. 3. 2 VOUT = 3.3 V VIN = 13.5 V 10000 Tj = +150°C 1000 Tj = +125°C 100 Tj = +25°C 10 Tj = −40°C VOUT = 5.0 V VIN = 13.5 V 10000 tWI,tr [ms] tWI,tr [ms] VIN = 13.5 V 3.0 Watchdog trigger time vs. Junction temperature 3. 2. 1 3. 3 VOUT = 5.0 V Tj = +150°C 1000 Tj = +125°C 100 Tj = +25°C 10 Tj = −40°C 1 1 1 10 100 CDLY [nF] 1000 1 10 100 1000 CDLY [nF] 31 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00 4. Overall Current consumption during operation vs. Input voltage 4. 1. 1 VOUT = 3.3 V, −VDET = 2.6 V 240 200 ISS1 [μA] 4. 1. 2 IOUT = 10 μA 160 − °C 120 + °C 80 + °C − °C 120 + °C 80 + 160 0 0 2 4 6 8 10 12 14 16 18 VIN [V] VOUT = 3.3 V, −VDET = 2.6 V 4. 2. 2 VIN = 4.3 V 100 − 4 6 8 10 12 14 16 18 VIN [V] 40 + + 0 0 50 °C °C 100 150 IOUT [mA] VOUT = 5.0 V, −VDET = 4.7 V VIN = 6.0 V 80 °C 60 20 − 60 40 + + 20 200 0 250 °C 0 50 °C °C 100 150 IOUT [mA] 200 250 Current consumption during operation vs. Junction temperature 4. 3. 1 10 VOUT = 3.3 V, −VDET = 2.6 V VIN = 13.5 V, IOUT = 10 μA 4. 3. 2 10 6 4 2 0 −40 −25 VOUT = 5.0 V, −VDET = 4.7 V VIN = 13.5 V, IOUT = 10 μA 8 ISS1 [μA] 8 ISS1 [μA] 2 100 ISS1 [μA] 80 ISS1 [μA] 0 Current consumption during operation vs. Output current 4. 2. 1 32 °C 40 0 4. 3 IOUT = 10 μA 200 40 4. 2 VOUT = 5.0 V, −VDET = 4.7 V 240 ISS1 [μA] 4. 1 6 4 2 0 25 50 75 100 125 150 Tj [°C] 0 −40 −25 0 25 50 75 100 125 150 Tj [°C] AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series  Reference Data 1. Characteristics of input transient response (Ta = +25°C) 5.6 12 5.4 3.3 2.9 11 10 VOUT −1 0 1 2 3 t [ms] 4 5 4.8 8 4.6 1. 3 VOUT = 3.3 V IOUT = 250 mA, CL = 1.0 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 4.1 14 3.5 3.3 3.1 VIN 12 5.4 10 VOUT 2.9 −0.2 5.6 11 0 0.2 0.4 0.6 t [ms] 0.8 1.0 5.2 5.0 4.8 9 8 10 VOUT −1 9 8 0 1 2 3 t [ms] 4 5 6 13 12 VIN 11 10 VOUT 4.6 −0.2 1.2 11 1. 4 VOUT = 5.0 V IOUT = 250 mA, CL = 1.0 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 5.8 14 13 VIN [V] VOUT [V] 3.7 5.0 9 6 3.9 5.2 12 VIN VIN [V] 3.5 VIN 13 VIN [V] 13 3.7 3.1 VOUT [V] 1. 2 VOUT = 5.0 V IOUT = 0.1 mA, CL = 1.0 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 5.8 14 3.9 VIN [V] VOUT [V] VOUT [V] 1. 1 VOUT = 3.3 V IOUT = 0.1 mA, CL = 1.0 μF, VIN = 11.5 V ↔ 13.5 V, tr = tf = 5.0 μs 4.1 14 9 8 0 0.2 0.4 0.6 t [ms] 0.8 1.0 1.2 2. Characteristics of load transient response (Ta = +25°C) 2. 2 VOUT = 5.0 V VIN = 6.0 V, CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA, tr = tf = 1.0 μs 5.8 150 100 5.6 3.7 50 5.4 3.3 3.1 2.9 0 −50 VOUT −1 0 1 2 3 t [ms] 4 5 6 4.8 −150 4.6 3.8 3.3 2.8 2.3 IOUT 6.5 0 6.0 −400 VOUT −1 200 −200 0 −600 1 2 3 t [ms] 4 5 6 −800 0 −50 VOUT −1 0 −100 1 2 3 t [ms] 4 5 6 −150 2. 4 VOUT = 5.0 V VIN = 6.0 V, CL = 1.0 μF, IOUT = 1 mA ↔ 250 mA, tr = tf = 1.0 μs 7.0 400 IOUT [mA] VOUT [V] VOUT [V] 4.3 5.0 −100 2. 3 VOUT = 3.3 V VIN = 4.3 V, CL = 1.0 μF, IOUT = 1 mA ↔ 250 mA, tr = tf = 1.0 μs 5.3 400 4.8 5.2 50 IOUT 5.5 5.0 4.5 4.0 200 0 IOUT −200 −400 VOUT −1 0 IOUT [mA] 3.5 IOUT 100 IOUT [mA] 3.9 IOUT [mA] VOUT [V] VOUT [V] 2. 1 VOUT = 3.3 V VIN = 4.3 V, CL = 1.0 μF, IOUT = 50 mA ↔ 100 mA, tr = tf = 1.0 μs 4.1 150 −600 1 2 3 t [ms] 4 5 6 −800 33 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION S-19518 Series Rev.1.5_00 3. Characteristics of EN pin transient response (Ta = +25°C) 12 12 12 12 9 6 9 6 6 3 0 −3 0 VEN −6 VOUT −1 0 1 2 3 4 t [ms] 5 6 7 8 6 3 −12 0 −18 −3 0 VEN −6 −12 VOUT −1 0 VEN [V] 3. 2 VOUT = 5.0 V VIN = 13.5 V, CL = 1.0 μF, IOUT = 100 mA, VEN = 0 V ↔ 13.5 V 15 18 VEN [V] VOUT [V] VOUT [V] 3. 1 VOUT = 3.3 V VIN = 13.5 V, CL = 1.0 μF, IOUT = 100 mA, VEN = 0 V ↔ 13.5 V 15 18 1 2 3 4 t [ms] 5 6 7 8 −18 4. Load dump characteristics (Ta = +25°C) 4. 1 VOUT = 5.0 V IOUT = 0.1 mA, VIN = 14.0 V ↔ 45.0 V, CIN = CL = 1.0 μF 6.0 50 40 5.6 5.4 30 VIN 20 10 5.2 VIN [V] VOUT [V] 5.8 5.0 0 VOUT −10 4.8 −0.1 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 t [s] 5. Example of equivalent series resistance vs. Output current characteristics (Ta = −40°C to +125°C) CIN = CL = 1.0 μF, CDLY = 10 nF 100 VOUT VIN WO / RO RESR [Ω] EN CIN Stable WEN WI 0 S-19518 Series DLY RESR VSS 0.1 250 CL*1 CDLY IOUT [mA] *1. Figure 30 34 CL: TDK Corporation CGA5L3X8R1H105K (1.0 μF) Figure 31 AUTOMOTIVE, 125°C OPERATION, 36 V INPUT, 250 mA, BUILT-IN WINDOW WATCHDOG TIMER VOLTAGE REGULATOR WITH RESET FUNCTION Rev.1.5_00 S-19518 Series  Power Dissipation TO-252-9S HSOP-8A Tj = +150°C max. 5 E 4 3 2 1 A 0 0 25 50 75 100 125 150 Tj = +150°C max. 6 Power dissipation (PD) [W] Power dissipation (PD) [W] 6 175 5 4 E 3 2 1 A 0 0 25 Ambient temperature (Ta) [°C] *1. 50 75 100 125 150 Ambient temperature (Ta) [°C] Board Power Dissipation (PD)*1 Board Power Dissipation (PD)*1 A B C D E 1.49 W − − − A B C D E 1.19 W − − − 5.21 W Measurement values when this IC is mounted on each board 175 4.03 W 35 TO-252-9S Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm No. TO252-9S-A-Board-SD-1.0 enlarged view ABLIC Inc. TO-252-9S Test Board (4) Board D IC Mount Area Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Thermal via 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer Specification 114.3 x 76.2 x t1.6 FR-4 4 Copper foil layer [mm] 1 2 3 4 (5) Board E Copper foil layer [mm] Thermal via 1 2 3 4 2 Pattern for heat radiation: 2000mm t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. TO252-9S-A-Board-SD-1.0 ABLIC Inc. HSOP-8A Test Board (1) Board A IC Mount Area Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 2 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.070 - (2) Board B Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] 1 2 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - (3) Board C Item Size [mm] Material Number of copper foil layer Copper foil layer [mm] Thermal via 1 2 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Land pattern and wiring for testing: t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm enlarged view No. HSOP8A-A-Board-SD-1.0 ABLIC Inc. HSOP-8A Test Board (4) Board D IC Mount Area Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Thermal via Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 - Item Size [mm] Material Number of copper foil layer 1 2 Copper foil layer [mm] 3 4 Specification 114.3 x 76.2 x t1.6 FR-4 4 Pattern for heat radiation: 2000mm2 t0.070 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.035 74.2 x 74.2 x t0.070 Number: 4 Diameter: 0.3 mm (5) Board E Thermal via enlarged view No. HSOP8A-A-Board-SD-1.0 ABLIC Inc. 6.5±0.2 5.8 1.2±0.1 (5.2) 0.80 0.25±0.06 0.22±0.05 0.65 No. VA009-A-P-SD-2.0 TITLE TO252-9S-A-PKG Dimensions No. VA009-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.5 +0.1 -0.0 0.2±0.05 ø1.7±0.1 8.0±0.1 1.5±0.1 6.9±0.1 9 1 Feed direction No. VA009-A-C-SD-1.0 TITLE TO252-9S-A-C a r r i e r T a p e No. VA009-A-C-SD-1.0 ANGLE UNIT mm ABLIC Inc. 60° 13.4±1.0 17.4±1.0 Enlarged drawing in the central part 2±0.5 ø21±0.8 ø13±0.2 No. VA009-A-R-SD-1.1 TITLE TO252-9S-A-Reel VA009-A-R-SD-1.1 No. ANGLE UNIT QTY. mm ABLIC Inc. 4,000 6.0 0.37 1.3 0.65 No. VA009-A-L-SD-1.0 TITLE TO252-9S-A -Land Recommendation No. VA009-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. 5.02±0.2 3.0 8 5 1 4 1.27 0.20±0.05 5 8 4 1 0.4±0.05 No. FH008-A-P-SD-2.0 TITLE HSOP8A-A-PKG Dimensions No. FH008-A-P-SD-2.0 ANGLE UNIT mm ABLIC Inc. 4.0±0.1(10 pitches:40.0±0.2) 2.0±0.05 ø1.5 +0.1 -0.0 0.3±0.05 ø2.0±0.05 8.0±0.1 2.1±0.1 6.7±0.1 1 8 4 5 Feed direction No. FH008-A-C-SD-1.0 TITLE HSOP8A-A-Carrier Tape FH008-A-C-SD-1.0 No. ANGLE UNIT mm ABLIC Inc. 13.4±1.0 17.4±1.0 Enlarged drawing in the central part 2±0.5 ø21±0.8 ø13±0.2 No. FH008-A-R-SD-1.1 TITLE HSOP8A-A-Reel No. FH008-A-R-SD-1.1 QTY. ANGLE UNIT mm ABLIC Inc. 4,000 0.76 3.2 1.27 1.27 1.27 No. FH008-A-L-SD-1.0 TITLE HSOP8A-A -Land Recommendation No. FH008-A-L-SD-1.0 ANGLE UNIT mm ABLIC Inc. Disclaimers (Handling Precautions) 1. All the information described herein (product data, specifications, figures, tables, programs, algorithms and application circuit examples, etc.) is current as of publishing date of this document and is subject to change without notice. 2. The circuit examples and the usages described herein are for reference only, and do not guarantee the success of any specific mass-production design. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the reasons other than the products described herein (hereinafter "the products") or infringement of third-party intellectual property right and any other right due to the use of the information described herein. 3. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by the incorrect information described herein. 4. Be careful to use the products within their ranges described herein. Pay special attention for use to the absolute maximum ratings, operation voltage range and electrical characteristics, etc. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by failures and / or accidents, etc. due to the use of the products outside their specified ranges. 5. Before using the products, confirm their applications, and the laws and regulations of the region or country where they are used and verify suitability, safety and other factors for the intended use. 6. When exporting the products, comply with the Foreign Exchange and Foreign Trade Act and all other export-related laws, and follow the required procedures. 7. The products are strictly prohibited from using, providing or exporting for the purposes of the development of weapons of mass destruction or military use. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by any provision or export to the person or entity who intends to develop, manufacture, use or store nuclear, biological or chemical weapons or missiles, or use any other military purposes. 8. The products are not designed to be used as part of any device or equipment that may affect the human body, human life, or assets (such as medical equipment, disaster prevention systems, security systems, combustion control systems, infrastructure control systems, vehicle equipment, traffic systems, in-vehicle equipment, aviation equipment, aerospace equipment, and nuclear-related equipment), excluding when specified for in-vehicle use or other uses by ABLIC, Inc. Do not apply the products to the above listed devices and equipments. ABLIC Inc. is not liable for any losses, damages, claims or demands caused by unauthorized or unspecified use of the products. 9. In general, semiconductor products may fail or malfunction with some probability. The user of the products should therefore take responsibility to give thorough consideration to safety design including redundancy, fire spread prevention measures, and malfunction prevention to prevent accidents causing injury or death, fires and social damage, etc. that may ensue from the products' failure or malfunction. The entire system in which the products are used must be sufficiently evaluated and judged whether the products are allowed to apply for the system on customer's own responsibility. 10. The products are not designed to be radiation-proof. The necessary radiation measures should be taken in the product design by the customer depending on the intended use. 11. The products do not affect human health under normal use. However, they contain chemical substances and heavy metals and should therefore not be put in the mouth. The fracture surfaces of wafers and chips may be sharp. Be careful when handling these with the bare hands to prevent injuries, etc. 12. When disposing of the products, comply with the laws and ordinances of the country or region where they are used. 13. The information described herein contains copyright information and know-how of ABLIC Inc. The information described herein does not convey any license under any intellectual property rights or any other rights belonging to ABLIC Inc. or a third party. Reproduction or copying of the information from this document or any part of this document described herein for the purpose of disclosing it to a third-party is strictly prohibited without the express permission of ABLIC Inc. 14. For more details on the information described herein or any other questions, please contact ABLIC Inc.'s sales representative. 15. This Disclaimers have been delivered in a text using the Japanese language, which text, despite any translations into the English language and the Chinese language, shall be controlling. 2.4-2019.07 www.ablic.com
S-19518AY2A-V9T1U4 价格&库存
很抱歉,暂时无法提供与“S-19518AY2A-V9T1U4”相匹配的价格&库存,您可以联系我们找货
