SS32 Forward
THRU
SS320
Current - 3.0 Ampere
Reverse Voltage - 20 to 200 Volts
PINNING
Features
PIN
DESCRIPTION
1
Cathode
Metal silicon junction, majority carrier conduction
2
Anode
For surface mounted applications
Low power loss, high efficiency
High forward surge current capability
For use in low voltage, high frequency inverters ,
free wheeling, and polarity protection applications
DO-214AA/SMB
2
1
MECHANICAL DATA
Case: SMB
Terminals: Solderable per MIL-STD-750, Method 2026
Approx. Weight: 95mg / 0 .0034oz
Unipolar
Maximum Ratings and Electrical characteristics
Ratings at 25 °C ambient temperature unless otherwise specified.
Single phase half-wave 60 Hz, resistive or inductive load, for capacitive load current derate by 20 %.
Parameter
Symbols
SS32
SS34
SS36
SS38
SS310
SS312
SS3150
SS320
Units
Maximum Repetitive Peak Reverse Voltage
V RRM
60
80
100
120
150
200
V
Maximum RMS voltage
V RMS
14
28
42
56
70
84
105
140
V
Maximum DC Blocking Voltage
V DC
60
80
100
120
150
200
V
Maximum Average Forward Rectified Current
I F(AV)
3.0
A
Peak Forward Surge Current,8.3ms
Single Half Sine-wave Superimposed
on Rated Load (JEDEC method)
I FSM
80
A
Max Instantaneous Forward Voltage at 3 A
VF
Maximum DC Reverse Current T a = 25°C
T a =100°C
IR
0.5
5
0.3
3
mA
Typical Junction Capacitance(1)
Cj
450
400
pF
Typical Thermal Resistance (2)
RθJA
60
°C/W
Tj
-55 ~ +150
°C
T stg
-55 ~ +150
°C
at Rated DC Reverse Voltage
Operating Junction Temperature Range
Storage Temperature Range
0.55
0.70
(1)Measured at 1 MHz and applied reverse voltage of 4 V D.C
(2)P.C.B. mounted with 2.0" X 2.0" (5 X 5 cm) copper pad areas.
www.tw-gmc.com
1
0.95
0.85
V
SS32 Forward
THRU
SS320
Typical Characterisitics
Fig.2 Typical Reverse Characteristics
Instaneous Reverse Current ( μA)
Average Forward Current (A)
Fig.1 Forward Current Derating Curve
3.5
3.0
2.4
1.8
1.2
0.6
0.0
25
50
75
100
125
150
10 4
T J =100°C
10 3
T J =75°C
10
2
SS32 ~ SS36
T J =25°C
10 0
Case Temperature (°C)
60
100
80
Fig.4 Typical Junction Capacitance
T J =25°C
Junction Capacitance ( pF)
1.0
SS32~SS34
SS36 ~ SS38
SS310~ SS312
SS3150~ SS320
0.1
0.4
0.6
0.8
1.0
1.2
1.4
1.6
200
100
SS3 2~SS36
SS38~SS320
10
0.1
10
1
100
Reverse Voltage (V)
Fig.5 Maximum Non-Repetitive Peak
Forward Surage Current
Fig.6- Typical Transient Thermal Impedance
80
70
60
50
40
8.3 ms Single Half Sine Wave
(JEDEC Method)
500
1.8
90
30
1000
Instaneous Forward Voltage (V)
Transient Thermal Impedance( °C /W)
Instaneous Forward Current (A)
Peak Forward Surage Current (A)
40
Percent of Rated Peak Reverse Voltage(%)
Fig.3 Typical Forward Characteristic
10
100
Number of Cycles at 60Hz
www.tw-gmc.com
SS38 ~SS32 0
10 1
100
10
1
0.01
0.1
1
10
t, Pulse Duration(sec)
2
100
SS32 Forward
THRU
SS320
PACKAGE OUTLINE
Plastic surface mounted package; 2 leads
SMB
L
A
A1
C
A
b
D
E
E1
VM
A
SMB mechanical data
UNIT
mm
mil
A
E
D
max
2.44
4.70
3.94
min
2.13
4.06
3.3
A1
L
C
b
5.59
0.20
1.5
0.305
2.2
5.08
0.05
0.8
0.152
1.9
59
12
87
32
6
75
E1
max
96
185
155
220
7.9
min
84
160
130
200
2.0
The recommended mounting pad size
2.4
(94)
2.4
(94)
2.8
(110)
2.2
(86)
mm
Unit :
(mil)
www.tw-gmc.com
3
很抱歉,暂时无法提供与“SS320”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 20+0.44478
- 200+0.41608
- 500+0.38739
- 1000+0.35869
- 3000+0.34434
- 6000+0.32426
