PIMP31X
PIMP31X
    NEXPERIA(安世)
    SC74,SOT457
    晶体管 - 双极 (BJT) - 阵列 - 预偏置 2 个 PNP 预偏压式(双) 50V 500mA 140MHz 290mW 表面贴装型 6-TSOP
PIMP31X 数据手册
PIMP31 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 16 February 2022 Product data sheet 1. General description PNP/PNP Resistor-Equipped double Transistor (RET) in a small SOT457 (SC-74) SurfaceMounted Device (SMD) plastic package. NPN/NPN complement: PIMN31 NPN/PNP complement: PIMC31 2. Features and benefits • • • • • 500 mA output current capability Built-in bias resistors Simplifies circuit design Reduces component count Reduces pick and place costs 3. Applications • • • • Digital applications Cost-saving alternative to BC807 series in digital applications Control of IC inputs Switching loads 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit open base - - -50 V - - -500 mA kΩ Per transistor VCEO collector-emitter voltage IO output current R1 bias resistor 1 (input) [1] 0.7 1 1.3 R2/R1 bias resistor ratio [1] 9 10 11 [1] See section "Test information" for resistor calculation and test conditions. PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 5. Pinning information Table 2. Pinning information Pin Symbol Description Simplified outline 1 GND1 GND (emitter) TR1 2 I1 input (base) TR1 3 O2 output (collector) TR2 4 GND2 GND (emitter) TR2 5 I2 input (base) TR2 6 O1 output (collector) TR1 Graphic symbol O1 6 5 4 I2 R1 GND2 R2 TR2 TR1 1 2 3 R2 R1 SC-74; TSOP6 (SOT457) GND1 I1 O2 aaa-019790 6. Ordering information Table 3. Ordering information Type number Package Name PIMP31 Description Version SC-74; TSOP6 plastic, surface-mounted package (SC-74; TSOP6); 6 leads SOT457 7. Marking Table 4. Marking codes Type number Marking code PIMP31 4F 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - -50 V VCEO collector-emitter voltage open base - -50 V VEBO emitter-base voltage open collector - -5 V VI input voltage -10 5 V IO output current - -500 mA Ptot total power dissipation Tamb ≤ 25 °C [1] - 290 mW Ptot total power dissipation Tamb ≤ 25 °C [1] - 420 mW Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C Per transistor Per device [1] Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided, 35 µm copper, tin-plated and standard footprint. PIMP31 Product data sheet All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 2 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 006aab531 500 Ptot (mW) 400 300 200 100 0 - 75 - 25 25 75 125 175 Tamb (°C) FR4 PCB, single-sided, 35 µm copper, tin-plated and standard footprint Fig. 1. Per device: Power derating curve 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Min Typ Max Unit - - 432 K/W - - 105 K/W - - 298 K/W Per transistor Rth(j-a) thermal resistance from in free air junction to ambient Rth(j-sp) thermal resistance from junction to solder point [1] Per device Rth(j-a) [1] thermal resistance from in free air junction to ambient [1] Device mounted on an FR4 PCB, single-sided, 35 µm copper, tin-plated and standard footprint. 006aaa494 103 δ= 1 Zth(j-a) (K/W) 0.50 102 0.75 0.33 0.20 0.10 0.05 10 0.02 0.01 0 1 10- 5 10- 4 10- 3 10- 2 10- 1 1 10 102 tp (s) 103 FR4 PCB, single-sided, 35µm copper, tin-plated and standard footprint Fig. 2. Per transistor: Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PIMP31 Product data sheet All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 3 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Per transistor V(BR)CBO collector-base breakdown voltage IC = -100 µA; IE = 0 A; Tamb = 25 °C -50 - - V V(BR)CEO collector-emitter breakdown voltage IC = -10 mA; IB = 0 A; Tamb = 25 °C -50 - - V ICBO collector-base cut-off current VCB = -50 V; IE = 0 A; Tamb = 25 °C - - -100 nA ICEO collector-emitter cut-off VCE = -50 V; IB = 0 A; Tamb = 25 °C current - - -0.5 µA IEBO emitter-base cut-off current VEB = -5 V; IC = 0 A; Tamb = 25 °C - - -0.72 mA hFE DC current gain VCE = -5 V; IC = -50 mA; Tamb = 25 °C 70 - - VCEsat collector-emitter saturation voltage IC = -50 mA; IB = -2.5 mA; Tamb = 25 °C - - -100 mV VI(off) off-state input voltage VCE = -5 V; IC = -100 µA; Tamb = 25 °C -0.3 -0.6 -1 V VI(on) on-state input voltage VCE = -0.3 V; IC = -20 mA; Tamb = 25 °C -0.4 -0.8 -1.4 V R1 bias resistor 1 (input) [1] 0.7 1 1.3 kΩ R2/R1 bias resistor ratio [1] 9 10 11 Cc collector capacitance VCB = -10 V; IE = 0 A; ie = 0 A; f = 1 MHz; Tamb = 25 °C - 11 - pF fT transition frequency VCE = -5 V; IC = -50 mA; f = 100 MHz; Tamb = 25 °C - 140 - MHz [1] [2] [2] See section "Test information" for resistor calculation and test conditions. Characteristics of built-in transistor 006aaa349 103 -2.5 IC (A) (1) hFE aaa-012069 -0.5 (2) -2.25 -2 -0.4 (3) -1.75 102 -1.5 -0.3 -1.25 -1 -0.2 10 -0.75 -0.1 1 - 10- 1 -1 - 10 - 102 IC (mA) 0 - 103 VCE = -5 V (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −40 °C Fig. 3. -0.5 IB = -0.25 mA 0 -1 -2 -3 -4 VCE (V) -5 Tamb = 25 °C Fig. 4. Collector current as a function of collectoremitter voltage; typical values DC current gain as a function of collector current; typical values PIMP31 Product data sheet All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 4 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 006aaa351 - 10 006aaa352 - 10 VI(on) (V) VI(off) (V) (1) (1) (2) -1 - 10- 1 - 10- 1 Fig. 5. -1 (2) -1 (3) - 10 - 102 IC (mA) (3) - 10- 1 - 10- 1 - 103 -1 IC (mA) - 10 VCE = -0.3 V (1) Tamb = -40 °C (2) Tamb = 25 °C (3) Tamb = 100 °C VCE = -5 V (1) Tamb = -40 °C (2) Tamb = 25 °C (3) Tamb = 100 °C On-state input voltage as a function of collector Fig. 6. current; typical values Off-state input voltage as a function of collector current; typical values 006aaa350 - 10- 1 Cc (pF) (1) (2) VCEsat (V) aaa-012070 40 (3) 30 20 10 - 10- 2 -1 - 10 - 102 IC (mA) 0 - 103 IC/IB = 20 (1) Tamb = 100 °C (2) Tamb = 25 °C (3) Tamb = −40 °C Fig. 7. Product data sheet -10 -20 -30 -40 -50 VCB (V) f = 1 MHz Tamb = 25 °C Fig. 8. Collector-emitter saturation voltage as a function of collector current; typical values PIMP31 0 Collector capacitance as a function of collectorbase voltage; typical values All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 5 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ aaa-012064 103 fT (MHz) 102 10 1 -10-1 -1 -10 -102 IC (mA) -103 f = 100 MHz Tamb = 25 °C VCE = -5 V Fig. 9. Transition frequency as a function of collector current; typical values of built-in transistor PIMP31 Product data sheet All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 6 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 11. Test information Resistor calculation • Calculation of bias resistor 1 (R1) • Calculation of bias resistor ratio (R2/R1) n.c. II1; II2 R1 II3; II4 R2 GND aaa-020083 Fig. 10. Resistor test circuit Resistor test conditions Table 8. Resistor test conditions R1 (kΩ) 1 R2 (kΩ) Test conditions 10 II1 II2 II3 II4 -0.7 mA -0.8 mA 0.45 mA 0.55 mA 12. Package outline 3.1 2.7 6 3.0 2.5 1.7 1.3 1.1 0.9 5 4 2 3 0.6 0.2 pin 1 index 1 0.95 1.9 0.40 0.25 Dimensions in mm 0.26 0.10 18-03-11 Fig. 11. Package outline SC-74; TSOP6 (SOT457) PIMP31 Product data sheet All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 7 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 13. Soldering 3.45 1.95 0.45 0.55 (6×) (6×) 0.95 solder lands solder resist 3.3 2.825 0.95 solder paste occupied area 0.7 (6×) Dimensions in mm 0.8 (6×) 2.4 sot457_fr Fig. 12. Reflow soldering footprint for SC-74; TSOP6 (SOT457) 5.3 1.5 (4×) 1.475 0.45 (2×) 5.05 1.475 solder lands solder resist occupied area Dimensions in mm preferred transport direction during soldering 1.45 (6×) 2.85 sot457_fw Fig. 13. Wave soldering footprint for SC-74; TSOP6 (SOT457) PIMP31 Product data sheet All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 8 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 14. Revision history Table 9. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PIMP31 v.1 Product data sheet - - PIMP31 Product data sheet 20220216 All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 9 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PIMP31 Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 10 / 11 PIMP31 Nexperia 50 V, 500 mA PNP/PNP Resistor-Equipped double Transistor (RET); R1 = 1 kΩ, R2 = 10 kΩ Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 2 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 4 11. Test information.......................................................... 7 12. Package outline.......................................................... 7 13. Soldering..................................................................... 8 14. Revision history..........................................................9 15. Legal information......................................................10 © Nexperia B.V. 2022. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 16 February 2022 PIMP31 Product data sheet All information provided in this document is subject to legal disclaimers. 16 February 2022 © Nexperia B.V. 2022. All rights reserved 11 / 11
PIMP31X 价格&库存
很抱歉,暂时无法提供与“PIMP31X”相匹配的价格&库存,您可以联系我们找货
