AIDC5V5V200MATH
AIDC5V5V200MATH
    ATI(恒光)
    SIP4 模块
    隔离模块 直流转换器 1 输出 5V 200mA 4.5V - 5.5V 输入
AIDC5V5V200MATH 数据手册
ISOLATED 1W DC-DC Converter Analog Technologies AIDC5V5V200MATH We have been proudly serving you since 1997 base stations. They provide high efficiency and reliability in a compact form factor, making them ideal for use in these applications. 2. Industrial automation and control systems: Isolated DC-DC converter modules are used in a wide range of industrial automation and control systems, such as robotics, process control, and factory automation. They provide reliable and stable power to sensitive control circuits and sensors. 3. Medical devices: Isolated DC-DC converter modules are used in various medical devices, such as patient Figure 1. Physical Photo of AIDC5V5V200MATH monitoring systems, infusion pumps, and imaging equipment. They offer reliable and efficient power FEATURES  Output conversion while providing safety and protection to patients and medical staff. Voltage Proportional to Input Voltage  High Isolation Voltage: 1500VDC 4.  Input Voltage Range: 4.5V ~ 5.5V converter modules are used in renewable energy  Max. Output Current: 200mA systems, such as solar power and wind power systems,  High Efficiency: 77% @VIN = 5V & IOUT = 200mA to convert the DC output from the renewable energy  Switching  Compact  Wide Renewable energy systems: Isolated DC-DC Frequency: 220kHz source to a regulated DC voltage suitable for charging SIP package batteries or powering electronic devices. Operating Temperature Range: −40C ~ 85C 5. Automotive electronics: Isolated DC-DC converter modules are used in automotive electronics, such as APPLICATIONS infotainment systems, powertrain control modules, and Isolated DC-DC converter modules are electronic advanced driver assistance systems. They provide devices that convert a DC input into a DC output reliable and efficient power conversion in the harsh voltage proportional to the input voltage value with automotive environment, where high temperatures and galvanic isolation between the input and output circuits. voltage spikes are common. Our newly developed power supply module, AIDC5V5V200MATH, is designed to have a high isolation voltage capability, 1500V, at an efficiency of up to 77%. Here are some common applications of Overall, isolated DC-DC converter modules are used in various applications where reliable, efficient, and regulated power conversion is required with galvanic isolation between the input and output circuits. isolated DC-DC converter modules: This product line offers a variety of input and output 1. Power networking supplies for equipment: telecommunications Isolated DC-DC and converter voltages, its full families are shown in Table 4. on page 5. modules are commonly used to power telecom and networking equipment, such as routers, switches, and www.analogtechnologies.com Sales: sales@analogti.com Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 1 ISOLATED 1W DC-DC Converter Analog Technologies We have been proudly serving you since 1997 AIDC5V5V200MATH DESCRIPTION AND SPECIFICATIONS Our power supply unit is designed to withstand extreme temperatures, with a wide operating range of −40°C to +85°C. This makes it a versatile and reliable choice for use in a variety of industrial and commercial settings. With a mean time between failure of 35×10⁵ hours (equivalent to 400 years of continuous use), you can trust that it will keep your equipment running smoothly for years to come. Table 1. Pin Names AND Functions. No. Name Type Description 1 GND Power Ground Negative Input Voltage 2 VIN+ Power Input Positive Input Voltage 3 VOUT− Power Output Negative Output Voltage 4 VOUT+ Power Output Positive Output Voltage Table 2. Specifications INPUT Parameter Symbol Input Voltage VIN Input Current IIN Test Conditions Min. Typ. Max. Unit/Note 4.5 5.0 5.5 V Full Load 239 mA No Load 17 mA −0.7 Surge Voltage (1sec. max.) Filter 9 VDC Max. Unit/Note Capacitor OUTPUT Parameter Symbol Test Conditions Output Power P 0.1 1 W Output Voltage VOUT 4.5 5 V Output Current IOUT 200 mA Output Voltage Accuracy Typ. See Figure 2 and Figure 3 Line Regulation ∆VOUT/∆VVPS Load Regulation ∆VOUT/∆IOUT Ripple & Noise Min. Input voltage change: ±1% Load change from 10% to 100% Full Load Bandwidth = 20MHz −1.2 1.2 % −15 15 % 100 mVp-p 470 μF 75 Capacitive Load www.analogtechnologies.com Sales: sales@analogti.com Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 2 ISOLATED 1W DC-DC Converter Analog Technologies AIDC5V5V200MATH We have been proudly serving you since 1997 η Efficiency Temperature Coefficient Full Load 76 80 % −0.03 0.03 %/C Continuous, self-recovery (The AIDC24V24V42MATH lacks short circuit protection) Short Circuit Protection GENERAL CHARACTERISTIC Parameter Symbol Test Conditions Isolation Voltage VIS ttest= 60s, IL≤ 0.5mA 1500 VDC 100kHz/0.1V 20 pF 1000 MΩ 220 kHz Isolation Capacitance Min. Isolation Resistance Typ. Max. Unit/Note Switching Frequency fSW Operating Temperature Range Topr −40 85 C Storage Temperature Range Tstg −55 125 C Case Temperature Rise Tcr The distance between the solder joint and the case is 1.5mm, for 10 second. Pin Soldering Temperature Storage Relative Humidity Range RH Mean Time Between Failure MTBF 5 MIL-HDBK-217F@25C Case Material 35×105 300 C 95 % Hrs Black thermoplastic UL94V-0 Weight www.analogtechnologies.com C 25 TA = 25C Sales: sales@analogti.com 1.4 g 0.003 lbs 0.049 Oz Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 3 ISOLATED 1W DC-DC Converter Analog Technologies AIDC5V5V200MATH We have been proudly serving you since 1997 TYPICAL PERFORMANCE CHARACTERISTICS 15 Output Voltage Accuracy(%) Ma x . 5 1% Typ. 0 −5 −7.5% Min. −10 −15 10 −15% 20 40 60 Output Voltage Accuracy(%) 10 10 5 Typ. 2.5% Min. −2.5% −5 −7.5% −10 10 20 40 60 100 80 Output Current Percentage(%) Output Current Percentage(%) Figure 2. Load vs. Output Voltage (VIN=3.3V) Figure 3. Load vs. Output Voltage 100 95 100 90 90 80 85 70 Efficiency(%) Efficiency(%) . 0 100 80 Ma x 80 75 70 65 60 50 40 30 60 20 55 10 50 4.5 4.6 4.7 4.8 4.9 5.0 5.1 5.2 5.3 5.4 5.5 5.6 0 0 10 20 30 40 50 60 70 80 90 100 Output Current Percentage(%) Input Voltage(V) Figure 4. Input Voltage vs. Efficiency (Full Load) Figure 5. Load vs. Efficiency (VIN = 5V) Temperature Derating Graph 100 Output Power(%) 90 80 70 60 50 40 30 20 10 0 −40 −30 −20 −10 0 10 20 30 40 50 60 70 85 90 105 Ambient Temperature(°C) Figure 6. Derating Curve www.analogtechnologies.com Sales: sales@analogti.com Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 4 ISOLATED 1W DC-DC Converter Analog Technologies AIDC5V5V200MATH We have been proudly serving you since 1997 TYPICAL APPLICATIONS VIN+ VIN+ CIN 4.7μF VOUT+ COUT 10μF DC-DC VIN− VIN− VOUT+ VOUT− VOUT− Figure 7. Recommended Circuit The simplest way to use AIDC5V5V200MATH is shown in Figure 7, where CIN can be 4.7μF and COUT 10μF. Choose a low ESR capacitor, such as MLCC (Multi-Layer Ceramic Capacitor) type, with appropriate voltage ratings. VIN+ REG VIN+ C1 4.7μF DC-DC VIN− VIN− REG VOUT+ VOUT+ C2 4.7μF VOUT− VOUT− Figure 8. Output Voltage Regulator and Overvoltage Protection Circuit 1. Parallel usage and hot-swapping are not supported by this product. 2. To ensure that the power module operates efficiently and reliably, it is recommended that the minimum load not be less than 10% of the rated resistive load. If the required power is lower than this, it is advised to connect a resistor at the output end that is equivalent to 10% of the rated load. 3. The maximum capacitive load of the product is based on the rated full-load test, and should not be exceeded when in use. Otherwise, it may cause difficulties in starting and damage the product. www.analogtechnologies.com Sales: sales@analogti.com Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 5 ISOLATED 1W DC-DC Converter Analog Technologies AIDC5V5V200MATH We have been proudly serving you since 1997 OUTLINE DIMENSIONS Through Hole Package (TH) Side View Top View Top View Side View Unit: mm[inch] ORDING INFORMATION A IDC 5V 5V 200MA TH Product Line: Isolated DC-DC Converter Company Code: Analog Technologies, Inc. Nominal Input Voltage: 5V 12V 24V Output Voltage: 5V 12V 24V Output Current: 300mA 200mA 110mA Mounting Type: SM = Surface Mount TH = Through Hole Figure 9. Naming Convention of AIDC5V5V200MATH Part Number Buy Now AIDC5V5V200MATH *: both and are our online store icons. Our products can be ordered from either one of them with the same pricing and delivery time. www.analogtechnologies.com Sales: sales@analogti.com Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 6 ISOLATED 1W DC-DC Converter Analog Technologies AIDC5V5V200MATH We have been proudly serving you since 1997 Table 4. AIDC5V5V200MATH Families with Different VIN Input Voltage Product Model Typ. Range Output Output Voltage Current MAX. Input Capacitive Ripple & Efficiency Current Noise (%) Load (mA) Full No μF mVp-p Min. Typ. Load Load V mA 3.3 303 404 30 220 150 68 72 5 200 404 30 220 150 72 76 AIDC3V12V83MATH 12 83 347 45 470 150 76 80 AIDC5V3V300MATH 3.3 300 277 25 470 150 68 72 AIDC5V5V200MATH 5 200 239 17 470 150 76 80 9 110 277 20 470 150 76 80 AIDC5V12V83MATH 12 83 277 20 470 150 76 80 AIDC5V15V67MATH 15 67 277 20 470 150 76 80 AIDC5V24V42MATH 24 42 277 20 470 150 76 80 AIDC12V3V300MATH 3.3 300 116 15 470 150 68 72 AIDC12V5V200MATH 5 200 101 11 470 150 76 80 9 110 108 15 470 150 76 80 AIDC12V12V83MATH 12 83 101 16 470 150 76 80 AIDC12V15V67MATH 15 67 99 13 470 150 76 80 AIDC12V24V42MATH 24 42 115 15 470 150 76 80 AIDC15V5V200MATH 5 200 82 10 470 150 76 80 12 83 82 12 470 150 76 80 AIDC15V15V67MATH 15 67 82 10 470 150 85 87 AIDC24V3V300MATH 3.3 300 57 7 470 150 68 72 5 200 48 7 470 150 79 83 9 110 57 7 470 150 76 80 AIDC3V3V300MATH AIDC3V5V200MATH 3.3 2.97~3.63 AIDC5V9V110MATH 5 4.5~5.5 AIDC12V9V110MATH 12 AIDC15V12V83MATH AIDC24V5V200MATH AIDC24V9V110MATH 15 24 10.8~13.2 13.5~16.5 21.6~26.4 *Note: See Figure 9. www.analogtechnologies.com Sales: sales@analogti.com Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 7 Analog Technologies ISOLATED 1W DC-DC Converter We have been proudly serving you since 1997 AIDC5V5V200MATH NOTICE 1. ATI warrants its products to perform according to specifications for one year from the date of sale, except when damaged due to excessive abuse. If a product fails to meet specifications within one year of the sale, it can be exchanged free of charge. 2. ATI reserves the right to make changes or discontinue products or services without notice. Customers are advised to obtain the latest information before placing orders. 3. All products are sold subject to terms and conditions of sale, including those pertaining to warranty, patent infringement, and limitation of liability. Customers are responsible for their applications using ATI products, and ATI assumes no liability for applications assistance or customer product design. 4. ATI does not grant any license, either express or implied, under any patent right, copyright, mask work right, or other intellectual property right of ATI. 5. ATI's publication of information regarding third-party products or services does not constitute approval, warranty, or endorsement. 6. ATI retains ownership of all rights for special technologies, techniques, and designs for its products and projects, as well as any modifications, improvements, and inventions made by ATI. www.analogtechnologies.com Sales: sales@analogti.com Help Improve Datasheet: datasheet@analogti.com Tel.: (408) 748-9100‬ Copyrights 2000-2023, Analog Technologies, Inc. All Rights Reserved. Updated on 3/3/2023 1161 Ringwood Ct, #110, San Jose, CA 95131, U. S. A. 8
AIDC5V5V200MATH 价格&库存
很抱歉,暂时无法提供与“AIDC5V5V200MATH”相匹配的价格&库存,您可以联系我们找货
