RF-SM-1077B1
RF-SM-1077B1
    RF-STAR(信驰达)
    SMD,MODULE_26x18mm
    CC1310 868MHz 915MHz Sub-1G透传无线收发模块RF-SM-1077B1
RF-SM-1077B1 数据手册
Shenzhen RF-star Technology Co.,Ltd. RF-SM-1077B1 硬件规格书 (CC1310 868&915MHz 频段) 深圳市信驰达科技有限公司 更新日期:2020 年01 月15 日 Shenzhen RF-star Technology Co.,Ltd. 目录 ⚫ 选型表 .....................................................................................................................................................3 ⚫ 概述 .........................................................................................................................................................4 ⚫ 模块参数 ..................................................................................................................................................5 ⚫ 模块尺寸与引脚定义................................................................................................................................5 ⚫ 天线规格 ..................................................................................................................................................7 ⚫ 硬件设计注意事项 ...................................................................................................................................8 ⚫ 常见问题 ..................................................................................................................................................9 ➢ 传输距离不理想...................................................................................................................................9 ➢ 易损坏——异常损坏 ...........................................................................................................................9 ➢ 误码率太高 ..........................................................................................................................................9 ⚫ 回流焊条件 ............................................................................................................................................10 ⚫ 静电放电警示.........................................................................................................................................10 ⚫ 版本更新记录.........................................................................................................................................11 ⚫ 联系我们 ................................................................................................................................................11 RF-SM-1077B1 硬件规格书 2 Shenzhen RF-star Technology Co.,Ltd. ⚫ 选型表 芯片 型号 CC1310 F128RGZ CC1310 F128RSM 内核 M3 M3 FLASH RAM (KB) 128 128 (KB) 模块型号 天线 频段 形式 (MHz) 模块尺寸 (mm) 发射 功率(d Bm) 通信 模块照片 距离( (点击可访问) M) RF-SM-1077B1 IPEX 868 915 18*26 14 2500 RF-SM-1077B2 IPEX 433 470 18*26 15 2500 RF-SM-1044B1 PCB 868 915 14*22 14 2500 868 915 9*12.5 14 2500 8 8 RF-SM-1044B2 邮票 半孔 注: 1、通信距离为以模块最大发射功率在晴朗天气下空旷无干扰环境下测试所得最远距离。 2、点击图片可跳转至购买链接。 RF-SM-1077B1 硬件规格书 3 Shenzhen RF-star Technology Co.,Ltd. ⚫ 概述 RF-SM-1077B1 模块是 RF-star 推出的 Sub-1G 系列模块,其芯 片 CC1310 内置高性能的 ARM Cortex-M3 + ARM Cortex-M0 双核处 理器,主 MCU ARM Cortex-M3 的高性能能更快地处理应用层的事 件,而 ARM Cortex-M0 能够最大化地节省功耗去处理无线数据的传 输,并且 CC1310 也是第一个同时具有低成本和超低功耗并采用Sub -1G 无线通信的 MCU。 此模块的设计目的是处理低功耗和无线通信距离要求较高的应 用,可广泛应用于有此需求的各种电子设备,如仪器仪表、物流跟 踪、健康医疗、楼宇自动化、运动计量、汽车电子、休闲玩具、农业 监测等方向。用户可借此模块以最短的开发周期整合现有方案或产品,以最快的速度占领市 场,同时为企业的发展注入崭新的技术力量。 RF-SM-1077B1 模块支持 868MHz、915MHz 段,需要支持433MHz、470MHz频段的 可使用 RF-SM-1077B2 模块; 图 1. RF-SM-1077B1 原理框图 RF-SM-1077B1 硬件规格书 4 Shenzhen RF-star Technology Co.,Ltd. ⚫ 模块参数 表 1. RF-SM-1077B1参数 芯片型号 CC1310F128RGZ 工作电压 1.8 ~ 3.8 V,推荐为 3. 3 V 工作频段 868 MHz, 915 MHz 最大发射功率 +14 dBm 接收灵敏度 -124.0 dBm (@long range mode) -110.0 dBm (@50 kpbs) RAM 20 KB FLASH 128 KB GPIO数量 30 个 晶振频率 24 MHz,32.768 KHz 封装方式 SMT(邮票半孔) 工作温度 - 40 ℃ ~ + 85 ℃ 储存温度 - 40 ℃ ~ + 125 ℃ ⚫ 模块尺寸与引脚定义 图 2. RF-SM-1077B1 尺寸图 RF-SM-1077B1 硬件规格书 5 Shenzhen RF-star Technology Co.,Ltd. 图 3. RF-SM-1077B1 引脚图 表 2. RF-SM-1077B1 模块引脚定义 引脚序号 名称 功能 1 P01 I/O 2 P02 I/O 3 P03 I/O 4 P04 I/O 5 P05 I/O 6 P06 I/O 7 P07 I/O 8 P08 I/O 9 P09 I/O 10 P10 I/O 11 P11 I/O 12 P12 I/O 13 P13 I/O 14 P14 I/O 15 P15 I/O 16 TMS I/O JTAG TMS 17 TCK I/O JTAG TCK RF-SM-1077B1 硬件规格书 备注 6 Shenzhen RF-star Technology Co.,Ltd. 18 P16 I/O JTAG TDO 19 P17 I/O JTAG TDI 20 P18 I/O 21 P19 I/O 22 P20 I/O 23 P21 I/O 24 P22 I/O 25 RST 复位脚 26 P23 I/O 27 P24 I/O 28 P25 I/O 29 P26 I/O 30 P27 I/O 31 P28 I/O 32 P29 I/O 33 P30 I/O 34 VCC — 模块电源,1.8 ~ 3.8 V,推荐3.3 V 35 ANT — 外接天线引脚 36 GND — 低电平有效 ⚫ 天线规格 1、IPEX天线座的规格下图所示: 图 4. 天线座规格 RF-SM-1077B1 硬件规格书 7 Shenzhen RF-star Technology Co.,Ltd. 2、IPEX线端的规格如下图所示: 图 5. 天线扣规格 3、常用天线: 图 6. 常用天线 ⚫ 硬件设计注意事项 1、推荐使用直流稳压电源对模块进行供电,电源纹波系数尽量小,模块需可靠接地;请 注意电源正负极的正确连接,如反接可能会导致模块永久性损坏; 2、请检查供电电源,确保在推荐供电电压之间,如超过最大值会造成模块永久性损坏; 请检查电源稳定性,电压不能大幅频繁波动; 3、在针对模块设计供电电路时,往往推荐保留 30% 以上余量,有利于整机长期稳定地 工作;模块应尽量远离电源、变压器、高频走线等电磁干扰较大的部分; 4、高频数字走线、高频模拟走线、电源走线必须避开模块下方,若实在不得已需要经过 模块下方,假设模块焊接在 Top Layer,在模块接触部分的 Top Layer 铺地铜(全部铺铜并良 好接地),必须靠近模块数字部分并走线在 Bottom Layer; 5、假设模块焊接或放置在 Top Layer,在 Bottom Layer 或者其他层随意走线也是错误 的, 会在不同程度影响模块的杂散以及接收灵敏度; RF-SM-1077B1 硬件规格书 8 Shenzhen RF-star Technology Co.,Ltd. 6、假设模块周围有存在较大电磁干扰的器件也会极大影响模块的性能,跟据干扰的强度 建议适当远离模块,若情况允许可以做适当的隔离与屏蔽; 7、假设模块周围有存在较大电磁干扰的走线(高频数字、高频模拟、电源走线)也会极 大影响模块的性能,跟据干扰的强度建议适当远离模块,若情况允许可以做适当的隔离与屏 蔽; 8、通信线若使用5V电平, 必须使用电平转换电路; ⚫ 常见问题 ➢ 传输距离不理想 1、当存在直线通信障碍时,通信距离会相应的衰减;温度、湿度,同频干扰,会导致通信 丢包率提高;地面吸收、反射无线电波,靠近地面测试效果较差; 2、海水具有极强的吸收无线电波能力,故海边测试效果差; 3、天线附近有金属物体,或放置于金属壳内,信号衰减会非常严重; 4、功率寄存器设置错误、空中速率设置过高(空中速率越高,距离越近); 5、室温下电源低压低于推荐值,电压越低发功率越小; 6、使用天线与模块匹配程度较差或天线本身品质问题。 ➢ 易损坏——异常损坏 1、请检查供电电源,确保在推荐供电电压之间,如超过最大值会造成模块永久性损坏; 请检查电源稳定性,电压不能大幅频繁波动; 2、请确保安装使用过程防静电操作,高频器件静电敏感性; 3、请确保安装使用过程湿度不宜过高,部分元件为湿度敏感器件;如果没有特殊需求不建 议在过高、过低温度下使用。 ➢ 误码率太高 1、附近有同频信号干扰,远离干扰源或者修改频率、信道避开干扰; 2、电源不理想也可能造成乱码,务必保证电源的可靠性; 3、延长线、馈线品质差或太长,也会造成误码率偏高。 RF-SM-1077B1 硬件规格书 9 Shenzhen RF-star Technology Co.,Ltd. ⚫ 回流焊条件 1、加热方法:常规对流或 IR 对流; 2、允许回流焊次数:2 次,基于以下回流焊(条件)(见图 7 ); 3、温度曲线:回流焊应按照下列温度曲线(见图 7 ); 4、最高温度:245°C。 图 7. 部件的焊接耐热性温度曲线(焊接点) ⚫ 静电放电警示 模块会因静电释放而被损坏,RF-star 建议所有模块应在以下 3 个预防措施下处理: 1、必须遵循防静电措施,不可以裸手拿模块。 2、模块必须放置在能够预防静电的放置区。 3、在产品设计时应该考虑高电压输入或者高频输入处的防静电电路。 静电可能导致的结果为细微的性能下降到整个设备的故障。由于非常小的参数变化都可 能导致设备不符合其认证要求的值限,从而模块会更容易受到损害。 RF-SM-1077B1 硬件规格书 10 Shenzhen RF-star Technology Co.,Ltd. ⚫ 版本更新记录 版本号 文档日期 V1.0 2020/01/15 更新内容 第一次发布 ⚫ 联系我们 深圳市信驰达科技有限公司 Shenzhen RF-star Technology Co., Ltd. Tel(Sales):0755–8632 9829 Tel(FAE):0755-3695 3756 E-mail:sales@szrfstar.com Web: www.szrfstar.com 地址:深圳市南山区高新园科技南一道创维大厦 C 座 601 室 Add:Room 601,Block C,Skyworth Building,Nanshan High-Tech Park,Shenzhen. RF-SM-1077B1 硬件规格书 11 Shenzhen RF-star Technology Co.,Ltd. 低功耗 Sub-1GHz模块及协议 (CC1310) 深圳市信驰达科技有限公司 更新日期:2020 年01 月17 日 Shenzhen RF-star Technology Co.,Ltd. 目录  模块介绍..................................................................................................................................................................3  功能介绍.............................................................................................................................................................3  工作模式示意图.................................................................................................................................................3  模块尺寸与引脚定义.........................................................................................................................................4  RF-SM-1077B1/B2......................................................................................................................................4  RF-SM-1044B1............................................................................................................................................6  RF-SM-1044B2............................................................................................................................................7  功能介绍..................................................................................................................................................................9  数据透传.............................................................................................................................................................9  传感器数据采集.................................................................................................................................................9  AT命令.................................................................................................................................................................. 10  AT命令格式说明............................................................................................................................................. 10  AT命令及参数说明......................................................................................................................................... 10  启动/退出 AT 命令操作模式.....................................................................................................................10  串口参数查询/设置命令............................................................................................................................ 11  RF功率查询/设置命令...............................................................................................................................11  RF 信道查询/设置命令..............................................................................................................................11  RF 接收 RSSI 值查询命令....................................................................................................................... 12  设备 MAC 地址查询命令.......................................................................................................................... 12  启动/退出AD电压采集命令.......................................................................................................................12  设备软件、硬件版本查询命令................................................................................................................. 12  设备重启命令............................................................................................................................................. 12  设备恢复出厂配置参数命令..................................................................................................................... 12 AT 命令表...........................................................................................................................................................13  功耗测试记录....................................................................................................................................................... 14  天线规格............................................................................................................................................................... 14  硬件设计注意事项............................................................................................................................................... 16  常见问题............................................................................................................................................................... 16  传输距离不理想.............................................................................................................................................. 16  模块易损坏...................................................................................................................................................... 17  误码率太高...................................................................................................................................................... 17  回流焊条件........................................................................................................................................................... 17  静电放电警示....................................................................................................................................................... 18  版本更新记录....................................................................................................................................................... 18  联系我们............................................................................................................................................................... 18 低功耗 Sub-1G 模块及协议(CC1310) 2 Shenzhen RF-star Technology Co.,Ltd.  模块介绍  功能介绍 信驰达推出的 Sub-1GHz 系列模块,芯片使用 TI CC1310,内置高性能的 ARM CortexM3 + ARM Cortex-M0 双核处理器,主 MCU ARM Cortex-M3 的高性能能更快地处理应用层 的事件,而 ARM Cortex-M0 能够最大化地节省功耗去处理无线数据的传输,并且 CC1310 也是第一个同时具有低成本和超低功耗并采用 Sub-1G 无线通信的 MCU。 此系列模块的设计目的是处理低功耗和无线通信距离要求较高的应用,可广泛应用于有 此需求的各种电子设备,如仪器仪表、物流跟踪、健康医疗、楼宇自动化、运动计量、汽车 电子、休闲玩具、农业监测等方向。用户可借此模块以最短的开发周期整合现有方案或产 品,以最快的速度占领市场,同时为企业的发展注入崭新的技术力量。 RF-SM-1077B1 模 块 支 持 868MHz 、 915MHz 频 段 , RF-SM-1077B2 模 块 支 持 433MHz、470MHz 频段,这两款模块使用7mm * 7mm封装的芯片CC1310F128RGZ,可用 IO 数量为 30 个;RF-SM-1044B1/B2 模块支持 868MHz、915MHz 频段,这两款模块使用 4mm * 4mm 封装的芯片CC1310F128RSM,可用IO 数量分别为 8 个和 7 个。 模块默认都烧录带有 AT 命令的数据透传固件,其串口默认的波特率为 115200、数据位 8 位、无奇偶校验位、1 位停止位。默认的工作频段和发射功率:RF-SM-1077B1 、RF-SM1044B1/B2 默认工作于 868MHz 频段,发射功率14 dBm,RF-SM-1077B2 模块默认工作于 433 MHz,发射功率 15 dBm;模块启动后串口会打印 "Application Start\r\n" 字符串,且默 认开启数据透传模式,串口接收到的除“+++”字符串以外的数据都将作为透传数据发送出 去,详情请参考功能介绍中的数据透传小节。  工作模式示意图 图1 模块工作示意图 低功耗 Sub-1G 模块及协议(CC1310) 3 Shenzhen RF-star Technology Co.,Ltd.  模块尺寸与引脚定义  RF-SM-1077B1/B2 图 2. RF-SM-1077B1/B2 尺寸图 图 3. RF-SM-1077B1/B2 引脚图及照片 低功耗 Sub-1G 模块及协议(CC1310) 4 Shenzhen RF-star Technology Co.,Ltd. 表 1. RF-SM-1077B1/B2 模块引脚定义 引脚 序号 模块脚 位名称 芯片脚 位名称 功能 1 P01 DIO_1 Digital I/O GPIO, Sensor Controller 2 P02 DIO_2 Digital I/O 模块串口接收端(GPIO, Sensor Controller) 3 P03 DIO_3 Digital I/O 模块串口发送端(GPIO, Sensor Controller) 4 P04 DIO_4 Digital I/O GPIO, Sensor Controller 5 P05 DIO_5 Digital I/O GPIO, Sensor Controller 6 P06 DIO_6 Digital I/O GPIO, Sensor Controller 7 P07 DIO_7 Digital I/O GPIO, Sensor Controller 8 P08 DIO_8 Digital I/O GPIO 9 P09 DIO_9 Digital I/O GPIO 10 P10 DIO_10 Digital I/O GPIO 11 P11 DIO_11 Digital I/O GPIO 12 P12 DIO_12 Digital I/O GPIO 13 P13 DIO_13 Digital I/O GPIO 14 P14 DIO_14 Digital I/O GPIO 15 P15 DIO_15 Digital I/O GPIO 16 TMS JTAG_TMSC — JTAG TMS 17 TCK JTAG_TCKC — JTAG TCK 18 P16 DIO_16 Digital I/O JTAG TDO 19 P17 DIO_17 Digital I/O JTAG TDI 20 P18 DIO_18 Digital I/O GPIO 21 P19 DIO_19 Digital I/O GPIO 22 P20 DIO_20 Digital I/O GPIO 23 P21 DIO_21 Digital I/O GPIO 24 P22 DIO_22 Digital I/O GPIO 25 RESET RESET_N — 26 P23/ADC0 DIO_23 Digital or analog I/O GPIO, Sensor Controller, analog 27 P24/ADC1 DIO_24 Digital or analog I/O GPIO, Sensor Controller, analog 28 P25 DIO_25 Digital or analog I/O GPIO, Sensor Controller, analog 29 P26 DIO_26 Digital or analog I/O GPIO, Sensor Controller, analog 30 P27 DIO_27 Digital or analog I/O GPIO, Sensor Controller, analog 31 P28 DIO_28 Digital or analog I/O GPIO, Sensor Controller, analog 低功耗 Sub-1G 模块及协议(CC1310) 备注 模块复位脚,低电平有效 5 Shenzhen RF-star Technology Co.,Ltd. 32 P29 DIO_29 Digital or analog I/O GPIO, Sensor Controller, analog 33 P30 DIO_30 Digital or analog I/O GPIO, Sensor Controller, analog 34 VCC VCC — 模块电源正极 1.8V ~ 3.8V 35 ANT — — 外接天线脚 36 GND GND — 模块电源负极  RF-SM-1044B1 图 4. RF-SM-1044B1 尺寸图 图 5. RF-SM-1044B1 引脚图及照片 低功耗 Sub-1G 模块及协议(CC1310) 6 Shenzhen RF-star Technology Co.,Ltd. 表 2. RF-SM-1044B1 模块引脚定义 引脚 序号 模块脚 位名称 芯片脚 位名称 功能 1 GND GND — 模块电源负极 2 RESET RESET_N — 模块复位脚,低电平有效 3 TMS JTAG_TMSC — JTAG TMS 4 TCK JTAG_TCKC — JTAG TCK 5 VCC VCC — 模块电源正极 1.8V ~ 3.8V 6 VCC VCC — 模块电源正极 1.8V ~ 3.8V 7 GND GND — 模块电源负极 8 P00 DIO_0 Digital I/O GPIO, Sensor Controller 9 P01 DIO_1 Digital I/O GPIO, Sensor Controller 10 P02 DIO_2 Digital I/O 模块串口接收端(GPIO, Sensor Controller) 11 P03 DIO_3 Digital I/O 模块串口发送端(GPIO, Sensor Controller) 12 P04 DIO_4 Digital I/O GPIO, Sensor Controller 13 P05 DIO_5 Digital I/O GPIO, Sensor Controller 14 P07 DIO_7 Digital I/O GPIO, Sensor Controller 15 P06 DIO_6 Digital I/O GPIO, Sensor Controller 16 GND GND — 模块电源负极 17 GND GND — 模块电源负极 18 GND GND — 模块电源负极 备注  RF-SM-1044B2 图 6. RF-SM-1044B2 尺寸图 低功耗 Sub-1G 模块及协议(CC1310) 7 Shenzhen RF-star Technology Co.,Ltd. 图 7. RF-SM-1044B2 引脚图及照片 表 3. RF-SM-1044B2 模块引脚定义 引脚 序号 模块脚 位名称 芯片脚 位名称 功能 1 P00 DIO_0 Digital I/O GPIO, Sensor Controller 2 P04 DIO_4 Digital I/O GPIO, Sensor Controller 3 P01 DIO_1 Digital I/O GPIO, Sensor Controller 4 P02 DIO_2 Digital I/O 模块串口接收端(GPIO, Sensor Controller) 5 P03 DIO_3 Digital I/O 模块串口发送端(GPIO, Sensor Controller) 6 VCC VCC — 模块电源正极 1.8V ~ 3.8V 7 GND GND — 模块电源负极 8 ANT — 外接天线引脚 9 GND GND — 模块电源负极 10 TMS JTAG_TMSC — JTAG TMS 11 TCK JTAG_TCKC — JTAG TCK 12 RESET RESET_N — 模块复位脚,低电平有效 13 P06 DIO_6 Digital I/O GPIO, Sensor Controller 14 GND GND — 15 P07 DIO_7 Digital I/O 16 VCC VCC — 低功耗 Sub-1G 模块及协议(CC1310) 备注 模块电源负极 GPIO, Sensor Controller 模块电源正极 1.8V ~ 3.8V 8 Shenzhen RF-star Technology Co.,Ltd.  功能介绍  数据透传 模块的透传模式是指,模块发送数据到远端的设备。该透传功能实现的条件:首先两个 或多个设备需处于相同频段,其次通信设备间的地址是相互允许的。用户可以根据实际情况 自行定义每个设备所使用的信道,而只有处在相同频段且相同信道的设备才能进行通信,用 户可通过 AT 命令来设置设备的信道值,详情请参考 AT 命令章节。 模块透传速率说明:此设备是采用射频端通信的,设备遵循 IEEE 802.15.4g 标准;设定 了三种速率模式 625 bps、50 Kbps、200 Kbps;在透传功能中有数据确认处理机制,该机 制涉及到接收确认数据包的超时机制,项目定义的超时时间会根据不同的模式调整得出参数 值,200 Kbps 的超时时间设定值为 15 ms,50 Kbps 的超时时间设定值为 35 ms,625 bps 设定的超时时间是 500 ms。同时项目中规定了不同模式的数据包大小,其中 200 Kbps、50 Kbps 速率模式的数据包大小为 128 字节,数据包本身包含的序列号占用了 2 字节,所以实 际的数据包不能超过 126 字节;625 bps 速率模式的数据包大小为 30 字节,序列号占用 2 字 节,所以实际的数据包不能超过 28 字节。当发送数据量大于规定的数据包最大长度,默认的 处理机制是只发送规定数据包长度相同的字节,后面的数据将会被丢弃。 模块透传机制说明:设备上电默认开启透传模式,即设备上电后从串口收到的数据将作 为透传数据发送出去。“+++”字符串是 AT 命令模式的启动命令,串口收到该命令时将关闭透 传模式,进入 AT 命令模式,详情请参考 AT 命令章节。设备在退出 AT 命令模式后设备将会 进入数据透传模式。 此设备的设计是为了实现远距离传输,支持的数据传输速率较低,建议用户在传输速率 要求不高的条件下可选择使用此设备透传数据。  传感器数据采集 CC1310 带 有 协处 理 器 Sensor Controller , 其 特色 是 支 持 低功 耗 采 集 数据 。 Sensor Controller 的工作时钟由 RTC 提供。例如,设定 RTC 时钟为 100 ms,则 Sensor Controller 每 100 ms 执行一次 Sensor Controller 任务,当 Sensor Controller 中的任务执行结束后,协 处理器会自动进入低功耗模式。应用层通过控制 RTC 时钟即可控制传感器的采集频率。 Sensor Controller 可控制的资源有 7 个数字 I/O (DIO1-DIO7)、8 个数字/模拟 I/O (DIO23DIO30),这些 I/O 可配置为 SPI、I2C、ADC 等。 透传固件中默认配置有 AD 电压采集功能;该功能使能了2 个 ADC 通道,通道 0 为 DIO23,通道 1 为 DIO 24。AD 电压采集的范围为 0 ~ 3.8 V,AD 采集由 Sensor Controller 控制 RTC 提供时钟,默认配置为每秒采集一次数据;用户可以通过 AT 命令来控制 AD 电压 采集的启动和关闭,详情请看考 AT 命令章节。 低功耗 Sub-1G 模块及协议(CC1310) 9 Shenzhen RF-star Technology Co.,Ltd.  AT 命令 以"AT#"开头的字符串会被当成AT指令进行解析并执行,并从串口原样返回,之后会输 出执行结果:"OK↲"表示操作成功, "ERROR↲"表示操作错误,"FAIL↲"表示操作失败。  AT 命令格式说明 AT 命令格式:“AT#EXIT” + “回车”。在没有特别说明的情况下,AT commands 中的字 母不分大小写。具体格式说明如下: AT 命令起始符:AT 命令所有命令都要以“AT”字符开头,大小写均可; 命令分隔符:“AT”起始字符与命令类型的分隔符,固定为“#”字符; AT 命令类型:AT 命令类型,如:“UART”、“RF”等,大小写均可; 参数分隔符:用于分隔命令类型与配置参数或分隔多个配置参数,固定为一个空格键; 参数起始符:配置参数起始符,表示该配置参数的开始字符,固定为“-”; 参数标识符:表示该配置参数的含义,不同的配置参数该标识符会不同,大小写均可, 详情请参考命令表各命令参数描述; 配置参数:配置参数值,不同的配置参数有不同的取值范围,详情请参考命令表各命令 参数描述; 命令结束符:AT命令结束符,用于表示该命令结束,固定为回车换行符“↲ ”(\r\n)。  AT 命令及参数说明  启动/退出 AT 命令操作模式 "+++" AT 命令模式启动命令;向串口输入该字符串表示启动进入 AT 命令模式;串口返 回"OK↲"表示成功启动 AT 命令模式,之后对串口收到的数据都将当做 AT 命令判断处理。 "AT#EXIT↲"AT命令模式退出命令;向串口输入该字符串表示退出AT命令模式;串口返 回"OK↲"表示成功退出AT命令模式,退出命令模式后设备默认进入透传模式,串口收到的除 低功耗 Sub-1G 模块及协议(CC1310) 10 Shenzhen RF-star Technology Co.,Ltd. “+++” 外的所有数据都将作为透传数据发送出去。  串口参数查询/设置命令 " AT#UART↲" 串口参数查询命令;输入该命令串口返回 "OK↲" 字符串表示操作成功, 同时返回当前设备串口的配置参数,如返回字符串 "AT#UART -Bxxxx -Dx -Px -Sx↲",“-B” 为波特率参数,“-D” 为数据位参数,“-P” 为奇偶校验位参数,“-S” 为停止位参数;如果指令 格式错误,则串口会返回 "ERROR↲" 字符串。 " AT#UART -Bxxxx -Dx -Px -Sx↲" 串口参数设置命令;输入该命令串口返回 "OK↲" 字 符串表示设置串口参数操作成功,命令中 “-B” 为波特率参数,“-D” 为数据位参数,“-P” 为奇 偶校验位参数,“-S” 为停止位参数,如果指令格式错误,则串口会返回 "ERROR↲" 字符串。 串口参数设置命令默认保存参数到 flash,重启设备后,设备以 flash 中的参数配置串 口。 串口默认的波特率为115200、数据位8位、无奇偶校验位、1位停止位。  RF功率查询/设置命令 "AT#RF↲" RF 功率查询命令;输入该命令串口返回 "OK↲" 字符串表示操作成功,同时 返回当前设备的射频发射功率参数,如返回字符串 "AT#RF -Px↲",“-P” 表示射频端发射功 率,如果指令格式错误,则串口会返回 "ERROR↲" 字符串。 "AT#RF -Pxx↲" RF 功率设置命令;向串口输入该字符串串口返回 "OK↲" 字符串,表示 设置射频参数成功;命令中 “-P” 参数表示设定射频端的发射功率,对于 RF-SM-1077B1 模 块参数支持 -10 dBm 和 0 到 14 dBm 之间的任意值,对于 RF-SM-1077B2 模块参数支持 -10 dBm 和 0 到 15 dBm 之间的任意值,如果指令格式错误,则串口会返回 "ERROR↲" 字符 串。 默 认 的 RF 发射 功 率 , RF-SM-1077B1 、RF-SM-1044B1/B2 模块 14 dBm, RF-SM1077B2 模块 15dBm。  RF 信道查询/设置命令 "AT#CHN↲" RF 信道查询命令;输入该命令串口返回 "OK↲" 字符串表示操作成功,同 时返回当前设备所使用的信道参数,如返回字符串 "AT#CHN -Cx↲","-C" 表示信道参数,如 果指令格式错误,则串口会返回 "ERROR↲" 字符串。 "AT#CHN -Cx↲" RF 信道设置命令;向串口输入该字符串串口返回 "OK↲" 字符串,表示 设置设备射频信道参数成功;命令中“-C”参数表示设定射频信道参数,参数值支持 0 到 6 的 任意值,如果指令格式错误,则串口会返回 "ERROR↲" 字符串。 默认的 RF 信道值 0。 低功耗 Sub-1G 模块及协议(CC1310) 11 Shenzhen RF-star Technology Co.,Ltd.  RF 接收 RSSI 值查询命令 "AT#RSSI↲" RF 接信号强度查询;输入该命令串口返回 "OK↲" 字符串表示操作成功, 同时返回设备上一次接收到数据的信号强度值,如返回字符串 "AT#RSSI -Rx↲", "-R" 表示 信号强度,如果指令格式错误,则串口会返回 "ERROR↲" 字符串。 如果在设备没有收到数据的时候输入该命令,返回值默为255。  设备 MAC 地址查询命令 "AT#MAC↲" 查询当前设备的 MAC 地址;输入该命令串口返回 "OK↲" 字符串表示操作 成功,同时返回该设备 6 字节的 MAC 地址,如返回字符串 "AT#MAC -Mxxxxxxxxxxxx↲","M" 表示 MAC 地址参数,如果指令格式错误,则串口会返回 "ERROR↲" 字符串。  启动/退出AD电压采集命令 "AT#ADC -Ex↲" AD 电压采集命令,命令中 “-E” 参数表示使能 AD 电压采集功能,如 x 值为 1 表示使能 AD 电压采集为真,即启动 AD 电压采集功能,如 x 值为 0 表示使能 AD 电压 采集为假,即关闭 AD 电压采集;向串口输入该命令串口返回 "OK↲" 字符串,表示操作成 功;若启动 AD 电压采集功能,设备将开启 ADC 通道 0、1 电压采集功能,并且串口每秒钟 返回一次 ADC 通道 0、1 中的数据;若关闭 AD 电压采集功能,设备停止 ADC 通道 0、1 的 电压采集功能并停止数据返回;AD 电压采集支持 0 ~ 3.8 V,串口返回值值为 0 ~ 3800(mV) 的整数。  设备软件、硬件版本查询命令 "AT#VER↲" 软件/硬件版本查询命令,输入该命令串口返回 "OK↲" 字符串,表示操作成 功并且会返回该设备的软件、硬件版本号,如 "AT#VER -Sm1.0.0 -D1077B1↲" ,“-S” 参数 表示软件版本,字符串 "m1.0.0" 表示设备的软件为主设备 1.0.0 版,“-D” 参数表示硬件版 本,字符串 "1077B1" 表示设备的硬件版本为 1077B1。  设备重启命令 "AT#RESTART↲" 设备重启命令,输入该命令串口返回 "OK↲" 字符串,表示操作成功, 并且在100ms之后设备自动重启,启动成功后模块从串口打印 "Application Start↲" 字符串。 若用户想再次进入 AT 命令模式则需要重新启动命令模式(发送“+++”),详细操作请参考 AT 命令表。  设备恢复出厂配置参数命令 "AT#RESET↲" 设备恢复出厂配置命令,输入该命令串口返回 "OK↲" 字符串,表示操作 成功,并且在下一次启动设备时,设备的所有参数配置均恢复到出厂配置。 低功耗 Sub-1G 模块及协议(CC1310) 12 Shenzhen RF-star Technology Co.,Ltd. AT 命令表 AT 命令 参数 +++ 无 AT#EXIT 无 说明 设备进入 AT 命令模式,返回 “OK” 表示成功进入 AT 命令模 式,否则操作失败。 退出 AT 命令模式,返回 “OK” 表示操作成功,否则操作失 败。 查询软件、硬件版本号,返回 “OK ”表示操作成功,并且串口 AT#VER 返 回 软 件 版 本 和 硬 件 版 本 , 例 如 “AT#VER -Sm1.0.0 - 无 D1077B1”,否则操作失败。 AT#RESTART 重启设备命令,返回 “OK” 表示操作成功并且设备在 100 ms 无 之后重启,否则操作失败。 设备配置参数恢复到出厂配置,返回 “OK” 表示操作成功,并 AT#RESET 无 且在下一次启动设备时,设备的所有参数配置均恢复到出厂 配置。 -B:波特率参数(默认 为115200bps) -D:数据位参数(默认 AT#UART 为8位) -P:数据奇偶校验位参 数(默认为0) -S : 数 据 停 止 位 参 数 (默认为1) AT#UART↲:查询串口配置参数,返回“OK”表示操作成功并 且串口打印当前的串口配置参数,例如“AT#UART -B9600 D8 -P0 -S1”,否则操作失败。 AT#UART -B115200 -D8 -P0 -S1↲:配置串口参数,波特率 参 数 支 持 : 115200 、 38400 、 57600 、 14400 、 9600 、 4800;数据位参数支持:8、7、6、5;奇偶校验位支持:0 和 1;停止位支持:0 和 1。返回字符串 “OK” 表示操作成 功,返回“ERROR”表示命令参数错误,返回 “FAIL” 表示操 作失败。 AT#RF ↲ :查询射频发射功率,返回“OK”表示操作成功并且 -P:射频发射功率参数 AT#RF (RF-SM-1077B1 、 1044B1/B2 硬件默认为 14 dBm , RF-SM- 1077B2 硬 件 默 认 为 15 dBm) 串口返回当前射频发射功率,例如“AT#RF -P14”,否则操作 失败。 AT#RF -P10↲ :配置射频发射功率参数。RF-SM-1077B1 硬 件支持参数范围为-10dBm 和 0 到 14dBm 间的任意值,RFSM-1077B2 硬件支持-10dBm 和 0 到 15dBm 间的任意值。串 口返回字符串“OK”表示操作成功,返回“ERROR”表示命令参 数错误,返回“FAIL”表示操作失败。 AT#ADC -E1 ↲ :开启使能 ADC通道0、1的数据采集,返回 “OK”表示操作成功,并且串口会每秒打印一次ADC通道 AT#ADC -E:使能ADC通道0、1 的数据采集 0、1的数据值(采集电压范围支持0 ~ 3.8 V),否则操作失 败。 AT#ADC -E0 ↲ :关闭使能 ADC通道0、1的数据采集,返回 “OK”表示操作成功,并且设备关闭ADC通道0、1的数据采 集。 低功耗 Sub-1G 模块及协议(CC1310) 13 Shenzhen RF-star Technology Co.,Ltd. AT#CHN↲:查询RF信道值,返回“OK”表示操作成功并且 打印当前RF信道参数,例如“AT#CHN -C1”,否则操作失 AT#CHN -C:设置RF信道值 败。 AT#CHN -C1 ↲ :设置RF信道值为1,返回“OK”表示操作 成功,参数在设备重启之后生效。 查询设备上一次接收到数据的信号强度值,返回“OK”表示操 AT#RSSI 作成功并且打印信号强度值,例如“AT#RSSI -R-64”,否则操 无 作失败。(若设备未收到数据操作该命令,返回的信号强度值 为 255) 查询设备 MAC 地址,返回“OK”表示操作成功并,并打印设备 AT#MAC 6byte 的 MAC 地址,例如:“AT#MAC -M06367D11004B”, 无 否则操作失败。  功耗测试记录 模式 最小电流 最大电流 平均电流 采样个数 idle 1.29 mA 1.32 mA 1.31 mA 5000 standby 68 nA 69.2 μA 980 nA 5000 shutdown 52 nA 88 nA 79 nA 5000 RF-RX 5.2 mA 5.7 mA 5.4 mA 5000 RF-TX — 25.2 mA(15 dBm) — — *测试条件:电池供电 2.88V,RIGOL DM3068 数字万用表。 说明:RF-TX 功耗测试数据只提供峰值作为参考,平均功耗与发送数据的频率成正比。  天线规格 1、IPEX 天线座的规格下图所示: 低功耗 Sub-1G 模块及协议(CC1310) 14 Shenzhen RF-star Technology Co.,Ltd. 图 8. 天线座规格 2、IPEX 线端的规格如下图所示: 图 9. 天线扣规格 3、常用天线: 图 10. 常用天线 低功耗 Sub-1G 模块及协议(CC1310) 15 Shenzhen RF-star Technology Co.,Ltd.  硬件设计注意事项 1、推荐使用直流稳压电源对模块进行供电,电源纹波系数尽量小,模块需可靠接地;请 注意电源正负极的正确连接,如反接可能会导致模块永久性损坏; 2、请检查供电电源,确保在推荐供电电压之间,如超过最大值会造成模块永久性损坏; 请检查电源稳定性,电压不能大幅频繁波动; 3、在针对模块设计供电电路时,往往推荐保留 30% 以上余量,有利于整机长期稳定地 工作;模块应尽量远离电源、变压器、高频走线等电磁干扰较大的部分; 4、高频数字走线、高频模拟走线、电源走线必须避开模块下方,若实在不得已需要经过 模块下方,假设模块焊接在 Top Layer,在模块接触部分的 Top Layer 铺地铜(全部铺铜并良 好接地),必须靠近模块数字部分并走线在 Bottom Layer; 5、假设模块焊接或放置在 Top Layer,在 Bottom Layer 或者其他层随意走线也是错误 的, 会在不同程度影响模块的杂散以及接收灵敏度; 6、假设模块周围有存在较大电磁干扰的器件也会极大影响模块的性能,跟据干扰的强度 建议适当远离模块,若情况允许可以做适当的隔离与屏蔽; 7、假设模块周围有存在较大电磁干扰的走线(高频数字、高频模拟、电源走线)也会极 大影响模块的性能,跟据干扰的强度建议适当远离模块,若情况允许可以做适当的隔离与屏 蔽; 8、通信线若使用 5V 电平, 必须使用电平转换电路;  常见问题  传输距离不理想 1、当存在直线通信障碍时,通信距离会相应的衰减;温度、湿度,同频干扰,会导致通信 丢包率提高;地面吸收、反射无线电波,靠近地面测试效果较差; 2、海水具有极强的吸收无线电波能力,故海边测试效果差; 3、天线附近有金属物体,或放置于金属壳内,信号衰减会非常严重; 4、功率寄存器设置错误、空中速率设置过高(空中速率越高,距离越近); 5、室温下电源低压低于推荐值,电压越低发功率越小; 6、使用天线与模块匹配程度较差或天线本身品质问题。 低功耗 Sub-1G 模块及协议(CC1310) 16 Shenzhen RF-star Technology Co.,Ltd.  模块易损坏 1、请检查供电电源,确保在推荐供电电压之间,如超过最大值会造成模块永久性损坏; 请检查电源稳定性,电压不能大幅频繁波动; 2、请确保安装使用过程防静电操作,高频器件静电敏感性; 3、请确保安装使用过程湿度不宜过高,部分元件为湿度敏感器件;如果没有特殊需求不建 议在过高、过低温度下使用。  误码率太高 1、附近有同频信号干扰,远离干扰源或者修改频率、信道避开干扰; 2、电源不理想也可能造成乱码,务必保证电源的可靠性; 3、延长线、馈线品质差或太长,也会造成误码率偏高。  回流焊条件 1、加热方法:常规对流或 IR 对流; 2、允许回流焊次数:2 次,基于以下回流焊(条件)(见图 11 ); 3、温度曲线:回流焊应按照下列温度曲线(见图 11 ); 4、最高温度:245°C。 图 11. 部件的焊接耐热性温度曲线(焊接点) 低功耗 Sub-1G 模块及协议(CC1310) 17 Shenzhen RF-star Technology Co.,Ltd.  静电放电警示 模块会因静电释放而被损坏,RF-star 建议所有模块应在以下 3 个预防措施下处理: 1、必须遵循防静电措施,不可以裸手拿模块。 2、模块必须放置在能够预防静电的放置区。 3、在产品设计时应该考虑高电压输入或者高频输入处的防静电电路。 静电可能导致的结果为细微的性能下降到整个设备的故障。由于非常小的参数变化都可 能导致设备不符合其认证要求的值限,从而模块会更容易受到损害。  版本更新记录 版本号 文档日期 1.0.0 2017-10-19 更新内容 第一次发布 修改RF命令参数 2.0.0 2018-03-12 增加RF信道设置命令 增加RSSI值查询命令 2.1.0 2018-04-25 增加MAC地址查询命令 2.2.0 2020-01-17 增加 RF-SM-1044B1/B2 模块  联系我们 深圳市信驰达科技有限公司 Shenzhen RF-star Technology Co., Ltd. Tel(Sales):0755–8632 9829 Tel(FAE):0755-3695 3756 E-mail:sales@szrfstar.com Web: www.szrfstar.com 地址:深圳市南山区高新园科技南一道创维大厦 C 座 601 室 Add:Room 601,Block C,Skyworth Building,Nanshan High-Tech Park,Shenzhen. 低功耗 Sub-1G 模块及协议(CC1310) 18
RF-SM-1077B1 价格&库存
很抱歉,暂时无法提供与“RF-SM-1077B1”相匹配的价格&库存,您可以联系我们找货
