SRM201TJ2K00TKZTR2K5 数据手册
Special Request
SRM201T – Surge Resistant MELF Resistor
Specifications per
● IEC 600115-1
● AEC-Q200 Rev.D
Features
● AEC-Q200 Compliant
● Anti-sulfuration test qualified
● Excellent in heat dissipation than chip resistor
● Stronger mechanical structure to endure vibration and thermal shock
● MELF packaging yet capable of high power handling
● Special conductive film enhances anti-surge capability
● Absorbs harmful surge which damages precious devices or components
● SMD-enabled alternative to carbon composition resistors
● RoHS and REACH compliant
◼ DIMENSION
Type
Body Length
(L , mm)
Cap Diameter
(D1 , mm)
Body Diameter
(D2, mm)
Soldering spot
(B, mm)
Net Weight
Per 1,000 pcs
SRM201T
8.50 ± 0.50
3.00 ± 0.2
D1+0.05/ -0.35
1.3 Min.
186 grams
◼ GENERAL SPECIFICATIONS
Type
Power
Rating
(at 70℃)
SRM201T
2W
Maximum
Maximum
Available
Permissible Minimum Maximum Resistance
Working
Resistance
Surge
Resistance Resistance Tolerance
Voltage*
Value
Voltage*
√𝑃𝑥𝑅
9,000V
0.1Ω
10MΩ
±1%~ ±5%
E-24/ E-96
* Rated Continuous Working Voltage (RCWV) should be determined from
RCWV = √ Power Rating × Resistance Values
Feb. 01, 2023
Page 1
◼ PART NUMBER
Example:SRM201TJ1K00TKZTR2K5
SRM201T
J
1K00
Type
Tolerance
TKZ
TR2K5
TCR
Packaging
3-character code
TKZ = Default
Product
Temperature
Coefficient.
5-character code
TR = Tape Reel
Resistance
1KΩ
F (5%)
4-character code
containing 3 significant digits
1 letter multiplier
(pieces per reel)
2K5 = 2,500pcs
MULTIPLIER
R=1
K = 103
M = 106
G = 109
Information of
typical product
temperature
coefficient can be
found in the
Technical Summary
section of the
datasheet.
◼ POWER DERATING CURVE
100%
90%
80%
70%
60%
RATED 50%
LOAD
40%
30%
20%
10%
0%
30
40
50
60
70
80
90
100
110
AMBIENT TEMPERATURE
120
130
140
150
160
(oC)
◼ TECHNICAL SUMMARY
Characteristics
Ranges & Limits
Dielectric Withstanding Voltage, VAC or DC
500
Temperature Coefficient, PPM /℃*
±200, ±400, ±800, ±1200
Operating Temperature Range,℃
Insulation Resistance, MΩ
Tin Whisker (JESD201 Temperature Cycling & High Temp.
/Humidity Storage), μm
-55 ~ +150
>104
Failure Rate in Time, pcs / 109 device hours
SRM201TJ2K00TKZTR2K5 价格&库存
很抱歉,暂时无法提供与“SRM201TJ2K00TKZTR2K5”相匹配的价格&库存,您可以联系我们找货
