SN74HC366N
SN74HC366N
    XBLW(芯伯乐)
    DIP16
    带三态控制输出的6路缓冲器/线驱动器(反相),工作电压2-6V,静态电流8uA
SN74HC366N 数据手册
XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting General Description The SN74HC/HCT366 is a hex inverting buffer/line driver with 3-state outputs controlled by the output — — enable inputs (OEn). A HIGH on OEn causes the outputs to assume a high impedance OFF-state. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. Features  Input levels: For SN74HC366: CMOS level For SN74HCT366: TTL level  Inverting outputs  Specified from -40℃ to +125℃  Packaging information: DIP16/SOP16/TSSOP16 Ordering Information Product Model XBLW SN74HC366N XBLW SN74HC366DTR XBLW SN74HC366TDTR XBLW SN74HCT366N XBLW SN74HCT366DTR XBLW SN74HCT366TDTR Package Type DIP-16 SOP-16 TSSOP-16 DIP-16 SOP-16 TSSOP-16 Marking 74HC366N 74HC366 74HC366 74HCT366N 74HCT366 74HCT366 Packing Packing Qty Tube Tape Tape Tube Tape Tape 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 1 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting Figure 2. IEC logic symbol Figure 3. Functional diagram Figure 4. Logic diagram XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 2 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting Pin Configurations Pin DescriptionFunction Table Pin No. Pin Name Description 1 OE1 output enable input 1 (active LOW) 2 1A data input 1 3 1Y data output 1 4 2A data input 2 5 2Y data output 2 6 3A data input 3 7 3Y data output 3 8 GND ground (0V) 9 4Y data output 4 10 4A data input 4 11 5Y data output 5 12 5A data input 5 13 6Y data output 6 14 6A data input 6 15 OE2 output enable input 2 (active LOW) 16 VCC supply voltage Function Table Input Output OE1 OE2 nA nY L L L H L L H L X H X Z H X X Z Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; Z=high-impedance OFF-state. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 3 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND(ground=0V), unless otherwise specified.) Parameter Symbol Conditions supply voltage Min. -0.5 Max. +7.0 Unit VCC input clamping current - IIK VI < -0.5V or VI > VCC+0.5V - ±20 mA output clamping current IOK VO < -0.5V or VO > VCC+0.5V - ±20 mA output current IO -0.5V < VO < VCC+0.5V ICC ground current storage temperature IGND - -70 ±35 70 mA supply current - - mA Tstg - -65 +150 ℃ total power dissipation Ptot - - 500 mW Soldering temperatur e TL 245 260 DIP SOP/TSSOP 10s V mA ℃ Recommended Operating Conditions Parameter Symbol supply voltage VCC input voltage VI output voltage VO Conditions Min. Typ. Max. Unit 2.0 5.0 6.0 V 0 - VCC V - VCC 625 ns/V 139 ns/V SN74HC366 input transition rise and fall rate Δt/ΔV ambient temperature Tamb VCC=2.0V 0 VCC=4.5V - 1.67 VCC=6.0V - - 83 ns/V - -40 - +125 ℃ 4.5 5.0 5.5 V 0 - VCC V - VCC V - V SN74HCT366 supply voltage VCC - input voltage VI output voltage VO input transition rise and fall rate - 0 Δt/ΔV VCC=4.5V - 1.67 139 ns/V ambient temperature Tamb - -40 - +125 ℃ XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 4 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Conditions Symbol Min. Typ. Max. Unit - V SN74HC366 HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage LOW-level output voltage VOH VCC=2.0V 1.5 1.2 VCC=4.5V 3.15 2.4 VCC=6.0V 4.2 3.2 VCC=2.0V - V V 0.8 0.5 V 2.1 1.35 V VCC=4.5V - VCC=6.0V 2.8 1.8 V IO=-20uA; VCC=2.0V 1.9 2.0 4.4 4.5 - V IO=-20uA; VCC=4.5V IO=-20uA; VCC=6.0V 5.9 6.0 IO=-6.0mA; VCC=4.5V 3.98 4.32 IO=-7.8mA; VCC=6.0V 5.48 5.81 IO=20uA; VCC=2.0V - VI = VIH or VIL IO=20uA; VCC=4.5V VOL - IO=20uA; VCC=6.0V VI = VIH or VIL IO=6.0mA; VCC=4.5V IO=7.8mA; VCC=6.0V - V V - V V 0 0.1 V 0 0.1 V 0 0.1 V 0.15 0.26 V - 0.16 0.26 V - input leakage current II VI=VCC or GND; VCC=6.0V - - ±1.0 uA OFF-state output current IOZ VI=VIH orVIL; VCC=6.0V; VO=VCC or GND - - ±1.0 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 8.0 uA input capacitance CI - 3.5 - pF SN74HCT366 HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 1.6 - V LOW-level input voltage VIL VCC=4.5V to 5.5V - 1.2 0.8 V HIGH-level output voltage VOH VI = VIH or VIL; VCC=4.5V - V V LOW-level output voltage VOL VI = VIH or VIL; VCC=4.5V V input leakage current II OFF-state output current supply current additional supply current input capacitance XBLWversion1.0 IO=-20uA 4.4 4.5 IO=-6.0mA 3.98 4.32 IO=20uA - 0 0.1 - 0.16 0.26 V VI=VCC or GND; VCC=5.5V - - ±1.0 uA IOZ VI=VIH orVIL; VCC=5.5V; VO=VCC or GND - - ±1.0 uA ICC VI=VCC or GND; IO=0A; VCC=5.5V - - - pin OE1 pin OE2 ΔICC IO=6.0mA pins nA VI=VCC-2.1V; other inputs at VCC or GND; IO=0A CI - www.xinboleic.com 8.0 uA - 360 uA - - 360 uA - - 320 uA - 3.5 - pF Technical Support:4009682003 5 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit VCC=2.0V 1.5 VCC=4.5V - - V 3.15 4.2 - V VCC=6.0V - - - 0.5 V VCC=2.0V - V - - 1.35 V - 1.8 V IO=-20uA; VCC=2.0V 1.9 IO=-20uA; VCC=4.5V - - V 4.4 IO=-20uA; VCC=6.0V 5.9 - - IO=-6.0mA; VCC=4.5V 3.84 - - 5.34 - - V IO=-7.8mA; VCC=6.0V - - 0.1 V IO=20uA; VCC=2.0V - V - - 0.1 V - - 0.1 V - - 0.33 V - - 0.33 V SN74HC366 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VIH VIL VCC=4.5V VCC=6.0V VOH VI = VIH or VIL IO=20uA; VCC=4.5V VOL IO=20uA; VCC=6.0V VI = VIH or VIL IO=6.0mA; VCC=4.5V IO=7.8mA; VCC=6.0V V V input leakage current II VI=VCC or GND; VCC=6.0V - - ±1.0 uA OFF-state output current IOZ VI=VIH orVIL; VCC=6.0V; VO=VCC or GND - - ±5.0 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 80 uA SN74HCT366 HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V LOW-level input voltage VIL VCC=4.5V to 5.5V - - 0.8 V HIGH-level output voltage VOH VI = VIH or VIL; VCC=4.5V - - V - V LOW-level output voltage VOL VI = VIH or VIL; VCC=4.5V 0.1 V input leakage current II OFF-state output current IOZ supply current ICC additional supply current XBLWversion1.0 ΔICC IO=-20uA 4.4 IO=-6.0mA 3.84 IO=20uA - - - - 0.33 V - - ±1.0 uA VI=VIH orVIL; VCC=5.5V; VO=VCC or GND - - ±5.0 uA VI=VCC or GND; IO=0A; VCC=5.5V - - - IO=6.0mA VI=VCC or GND; VCC=5.5V VI=VCC-2.1V; other inputs at VCC or GND; IO=0A www.xinboleic.com pins nA pin OE1 — pin OE2 80 uA - 450 uA - - 450 uA - - 400 uA Technical Support:4009682003 6 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting DC Characteristics 3 (Tamb=-40℃ to +125℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit VCC=2.0V 1.5 VCC=4.5V - - V 3.15 4.2 - V VCC=6.0V - - - 0.5 V VCC=2.0V - V - - 1.35 V - 1.8 V IO=-20uA; VCC=2.0V 1.9 IO=-20uA; VCC=4.5V - - V 4.4 IO=-20uA; VCC=6.0V 5.9 - - IO=-6.0mA; VCC=4.5V 3.7 - IO=-7.8mA; VCC=6.0V - - V 5.2 - - 0.1 V IO=20uA; VCC=2.0V - V - - 0.1 V - - 0.1 V - - 0.4 V - - 0.4 V SN74HC366 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VIH VIL VCC=4.5V VCC=6.0V VOH VI = VIH or VIL IO=20uA; VCC=4.5V VOL IO=20uA; VCC=6.0V VI = VIH or VIL IO=6.0mA; VCC=4.5V IO=7.8mA; VCC=6.0V V V input leakage current II VI=VCC or GND; VCC=6.0V - - ±1.0 uA OFF-state output current IOZ VI=VIH orVIL; VCC=6.0V; VO=VCC or GND - - ±10 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 160 uA SN74HCT366 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V IO=-20uA 4.4 - - V IO=-6.0mA 3.7 - - 0.1 V IO=20uA - V IO=6.0mA - - 0.4 V HIGH-level output voltage VOH VI = VIH or VIL; VCC=4.5V LOW-level output voltage VOL VI = VIH or VIL; VCC=4.5V input leakage current II VI=VCC or GND; VCC=5.5V - - ±1.0 uA OFF-state output current IOZ VI=VIH orVIL; VCC=5.5V; VO=VCC or GND - - ±10 uA supply current ICC VI=VCC or GND; IO=0A; VCC=5.5V - - - pin OE1 pin OE2 additional supply current XBLWversion1.0 ΔICC VI=VCC-2.1V; other inputs at VCC or GND; IO=0A www.xinboleic.com pins nA 160 uA - 490 uA - - 490 uA - - 441 uA Technical Support:4009682003 7 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting AC Characteristics 1 (Tamb=25℃, GND =0V, CL=50pF, unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit - 33 100 ns 12 20 ns 10 ns 10 17 44 150 ns 16 30 ns - 13 16 ns - 55 150 ns 20 30 ns 16 26 ns 14 60 ns SN74HC366 nA tonY propagation delay OEn to nY enable time OEn to nY disable time VCC=2.0V tpd see Figure 6 VCC=4.5V VCC=5.0V; CL=15pF - VCC=6.0V - VCC=2.0V ten see Figure 7 VCC=4.5V VCC=6.0V VCC=2.0V tdis see Figure 7 VCC=4.5V VCC=6.0V VCC=2.0V transition time tt see Figure 6 CPD nA tonY propagation delay tpd - - ns 5 12 ns - 4 10 ns - 30 - pF VCC=4.5V - 13 24 ns VCC=5.0V; CL=15pF - 11 - ns VCC=4.5V VCC=6.0V power dissipation capacitanc e - per buffer; VI=GND to VCC - SN74HCT366 see Figure 6 OEn to nY enable time ten VCC=4.5V; see Figure 7 - 16 35 ns OEn to nY disable time tdis VCC=4.5V; see Figure 7 - 20 35 ns transition time power dissipation capacitanc e tt VCC=4.5V; see Figure 6 - 5 12 ns - 30 - pF per buffer; VI=GND to VCC- 1.5V CPD Note: [1] tpd is the same as tPLH and tPHL. [2] ten is the same as tPZL and tPZH. [3] tdis is the sameastPLZ and tPHZ. [4] tt is the sameastTHL and tTLH. [5] CPD isused to determine the dynamic power dissipation (PD in uW). PD=CPD ×VCC2 ×fi×N+Σ(CL×VCC2 ×fo) where: f i=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; Σ(CL×VCC2 ×fo)=sum of outputs. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 8 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting AC Characteristics 2 (Tamb=-40℃ to +85℃, GND=0V, CL=50pF, unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit - - 125 ns - - 25 ns - - 21 ns - - 190 ns - - 38 ns - - 33 ns - - 190 ns - - 38 ns - - 33 ns - - 75 ns - - 15 ns - - 13 ns - - 30 ns SN74HC366 nA tonY propagation delay OEn to nY enable time OEn to nY disable time VCC=2.0V tpd see Figure 6 VCC=4.5V VCC=6.0V VCC=2.0V ten see Figure 7 VCC=4.5V VCC=6.0V VCC=2.0V tdis see Figure 7 VCC=4.5V VCC=6.0V VCC=2.0V transition time tt see Figure 6 VCC=4.5V VCC=6.0V SN74HCT366 nA tonY propagation delay tpd see Figure 6 VCC=4.5V OEn to nY enable time ten VCC=4.5V; see Figure 7 - - 44 ns OEn to nY disable time tdis VCC=4.5V; see Figure 7 - - 44 ns transition time tt VCC=4.5V; see Figure 6 - - 15 ns Note: [1] tpd is the same as tPLH and tPHL. [2] ten is the same as tPZL and tPZH. [3] tdis is the sameastPLZ and tPHZ. [4] tt is the sameastTHL and tTLH. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 9 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting AC Characteristics 3 (Tamb=-40℃ to +125℃, GND=0V, CL=50pF, unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit - - 150 ns - - 30 ns - - 26 ns - - 225 ns - - 45 ns - - 38 ns - - 225 ns - - 45 ns - - 38 ns - - 90 ns - - 18 ns - - 15 ns - - 36 ns SN74HC366 nA tonY propagation delay VCC=2.0V tpd VCC=2.0V ten see Figure 7 VCC=4.5V VCC=6.0V VCC=2.0V — OEn to nY disable time VCC=4.5V VCC=6.0V — OEn to nY enable time see Figure 6 tdis see Figure 7 VCC=4.5V VCC=6.0V VCC=2.0V transition time tt see Figure 6 VCC=4.5V VCC=6.0V SN74HCT366 nA tonY propagation delay tpd see Figure 6 — OEn to nY enable time VCC=4.5V ten VCC=4.5V; see Figure 7 - - 53 ns OEn to nY disable time tdis VCC=4.5V; see Figure 7 - - 53 ns transition time tt VCC=4.5V; see Figure 6 - - 18 ns — Note: [1] tpd is the same as tPLH and tPHL. [2] ten is the same as tPZL and tPZH. [3] tdis is the sameastPLZ and tPHZ. [4] tt is the sameastTHL and tTLH. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 10 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting Testing Circuit AC Testing Circuit Figure 5. Test circuit for measuring switching times Definitions for test circuit: RL=Load resistance. CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. S1=Test selection switch. AC Testing Waveforms Figure 6. Input (nA) to output (nY) propagation delays and output transition times Figure 7. 3-state enable and disable times XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 11 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting Measurement Points Input Type Output SN74HC366 VM VM VX VY 0.5×VCC 0.5×VCC 0.1×VCC 0.9×VCC SN74HCT366 1.3V 1.3V 0.1×VCC 0.9×VCC Test Data Input Type S1 position Load tPHL, tPZH, tPZL, tPLH tPHZ tPLZ 1kΩ open GND VCC 1kΩ open GND VCC VI t r ,t f CL RL SN74HC366 VCC 6ns 15pF, 50pF SN74HCT366 3V 6ns 15pF, 50pF XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 12 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting Package Information DIP16 SOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 13 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 14 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting TSSOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 15 / 16 XBLW SN74HC/HCT366 Hex Buffer/Line Driver; 3-state; Lnverting Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  This document is for referenceonly,and the actual use should be based on the application test results.  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 16 / 16
SN74HC366N 价格&库存
很抱歉,暂时无法提供与“SN74HC366N”相匹配的价格&库存,您可以联系我们找货
