SN74HC175N
SN74HC175N
    XBLW(芯伯乐)
    DIP16
    四位D型复位触发器,工作电压2-6V,静态电流4uA
SN74HC175N 数据手册
XBLW SN74HC/HCT175 Quad D-type flip-flop with reset General Description The SN74HC/HCT175 is a quad positive-edge triggered D-type flip-flop with individual data inputs (Dn) and complementary outputs (Qn and Qn ). Features  Input levels: For SN74HC175: CMOS level For SN74HCT175: TTL level  Four edge-triggered D-type flip-flops  Asynchronous master reset  Specified from -40℃ to +125℃  Packaging information:DIP16/SOP16/TSSOP16 Ordering Information Product Model XBLW SN74HC175N XBLW SN74HC175DTR XBLW SN74HC175TDTR XBLW SN74HCT175N XBLW SN74HCT175DTR XBLW SN74HCT175TDTR Package Type DIP-16 SOP-16 TSSOP-16 DIP-16 SOP-16 TSSOP-16 Marking 74HC175N 74HC175 74HC175 74HCT175N 74HCT175 74HCT175 Packing Tube Tape Tape Tube Tape Tape Packing Qty 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel Block Diagram And Pin Description Block Diagram XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 1 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset Pin Configurations Pin Description Pin No. Pin Name Description 1 MR Q0 asynchronous master reset input (active LOW) Q0 D0 D1 complementary flip-flop output Q1 Q1 GND CP Q2 complementary flip-flop output 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 flip-flop output data input data input flip-flop output ground (0V) clock input (LOW-to-HIGH edge-triggered) flip-flop output Q2 D2 D3 complementary flip-flop output Q3 Q3 VCC complementary flip-flop output data input data input flip-flop output positive supply voltage 2.4 Function table Operating mode reset (clear) load “1” load “0” Inputs MR L H H Outputs CP Dn Qn X X L ↑ h H ↑ l L Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care; Qn H L H ↑=LOW-to-HIGH clock transition; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 2 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset Electrical Parameter Absolute Maximum Ratings (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified) Characteristic Symbol supply voltage VCC input clamping current IIK output clamping current IOK output current IO supply current ICC ground current IGND storage temperature Tstg total power dissipation Ptot soldering temperature TL Conditions Min. -0.5 Max. +7.0 Unit - +20 mA - ±20 mA - ±25 +50 mA - +150 mA -65 - - 500 mW VIVCC+0.5V VOVCC+0.5V VO=-0.5V to (VCC+0.5V) - -50 - 10s DIP V mA ℃ 245 SOP/TSSOP ℃ ℃ 260 Recommended Operating Conditions (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit 2.0 5.0 6.0 V 0 - VCC V V - VCC +125 ℃ 4.5 5.0 5.5 V 0 - VCC V VCC V +125 ℃ SN74HC175 supply voltage VCC input voltage VI output voltage VO ambient temperature Tamb supply voltage VCC input voltage VI output voltage VO ambient temperature Tamb SN74HCT175 - 0 - -40 0 - -40 - DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified) Parameter Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage LOW-level output voltage VOH VOL VI=VIH or VIL VI=VIH or VIL Conditions SN74HC175 Min. Typ. Max. Unit VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V IO=-20uA; VCC=6.0V IO=-4mA; VCC=4.5V 1.5 3.15 4.2 1.2 2.4 3.2 0.8 2.1 0.5 1.35 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 1.8 V V V V V V V V V V V V V V V V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V IO=20uA; VCC=6.0V IO=4mA; VCC=4.5V IO=5.2mA; VCC=6.0V XBLWversion1.0 1.9 4.4 5.9 3.98 5.48 - www.xinboleic.com Technical Support:4009682003 0.1 0.1 0.1 0.26 0.26 3 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset input leakage current II VI=VCC or GND; VCC=6.0V - - ±1 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V SN74HCT175 - - 1 uA HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 1.6 - V LOW-level input voltage VIL VCC=4.5V to 5.5V - 1.2 0.8 V HIGH-level output voltage VOH VI=V IH orV IL 4.4 3.98 LOW-level output voltage VOL VI=V IH orV IL - 4.5 4.32 0 0.15 0.1 0.26 V V V input leakage current II VI=VCC or GND; VCC=5.5V - - ±1 uA supply current ICC VI=VCC or GND; IO=0A; VCC=5.5V - 1 uA 144 uA additional supply current ∆ICC IO=-20uA; VCC=4.5V IO=-4mA; VCC=4.5V IO=20uA; VCC=4.5V IO=5.2mA; VCC=5.5V per input pin; VI=VCC-2.1V; other inputs at VCC or GND; VCC=4.5V to 5.5V V Dn input - 40 CP input - 60 216 uA MR input - 100 360 uA DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified) Parameter Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage VOH VI=VIH or VIL Conditions SN74HC175 Min. Typ. Max. Unit VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V IO=-20uA; VCC=6.0V IO=-4mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V IO=20uA; VCC=6.0V IO=4mA; VCC=4.5V IO=5.2mA; VCC=6.0V 1.5 3.15 4.2 - - - 0.5 1.35 1.8 V V V V V - - 0.1 0.1 0.1 0.33 0.33 V V V V V V V V V V V 1.9 4.4 5.9 3.84 5.34 LOW-level output voltage VOL input leakage current II VI=VCC or GND; VCC=6.0V - - ±2 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V SN74HCT175 - - 2 uA HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V LOW-level input voltage VIL VCC=4.5V to 5.5V - - 0.8 V HIGH-level output voltage VOH VI=V IH orV IL 4.4 3.84 LOW-level output voltage VOL VI=V IH orV IL - 0.1 V V V V XBLWversion1.0 VI=VIH or VIL IO=-20uA; VCC=4.5V IO=-4mA; VCC=4.5V IO=20uA; VCC=4.5V IO=5.2mA; VCC=5.5V - www.xinboleic.com Technical Support:4009682003 0.33 4 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset input leakage current II VI=VCC or GND; VCC=5.5V - - ±2 uA supply current ICC VI=VCC or GND; IO=0A; VCC=5.5V - - 2 uA Dn input - - 180 uA CP input - - 270 uA MR input - - 450 uA additional supply current ∆ICC per input pin; VI=VCC-2.1V; other inputs at VCC or GND; VCC=4.5V to 5.5V DC Characteristics 3 (Tamb=-40℃ to +125℃, voltages are referenced to GND (ground=0V), unless otherwise specified) Parameter Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage LOW-level output voltage VOH VOL VI=VIH or VIL VI=VIH or VIL Conditions SN74HC175 Min. Typ. Max. Unit VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V 1.5 3.15 4.2 0.5 1.35 - - 0.1 0.1 0.1 0.4 0.4 V V V V V V V V V V V V V V V V IO=-20uA; VCC=6.0V IO=-4mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V IO=20uA; VCC=6.0V IO=4mA; VCC=4.5V IO=5.2mA; VCC=6.0V 1.9 4.4 5.9 3.7 5.2 1.8 input leakage current II VI=VCC or GND; VCC=6.0V - - ±4 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V SN74HCT175 - - 4 uA HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V LOW-level input voltage VIL VCC=4.5V to 5.5V - - 0.8 V HIGH-level output voltage VOH VI=V IH orV IL 4.4 3.7 LOW-level output voltage VOL VI=V IH orV IL - - 0.1 0.4 V V V input leakage current II VI=VCC or GND; VCC=5.5V - - ±4 uA supply current ICC VI=VCC or GND; IO=0A; VCC=5.5V - - 4 uA Dn input - - 196 uA CP input - - 294 uA MR input - - 490 uA additional supply current XBLWversion1.0 ∆ICC IO=-20uA; VCC=4.5V IO=-4mA; VCC=4.5V IO=20uA; VCC=4.5V IO=5.2mA; VCC=5.5V per input pin; VI=VCC-2.1V; other inputs at VCC or GND; VCC=4.5V to 5.5V www.xinboleic.com Technical Support:4009682003 V 5 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset AC Characteristics 1 (Tamb=25℃, GND=0V, CL=50pF, unless otherwise specified) Parameter Symbol Conditions Min. Typ. Max. Unit VCC=2.0V - 55 175 ns VCC=4.5V VCC=5.0V CL=15pF - 50 35 ns 17 30 ns 16 50 150 ns 18 30 ns 15 ns 14 26 19 75 ns 7 15 ns SN74HC175 propagation delay HIGH to LOW propagation delay transition time pulse width recovery time set-up time hold time maximum frequency tPLH/tPHL tPHL tt tW trec tsu th fmax CP to Qn, Qn ; see Figure 4 MR to Qn, Qn ; see Figure 6 Qn output; see Figure 4 - VCC=6.0V - VCC=2.0V - VCC=4.5V VCC=5.0V CL=15pF - VCC=6.0V - VCC=2.0V - - HIGH to LOW propagation delay tPLH/tPHL tPHL transition time tt pulse width tW XBLWversion1.0 ns VCC=4.5V - VCC=6.0V 6 13 ns 22 - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns - ns CP input HIGH or LOW; see Figure 4 VCC=2.0V 80 VCC=4.5V 16 8 VCC=6.0V 14 6 MR input LOW; see Figure 6 VCC=2.0V 80 19 VCC=4.5V 16 7 VCC=6.0V 14 6 VCC=2.0V 5 -33 VCC=4.5V 5 -12 VCC=6.0V 5 -10 VCC=2.0V 80 3 VCC=4.5V 16 1 VCC=6.0V 14 1 VCC=2.0V 25 2 VCC=4.5V 5 0 VCC=6.0V 4 0 VCC=2.0V 6 25 VCC=4.5V VCC=5.0V CL=15pF 30 75 35 83 - 19 33 ns - 16 - ns - 22 38 ns - 19 - ns - 19 35 ns - 16 - ns VCC=4.5V - 7 15 ns VCC=4.5V 20 12 - ns MR to CP; see Figure 6 Dn to CP; see Figure 4 Dn to CP; see Figure 4 CP input; see Figure 4 VCC=6.0V 89 SN74HCT175 propagation delay ns CP to Qn, Qn ; see Figure 4 MR to Qn; see Figure 6 MR to Qn ; see Figure 6 Qn output; see Figure 4 CP input; see Figure 4 VCC=4.5V VCC=5V; CL=15pF VCC=4.5V VCC=5V; CL=15pF VCC=4.5V VCC=5V; CL=15pF www.xinboleic.com Technical Support:4009682003 6 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset MR input LOW; see Figure 6 recovery time trec set-up time tsu hold time th maximum frequency fmax MR to CP; see Figure 6 Dn to CP; see Figure 4 Dn to CP; see Figure 4 CP input; see Figure 4 VCC=4.5V 20 11 - ns VCC=4.5V 5 -10 - ns VCC=4.5V 16 5 - ns VCC=4.5V 5 0 - ns VCC=4.5V 25 49 - ns Min. Typ. Max. Unit - - 220 ns VCC=4.5V - - 44 ns VCC=6.0V - - 37 ns VCC=2.0V 190 ns 38 ns AC Characteristics 2 (Tamb=-40℃ to +85℃, GND=0V, CL=50pF, unless otherwise specified) Parameter Conditions Symbol SN74HC175 propagation delay HIGH to LOW propagation delay transition time pulse width recovery time set-up time hold time maximum frequency tPLH/tPHL tPHL tt CP to Qn, Qn ; see Figure 4 MR to Qn, Qn ; see Figure 6 Qn output; see Figure 4 CP input HIGH or LOW; see Figure 4 tW trec tsu th fmax MR input LOW; see Figure 6 MR to CP; see Figure 6 Dn to CP; see Figure 4 Dn to CP; see Figure 4 CP input; see Figure 4 VCC=2.0V - - VCC=4.5V - - VCC=6.0V - - 33 ns VCC=2.0V - - 95 ns VCC=4.5V - - 19 ns VCC=6.0V - 16 ns VCC=2.0V 100 - ns 20 - VCC=4.5V - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - 41 ns VCC=6.0V 17 VCC=2.0V 100 VCC=4.5V 20 VCC=6.0V 17 VCC=2.0V 5 VCC=4.5V 5 VCC=6.0V 5 VCC=2.0V 100 VCC=4.5V 20 VCC=6.0V 17 VCC=2.0V 30 VCC=4.5V 6 VCC=6.0V 5 VCC=2.0V 4.8 VCC=4.5V 24 VCC=6.0V 28 SN74HCT175 propagation delay XBLWversion1.0 tPLH/tPHL CP to Qn, Qn ; see Figure 4 VCC=4.5V - www.xinboleic.com Technical Support:4009682003 7 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset HIGH to LOW propagation delay transition time pulse width tPHL tt tW recovery time trec set-up time tsu hold time th maximum frequency fmax MR to Qn; see Figure 6 VCC=4.5V - - 48 ns MR to Qn ; see Figure 6 Qn output; see Figure 4 CP input; see Figure 4 VCC=4.5V - - 44 ns VCC=4.5V - - 19 ns VCC=4.5V 25 - - ns VCC=4.5V 25 - - ns VCC=4.5V 5 - - ns VCC=4.5V 20 - - ns VCC=4.5V 5 - - ns VCC=4.5V 20 - - ns Min. Typ. Max. Unit 265 ns 53 ns MR input LOW; see Figure 6 MR to CP; see Figure 6 Dn to CP; see Figure 4 Dn to CP; see Figure 4 CP input; see Figure 4 AC Characteristics 3 (Tamb=-40℃ to +125℃, GND=0V, CL=50pF, unless otherwise specified) Parameter Conditions Symbol SN74HC175 propagation delay HIGH to LOW propagation delay transition time pulse width recovery time set-up time hold time XBLWversion1.0 tPLH/tPHL tPHL tt tW trec tsu th CP to Qn, Qn ; see Figure 4 MR to Qn, Qn ; see Figure 6 Qn output; see Figure 4 VCC=2.0V - - VCC=4.5V - - VCC=6.0V - - 45 ns VCC=2.0V - - 225 ns 45 ns ns VCC=4.5V - - VCC=6.0V - - 38 VCC=2.0V 110 ns 22 ns - - VCC=4.5V - - VCC=6.0V - 19 ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns CP input HIGH or LOW; see Figure 4 VCC=2.0V 120 VCC=4.5V 24 VCC=6.0V 20 MR input LOW; see Figure 6 VCC=2.0V 120 VCC=4.5V 24 VCC=6.0V 20 VCC=2.0V 5 VCC=4.5V 5 VCC=6.0V 5 VCC=2.0V 120 VCC=4.5V 24 VCC=6.0V 20 VCC=2.0V 40 VCC=4.5V 8 MR to CP; see Figure 6 Dn to CP; see Figure 4 Dn to CP; see Figure 4 www.xinboleic.com Technical Support:4009682003 8 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset maximum frequency fmax propagation delay tPLH/tPHL HIGH to LOW propagation delay transition time pulse width tPHL tt tW recovery time trec set-up time tsu hold time th maximum frequency fmax CP input; see Figure 4 VCC=6.0V 7 VCC=2.0V 4 VCC=4.5V 20 VCC=6.0V SN74HCT175 24 - - ns - - ns - - ns - - ns CP to Qn, Qn ; see Figure 4 VCC=4.5V - - 50 ns MR to Qn; see Figure 6 VCC=4.5V - - 57 ns MR to Qn ; see Figure 6 Qn output; see Figure 4 CP input; see Figure 4 VCC=4.5V - - 53 ns VCC=4.5V - - 22 ns VCC=4.5V 30 - - ns VCC=4.5V 30 - - ns VCC=4.5V 5 - - ns VCC=4.5V 24 - - ns VCC=4.5V 5 - - ns VCC=4.5V 17 - - ns MR input LOW; see Figure 6 MR to CP; see Figure 6 Dn to CP; see Figure 4 Dn to CP; see Figure 4 CP input; see Figure 4 Testing Circuit AC Testing Circuit XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 9 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset Definitions for test circuit: CL includes probe and jig capacitance AC Testing Waveforms Measurement Points Input Type Output VI VM VM SN74HC175 VCC 0.5×VCC 0.5×VCC SN74HCT175 3V 1.3V 1.3V Test Data Type Input Load Test VI t r ,t f CL RL SN74HC175 VCC 3.0ns 15pF, 50pF 1kΩ tPLH , tPHL SN74HCT175 3.0V 3.0ns 15pF, 50pF 1kΩ tPLH , tPHL XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 10 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset Package Information DIP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 11 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset SOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 12 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset TSSOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 13 / 14 XBLW SN74HC/HCT175 Quad D-type flip-flop with reset Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  This document is for referenceonly,and the actual use should be based on the application test results.  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 14 / 14
SN74HC175N 价格&库存
很抱歉,暂时无法提供与“SN74HC175N”相匹配的价格&库存,您可以联系我们找货
