SN74HC163N
SN74HC163N
    XBLW(芯伯乐)
    DIP16
    同步置数/同步复位4位二进制计数器,工作电压2-6V,静态电流8uA
SN74HC163N 数据手册
XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS General Description The SN74HC/HCT163 is a synchronous presettable binary counter with an internal look-head carry. Synchronous operation is provided by having all flip-flops clocked simultaneously on the positive-going edge of the clock (CP). The outputs (Q0 to Q3) of the counters maybe preset to a HIGH or LOW. A LOW at the parallel enable input (PE) disables the counting action. It causes the data at the data inputs (D0 to D3) to be loaded into the counter on the positive-going edge of the clock. Preset takes place regardless of the levels at count enable inputs (CEP and CET). A LOW at the master reset input (MR) sets Q0 to Q3 LOW after the next positive-going transition on the clock input (CP). This action occurs regardless of the levels at input pins PE, CET and CEP. This synchronous reset feature enables the designer to modify the maximum count with only one external NAND gate. The look-ahead carry simplifies serial cascading of the counters. Both CEP and CET must be HIGH to count. The CET input is fed forward to enable the terminal count output (TC). The TC output thus enabled will produce a HIGH output pulse of a duration approximately equal to a HIGH output of Q0. This pulse can be used to enable the next cascaded stage. Inputs include clamp diodes. This enables the use of current limiting resistors to interface inputs to voltages in excess of VCC. The CP to TC propagation delay and CEP to CP set-up time determine the maximum clock frequency for the cascaded counters according to the following formula: fmax=1/(tP(max)(CP to TC)+tSU(CEP to CP)) Features  Input levels: For SN74HC163: CMOS level For SN74HCT163: TTL level  Synchronous counting and loading  2 count enable inputs for n-bit cascading  Synchronous reset  Positive-edge triggered clock  Specified from -40℃ to +125℃  Packaging information: DIP16/SOP16/TSSOP16 Ordering Information Product Model XBLW SN74HC163N XBLW SN74HC163DTR XBLW SN74HC163TDTR XBLW SN74HCT163N XBLW SN74HCT163DTR XBLW SN74HCT163TDTR XBLWversion1.0 Package Type DIP-16 SOP-16 TSSOP-16 DIP-16 SOP-16 TSSOP-16 www.xinboleic.com Marking 74HC163N 74HC163 74HC163 74HCT163N 74HCT163 74HCT163 Packing Tube Tape Tape Tube Tape Tape Technical Support:4009682003 Packing Qty 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel 1000Pcs/Box 2500Pcs/Reel 3000Pcs/Reel 1 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS Block Diagram And Pin Description Block Diagram Figure 1. Logic symbol Figure 2. IEC logic symbol Figure 3.Functional diagram XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 2 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS Figure 4. Logic diagram Figure 5. State diagram Figure 6. Typical timing sequence XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 3 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS Pin Configurations Pin Description Pin No. Pin Name Description 1 MR asynchronous master reset (active LOW) 2 CP clock input (LOW-to-HIGH, edge triggered) 3 D0 data input 4 D1 data input 5 D2 data input 6 D3 data input 7 CEP count enable input 8 GND ground (0V) 9 PE parallel enable input (active LOW) 10 CET count enable carry input 11 Q3 flip-flop output 12 Q2 flip-flop output 13 Q1 flip-flop output 14 Q0 15 TC flip-flop output terminal count output 16 VCC supply voltage Function Table Operating mode reset (clear) parallel load count hold (do nothing) XBLWversion1.0 Input Output MR l CP CEP CET ↑ Dn Qn TC X PE X X h ↑ X L L h ↑ X X l l L L h ↑ X X l h H L h X h h h X count [2] l X h X qn L www.xinboleic.com Technical Support:4009682003 4 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS h X X l X h L qn Note: [1] H=HIGH voltage level; L=LOW voltage level; X=don’t care; ↑=LOW-to-HIGH clock transition; l=LOW voltage level one set-up time prior to the LOW-to-HIGH clock transition; h=HIGH voltage level one set-up time prior to the LOW-to-HIGH CP transition; q=lower case letters indicate the state of the referenced output one set-up time prior to the LOWto-HIGH CP transition. [2] The TC output is HIGH when CET is HIGH and the counter is at terminal count (HHHH). Electrical Parameter Absolute Maximum Ratings (Voltages are referenced to GND(ground=0V), unless otherwise specified.) Parameter Symbol Conditions - Min. -0.5 Max. +7.0 Unit supply voltage VCC input clamping current IIK VI < -0.5V or VI > VCC+0.5V - ±20 mA output clamping current IOK VO < -0.5V or VO > VCC+0.5V - ±20 mA -0.5V < VO < VCC+0.5V - ±25 mA +50 mA - mA V output current IO supply current ICC ground current storage temperature - IGND - -50 Tstg - -65 +150 ℃ total power dissipation Ptot - - 500 mW Soldering temperatur e TL 3.2 245 260 DIP SOP/TSSOP 10s ℃ Recommended Operating Conditions Conditions Parameter Symbol supply voltage VCC input voltage - VI - Min. Typ. Max. Unit 2.0 5.0 6.0 V 0 - VCC V - VCC V 625 ns/V 139 ns/V ns/V SN74HC163 output voltage VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb VCC=2.0V 0 VCC=4.5V - 1.67 VCC=6.0V - - 83 - -40 - +125 ℃ 4.5 5.0 5.5 V 0 - VCC V - VCC V - SN74HCT163 supply voltage VCC - input voltage VI output voltage VO input transition rise and fall rate - 0 Δt/ΔV VCC=4.5V - 1.67 139 ns/V ambient temperature Tamb - -40 - +125 ℃ XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 5 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS DC Characteristics 1 (Tamb=25℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit - V SN74HC163 HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage LOW-level output voltage VOH VCC=2.0V 1.5 1.2 VCC=4.5V 3.15 2.4 VCC=6.0V 4.2 3.2 VCC=2.0V - supply current input capacitance V 0.8 0.5 V 2.1 1.35 V - VCC=6.0V 2.8 1.8 V IO=-20uA; VCC=2.0V 1.9 2.0 4.4 4.5 - V IO=-20uA; VCC=4.5V IO=-20uA; VCC=6.0V 5.9 6.0 IO=-4.0mA; VCC=4.5V 3.98 4.32 IO=-5.2mA; VCC=6.0V 5.48 5.81 IO=20uA; VCC=2.0V - VI = VIH or VIL IO=20uA; VCC=6.0V VI = VIH or VIL IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V input leakage current V VCC=4.5V IO=20uA; VCC=4.5V VOL - - V V - V V 0 0.1 V 0 0.1 V 0 0.1 V 0.15 0.26 V - 0.16 0.26 V - II VI=VCC or GND; VCC=6.0V - - ±1.0 uA ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 8.0 uA - 3.5 - pF CI SN74HCT163 HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 1.6 - V LOW-level input voltage VIL VCC=4.5V to 5.5V - 1.2 0.8 V HIGH-level output voltage VOH VI = VIH or VIL; VCC=4.5V IO=-20uA 4.4 4.5 V IO=-4.0mA 3.98 4.32 - V LOW-level output voltage VOL VI = VIH or VIL; VCC=4.5V IO=20uA - 0 0.1 V IO=4.0mA 0.26 V input leakage current - 0.15 II VI=VCC or GND; VCC=5.5V - - ±1.0 uA supply current ICC VI=VCC or GND; IO=0A; VCC=5.5V - - 8.0 uA - - 342 uA - - 396 uA - - 90 uA - - 270 uA - - 108 uA - 3.5 - pF — additional supply current input capacitance XBLWversion1.0 ΔICC CI pin MR pin CP per input pin; VI=VCC-2.1V; other inputs at VCC or GND; IO=0A; VCC=4.5V to 5.5V pin CEP and Dn pin CET pin PE - www.xinboleic.com Technical Support:4009682003 6 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS DC Characteristics 2 (Tamb=-40℃ to +85℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit VCC=2.0V 1.5 3.15 - V VCC=4.5V - 4.2 - - V VCC=6.0V - V VCC=2.0V - - 0.5 V - - 1.35 V - V IO=-20uA; VCC=2.0V 1.9 1.8 IO=-20uA; VCC=4.5V - - V 4.4 IO=-20uA; VCC=6.0V 5.9 - - IO=-4.0mA; VCC=4.5V 3.84 - - IO=-5.2mA; VCC=6.0V - - V 5.34 - - 0.1 V IO=20uA; VCC=2.0V - V - - 0.1 V - - 0.1 V - - 0.33 V - - 0.33 V SN74HC163 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VIH VCC=4.5V VIL VCC=6.0V VOH VI = VIH or VIL IO=20uA; VCC=4.5V VOL IO=20uA; VCC=6.0V VI = VIH or VIL IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V V V input leakage current II VI=VCC or GND; VCC=6.0V - - ±1.0 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 80 uA SN74HCT163 HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V LOW-level input voltage VIL VCC=4.5V to 5.5V - - 0.8 V HIGH-level output voltage VOH VI = VIH or VIL; VCC=4.5V IO=-20uA 4.4 - V IO=-4.0mA 3.84 - V LOW-level output voltage VOL VI = VIH or VIL; VCC=4.5V IO=20uA - - 0.1 V IO=4.0mA - V input leakage current - 0.33 II VI=VCC or GND; VCC=5.5V - - ±1.0 uA supply current ICC VI=VCC or GND; IO=0A; VCC=5.5V - - 80 uA pin MR pin CP - - 427.5 uA - 495 uA pin CEP and Dn - - - additional supply current XBLWversion1.0 ΔICC per input pin; VI=VCC-2.1V; other inputs at VCC or GND; IO=0A; VCC=4.5V to 5.5V www.xinboleic.com pin CET pin PE Technical Support:4009682003 112.5 uA - 337.5 uA - 135 uA 7 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS DC Characteristics 3 (Tamb=-40℃ to +125℃, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit VCC=2.0V 1.5 VCC=4.5V - - V 3.15 4.2 - V VCC=6.0V - - - 0.5 V VCC=2.0V - V - - 1.35 V - 1.8 V IO=-20uA; VCC=2.0V 1.9 4.4 - - V IO=-20uA; VCC=4.5V IO=-20uA; VCC=6.0V 5.9 - - IO=-4.0mA; VCC=4.5V 3.7 - - 5.2 - - V IO=-5.2mA; VCC=6.0V - V IO=20uA; VCC=2.0V - - 0.1 V - - 0.1 V - - 0.1 V - - 0.4 V - - 0.4 V SN74HC163 HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage VIH VIL VCC=4.5V VCC=6.0V VOH VI = VIH or VIL IO=20uA; VCC=4.5V VOL IO=20uA; VCC=6.0V VI = VIH or VIL IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V V V input leakage current II VI=VCC or GND; VCC=6.0V - - ±1.0 uA supply current ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 160 uA SN74HCT163 HIGH-level input voltage VIH VCC=4.5V to 5.5V 2.0 - - V LOW-level input voltage VIL VCC=4.5V to 5.5V - - 0.8 V HIGH-level output voltage VOH VI = VIH or VIL; VCC=4.5V IO=-20uA 4.4 - V IO=-4.0mA 3.7 - LOW-level output voltage VOL VI = VIH or VIL; VCC=4.5V - V IO=4.0mA - 0.1 V IO=20uA - V input leakage current - 0.4 II VI=VCC or GND; VCC=5.5V - - ±1.0 uA supply current ICC VI=VCC or GND; IO=0A; VCC=5.5V - - 160 uA pin MR pin CP - - 465.5 uA - - - - - additional supply current XBLWversion1.0 ΔICC per input pin; VI=VCC-2.1V; other inputs at VCC or GND; IO=0A; VCC=4.5V to 5.5V www.xinboleic.com pin CEP and Dn pin CET pin PE Technical Support:4009682003 539 uA 122.5 uA - 367.5 uA - 147 uA 8 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS AC Characteristics 1 (Tamb=25℃, GND=0V, CL=50pF, unless otherwise specified.) Parameter Symbol Conditions Min. Typ. Max. Unit SN74HC163 55 185 ns 20 37 ns 17 ns 16 31 69 215 ns 25 43 ns 21 37 ns 20 36 120 ns 13 24 ns 11 20 ns 10 19 75 ns 7 15 ns 13 ns VCC=2.0V 80 6 17 16 6 - ns VCC=4.5V 14 5 - ns VCC=6.0V ns VCC=2.0V 80 22 - 16 8 - ns VCC=4.5V ns VCC=6.0V 14 6 - ns VCC=2.0V 80 17 ns VCC=4.5V 16 6 - VCC=6.0V 5 - ns 14 175 58 - ns VCC=2.0V ns VCC=4.5V 35 21 - 30 17 - ns VCC=6.0V 0 -14 - ns VCC=2.0V ns VCC=4.5V 0 -5 - VCC=6.0V -4 - ns 0 5 15 - VCC=2.0V ns MHz VCC=4.5V 27 46 32 51 - VCC=2.0V CP to Qn; see Figure 8 VCC=4.5V VCC=5.0V; CL=15pF VCC=6.0V VCC=2.0V propagation delay tpd CP to TC; see Figure 8 VCC=4.5V VCC=5.0V; CL=15pF VCC=6.0V VCC=2.0V CET to TC; see Figure 9 VCC=4.5V VCC=5.0V; CL=15pF VCC=6.0V transition time pulse width tt tW see Figure 8 and Figure 9 CP HIGH or LOW; see Figure 8 R, Dn to CP; see Figure 10, 11 set-up time tsu PE to CP; see Figure 10 CEP, CET to CP; see Figure 12 — Dn, PE, CEP, CET, hold time maximum frequency th fmax MR to CP; see Figure 10, 11, 12 CP; see Figure 8 VCC=2.0V VCC=4.5V VCC=6.0V VCC=5.0V; CL=15pF VCC=6.0V power dissipation capacitanc e CPD f i=1MHz; VCC=5.0V; VI=GND to VCC - 55 - ns ns ns MHz MHz - MHz 33 - pF 23 39 ns 20 49 ns 32 ns SN74HCT163 propagation delay tpd CP to Qn; see Figure 8 VCC=4.5V VCC=5.0V; CL=15pF - CP to TC; see Figure 8 VCC=4.5V - 29 VCC=5.0V; CL=15pF - 25 CET to TC; see Figure 9 VCC=4.5V VCC=5.0V; CL=15pF transition time tt VCC=4.5V; see Figure 8, 9 pulse width tW CP HIGH or LOW; VCC=4.5V; see Figure 8 XBLWversion1.0 www.xinboleic.com - - 17 ns ns - 14 20 15 ns 7 6 - ns Technical Support:4009682003 ns 9 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS — set-up time MR, Dn to CP; VCC=4.5V; see Figure 10, 11 20 9 - ns PE to CP; VCC=4.5V; see Figure 10 20 11 - ns CEP, CET to CP; VCC=4.5V;see Figure 12 40 24 - ns 0 -5 - ns 26 45 - MHz - 50 - tsu — hold time th maximum frequency fmax power dissipation capacitanc e CPD — Dn, PE, CEP, CET, MR to CP; VCC=4.5V; see Figure 10, 11, 12 CP; see Figure 8 VCC=4.5V VCC=5.0V; CL=15pF - MHz 35 - pF Min. Typ. Max. Unit - - 230 ns - - 46 ns - - - - - - - - - - - - - - - - - - VCC=2.0V 100 VCC=4.5V 20 f i=1MHz; VCC=5.0V; VI=GND to VCC- 1.5V Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the sameastTHL and tTLH. [3] CPD isused to determine the dynamic power dissipation (PD in uW). PD=CPD ×VCC2 ×fi×N+Σ(CL×VCC2 ×fo) where: f i=input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; Σ(CL×VCC2 ×fo)=sum of outputs. AC Characteristics 2 (Tamb=-40℃ to +85℃, GND=0V, CL=50pF, unless otherwise specified.) Parameter Symbol Conditions SN74HC163 CP to Qn; see Figure 8 propagation delay tpd CP to TC; see Figure 8 CET to TC; see Figure 9 transition time pulse width tt tW see Figure 8 and Figure 9 CP HIGH or LOW; see Figure 8 R, Dn to CP; see Figure 10, 11 set-up time XBLWversion1.0 tsu PE to CP; www.xinboleic.com VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=6.0V 17 VCC=2.0V 100 VCC=4.5V 20 VCC=6.0V 17 VCC=2.0V 100 VCC=4.5V 20 Technical Support:4009682003 39 ns 270 ns 54 ns 46 ns 150 ns 30 ns 26 ns 95 ns 19 ns - 16 ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns - - ns 10 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS see Figure 10 CEP, CET to CP; see Figure 12 Dn, PE, CEP, CET hold time maximum frequency th MR to CP; see Figure 10, 11, 12 CP; see Figure 8 fmax VCC=6.0V 17 VCC=2.0V 220 VCC=4.5V 44 VCC=6.0V 37 VCC=2.0V 0 VCC=4.5V 0 VCC=6.0V 0 VCC=2.0V 4 VCC=4.5V 22 VCC=6.0V 26 SN74HCT163 propagation delay tpd - - ns - - ns - - ns - - ns - - ns - - ns - - - - ns MHz - - - - MHz MHz CP to Qn; see Figure 8 VCC=4.5V - - 49 ns CP to TC; see Figure 8 VCC=4.5V - - 61 ns CET to TC; see Figure 9 VCC=4.5V - - 44 ns transition time pulse width tt VCC=4.5V; see Figure 8, 9 25 19 ns CP HIGH or LOW; VCC=4.5V; see Figure 8 - tW - - ns set-up time tsu MR, Dn to CP; VCC=4.5V; see Figure 10, 11 25 - - ns PE to CP; VCC=4.5V; see Figure 10 25 - - ns CEP, CET to CP; VCC=4.5V;see Figure 12 50 - - ns 0 - - ns 21 - - MHz Min. Typ. Max. Unit - - 280 ns - - - - - - - - - - - - - - - - - - - - — hold time th maximum frequency fmax — Dn, PE, CEP, CET, MRto CP; VCC=4.5V; see Figure 10, 11, 12 CP; see Figure 8 VCC=4.5V Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the sameastTHL and tTLH. AC Characteristics 3 (Tamb=-40℃ to +125℃, GND=0V, CL=50pF, unless otherwise specified.) Parameter Symbol Conditions SN74HC163 CP to Qn; see Figure 8 propagation delay tpd CP to TC; see Figure 8 CET to TC; see Figure 9 transition time XBLWversion1.0 tt see Figure 8 www.xinboleic.com VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V Technical Support:4009682003 56 ns 48 ns 320 ns 65 ns 55 ns 180 ns 36 ns 31 ns 110 ns 22 ns 11 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS and Figure 9 pulse width tW CP HIGH or LOW; see Figure 8 R, Dn to CP; see Figure 10, 11 set-up time PE to CP; see Figure 10 tsu CEP, CET to CP; see Figure 12 maximum frequency th - - 19 ns VCC=2.0V 120 24 - - ns VCC=4.5V 20 - ns VCC=6.0V - - ns VCC=2.0V 120 - 24 - - ns VCC=4.5V 20 - ns VCC=6.0V - - ns VCC=2.0V 120 - ns VCC=4.5V 24 - 20 - - ns VCC=6.0V 265 - ns VCC=2.0V - - ns - - ns - - ns - - ns - - ns - - - - ns MHz - - - - MHz VCC=4.5V 53 VCC=6.0V 45 Dn, PE, CEP, CET VCC=2.0V 0 MR to CP; see Figure 10, 11, 12 VCC=4.5V 0 VCC=6.0V 0 VCC=2.0V 4 VCC=4.5V 18 VCC=6.0V 21 — hold time VCC=6.0V — CP; see Figure 8 fmax SN74HCT163 propagation transition time pulse width set-up time VCC=4.5V - - 59 ns CP to TC; see Figure 8 VCC=4.5V - - 74 ns CET to TC; see Figure 9 VCC=4.5V - - 48 ns CP to Qn; tpd delay MHz see Figure 8 tt VCC=4.5V; see Figure 8, 9 30 22 ns CP HIGH or LOW; VCC=4.5V; see Figure 8 - tW - - ns MR, Dn to CP; VCC=4.5V; see Figure 10, 11 30 - - ns PE to CP; VCC=4.5V; see Figure 10 30 - - ns CEP, CET to CP; VCC=4.5V;see Figure 12 60 - - ns 0 - - ns 17 - - MHz — tsu — hold time th maximum frequency fmax — Dn, PE, CEP, CET, MRto CP; VCC=4.5V; see Figure 10, 11, 12 CP; see Figure 8 VCC=4.5V Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the sameastTHL and tTLH. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 12 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS Testing Circuit AC Testing Circuit Figure 7. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. RL=Load resistance. S1=Test selection switch AC Testing Waveforms Figure 8. The clock (CP) to outputs (Qn, TC) propagation delays, pulse width, output transition times and maximum frequency XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 13 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS Figure 9. The count enable carry input (CET) to terminal count output (TC) propagation delays and output transition times — Figure 10. The data input (Dn) and parallel enable input (PE) set-up and hold times Measurement Points Input Type Output SN74HC163 VI VM VM GND to VCC 0.5×VCC 0.5×VCC SN74HCT163 GND to 3V 1.3V 1.3V Test Data Type Input Load S1 position VI CL RL tPHL, tPLH SN74HC163 t r ,t f VCC 6ns 15pF, 50pF 1kΩ open SN74HCT163 3V 6ns 15pF, 50pF 1kΩ open XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 14 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS Package Information DIP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 15 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS SOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 16 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS TSSOP16 XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 17 / 18 XBLW SN74HC/HCT163 4-BIT SYNCHRONOUS BINARY COUNTERS Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  This document is for referenceonly,and the actual use should be based on the application test results.  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 www.xinboleic.com Technical Support:4009682003 18 / 18
SN74HC163N 价格&库存
很抱歉,暂时无法提供与“SN74HC163N”相匹配的价格&库存,您可以联系我们找货
