SN74HC157N
SN74HC157N
    XBLW(芯伯乐)
    DIP16
    4路2输入多路复用器,工作电压2-6V,静态电流8uA
SN74HC157N 数据手册
XBLW SN74HC/HCT157 Quad 2-input Multiplexer General Description The SN74HC/HCT157 are quad 2-input multiplexers which select 4 bits of data from two sources under — — the control of a common data select input (S). The enable input (E) is active LOW. When E is HIGH, all of the outputs (1Y to 4Y) are forced LOW regardless of all other input conditions. Moving the data from two groups of registers to four common output buses is a common use of the SN74HC/HCT157. The state of the common data select input (S) determines the particular register from which the data comes. It can also be used as function generator. The device is useful for implementing highly irregular logic by generating any four of the 1 6 different functions of two variables with one variable common. The SN74HC/HCT157 is logic implementation of a 4-pole, 2-position switch, where the position of the switch is determined by the logic levels applied to S. The logic equations are: — — — — — — — — 1Y=E×(1I1×S+1I0×S) 2Y=E×(2I1×S+2I0×S) 3Y=E×(3I1×S+3I0×S) 4Y=E×(4I1×S+4I0×S) The SN74HC/HCT157 is identical to the SN74HC/HCT158 but has non-inverting (true) outputs. Features Input levels: For SN74HC157: CMOS level For SN74HCT157: TTL level Low-power dissipation Non-inverting data path Specified from -40C to +105C Packaging information: DIP16/SOP16/TSSOP16 Ordering Information DEVICE SN74HC157N SN74HC157DTR SN74HCT157DTR SN74HCT157TDTR XBLWversion1.0 Package Type DIP-16 SOP-16 SOP-16 TSSOP-16 MARKING Packing Packing QTY 74HC157N 74HC157 74HCT157 74HCT157 Tube Tape Tape Tape 1000/Box 2500/Reel 2500/Reel 3000/Reel 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 1 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 2 、Block Diagram And Pin Description 2.1 Block Diagram Figure 1. Logic symbol Figure 2. IEC logic symbol Figure 3. Functional diagram XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 2 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer Figure 4. Logic diagram 2.2 Pin Configurations 2.3 Pin Description Pin No. 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 XBLWversion1.0 Description common data select input data input from source 0 data input from source 1 multiplexer output data input from source 0 data input from source 1 multiplexer output ground (0V) multiplexer output data input from source 1 data input from source 0 multiplexer output data input from source 1 data input from source 0 enable input (active LOW) supply voltage Pin Name S 1I0 1I1 1Y 2I0 2I1 2Y GND 3Y 3I1 3I0 4Y 4I1 4I0 — E VCC 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 3 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 2.4 Function Table Input Output — S nI0 nI1 E H X X X L L L X L L H X L H X L L H X H Note: H=HIGH voltage level; L=LOW voltage level; X=don’t care. nY L L H L H 3 、Electrical Parameter 3.1 Absolute Maximum Ratings (Voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter supply voltage input clamping current output clamping current output current supply current ground current storage temperature total power dissipation Symbol VCC IIK IOK IO ICC IGND Tstg Ptot soldering temperature TL Conditions Min. -0.5 VI < -0.5V or VI > VCC+0.5V VO < -0.5V or VO > VCC+0.5V VO= -0.5V to (VCC+0.5V) 10s Max. +7.0 ±20 ±20 ±25 +50 -50 -65 - DIP SOP 245 250 +150 500 Unit V mA mA mA mA mA C mW C C Note: [1] For DIP16 packages: above 70C the value of Ptot derates linearly with 12mW/K. [2] For SOP16 packages: above 70C the value of Ptot derates linearly with 8mW/K. [3] For (T)SSOP16 packages: above 60C the value of Ptot derates linearly with 5.5mW/K 3.2 Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC VI VO input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage input transition rise and fall rate ambient temperature VCC VI VO - 4.5 0 0 5.0 Δt/ΔV VCC=4.5V Tamb - XBLWversion1.0 Conditions SN74HC157 VCC=2.0V VCC=4.5V VCC=6.0V SN74HCT157 Min. Typ. Max. Unit 2.0 0 0 5.0 6.0 VCC VCC 625 139 83 V V V 1.67 +105 ns/V ns/V ns/V C - 5.5 VCC VCC V V V - 1.67 139 ns/V -40 - +105 C -40 - 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 4 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 3.3 Electrical Characteristics 3.3.1 DC Characteristics 1 (Tamb=25C, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage LOW-level output voltage Conditions SN74HC157 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V VI=VIH or VIL IO=-20uA; VCC=6.0V IO=-4.0mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V IO=20uA; VCC=6.0V VI=VIH or VIL IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 0.5 1.35 1.8 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V II VI=VCC or GND; VCC=6.0V - - ±0.1 uA ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 8.0 uA CI - - 3.5 - pF V OH VOL input leakage current supply current input capacitance 1.9 4.4 5.9 3.98 5.48 SN74HCT157 3.2 Recommended Operating Conditions Parameter Symbol supply voltage input voltage output voltage VCC VI VO Conditions SN74HC157 VCC=2.0V VCC=4.5V VCC=6.0V Min. Typ. Max. Unit 2.0 0 0 5.0 6.0 VCC VCC 625 139 83 V V V 1.67 +105 ns/V ns/V ns/V C - 5.5 VCC VCC V V V - 1.67 139 ns/V -40 - +105 C -40 input transition rise and fall rate Δt/ΔV ambient temperature Tamb supply voltage input voltage output voltage input transition rise and fall rate ambient temperature VCC VI VO - 4.5 0 0 5.0 Δt/ΔV VCC=4.5V Tamb - XBLWversion1.0 SN74HCT157 - 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 5 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 3.3 Electrical Characteristics 3.3.1 DC Characteristics 1 (Tamb=25C, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter Symbol HIGH-level input voltage VIH LOW-level input voltage VIL HIGH-level output voltage LOW-level output voltage input leakage current supply current input capacitance Conditions SN74HC157 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V VI=VIH or VIL IO=-20uA; VCC=6.0V IO=-4.0mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V IO=20uA; VCC=6.0V VI=VIH or VIL IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 0.5 1.35 1.8 - 1.2 2.4 3.2 0.8 2.1 2.8 2.0 4.5 6.0 4.32 5.81 0 0 0 0.15 0.16 0.1 0.1 0.1 0.26 0.26 V V V V V V V V V V V V V V V V II VI=VCC or GND; VCC=6.0V - - ±0.1 uA ICC VI=VCC or GND; IO=0A; VCC=6.0V - - 8.0 uA CI - - 3.5 - pF V OH VOL 1.9 4.4 5.9 3.98 5.48 SN74HCT157 HIGH-level input voltage LOW-level input voltage VIH VCC=4.5V to 5.5V 2.0 1.6 - V VIL VCC=4.5V to 5.5V - 1.2 0.8 V 4.4 3.98 - 4.5 4.32 0 0.15 0.1 0.26 V V V V - - ±0.1 uA - - 8.0 uA - 100 360 uA - 60 216 uA - 100 360 uA - 3.5 - pF HIGH-level output voltage V OH VI=VIH or VIL; VCC=4.5V LOW-level output voltage input leakage current supply current VOL VI=VIH or VIL; VCC=4.5V additional supply current input capacitance XBLWversion1.0 II ICC ΔICC CI IO=-20uA IO=-4.0mA IO=20uA IO=4.0mA VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; nI0, nI1 inputs VI=VCC-2.1V; per input pin; other inputs at VCC — or GND; IO=0A; E input VCC=4.5V to 5.5V per input pin; S input - 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 6 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 3.3.2 DC Characteristics 2 (Tamb=-40C to +85C, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current supply current HIGH-level input voltage LOW-level input voltage Symbol Conditions SN74HC157 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V VI=VIH or VIL IO=-20uA; VCC=6.0V IO=-4.0mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V IO=20uA; VCC=6.0V VI=VIH or VIL IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 0.5 1.35 1.8 - - 0.1 0.1 0.1 0.33 0.33 V V V V V V V V V V V V V V V V II VI=VCC or GND; VCC=6.0V - - ±1.0 uA ICC VI=VCC or GND; IO=0A; VCC=6.0V SN74HCT157 - - 80 uA VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V 4.4 3.84 - - 0.1 0.33 V V V V - - ±1.0 uA - - 80 uA - - 450 uA - - 270 uA - - 450 uA VIH VIL V OH VOL HIGH-level output voltage V OH VI=VIH or VIL; VCC=4.5V LOW-level output voltage input leakage current supply current VOL VI=VIH or VIL; VCC=4.5V additional supply current XBLWversion1.0 II ICC ΔICC IO=-20uA IO=-4.0mA IO=20uA IO=4.0mA VI=VCC or GND; VCC=5.5V VI=VCC or GND; IO=0A; VCC=5.5V per input pin; nI0, nI1 inputs VI=VCC-2.1V; per input pin; other inputs at VCC — or GND; IO=0A; E input VCC=4.5V to 5.5V per input pin; S input 1.9 4.4 5.9 3.84 5.34 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 7 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 3.3.3 DC Characteristics 3 (Tamb=-40C to +105C, voltages are referenced to GND (ground=0V), unless otherwise specified.) Parameter HIGH-level input voltage LOW-level input voltage HIGH-level output voltage LOW-level output voltage input leakage current supply current HIGH-level input voltage LOW-level input voltage Symbol Conditions SN74HC157 VCC=2.0V VCC=4.5V VCC=6.0V VCC=2.0V VCC=4.5V VCC=6.0V IO=-20uA; VCC=2.0V IO=-20uA; VCC=4.5V VI=VIH or VIL IO=-20uA; VCC=6.0V IO=-4.0mA; VCC=4.5V IO=-5.2mA; VCC=6.0V IO=20uA; VCC=2.0V IO=20uA; VCC=4.5V IO=20uA; VCC=6.0V VI=VIH or VIL IO=4.0mA; VCC=4.5V IO=5.2mA; VCC=6.0V Min. Typ. Max. Unit 1.5 3.15 4.2 0.5 1.35 1.8 - - 0.1 0.1 0.1 0.4 0.4 V V V V V V V V V V V V V V V V II VI=VCC or GND; VCC=6.0V - - ±1.0 uA ICC VI=VCC or GND; IO=0A; VCC=6.0V SN74HCT157 - - 160 uA VIH VCC=4.5V to 5.5V 2.0 - - V VIL VCC=4.5V to 5.5V - - 0.8 V IO=-20uA IO=-4.0mA IO=20uA VI=VIH or VIL; VCC=4.5V IO=4.0mA VI=VCC or GND; VCC=5.5V 4.4 3.7 - - 0.1 0.4 ±1.0 V V V V uA VI=VCC or GND; IO=0A; VCC=5.5V per input pin; nI0, nI1 inputs VI=VCC-2.1V; per input pin; other inputs at VCC — or GND; IO=0A; E input VCC=4.5V to 5.5V per input pin; S input - - 160 uA - - 490 uA - - 294 uA - - 490 uA VIH VIL V OH VOL HIGH-level output voltage V OH LOW-level output voltage input leakage VOL current supply current additional supply current XBLWversion1.0 II ICC ΔICC VI=VIH or VIL; VCC=4.5V 1.9 4.4 5.9 3.7 5.2 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 8 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 3.3.4 AC Characteristics 1 (Tamb=25C, GND =0V, CL=50pF, unless otherwise specified.) Symbol Parameter propagation delay tpd Conditions SN74HC157 VCC=2.0V VCC=4.5V nI0, nI1 to nY; see Figure 6[1] VCC=5.0V; CL=15pF VCC=6.0V VCC=2.0V VCC=4.5V S to nY; see Figure 6[1] VCC=5.0V; CL=15pF VCC=6.0V VCC=2.0V — VCC=4.5V E to nY; [1] V =5.0V; CL=15pF see Figure 7 CC VCC=6.0V VCC=2.0V nY; VCC=4.5V see Figure 6[2] VCC=6.0V Min. Typ. Max. Unit - 36 13 11 10 41 15 12 12 39 14 11 11 19 7 6 125 25 20 75 15 13 ns ns ns ns ns ns ns ns ns ns ns ns ns ns ns 21 125 25 21 115 23 transition time tt power dissipation capacitance CPD CL=50pF; f=1MHz; VI=GND to VCC[3] - 70 - pF - 16 13 22 19 15 12 7 27 tpd SN74HCT157 VCC=4.5V nI0, nI1 to nY; see Figure 6[1] VCC=5.0V; CL=15pF VCC=4.5V S to nY; see Figure 6[1] VCC=5.0V; CL=15pF — VCC=4.5V E to nY; [1] VCC=5.0V; CL=15pF see Figure 7 nY; VCC=4.5V; see Figure 6[2] 15 ns ns ns ns ns ns ns - 70 - pF propagation delay tt transition time power CL=50pF; f=1MHz; VI=GND to VCC- 1.5V[3] CPD dissipation capacitance Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH . [3] CPD is used to determine the dynamic power dissipation (PD in uW). 2 37 26 2 PD=CPD ×VCC ×fi ×N+∑(CL ×VCC ×fo) where: fi= input frequency in MHz; fo=output frequency in MHz; CL=output load capacitance in pF; VCC=supply voltage in V; N=number of inputs switching; ∑(CL ×VCC2 ×fo)=sum ofoutputs. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 9 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 3.3.5 AC Characteristics 2 (Tamb=-40C to +85C, GND=0V, CL=50pF, unless otherwise specified.) Symbol Parameter propagation delay tpd transition time tt propagation delay tpd Conditions SN74HC157 VCC=2.0V nI0, nI1 to nY; VCC=4.5V [1] see Figure 6 VCC=6.0V VCC=2.0V S to nY; VCC=4.5V see Figure 6[1] VCC=6.0V VCC=2.0V — E to nY; VCC=4.5V see Figure 7[1] VCC=6.0V VCC=2.0V nY; VCC=4.5V see Figure 6[2] VCC=6.0V SN74HCT157 nI0, nI1 to nY; VCC=4.5V see Figure 6[1] S to nY; VCC=4.5V see Figure 6[1] Min. Typ. Max. Unit - - 155 31 26 155 31 26 145 29 25 95 19 16 ns ns ns ns ns ns ns ns ns ns ns ns - - 34 ns - - 46 ns - - 33 ns - - 19 ns — E to nY; VCC=4.5V see Figure 7[1] nY; VCC=4.5V; see Figure 6[2] tt transition time Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 10 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 3.3.6 AC Characteristics 3 (Tamb=-40C to +105C, GND=0V, CL=50pF, unless otherwise specified.) Symbol Parameter propagation delay tpd transition time tt propagation delay tpd Conditions SN74HC157 VCC=2.0V nI0, nI1 to nY; VCC=4.5V see Figure 6[1] VCC=6.0V VCC=2.0V S to nY; VCC=4.5V see Figure 6[1] VCC=6.0V VCC=2.0V — E to nY; VCC=4.5V see Figure 7[1] VCC=6.0V VCC=2.0V nY; VCC=4.5V see Figure 6[2] VCC=6.0V SN74HCT157 nI0, nI1 to nY; VCC=4.5V see Figure 6[1] S to nY; VCC=4.5V see Figure 6[1] Min. Typ. Max. Unit - - 190 38 32 190 38 32 175 35 30 110 22 19 ns ns ns ns ns ns ns ns ns ns ns ns - - 41 ns - - 56 ns - - 39 ns - - 22 ns — E to nY; VCC=4.5V see Figure 7[1] nY; VCC=4.5V; see Figure 6[2] tt transition time Note: [1] tpd is the same as tPLH and tPHL. [2] tt is the same as tTHL and tTLH . XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 11 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 4 、Testing Circuit 4.1 AC Testing Circuit Figure 5. Test circuit for measuring switching times Definitions for test circuit: CL=Load capacitance including jig and probe capacitance. RT=Termination resistance should be equal to the output impedance Zo of the pulse generator. 4.2 AC Testing Waveforms Figure 6. Propagation delay input (nI0, nI1, S) to output (nYn — Figure 7. Propagation delay input (E) to output (nY) XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 12 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 5 、Package Information 5.1 DIP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 13 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 5.2、SOP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 14 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer 5.3,TSSOP16 XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 15 页 共 16 页 XBLW SN74HC/HCT157 Quad 2-input Multiplexer Statement:  Shenzhen xinbole electronics co., ltd. reserves the right to change the product specifications, without notice! Before placing an order, the customer needs to confirm whether the information obtained is the latest version, and verify the integrity of the relevant information.  Any semiconductor product is liable to fail or malfunction under certain conditions, and the buyer shall be responsible for complying with safety standards in the system design and whole machine manufacturing using Shenzhen xinbole electronics co., ltd products, and take appropriate security measures to avoid the potential risk of failure may result in personal injury or property losses of the situation occurred!  Product performance is never ending, Shenzhen xinbole electronics co., ltd will be dedicated to provide customers with better performance, better quality of integrated circuit products. XBLWversion1.0 文档仅供参考,实际应用测试为准 www.xinboleic.com 技术支持热线:4009682003 第 16 页 共 16 页
SN74HC157N 价格&库存
很抱歉,暂时无法提供与“SN74HC157N”相匹配的价格&库存,您可以联系我们找货
