1SA5624V12A0CAJ1
1SA5624V12A0CAJ1
    XMBRIGHTEK(弘硕光电)
    发光二极管/LED
1SA5624V12A0CAJ1 数据手册
承 认 书 SPECIFICATION FOR APPROVAL 客 戶 Customer 客 戶 料 号 Customer Part No. 弘 硕 型 号 XMBrightek Part No. 規 格 小蝴蝶红光 Specification 制 表 人 MARK 2017.07.01 Prepared By 审 1SA5624V12A0CAJ1 核 Checkedy 客 戶 回 签 Customer Comfirmation 说明:一.仅致执事者:兹提供我公司产品之有关详细规格及图面资料,敬请给 预办理测试认定手续.同时敬请送返一份附有贵公司签认之测试认定后之样 品认定书. We are sending you our specification and drawings for your approval.Please return to us one copy“For Approval”with your approved signatures. 二、客户意见栏 Customer’S Proposal □ Approve □ Disagree Reason 承认 (请于认可栏中签名) 不同意 原因:     COMMODITY: SURFACE MOUNT LED SMD SPECIFICATION Part No: Characters ITEM MATERIALS Lens Color Water Transparent Dice AlGaInP Emitted Color RED § 2.4mm×2.15mm SMT LED ,2.8mm THICKNESS § LOW POWER CONSUMPTION. § VIEWING ANGLE 20°. § VARIOUS COLORS AND LENS TYPES AVAILABLE. § PACKAGE:800 PCS/REEL. Absolute Maximum Ratings(Ta=25℃) Item Symbol Value Unit Power Dissipation PD 60 mW DC Forward Current IF 30 mA Pulsed Forward Current IFP Reverse Voltage VR 5 V Operating Temperature Topr -30~ +80° ℃ Storage Temperature Tstg -40 ~ +85° ℃ Soldering Temperature Tsol 250for5sec△ ℃ 100 mA Electrical-Optical Characteristics(Ta=25℃) Value Parameter Symbol Min. Typ. Max. Unit Test condition Forward Voltage Vf 1.7 ﹍ 2.5 V If=20mA Luminous intensity Iv 1000 2000 ﹍ mcd If=20mA Wavelength λd 615 ﹍ 630 nm If=20mA Reverse Current Ir ﹍ ﹍ 10 μA Vr=5V 2θ1/2 ﹍ 20 ﹍ Deg If=20mA Viewing angle ※Specifications are subject to change without notice. 第 2 頁 Outline Dimensions  此规格因有加滚镀制程,底部的 MARK 标示可能会消失;不影响贵司使用.  All dimensions are in millimeters(inches).  Tolerance is ±0.15 ㎜ unless otherwise noted.  Specifications are subject to change without notice. 第 3 頁 COMMODITY: SURFACE MOUNT LED LAMP SPECIFICATION Typical Characteristic The data typical , and the value is not guaranteed. Fig.1 IF-VF(Ta=25℃) Intensity (Ta=25℃) Relative Luminous Forward Current IF(mA) Fig.2 Relative Luminous Intensity-IF Forward Voltage VF(V) Forward Current IF(mA) Fig.3 Wavelength Characteristics Fig.4 Relative Luminous Intensity-Ta Ambient Temperature Ta (℃) Wavelength λ (nm) Forward Current IF(mA) Intensity Relative Luminous Intensity Relative Luminous (Ta=25℃) Directive Characteristics Fig.5 IF-Ta Ambient Temperature Ta (℃) 第 4 頁 Reflow Profile  Reflow Temp/Time NOTES: 1. We recommend the reflow temperature 245℃(± 5℃).the maximum soldering temperature should be limited to 260℃. 2. Don’t cause stress to the epoxy/silicone resin while it is exposed to high temperature. 3. Number of reflow process shall be 2 times or less. Soldering iron Basic spec is  5sec when 260℃. If temperature is higher, time should be shorter (+10℃ -1sec ).Power dissipation of iron should be smaller than 15W, and temperatures should be controllable .Surface temperature of the device should be under 230℃ . 第 5 頁 Test circuit and handling precautions  Test circuit  Handling precautions 1. Over-current-proof Customer must apply resistors for protection; otherwise slight voltage shift will cause big current change (Burn out will happen). 2.Storage 2.1 It is recommended to store the products in the following conditions: Humidity: 60% R.H. Max. Temperature : 5℃~30℃(41℉~86℉) 2.2 Shelf life in sealed bag: 12 month at <5℃~30℃ and <30% R.H. after the package is Opened, the products should be used within a week or they should be keeping to stored at ≦20 R.H. with zip-lock sealed. 3.Baking It is recommended to baking before soldering when the pack is unsealed after 72hrs. The Conditions are as followings: 3.1 60±3℃ x(12~24hrs) and <5%RH, taped reel type 3.2 100±3℃ x(45min~1hr), bulk type 3.3 130±3℃ x(15~30min), bulk type 第 6 頁 Test items and results of reliability Type Test Item Test Conditions Note Number of Damaged -45℃ 30min Temperature Cycle ↑↓20 min 100 cycle 0/22 100 cycle 0/22 10 cycle 0/22 1000 hrs 0/22 1000 hrs 0/22 1000 hrs 0/22 1000 hrs 0/22 500 hrs 0/22 1000 hrs 0/22 105℃ 30min -10℃ 15min Environmental Sequence Thermal Shock ↑↓5min 100℃ 15min High Humidity Heat Cycle 30℃ 65℃ 90%RH 24hrs/1cycle High Temperature Storage Humidity Heat Storage Ta=100℃ Ta=85℃ RH=85% Low Temperature Storage Life Test Ta=-40℃ Ta=25℃ Operation Sequence IF=20mA High Humidity Heat Life Test 85℃ RH=85% IF=10mA Low Temperature Life Test Ta=-20℃ IF=20mA 第 7 頁 Single-Color High Performance SMD Top LEDs Packaging Specifications  Dimensions of Reel (Unit: mm)  Dimensions of Tape (Unit: mm)  Moisture Resistant Packaging 第 8 頁 NOTES 1. Empty component pockets are sealed with top cover tape; 2. The maximum number of missing lamps is two; 3. The cathode is oriented towards the tape sprocket hole in accordance with ANSI/EIA RS-481 specifications; 4. 4,000pcs/Reel NOTES: Reeled products (the most numbers of products are 2,000pcs) packed in a seal off moisture-proof bag along with a desiccant one by one, Seven moisture-proof bag of maximums (total maximum number of products are 14,000pcs) packed in an inside box (size: about 238mm x about 194mm x about 102mm) and four inside boxes of maximums are put in the outside box (size: about 410mm x about 254mm x about 229mm) Together with buffer material, and it is packed. (Part No., Lot No., quantity should appear on the label on the moisture-proof bag, part No. And quantity should appear on the insertion request form on the cardboard box.) . LED Usage and Handling Instructions No.1、A、Manual soldering: 1、Soldering iron & tin wire A soldering iron of 25-30W is recommended; the diameter of tin wire should be less than 0.5mm. 2、Temperature adjustment To adjust the temperature from 280 to 350℃ according to different PCB board 3、Soldering time Please control the soldering time within 3-5 seconds. Do not apply any pressure to the epoxy encapsulation as well as the leads during the soldering process. 4、Soldering parameters according to different specifications Parameters SIDE VIEW TOP3020 Soldering iron 25-30W 25-30W Temperature 280-300℃ 300-320℃ Soldering time
1SA5624V12A0CAJ1 价格&库存
很抱歉,暂时无法提供与“1SA5624V12A0CAJ1”相匹配的价格&库存,您可以联系我们找货
