H
PCB Mount Orientation
Designed to comply with
physical, electrical and
environmental requirements
of Micro USB Standard (USB2.0).
10.00
2.60
9.23
0.65
7.40
0.90
1.60
Specifications
0.40
5
1
Material
Housing: LCP, UL94V-0, Black (E106764)
Terminal: Copper Alloy
Shell: Stainless Steel, SUS304, T = 0.25mm
1.35
G
2.00
0.50
PCB Edge
E
Plating
Terminal:
Contact Area: 30µ" Gold plating
Solder Tails: Gold Flash
Underplating: 50µ" Nickel
Shell: Matte Tin
1.88
1.45
2.15
1.90
F
1.40
3.90
5.60
6.80
7.80
Electrical
Voltage Rating: 30 V AC
Current Rating: Signal (Pins 2,3,4):1.0A.
Power (Pins1,5):1.8A.
Operating Temperature: -30°C to +85°C
Contact Resistance: 30mΩ max.
Insulating Resistance: 1000MΩ min.
Dielectric Withstand Voltage: 500V AC/Minute
Recommended PCB Layout
5.40±0.05
As viewed from component side
General Tolerance: ±0.05
A
Mechanical & Environmental
Mating Force: 35N max.
Unmating Force: 10N min.
Durability: 10,000 Cycles
2.85
0.24
6.20
2.47
1
5
C
5.00±0.30
2.77
0.85
A
Component Outline
6.90+0.05
-0.02
3.50
4.75
0.60
2.70
Ordering Grid
0.05±0.05
D
Solder Area
1.85+0.08
-0.02
5.00
3.5 Max.
0.50
B
30
USB3100
Request Samples
and Quotation
Packing Options
A = Tape & Reel
Contact Plating
30 = 30µ" Gold
0.10
A
0.24
(1.5K per Reel)
A
Section A-A
Part Number
Product Description
USB3100
Micro USB Receptacle, Type B, Surface Mount,
Horizontal, Top (Reverse) Mount, without Peg
Drawing Date
1st June 2012
0.28
0.65
By
Detail
2.60
1
2
3
4
Revision
Date
5
CC
Tolerances (Except as Noted)
USB3100
C PCN
C
22/08/23
X.X° ± 2°
X.X ± 0.2
X.XX° ± 1°
X.XX ± 0.10
X.XXX ± 0.05 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
3rd Angle Projection
7
This drawing is confidential and
copyright of Global Connector
Technology, Ltd (GCT).
This drawing must not be copied
or disclosed without written
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
1/2
4.0
Start of reel approximately
20 pcs empty carrier
5
1.
Ø
12.0
200mm min.
24.00
G
End of reel approximately
1.8
H
Cover Tape
I/O Direction
USB3100
12
0°
ø330
Products P/N
Ø1
3.
5
10°
Cover Tape
3
Ø2
Peel off Angle
F
Carrier Tape
1500
3
4500
Notes:
1. Peeling off force of top tape: 0.1-1.3N
2. Part Conforms to EIA-481-C Standards
3. All dimensions in millimeters
4. 10 sprocket hole pitch cumulative tolerance±0.2mm
120°
E
PCS/Reel Reels/Carton PCS/Carton
Detail F
6
P S
Detail F
Cardboard
Reel
D
Carton
Triangle Liner
Protection Tape
Vacuum Bag
490X490X0.15
Label
160mm
C
1500 pieces/reel
35
B
0m
m
35
0m
m
3 Reels
Part Number
Product Description
USB3100
Drawing Date
A
1st June 2012
By
Detail
1
2
3
4
Revision
Date
5
CC
USB3100
C PCN
C
22/08/23
X.X° ± 2°
X.X ± 0.5
X.XX° ± 1°
X.XX ± 0.30
X.XXX ± 0.20 X.XXX° ± 0.5°
Length
Angle
6
Units:
Metric (mm)
C
7
consent. E & OE
www.gct.co
Not to
Scale
Drawn By
ASE
8
Sheet No.
2/2
很抱歉,暂时无法提供与“USB3100-30-A”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+5.963961+0.72350
- 10+5.2285810+0.63429
- 25+4.7819625+0.58011
- 50+4.4992150+0.54581
- 100+4.31189100+0.52309
- 250+3.93692250+0.47760
- 500+3.74958500+0.45487
- 国内价格 香港价格
- 1500+2.475081500+0.30026
- 3000+2.463523000+0.29886
- 4500+2.463464500+0.29885
- 6000+2.463416000+0.29884
- 7500+2.463357500+0.29884
