AR1521P1
1-Line Ultra Low Capacitance Bi-directional TVS Diode
Description
Mechanical Characteristics
The AR1521P1 is a bi-directional TVS diode, utilizing
leading monolithic silicon technology to provide fast response time and low ESD clamping voltage, making this
device an ideal solution for protecting voltage sensitive
high-speed data lines. The AR1521P1 has an ultra-low
capacitance with a typical value at 0.3pF, and complies
with the IEC 61000-4-2 (ESD) with ±20kV air and ±15kV
contact discharge. It is assembled into an ultra-small
1.0x0.6x0.5mm lead-free DFN package. The small size,
ultra-low capacitance and high ESD surge protection
make AR1521P1 an ideal choice to protect cell phone
and high-power USB.
Package: DFN1006-2 (1.0×0.6×0.5mm)
Case Material: “Green” Molding Compound.
Moisture Sensitivity: Level 3 per J-STD-020
Terminal Connections: See Diagram Below
Marking Information: See Below
Applications
Cellular Handsets and Accessories
Serial ATA
MDDI Ports
USB Ports
PCI Express and Serial SATA Ports
Features
Ultra small package: 1.0x0.6x0.5mm
Ultra low capacitance: 0.3pF typical
Ultra low leakage: nA level
Operating voltage: 15V
Low clamping voltage
2-pin leadless package
Complies with following standards:
– IEC 61000-4-2 (ESD) immunity test
Air discharge: ±20kV
Contact discharge: ±15kV
– IEC61000-4-5 (Lightning) 2.5A (8/20μs)
RoHS Compliant
Marking Information
R15
Ordering Information
Dimensions and Pin Configuration
Part Number
Packaging
Reel Size
AR1521P1
10000/Tape & Reel
7 inch
1.0
1
0.6
0.5
Package Dimensions
All d ata sheet.com
Revision 12/2017
2
Circuit and Pin Schematic
1 of 4
www.appliedpowermicro.com
AR1521P1
Absolute Maximum Ratings (TA=25°C unless otherwise specified)
Parameter
Symbol
Value
Unit
Peak Pulse Power (8/20µs)
Ppk
90
W
Peak Pulse Current (8/20µs)
IPP
2.5
A
ESD per IEC 61000−4−2 (Air)
±20
VESD
ESD per IEC 61000−4−2 (Contact)
Operating Temperature Range
Storage Temperature Range
kV
±15
TJ
−55 to +125
°C
Tstg
−55 to +150
°C
Electrical Characteristics (TA=25°C unless otherwise specified)
Parameter
Reverse Working Voltage
Breakdown Voltage
Min
Typ
VRWM
VBR
Max
Unit
15
V
16.7
Test Condition
V
IT = 1mA
Reverse Leakage Current
IR
0.2
μA
VRWM = 15V
Clamping Voltage
VC
26
V
IPP = 1A (8 x 20µs pulse)
Clamping Voltage
VC
35
V
IPP = 2.5A (8 x 20µs pulse)
Junction Capacitance
CJ
0.5
pF
VR = 0V, f = 1MHz
Revision 12/2017
All d ata sheet.com
Symbol
0.3
2 of 4
AR1521P1
Typical Performance Characteristics (TA=25°C unless otherwise Specified)
Junction Capacitance vs. Reverse Voltage
Clamping Voltage vs. Peak Pulse Current
Peak Pulse Power vs. Pulse Time
Power Derating Curve
Note:Data is taken with a 10x attenuator
ESD Clamping Voltage
8 X 20μs Pulse Waveform
All d ata sheet.com
Revision 12/2017
8 kV Contact per IEC61000−4−2
3 of 4
AR1521P1
DFN1006-2 Package Outline Drawing
A
DIMENSIONS
MILLIMETERS
INCHES
MIN
NOM
MAX
MIN
NOM
MAX
0.45
0.50
0.55
0.018
0.020
0.022
A1
0.00
0.02
0.05
0.000
0.001
0.002
b
0.45
0.50
0.55
0.018
0.020
0.022
c
0.12
0.15
0.18
0.005
0.006
0.007
D
0.95
1.00
1.05
0.037
0.039
0.041
SYM
e
0.65 BSC
0.026 BSC
E
0.55
0.60
0.65
0.022
0.024
0.026
L
0.20
0.25
0.30
0.008
0.010
0.012
L1
0.05REF
h
0.07
0.12
0.002REF
0.17
0.003
0.005
0.007
Suggested Land Pattern
SYM
Y3
MILLIMETERS
INCHES
X
0.60
0.024
Y1
0.50
0.020
Y2
0.30
0.012
Y3
0.80
0.032
Z
1.30
0.052
Y1
Y2
Z
DIMENSIONS
X
Contact Information
Applied Power Microelectronics Co., Ltd.
Website: http://www.appliedpowermicro.com
Email: sales@appliedpowermicro.com
Phone: +86 (0519) 8399 3606
Applied Power Microelectronics Co., Ltd. (APM) reserves the right to make changes to the product specification and data in this document without notice. APM makes no warranty, representation or
guarantee regarding the suitability of its products for any particular purpose, nor does APM assume any liability arising from the application or use of any products or circuits, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages.
All d ata sheet.com
Revision 12/2017
4 of 4
很抱歉,暂时无法提供与“AR1521P1”相匹配的价格&库存,您可以联系我们找货
