Form No: T00271-7-0000-PBM02-220300574
Specification for Approval
Date: 2022/03/15
Customer :
TMPV0754SV-Series(N)-D
TAI-TECH P/N:
CUSTOMER P/N:
DESCRIPTION:
pcs
QUANTITY:
REMARK:
Customer Approval Feedback
西北臺慶科技股份有限公司
TAI-TECH Advanced Electronics Co., Ltd
Headquarter:
NO.1 YOU 4TH ROAD, YOUTH INDUSTRIAL DISTRICT, YANG-MEI,
TAO-YUAN HSIEN, TAIWAN, R.O.C.
TEL: +886-3-4641148
FAX: +886-3-4643565
http://www.tai-tech.com.tw
E-mail: sales@tai-tech.com.tw
臺慶精密電子(昆山)有限公司
TAI-TECH ADVANCED ELECTRONICS(KUNSHAN) CO., LTD
SHINWHA ROAD, KUNJIA HI-TECH INDUSTRIAL PARK, KUN-SHAN,
JIANG-SU, CHINA
TEL: +86-512-57619396 FAX: +86-512-57619688
E-mail: sales@tai-tech.cn
■ 慶邦電子元器件(泗洪)有限公司
TAIPAQ ELECTRONICS (SIHONG) CO., LTD
JIN SHA JIANG ROAD , CONOMIC DEVELOPMENT ZONE SIHONG ,
JIANGSU , CHINA.
TEL: +86-527-88601191 FAX: +86-527-88601190
E-mail: sales@taipaq.cn
Sales Dep.
APPROVED
CHECKED
Eric Kuan
Zhang
mengmeng
R&D Center
APPROVED
CHECKED
DRAWN
Sky Luo
Mr.Liang
Cui lingling
Downloaded From Oneyac.com
TAI-TECH
P1
SMD Power Inductor
ECN HISTORY LIST
REV
DATE
DESCRIPTION
APPROVED
CHECKED
DRAWN
1.0
22/03/15
New lssue
Sky Luo
Mr.Liang
Cui lingling
備
注
TAI-TECH
P2
SMD Power Inductor
TMPV0754 产品与PC
1. Features
PCB尺
产品尺寸
1. Low loss realized with low DCR.
7.9
3. Ultra low buzz noise, due to composite construction.
Halogen
4. 100% Lead(Pb)-Free and RoHS compliant.
5. High reliability -Reliability test complied to AEC-Q200.
Automotive applications.
3
7.3
Halogen-free
2. Applications
9
3
7.3
5.4
2. High performance realized by metal dust core.
2
3. Dimensions
Recommend PC Board Pattern
H
L
1R5
2212
Series
G
A(mm) A1(mm) B(mm)
TMPV0754SV 7.9±0.3
7.3±0.2
7.3±0.2
C(mm)
D(mm) D1(mm)
E(mm)
E1(mm)
5.2±0.2
1.7±0.3
3.0±0.2
5.4±0.2
1R5
M
N
D
E
F
2.0±0.3
4. Part Numbering
TMPV
0754
SV
A
B
C
A: Series
B: Dimension
C: Type
D: Inductance
E: Inductance Tolerance
F、G: Code
L(mm)
D
G
BxC
Standard.
1R5=1.50uH
K=±10%,L=±15%,M=±20%,N=±25%,Y=±30%
Marking direction cannot decide polarity.
Marking: Black.1R5 and 2212 (22:YY,12:WW, follow production date).
G(mm)
H(mm)
9.0
3.0
3.5
Note: 1.PCB layout is referred to standard IPC-7351B
2. The above PCB layout reference only.
3. Recommend solder paste thickness at
0.15mm and above.
TAI-TECH
P3
5. Specification
Heat Rating
Current DC
Irms( A )
Saturation
Current DC
I sat ( A )
Part Number
Inductance
L0 A(uH)
±20%
DCR
(mΩ)
Typ
DCR
(mΩ)
Max
Typ
Max
Typ
Max
TMPV0754SV-1R0MN-D
1.00
20.0
17.0
23.0
20.0
5.0
6.0
TMPV0754SV-1R5MN-D
1.50
17.0
15.0
TMPV0754SV-2R2MN-D
2.20
14.5
13.0
19.0
17.0
6.3
7.3
16.5
14.5
9.7
11.2
TMPV0754SV-3R3MN-D
3.30
11.5
TMPV0754SV-4R7MN-D
4.70
10.5
10.5
14.0
12.3
13.0
15.0
9.0
13.3
11.3
17.8
20.5
TMPV0754SV-5R6MN-D
5.60
9.3
8.5
11.0
9.5
19.2
22.1
TMPV0754SV-6R8MN-D
6.80
8.7
8.0
10.2
9.0
23.0
26.5
TMPV0754SV-8R2MN-D
8.20
8.0
7.5
9.2
8.1
27.3
31.4
TMPV0754SV-100MN-D
10.0
7.2
6.7
8.0
7.0
33.0
38.0
TMPV0754SV-120MN-D
12.0
6.3
5.8
7.7
6.7
43.0
52.0
TMPV0754SV-150MN-D
15.0
5.5
5.0
7.2
6.2
60.0
66.0
TMPV0754SV-220MN-D
22.0
5.0
4.5
6.3
5.4
85.0
93.5
TMPV0754SV-330MN-D
33.0
4.0
3.5
4.9
4.2
111.0
127.6
TMPV0754SV-470MN-D
47.0
3.2
2.7
4.1
3.5
156.0
171.6
TMPV0754SV-560MN-D
56.0
3.0
2.6
3.4
2.9
188.0
206.8
TMPV0754SV-680MN-D
68.0
2.7
2.4
3.0
2.6
218.0
251.0
TMPV0754SV-101MN-D
100.0
2.2
2.0
2.0
1.6
310.0
357.0
Note:
1. Test frequency : Ls : 100KHz /1.0V.
2. All test data referenced to 25℃ ambient.
3. Testing Instrument(or equ) : Agilent 4284A,E4991A,4339B,KEYSIGHT E4980A/AL,chroma3302,3250,16502.
4. Heat Rated Current (Irms) will cause the coil temperature rise approximately ΔT of 40℃
5. Saturation Current (Isat) will cause L0 to drop approximately 30%.
6. The part temperature (ambient + temp rise) should not exceed 165℃under worst case operating conditions.Circuit design,component,PCB trace size and
thickness,airflow and other cooling provisions all affect the part temperature. Part temperature should be verified in the end application.
7. Irms Testing : Temperature rise is highly dependent on many factors including pcb land pattern, trace size, and proximity to other components.
Therefore temperature rise should be verified in application conditions.
8. Rated DC current: The lower value of Irms and Isat.
TAI-TECH
P4
6. Material List
4
NO
Items
1
Core
Alloy Powder .
2
Wire
Polyester Wire or equivalent.
3
Clip
100% Pb free solder(Ni+Sn---Plating)
4
Ink
Halogen-free ketone
3
1
Materials
2
7. Packaging Information
(1) Reel Dimension
COVER TAPE
Type
A(mm)
B(mm)
C(mm)
D(mm)
13”x16mm
16.4+2/-0
100±2
13+0.5/-0.2
330
C
B
D
2.0∮0.5
A
EMBOSSED CARRIER
(2) Tape Dimension
4.0
Blank portions
Chip cavity
Blank portions
T
B0
W
F
D
K0
P
200mm or more
400mm or more
Direction of tape
Series
Bo(mm) Ao(mm) Ko(mm) P(mm)
TMPV0754
9.0±0.1
7.7±0.1
5.7±0.1
12.0±0.1
A0
W(mm)
F(mm)
T(mm)
D(mm)
16±0.3
7.5±0.1
0.40±0.05
1.5±0.1
(3) Packaging Quantity
Series
Reel
TMPV0754
800
(4) Tearing Off Force
F
Top cover tape
The force for tearing off cover tape is 10 to 130 grams in the arrow
direction under the following conditions(referenced
ANSI/EIA-481-D-2008 standard).
165° to180°
Base tape
Tearing Speed
mm
Room Temp.
Room Humidity
Room atm
(hPa)
300±10%
5~35
45~85
860~1060
TAI-TECH
P5
8. Reliability and Test Condition
Item
Performance
Test Condition
Operating temperature
-55~+165℃(Including self - temperature rise)
N/A
Storage temperature and
Humidity range
1. Less than40℃,85%RH (Product with taping)
2. -55~+165℃(on board)
N/A
Electrical Performance Test
Inductance
Agilent 4284A,E4991A,KEYSIGHT E4980A/AL,chroma 3302,3205
Refer to standard electrical characteristics list.
DCR
Agilent 4339B,chrom16502
Approximately △L30%
Saturation DC Current (Isat) will cause L0
to drop △L(%)
Approximately △T40℃
Heat Rated Current (Irms) will cause the coil temperature rise △
T(℃).
1.Applied the allowed DC current
2.Temperature measured by digital surface thermometer
Reliability Test
High Temperature
Exposure(Storage)
AEC-Q200
Temperature Cycling
AEC-Q200
Biased Humidity
(AEC-Q200)
Appearance:No damage.
Inductance:within±10% of initial value
Q:Shall not exceed the specification value.
RDC:within ±15% of initial value and shall not exceed
Preconditioning: Run through IR reflow for 3 times.
( IPC/JEDECJ-STD-020E Classification Reflow Profiles
Temperature:165±2℃(Inductor)
Duration :1000hrs Min. With 100% rated current.
Measured at room temperature after placing for24±2hrs
High Temperature
Operational Life
(AEC-Q200)
External Visual
Physical Dimension
Resistance to Solvents
Preconditioning: Run through IR reflow for 3 times.( IPC/JEDEC
Measured at room temperature after placing for 24±2 hrs
Condition for 1 cycle
Step1:-55±2℃ 30min Min.(Inductor)
Step2:165±2℃ transition time 1min MAX.
Step3:165±2℃ 30min Min.
Step4:Low temp. transition time 1min MAX.
Number of cycles: 1000
( IPC/JEDEC J-STD-020E Classification Reflow Profiles)
Humidity :85±3﹪R.H,
Temperature:85℃±2℃
Duration : 1000hrs Min
Inspect device construction, marking and workmanship. Electrical
Test not required.
According to the product specification size measurement
Add aqueous wash chemical - OKEM clean or equivalent.
Test condition
Mechanical Shock
Type
Peak value
Normal
(g’s)
duration (D) (ms)
Wave
form
Velocity
change (Vi)ft/sec
SMD
100
6
Half-sine
12.3
Lead
100
6
Half-sine
12.3
3 shocks in each direction along 3 perpendicular axes(18
shocks).
TAI-TECH
P6
Item
Performance
Vibration
Resistance to Soldering Heat
(AEC-Q200)
ESD
Temperature(℃)
Time(s)
260±5
(solder temp)
Temperature
ramp/immersion
and emersion rate
10±5
25mm/s±6 mm/s
Depth: completely cover the termination
Step1:-55±2℃ 15±1min(Inductor)
Step2:165±2℃ within 20Sec.
Step3:165±2℃ 15±1min
Number of cycles: 300
Measured at room fempraturc after placing fo24±2hrs
Thermal shock
HBM>=2KV
Test Condition
Oscillation Frequency: 10Hz~2KHz~10Hz for 20 minute
Equipment: Vibration checker
Total Amplitude: 5g
Testing Time : 12 hours(20 minutes, 12 cycles each of 3
orientations)。
Test condition:(MIL-STD-202 Condition B)
Number of heat cycles:1
Direct Contact and Air Discharge PASSIVE COMPONENT HBM ESD
Discharge Waveform to a Coaxial Target
Test method: AEC-Q200-002
Test mode:Contact Discharge
Discharge level:4 KV (Level: 2 )
Solderability
Electrical Characterization
Flammability
More than 95% of the terminal electrode should be covered
with solder。
a. Method B1, 4 hrs @155°C dry heat @255°C±5°C
Test time:5 +0/-0.5 seconds.
b. Method D category 3. (steam aging 8hours ± 15 min)@ 260°C±5°C
Test time: 30 +0/-0.5 seconds.
Refer Specification for Approval
Summary to show Min, Max, Mean and Standard deviation .
Electrical Test not required.
V-0 or V-1 are acceptable.
Place the 100mm X 40mm board into a fixture similar to the one
shown in below Figure with the component facing down. The
apparatus shall consist of mechanical means to apply a force which
will bend the board (D) x = 2 mm minimum. The duration of the
applied forces shall be 60 (+ 5) sec. The force is to be applied only
once to the board.
Board Flex
With the component mounted on a PCB with the device to be tested,
apply a 17.7 N (1.8 Kg) force to the side of a device being tested. This
force shall be applied for 60 +1 seconds. Also the force shall be
applied gradually as not to apply a shock to the component being
tested.
Terminal Strength(SMD)
Note : When there are questions concerning measurement result : measurement shall be made after 48 ± 2 hours of recovery under the standard
condition.
TAI-TECH
P7
9. Soldering Specifications
(1) Soldering
Mildly activated rosin fluxes are preferred. TAI-TECH terminations are suitable for re-flow soldering systems. If hand
soldering cannot be avoided, the preferred technique is the utilization of hot air soldering tools.
(2) IR Soldering Reflow:
Recommended temperature profiles for lead free re-flow soldering in Figure 1. Table 1.1&1.2 (J-STD-020E)
(3) Iron Reflow:
Products attachment with a soldering iron is discouraged due to the inherent process control limitations. In the event that
a soldering iron must be employed the following precautions are recommended.(Fig. 2)
‧Preheat circuit and products to 150℃
‧Never contact the ceramic with the iron tip
‧Use a 20 watt soldering iron with tip diameter of 1.0mm
‧355℃ tip temperature (max)
‧1.0mm tip diameter (max)
‧Limit soldering time to 4~5sec.
Fig.1 IR Soldering Reflow
Fig.2 Iron soldering temperature profiles
Soldering iron Method : 350± 5℃ max
Reflow times: 3 times max
Table (1.1): Reflow Profiles
Profile Type:
Pb-Free Assembly
Preheat
-Temperature Min(Tsmin)
-Temperature Max(Tsmax)
-Time(ts)from(Tsmin to Tsmax)
150℃
200℃
60-120seconds
Ramp-up rate(TLto Tp)
3℃/second max.
Liquidus temperature(TL)
Time(tL)maintained above TL
217℃
60-150 seconds
Classification temperature(Tc)
See Table (1.2)
Time(tp) at Tc- 5℃ (Tp should be equal to or less than Tc.)
*< 30 seconds
Ramp-down rate(Tp to TL)
6℃ /second max.
Time 25℃ to peak temperature
8 minutes max.
Tp: maximum peak package body temperature, Tc: the classification temperature.
For user (customer) Tp should be equal to or less than Tc.
* Tolerance for peak profile temperature (Tp) is defined as a supplier minimum and a user maximum.
Table (1.2) Package Thickness/Volume and Classification Temperature (Tc)
PB-Free Assembly
Package
Thickness
Volume mm3
>TAI-TECH(台庆)
很抱歉,暂时无法提供与“TMPV0754SV-150MN-D”相匹配的价格&库存,您可以联系我们找货
