XL-HD6070RGBC-A46L
XL-HD6070RGBC-A46L
    XINGLIGHT(成兴光)
    仿流明/6070球头七彩3W(6脚)(红:IV=50-55LM, 绿:IV=80-90LM,蓝:IV=20-25LM,(Typ)@IF=350mA)
XL-HD6070RGBC-A46L 数据手册
XL-HD6070RGBC-A46L Technical Data Sheet haracteristic * 发光颜色及胶体: 高亮度七彩/白色胶体 Luminous color and colloid: High brightness colorful / white colloid * 封装支架:6070支架 Packaging glue :6070 bracket * 发光角度:140度 Luminous Angle:140 degrees * 环保工艺符合ROHS标准 Environmental protection products Complied With RoHS Directive * EIA规范标准包装 EIA standard packaging * 适用于SMT贴片自动化生产 Suitable for SMT automatic production * 适用于回流焊制程(≤220℃) Suitable for reflow soldering process(≤220℃) roduct application * 普通照明 general linghting * 广告灯 adertisemen * 建筑照明 architectural lighting * 路灯 street lamps 1 Catalogue Electrical Characteristics...........................................................................................................................3 Typical Characteristic Curves...................................................................................................................6 Reliability Test Items And Conditions.......................................................................................................8 Outline Dimensions.....................................................................................................................................9 Packaging......................................................................................................................................................10 Guideline for Soldering.............................................................................................................................12 Precautions...................................................................................................................................................14 2 Electrical Characteristics (温度=25℃) Absolute Maximum Ratings (Temperature=25°C): 电气特性 Electrical characteristics 功耗 Power Dissipation 符号 Symbol PD 数值 Ratings 红 red 1250 绿 green 1750 蓝 blue 1750 单位 Unit mW 正向脉冲电流 PulseForward Current Ifp 1000 mA 反向电压 Reverse Voltage Vr 5 V 操作温度 Operating Temperatalure Top -40~+85 ℃ 存储温度 Storage Temperature Tst -40~+100 ℃ 结温 Junction Temperature Tj 140 ℃ ESD 2000 V 抗静电能力 Electrostatic Discharge Threshoi 手工焊接温度 HandSolderingTemperatur Ts 260℃ for 3 seconds *1.Input power and forward current are the values when the LED is used within the range of the derating curve in this data sheet. 当产品在较高的温度环境中使用时,请务必按照本规格书中的降额曲线对输入电流做相应的调整。 *2.Pulse width≤0.1ms, Duty≤1/10 脉冲宽度≤0.1ms, 占空比≤1/10 3.The data on this specification is for reference only 以上数据仅供参考. 3 Electro-Optical Charasteristics (Temperature=25°C): 参数 符号 Parameter Symbol 测试条件 最小 平均 最大 单位 Testconditions Min Typ Max Unit 2.0 2.3 2.6 3.0 3.3 3.6 蓝 blue 3.0 3.3 3.6 红 red 50 55 60 80 90 100 蓝 blue 15 20 25 红 red 620 625 630 520 525 530 457 460 465 发光颜色 Emitting color 红 red 正向电压 Forward Voltage 流明 Luminous Fiux 主波长 Dominant Wavelength VF Φ λd 绿 green 绿 green 绿 green IF=350mA IF=350mA IF=350mA 蓝 blue V lm nm 色温 CorrelatedColoTemperature CCT -- -- -- -- -- -- 反向电流 Reverse Current Ir -- VR=5V -- -- 10 μA 发光角度 Viewing Angle 2Θ1/2 -- IF=350mA -- 120 -- Deg 备注(Note): 以上数据是以我司测试机台进行测试 各参数测试误差为 正向电压+ / - 3%,光通量+ / - 10%,主波长 + / - 2nm,色温 +/-15% AbovedataaremeasuredbyJeray’stesterforwardvoltage+/-3%,luminousflux+/-10%,DominantWavelength+/-2nm,CCT +/-15% 4 : Brightness grading 颜色 Colour 代码 Code 最小值 Min 最大值 Max 单位 Unit 测试条件 Test conditions 红 red E20 50 55 LM IF=350mA 绿 green H05 80 90 LM IF=350mA 蓝 blue E14 20 25 LM IF=350mA 颜色 Colour 代码 Code 最小值 Min 最大值 Max 单位 Unit 测试条件 Test conditions 红 red A04 2.0 2.2 V IF=350mA 绿 green A09 3.0 3.2 V IF=350mA 蓝 blue A09 3.0 3.2 V IF=350mA 颜色 Colour 代码 Code 最小值 Min 最大值 Max 单位 Unit 测试条件 Test conditions 红 red HR02 620 625 nm IF=350mA 绿 green HG24 520 525 nm IF=350mA 蓝 blue HB33 460 465 nm IF=350mA : Voltage grading : Wavelength division: 5 Typical Characteristics Curves 6 6 7 7 Reliability Test Items And Conditions 测试项目 测试条件 Test Parameter Test Condition IF=350mA Ta=25℃ × 1000hrs 连续运行试验 Continuous Operation Test *1 IF=350mA Tj=140℃ × 1000hrs 低温贮存试验 Low Temperature Storage Test -40 ℃ × 1000 hours 高温贮存试验 High Temperature Storage Test 100℃ × 1000 hours 高温高湿试验 Moisture-proof Test 85 ℃, 85 %RH for 500 hours 冷热冲击试验 Thermal Shock Test -40 ℃ × 30 minutes-----100 ℃ × 30 minutes, 100 cycle Criteria For Judging Damage 项目 Parameter 正向电压 Forward Voltage 总光通量 Total Luninous Flux 符号 Symbol 实验条件 Measuring Condition 判定标准 Judgement standard VF IF=350mA >U × 1.1 Φv IF=350mA
XL-HD6070RGBC-A46L 价格&库存
很抱歉,暂时无法提供与“XL-HD6070RGBC-A46L”相匹配的价格&库存,您可以联系我们找货
XL-HD6070RGBC-A46L
  • 20+1.98000
  • 100+1.80000
  • 500+1.68000
  • 1000+1.56000
  • 5000+1.41600
  • 10000+1.35600
库存:2190
