MWT-5F
MWT-5F
    MWT
    模块
    RF Mosfet 6 V 30 mA 500MHz ~ 26GHz 19dB 芯片
MWT-5F 数据手册
MwT-5F 26 GHz High Gain, Dual Gate GaAs FET Features: • • • • • • • 21 dBm P1dB at 12 GHz 19 dB Small Signal Gain at 12 GHz 0.25 Micron Refractory Metal/Gold Gate Excellent for High Gain and High Linear Amplifier Applications Ideal for Commercial, Military, Hi-Rel Space Applications 300 Micron Dual Gate Width Choice of Chip and One Package Type Chip Dimensions: 415 x 260 microns Chip Thickness: 100 microns Description: The MwT-5F is a dual gate GaAs MESFET device whose nominal 0.25 micron gate length and 300 micron dual gate width make it ideally suited to applications requiring high gain and high linearity in the 500 MHz to 26 GHz frequency range. MwT-5F is equally effective for either wideband (e.g. 2 to 26 GHz) or narrow-band applications. All chips are passivated with SiN (Silicon Nitride). RF Specifications: DC Specifications: Updated October 2021 • • at Ta= 25° C at Ta= 25 °C MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Page 1 of 4 MwT-5F 26 GHz High Gain, Dual Gate GaAs FET Updated October 2021 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Page 2 of 4 MwT-5F 26 GHz High Gain, Dual Gate GaAs FET Updated October 2021 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Page 3 of 4 MwT-5F 26 GHz High Gain, Dual Gate GaAs FET S-PARAMETER Vds=6V, Ids= 0.7 x Idss Freq. GHz 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 S11 dB -0.586 -0.665 -0.788 -0.952 -1.126 -1.294 -1.629 -1.785 -1.992 -2.127 -2.366 -2.477 -2.605 -2.705 -2.793 -2.828 -2.839 -2.818 -2.782 -2.723 -2.653 -2.576 -2.507 -2.325 -2.182 -2.076 Ang (°) -10.932 -21.359 -31.452 -41.584 -50.186 -59.278 -67.336 -76.046 -84.861 -92.223 -100.035 -107.334 -114.579 -121.340 -127.874 -134.048 -139.752 -145.291 -150.694 -155.783 -160.797 -165.138 -169.324 -174.035 -178.106 177.969 dB 11.963 11.850 11.664 11.438 11.077 10.676 10.360 10.049 9.762 9.485 9.092 8.827 8.532 8.169 7.870 7.610 7.272 6.993 6.712 6.432 6.178 5.888 5.599 5.343 5.071 4.736 S21 S12 Ang (°) 168.981 158.721 148.752 138.778 129.326 120.403 111.513 103.060 94.576 86.527 78.385 70.834 62.809 55.257 47.661 40.430 33.063 25.669 18.589 11.146 3.738 -3.559 -11.177 -18.775 -26.257 -33.979 dB -46.999 -41.218 -37.963 -35.887 -34.461 -33.552 -32.670 -32.040 -31.559 -31.336 -31.133 -31.142 -31.411 -31.720 -32.359 -32.911 -33.671 -34.484 -35.437 -36.013 -36.062 -35.376 -34.224 -32.430 -30.832 -29.018 S22 Ang (°) 83.781 78.419 71.284 65.896 61.163 57.512 51.730 48.126 44.478 41.549 37.384 34.411 31.758 29.030 28.636 28.759 30.749 33.431 41.824 52.552 58.436 72.522 89.412 94.462 98.001 100.184 dB -1.057 -1.086 -1.129 -1.159 -1.315 -1.501 -1.397 -1.469 -1.495 -1.425 -1.455 -1.459 -1.375 -1.384 -1.264 -1.135 -1.027 -0.879 -0.725 -0.575 -0.409 -0.182 0.031 0.261 0.470 0.678 K Ang (°) -4.047 -8.292 -12.133 -16.103 -20.285 -22.832 -27.056 -30.428 -33.909 -37.483 -41.176 -44.608 -48.348 -52.261 -55.753 -60.133 -64.255 -68.499 -72.747 -77.547 -82.496 -87.488 -92.560 -97.751 -103.140 -108.574 0.812 0.525 0.506 0.519 0.593 0.686 0.751 0.795 0.841 0.851 0.941 0.989 1.026 1.116 1.144 1.114 1.104 1.025 0.851 0.576 0.249 -0.280 -0.731 -1.038 -1.227 -1.345 GMAX dB 29.481 26.534 24.813 23.663 22.769 22.114 21.515 21.045 20.660 20.410 20.113 19.985 18.992 17.870 17.812 18.207 18.511 19.776 21.074 21.223 21.120 20.632 19.911 18.886 17.952 16.877 MAXIMUM RATINGS AT Ta = 25 °C Notes: 1. Exceeding any one of these limits in continuous operation may reduce the mean-time- to-failure below the design goal. 2. Exceeding any one of these limits may cause permanent damage. ORDERING INFORMATION: When placing order or inquiring, please specify wafer number, if known. All dice are Visual Level 3 (military grade visual screening). MwT cannot guarantee dice will fall at the lower or upper end of the Idss Range. For details of Safe Handling Procedure please see supplementary information in available PDF on our website www.mwtinc.com. Available Packaging: 71 Package - MwT-5F71 Updated October 2021 MicroWave Technology, Inc., 4268 Solar Way, Fremont, CA 94538 510-651-6700 FAX 510-952-4000 WEB www.mwtinc.com Data contained herein is subject to change without notice. All rights reserved © Page 4 of 4
MWT-5F 价格&库存
很抱歉,暂时无法提供与“MWT-5F”相匹配的价格&库存,您可以联系我们找货
