WET TANTALUM CAPACITORS
DSCC 10004
Wet tantalum capacitors
Hermetically sealed tantalum cases
Very high capacitance
Enhanced performances
Axial leads
Polarized
ELECTRICAL AND CLIMATIC CHARACTERISTICS
DSCC 10004
Detail specification
DWG NO. 10004
Operating temperature
Capacitance range
Tolerance
Voltage range
–55°C +125°C
220µF 10000µF
±10% - ±20%
10V 125V
Max. capacitance change –55°C
Max. capacitance change +85°C
Max. capacitance change +125°C
see table
see table
see table
Max. impedance at 120Hz –55°C
see table
Max. leakage current at +25°C
Max. leakage current at +85°C / +125°C
see table
see table
Max. ESR at 120Hz +25°C
see table
Max. ripple current 40kHz +85°C
see table
No continuous Reverse voltage.
Reverse voltage is acceptable under some conditions: UREV ≤ 1,5 V, It ≤ 0,05 A second and repetition rate < 10Hz
Reverse voltage
Max. surge voltage at +85°C
1,15 x UR
DIMENSIONS (mm)
Case
(code)
T3
T4
Without
insulating sleeve
D ±0,41
9,52
9,52
L
+0,79
–0,41
19,46
26,97
E
With
insulating sleeve
Lead length
D max.
E ±6,35
10,31
10,31
57,15
57,15
E
0.64 ±0,05
D
6.35 max.
PACKAGING, CONSTRUCTION:
see general characteristics
L
HOW TO ORDER
EXXELIA PN
Model code
10004
www.exxelia.com
Dash Number
-38
2
Tolerance code
K
Insulating sleeve
S
K = ±10%
M = ±20%
U = Without
S = With
tantalum@exxelia.com
Page revised 04/19
DSCC 10004
STANDARD RATINGS - ELECTRICAL CHARACTERISTICS
Capacitance maximum change
Capacitance
120Hz
+25°C
(µF)
Case
(code)
Dash
Number
4700
10000
T3
T4
01
02
–80
–85
3300
6000
T3
T4
03
04
–80
–80
4000
T4
05
–80
3300
T4
06
–80
2800
T4
07
–80
900
1500
1500
2200
ST79
560
1000
1200
1800
470
750
940
1200
ST79
220
400
470
240
330
T3
T3
T4
T4
34
35
08
15
–75
–85
–70
–80
T3
T4
T4
T4
36
09
16
28
–70
–40
–70
–75
T3
T4
T4
T4
11
12
17
30
–45
–35
–60
–75
T3
T4
T4
38
13
18
–55
–40
–50
T4
T4
14
24
–35
–55
–55°C
www.exxelia.com
+85°C
+125°C
Max.
Impedance
120Hz
–55°C
(Ω)
Max. I leak
+25°C
(µA)
Rated voltage (+85°C) 10 V - Derated voltage (+125°C) 7 V
+10
+20
3,5
16
+20
+35
3
25
Rated voltage (+85°C) 16 V - Derated voltage (+125°C) 11 V
+10
+15
3,5
16
+15
+20
3
25
Rated voltage (+85°C) 25 V - Derated voltage (+125°C) 15 V
+15
+20
5
25
Rated voltage (+85°C) 30 V - Derated voltage (+125°C) 20 V
+20
+25
4
25
Rated voltage (+85°C) 35 V - Derated voltage (+125°C) 22 V
+20
+30
4,5
25
Rated voltage (+85°C) 50 V - Derated voltage (+125°C) 30 V
+20
+20
10
15
+25
+30
8
25
+20
+20
6
15
+25
+30
4,5
25
Rated voltage (+85°C) 60 V - Derated voltage (+125°C) 40 V
+12
+15
10
+15
5,5
+20
6
+25
6
25
Rated voltage (+85°C) 75 V - Derated voltage (+125°C) 50 V
+10
+25
10
25
+10
+15
6,5
+20
8
+25
8
25
Rated voltage (+85°C) 100 V - Derated voltage (+125°C) 65 V
+10
+15
18
5
+6
+12
15
10
+10
+20
10
25
Rated voltage (+85°C) 125 V - Derated voltage (+125°C) 85 V
+6
+12
+8
+12
15
25
3
Irms Max.
40kHz
+85°C
(mA)
Max. ESR
120Hz
+25°C
(Ω)
100
150
4000
5000
0,35
0,25
100
150
4000
4500
0,35
0,30
125
4250
0,35
125
2750
0,35
125
4000
0,35
125
130
110
125
2500
2400
3500
3000
0,90
1,00
0,45
0,60
120
120
200
250
2500
3500
3500
3000
0,90
0,50
0,50
0,50
100
120
200
250
3000
3500
3500
2750
0,60
0,50
0,50
0,80
25
120
250
2500
3000
3500
1,40
0,70
0,70
150
250
2500
2500
0,80
0,80
+85°C
+125°C
(µA)
Page revised 04/19
02/19
