PCT.33/6AK
PCT.33/6AK
    SUNTSU
    CAP TANT 0.33UF 10% 6.3V 1206
PCT.33/6AK 数据手册
PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS FEATURES - Surface Mount (SMT) Tantalum Capacitors - Meets or Exceeds EIA 535 BAAC and IECQ standards (QC300801/US001, IS-28) - Capacitance range: 0.1μF to 1500μF - Voltage range: 4 to 50 WVDC - Down sized, extended range values - Low profile sizes: XL, AL, BL, CL, DL - Surge tested for maximum robustness - Operating Temperature range -55°C to +125°C - Precision molded case with flat surfaces for vacuum pick-up Laser marking and bold videcon – readable polarity Compliant terminations Glue pad on underside for bonding to circuit board prior to soldering Encapsulant material satisfies the UL 94 V0 flammability classification MSL (moisture sensitivity level) per IPC/Jedec J-STD020B is level 1 PART NUMBERING GUIDE PCT 10 / 35 D K SERIES TYPE (optional) OPTIONAL -13 = 13 inch diameter Tape & Reel = 7 inch standard Tape & Reel TL = Tin/Lead TOLERANCE M = (±20%) K = (±10%) CAPACITANCE in microfarads (µF) Ex. 0.68µF would be .68 CASE SIZE A (3216-18) B (3528-21) C (6032-28) D (7343-31) H (7343-43) Z (7361-38) XL (2012-12) Low Profile AL (3216-12) Low Profile BL (3528-12) Low Profile CL (6032-15) Low Profile DL (7343-20) Low Profile VOLTAGE 4 6(6.3) 10 16 20 25 35 50 ELECTRICAL SPECIFICATION Technical Data: Capacitance Range Capacitance Tolerance Rated Voltage DC (VR) Category Voltage DC (VC) Surge Voltage (VS) Surge Voltage (VS) Temperature Range Reliability All technical data relate to an ambient temperature of +25°C 0.10µF to 1500µF ±10% (K); ±20% (M) 4 6.3 10 16 20 25 35 2.7 4 7 10 13 17 23 5.2 8 13 20 26 32 46 3.2 5 8 13 16 20 28 -55°C to +125°C with 2/3 Vr (linear derating) required for operation above +85°C Level M (1% per 1000 hours at rated voltage (VR), rated temperature (85°C) and 0.1Ω/volt circuit impedance. Fixed Tantalum Specifications: EIA 525BAAC and IECQ standards (QC300801/US001, IS-28) Solder-ability: Sn Plated Terminations – meets requirements of IEC 68 2.20 test Ta and MIL-STD=202, Method 208 MSL (moisture sensitivity level): Level 1 of IPC/Jedec J-STD-020B ≤+85°C ≤+125°C ≤+85°C ≤+125°C Qualifications CASE SIZE CROSS REFERENCE: CAPACITANCE AND VOLTAGE RATING (Rated Voltage DC@ 85°C) Cap (μF) 4V 6.3V 10V 16V 20V 0.10 0.15 0.22 0.33 0.47 0.68 1.0 1.5 2.2 3.3 4.7 6.8 10.0 15.0 22.0 33.0 47.0 68.0 100.0 150.0 220.0 330.0 470.0 680.0 1000.0 1500.0 50 33 65 40 25V 35V 50V A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL, XL A, AL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, XL A, AL, B, A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL A, AL, BL, XL AL, BL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C XL A, AL, B, BL, C A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, Z, XL A, AL, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z B, C, CL, D, DL, H A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z A, B, BL, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z C, D, DL, H A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, D, DL, XL A, AL, B, BL, C, CL, D, DL, H, XL A, AL, B, BL, C, CL, D, DL, H A, B, BL, C, CL, D, DL, H, Z A, B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, CL, D, DL, XL A, AL, B, BL, C, CL, D, DL, H A, AL, B, BL, C, D, DL A, B, BL, C, CL, D, DL, H A, B, BL, C, CL, D, DL, H B, C, CL, D, DL, H, Z B, C, CL, D, DL, H, Z A, AL, B, BL, C XL A, AL, B, BL, C, CL, XL A, AL, B, BL, C, D, XL A, AL, B, BL, C, D, XL A, B, BL, C, CL, D, DL A, B, BL, C, CL, D, DL, H A, AL, B, BL, C A, AL, B, BL, C, CL, XL A, B, BL, C, CL, D, DL A, B, BL, C, CL, D, DL, H A, B, BL, C, D, DL B, C, D, DL B, C, CL, D, DL, H B, C, D, DL, H, Z C, D, DL, H, J C, D, DL, H A, AL, B, BL, C A, B, C A, AL, B, BL, C, CL A, B, C, CL A, AL, B, BL, C, D A, B, BL, C, D B, C, D A, B, BL, C, D A, B, BL, C, D B, C, D B, C, D, DL C, D, DL C, D, DL, H C, D, DL C, D, DL C, D, DL B, C, CL, D, DL, H C, D, DL, H D, H B, C, CL, D, DL, H C, D, DL, H C, D, DL, H D, H B, C, CL, D, DL, H, Z C, D, DL, H, Z D, DL, H, Z Z C, D, DL, H, Z D, H, Z D, H, Z C, CL, D, DL, H, Z C, D, DL, H, Z D, DL, H, Z H, Z C, D, DL, H, Z C, D, DL, H, Z H, Z Z B, C, CL, D, DL, H, Z C, D, DL, H, Z D, H, Z H, Z C, D, DL, H, Z D, DL, H, Z H, Z Z C, D, DL, H H C, D, DL, H, J D, H, J J D, DL, H H D, DL, H H D, H, Z H, Z H 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS OUTLINE DRAWING AND PAD PRINT TAPE AND REEL DIMENSION (3) 0805 Footprint Compatible (4) 1206 Footprint Compatible NOTE: Dimensions in millimeters (mm) NEMCO Size EIA Size ±0.2 ± 0.2 ± 0.3 ± 0.1 ±0.3 S Min. PSL PL PS PW ±0.3 (Pitch) (MAX) I ±1 ±0.05 A(4) 3216-18 3.2 1.6 1.6 1.2 0.8 1.10 3.8 1.4 1.0 1.8 8 4 2.3 1.0 9.5 3.5 B 3528-21 3.5 2.8 1.9 2.2 0.8 1.40 4.0 1.4 1.2 2.8 8 4 2.6 1.0 9.5 3.5 C 6032-28 6.0 3.2 2.5 2.2 1.3 2.90 6.5 2.0 2.5 2.8 12 8 3.3 1.5 13 5.5 D 7343-31 7.3 4.3 2.8 2.4 1.3 4.40 8.0 2.0 4.0 3.0 12 8 3.6 1.5 13 5.5 H 7343-43 7.3 4.3 4.1 2.4 1.3 4.40 8.0 2.0 4.0 3.0 12 8 4.8 1.5 13 5.5 Z 7361-38 7.3 6.1 3.45 3.1 1.4 4.40 8.0 2.0 4.0 3.7 12 8 4.8 1.5 13 5.5 XL(3) 2012-12 2.05 1.3 1.2 1.2 0.5 0.85 2.7 1.0 0.8 1.6 8 4 1.9 1.0 9.5 3.5 AL(4) 3216-12 3.2 1.6 1.2 1.2 0.8 1.10 3.8 1.4 1.0 1.8 8 4 1.9 1.0 9.5 3.5 BL 3528-12 3.5 2.8 1.2 2.2 0.8 1.40 4.0 1.4 1.2 2.8 8 4 1.9 1.0 9.5 3.5 CL 6032-15 6.0 3.2 1.5 2.2 1.3 2.90 6.5 2.0 2.5 2.8 8 4 1.9 1.0 9.5 3.5 DL 7343-20 7.3 4.3 2.0 2.4 1.3 4.40 8.0 2.0 4.0 3.0 8 4 1.7 1.0 9.5 3.5 L W1 H W2 P TW PT REFLOW PROFILE M N F MARKING Case Sizes: XL, A, AL, B, BL Capacitance with μ representing decimal Voltage Code Polarity (+) C4µ7 DATE CODE C4µ7 = 4.7 µfd / 16V Case Sizes: C, CL, D, DL, H, Z Polarity (+) Capacitance Voltage Tantalum capacitors are lead-free system compatible system components, meeting the requirements of J-STD-020 standard. Maximum peak temperature 260°C for 10 seconds maximum, 3 reflow cycles. There are several important general soldering considerations for tantalum capacitors. • Soldering temperature and time should be the minimum for a good connection. • Recommended soldering profiles are designed to insure that the temperature of the internal construction of the capacitors does not exceed +220°C. • Positioning capacitors near components radiating heat such as power transistors should be avoided. • Allow for an increase to ESR ratings of 1.25 x catalog limit post PCB assembly. NEMCO reserves the right to supply a higher voltage rating, Voltage VDC 4V 6.3V 10V 16V 20V 25V 35V 50V Voltage Code G J A C D E V T tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 4 V DC @ 85°C Capacitance (μF) 2.2 2.2 3.3 3.3 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 68.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 220.0 330.0 330.0 330.0 470.0 470.0 470.0 470.0 680.0 680.0 680.0 1000.0 1000.0 1500.0 Case Size AL XL AL XL AL XL AL BL XL AL BL XL AL BL XL AL BL XL A AL BL CL A BL CL A B BL CL A B BL CL B C CL DL B C CL D DL C D DL C D DL H D DL H D H H Nemco Part No. PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT150 PCT220 PCT220 PCT220 PCT220 PCT220 PCT330 PCT330 PCT330 PCT470 PCT470 PCT470 PCT470 PCT680 PCT680 PCT680 PCT1000 PCT1000 PCT1500 / 4AL _ / 4XL _ / 4AL _ / 4XL _ / 4AL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4AL _ / 4BL _ / 4XL _ / 4A _ / 4AL _ / 4BL _ / 4CL _ / 4A _ / 4BL _ / 4CL _ / 4A _ / 4B _ / 4BL _ / 4CL _ / 4A _ / 4B _ / 4BL _ / 4CL _ / 4B _ / 4C _ / 4CL _ / 4DL _ / 4B _ / 4C _ / 4CL _ / 4D _ / 4DL _ / 4C _ / 4D _ / 4DL _ / 4C _ / 4D _ / 4DL _ / 4H _ / 4D _ / 4DL _ / 4H _ /4D _ /4H _ /4H _ 6.3 V DC @ 85°C (2.7 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.5 0.6 0.6 0.6 0.9 0.9 0.9 1.3 1.3 1.3 1.3 1.9 1.9 1.9 2.7 2.7 2.7 2.7 4.0 4.0 4.0 4.0 6.0 6.0 6.0 6.0 8.8 8.8 8.8 8.8 8.8 13.2 13.2 13.2 18.8 18.8 18.8 18.8 27.2 27.2 27.2 40.0 40.0 60.0 tan δ max. (%) 6 6 6 6 6 6 6 6 6 6 6 6 8 6 8 8 6 8 6 8 6 6 8 10 6 10 6 15 6 30 8 14 6 10 6 6 6 12 8 8 8 8 8 8 12 14 12 14 10 14 25 14 60 14 30 ESR @ 100kHz max. (Ω) 25.0 25.0 18.0 20.0 10.0 12.0 8.0 6.0 5.2 6.0 5.0 7.0 4.0 2.0 4.0 3.5 1.9 3.8 3.0 1.7 1.7 0.6 2.6 2.0 0.5 1.5 1.8 1.5 0.4 1.4 0.9 1.4 1.3 1.5 0.3 1.3 0.4 1.1 1.2 1.2 0.9 0.3 0.3 0.9 0.4 0.3 0.9 0.9 0.5 0.5 0.2 0.9 0.2 0.4 0.2 Capacitance (μF) 1.5 1.5 2.2 2.2 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 330.0 330.0 330.0 330.0 470.0 470.0 470.0 680.0 1000.0 1000.0 Case Size AL XL AL XL AL XL AL BL XL AL BL XL A AL BL XL A AL B BL XL A AL B BL CL A B BL C CL A B BL C CL B C CL D B C CL D DL B C CL D DL C D DL H C D DL H D DL H H H Z Nemco Part No. PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT150 PCT150 PCT220 PCT220 PCT220 PCT220 PCT330 PCT330 PCT330 PCT330 PCT470 PCT470 PCT470 PCT680 PCT1000 PCT1000 / 6AL _ / 6XL _ / 6AL _ / 6XL _ / 6AL _ / 6XL _ / 6AL _ / 6BL _ / 6XL _ / 6AL _ / 6BL _ / 6XL _ / 6A _ / 6AL _ / 6BL _ / 6XL _ / 6A _ / 6AL _ / 6B _ / 6BL _ / 6XL _ / 6A _ / 6AL _ / 6B _ / 6BL _ / 6CL _ / 6A _ / 6B _ / 6BL _ / 6C _ / 6CL _ / 6A _ / 6B _ / 6BL _ / 6C _ / 6CL _ / 6B _ / 6C _ / 6CL _ / 6D _ / 6B _ / 6C _ / 6CL _ / 6D _ / 6DL _ / 6B _ / 6C _ / 6CL _ / 6D _ / 6DL _ / 6C _ / 6D _ / 6DL _ / 6H _ / 6C _ / 6D _ / 6DL _ / 6H _ / 6D _ / 6DL _ / 6H _ / 6H _ / 6H _ / 6Z _ (4 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.6 0.6 0.6 0.9 0.9 1.0 1.0 0.9 1.4 1.3 1.4 1.4 1.3 2.1 2.1 2.1 2.1 2.1 2.8 3.0 2.8 3.0 3.0 4.0 4.3 4.3 4.3 6.3 6.3 6.3 6.3 6.3 9.5 9.5 9.0 9.5 9.0 13.9 13.9 13.9 13.9 19.8 20.8 20.8 20.8 28.0 28.2 28.0 42.8 60.0 60.0 tan δ max. (%) 6 6 6 6 6 6 6 6 6 6 6 8 6 8 6 8 6 8 6 6 8 6 10 6 8 6 8 6 10 6 6 10 6 10 6 6 8 6 6 6 10 6 6 6 6 10 6 8 6 6 8 8 10 8 12 8 8 8 12 20 10 10 20 16 ESR @ 100kHz max. (Ω) 25.0 25.0 18.0 20.0 9.0 12.0 7.5 6.0 7.0 2.6 5.0 7.0 4.0 4.0 4.0 6.0 3.5 4.0 2.5 3.5 4.1 3.0 1.8 2.5 2.5 0.6 3.2 2.2 2.5 1.8 1.8 1.6 2.0 1.6 1.6 1.5 0.9 1.5 1.5 0.9 1.7 0.9 0.9 0.9 0.9 1.2 1.3 0.3 0.9 0.4 1.2 0.4 0.9 0.4 0.5 0.4 0.4 0.4 0.4 0.2 0.4 0.5 0.2 0.4 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 10 V DC @ 85°C Capacitance (μF) 1.0 1.0 1.5 1.5 2.2 2.2 2.2 3.3 3.3 3.3 4.7 4.7 4.7 4.7 6.8 6.8 6.8 6.8 6.8 10.0 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 150.0 220.0 220.0 220.0 220.0 330.0 330.0 470.0 Case Size AL XL AL XL A AL XL AL BL XL A AL BL XL A AL B BL XL A AL B BL XL A AL B BL CL A B BL C CL A B C CL B C CL D DL B C D B C CL D DL C D DL H C D DL H D H H Nemco Part No. PCT1 PCT1 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT150 PCT220 PCT220 PCT220 PCT220 PCT330 PCT330 PCT470 / 10AL _ / 10XL _ / 10AL _ / 10XL _ / 10A _ / 10AL _ / 10XL _ / 10AL _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10B _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10B _ / 10BL _ / 10XL _ / 10A _ / 10AL _ / 10B _ / 10BL _ / 10CL _ / 10A _ / 10B _ / 10BL _ / 10C _ / 10CL _ / 10A _ / 10B _ / 10C _ / 10CL _ / 10B _ / 10C _ / 10CL _ / 10D _ / 10DL _ / 10B _ / 10C _ / 10D _ / 10B _ / 10C _ / 10CL _ / 10D _ / 10DL _ / 10C _ / 10D _ / 10DL _ / 10H _ / 10C _ / 10D _ / 10DL _ / 10H _ / 10D _ / 10H _ / 10H _ 16 V DC @ 85°C (7 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.7 0.7 0.7 0.7 0.7 1.0 1.0 1.0 1.0 1.0 1.5 1.5 1.5 1.5 1.5 2.2 2.2 2.2 2.2 2.2 3.3 3.3 3.3 3.3 4.7 4.7 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 33.0 33.0 47.0 tan δ max. (%) 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 8 6 6 20 6 6 6 8 6 8 6 8 6 6 8 6 6 6 8 6 6 6 6 6 6 6 8 8 6 6 6 8 8 6 8 8 8 10 8 8 8 10 ESR @ 100kHz max. (Ω) 25.0 25.0 20.0 20.0 7.0 12.0 15.0 8.0 6.0 8.0 5.0 5.0 5.0 9.0 4.0 4.0 3.0 4.0 5.2 3.0 4.0 2.5 3.0 6.0 3.2 2.0 2.8 2.8 0.7 3.0 2.4 2.2 1.8 0.6 1.7 1.8 1.6 1.6 1.0 1.2 1.4 0.9 0.5 1.4 1.3 0.9 1.4 1.2 0.4 0.9 0.9 0.9 0.9 1.2 0.9 0.5 0.5 0.5 0.5 0.9 0.9 0.5 Capacitance (μF) 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 2.2 2.2 2.2 2.2 3.3 3.3 3.3 3.3 3.3 4.7 4.7 4.7 4.7 6.8 6.8 6.8 6.8 6.8 10.0 10.0 10.0 10.0 10.0 15.0 15.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 100.0 100.0 100.0 100.0 150.0 150.0 150.0 220.0 330.0 Case Size AL XL A AL BL XL A AL XL A AL BL XL A AL B BL XL A AL B BL A AL B BL C A B BL C CL A B BL C CL B C CL D B C CL D DL C CL D DL C D DL C D DL H D DL H H H Nemco Part No. PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT100 PCT100 PCT100 PCT100 PCT150 PCT150 PCT150 PCT220 PCT330 / 16AL _ / 16XL _ / 16A _ / 16AL _ / 16BL _ / 16XL _ / 16A _ / 16AL _ / 16XL _ / 16A _ / 16AL _ / 16BL _ / 16XL _ / 16A _ / 16AL _ / 16B _ / 16BL _ / 16XL _ / 16A _ / 16AL _ / 16B _ / 16BL _ / 16A _ / 16AL _ / 16B _ / 16BL _ / 16C _ / 16A _ / 16B _ / 16BL _ / 16C _ / 16CL _ / 16A _ / 16B _ / 16BL _ / 16C _ / 16CL _ / 16B _ / 16C _ / 16CL _ / 16D _ / 16B _ / 16C _ / 16CL _ / 16D _ / 16DL _ / 16C _ / 16CL _ / 16D _ / 16DL _ / 16C _ / 16D _ / 16DL _ / 16C _ / 16D _ / 16DL _ / 16H _ / 16D _ / 16DL _ / 16H _ / 16H _ / 16H _ (10 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.8 0.8 0.8 0.8 1.1 1.1 1.1 1.1 1.1 1.6 1.6 1.6 1.6 1.6 2.4 2.4 2.4 2.4 2.4 3.5 3.5 3.5 3.5 5.3 5.3 5.3 5.3 5.3 7.5 7.5 7.5 7.5 10.9 10.9 10.9 16.0 16.0 16.0 16.0 24.0 24.0 24.0 35.2 52.8 tan δ max. (%) 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 8 6 8 6 6 6 8 6 6 6 8 6 8 6 6 6 6 6 6 6 6 6 6 6 8 6 6 6 6 6 6 6 6 6 6 6 8 6 8 6 6 15 8 10 30 ESR @ 100kHz max. (Ω) 25.0 25.0 11.0 15.0 5.0 20.0 8.0 12.0 10.0 6.5 6.0 6.5 6.5 5.0 5.0 4.5 5.0 5.0 4.0 4.5 3.5 4.5 3.5 2.4 2.5 3.5 2.5 3.0 2.8 2.2 2.0 2.0 2.0 2.5 2.0 1.8 0.7 2.3 1.0 1.6 1.1 2.1 1.5 1.5 0.9 0.9 0.5 0.4 0.9 0.7 1.3 0.9 0.9 1.0 0.6 0.9 0.9 0.9 0.3 0.3 0.5 0.4 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 20 V DC @ 85°C Capacitance (μF) 0.10 0.10 0.15 0.15 0.22 0.22 0.33 0.33 0.47 0.47 0.68 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 1.5 2.2 2.2 2.2 2.2 2.2 3.3 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 6.8 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 22.0 22.0 33.0 33.0 33.0 47.0 47.0 47.0 47.0 68.0 68.0 68.0 68.0 100.0 100.0 150.0 Case Size AL XL AL XL AL XL AL XL AL XL AL BL XL A AL BL XL A AL BL XL A AL B BL XL A B BL A B BL A B BL C B C CL B C CL B C CL D DL C D DL C D DL H C D DL H D H H Nemco Part No. PCT.1 PCT.1 PCT.15 PCT.15 PCT.22 PCT.22 PCT.33 PCT.33 PCT.47 PCT.47 PCT.68 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT47 PCT47 PCT47 PCT47 PCT68 PCT68 PCT68 PCT68 PCT100 PCT100 PCT150 / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20XL _ / 20AL _ / 20BL _ / 20XL _ / 20A _ / 20AL _ / 20BL _ / 20XL _ / 20A _ / 20AL _ / 20BL _ / 20XL _ / 20A _ / 20AL _ / 20B _ / 20BL _ / 20XL _ / 20A _ / 20B _ / 20BL _ / 20A _ / 20B _ / 20BL _ / 20A _ / 20B _ / 20BL _ / 20C _ / 20B _ / 20C _ / 20CL _ / 20B _ / 20C _ / 20CL _ / 20B _ / 20C _ / 20CL _ / 20D _ / 20DL _ / 20C _ / 20D _ / 20DL _ / 20C _ / 20D _ / 20DL _ / 20H _ / 20C _ / 20D _ / 20DL _ / 20H _ / 20D _ / 20H _ / 20H _ 25 V DC @ 85°C (13V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.7 0.7 0.7 0.9 0.9 0.9 1.4 1.4 1.4 1.4 2.0 2.0 2.0 3.0 3.0 3.0 4.4 4.4 4.4 4.4 4.4 6.6 6.6 6.6 9.4 9.4 9.4 9.4 13.6 13.6 13.6 13.6 20.0 20.0 30.0 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 8 6 6 6 6 6 8 ESR @ 100kHz max. (Ω) 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 25.0 15.0 20.0 9.0 12.0 9.0 20.0 6.5 5.4 6.5 9.6 5.3 4.5 3.5 6.0 6.0 4.5 3.0 3.0 4.0 3.0 3.0 2.4 2.5 2.6 2.0 2.1 2.2 1.9 2.0 1.7 1.7 1.8 1.6 1.6 0.9 0.9 1.5 0.9 0.6 0.5 0.9 0.9 0.9 0.5 0.4 0.9 0.9 0.5 0.4 0.3 Capacitance (μF) 0.15 0.22 0.33 0.47 0.47 0.68 0.68 1.0 1.0 1.0 1.5 1.5 1.5 1.5 2.2 2.2 2.2 3.3 3.3 3.3 3.3 3.3 4.7 4.7 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 33.0 33.0 47.0 47.0 47.0 68.0 100.0 100.0 150.0 Case Size XL XL XL AL XL AL XL A AL XL A AL B BL A B BL A B BL C CL A B BL C CL B C CL B C CL D C D DL C D DL D H D DL H H H Z Z Nemco Part No. PCT.15 PCT.22 PCT.33 PCT.47 PCT.47 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT33 PCT33 PCT47 PCT47 PCT47 PCT68 PCT100 PCT100 PCT150 / 25XL _ / 25XL _ / 25XL _ / 25AL _ / 25XL _ / 25AL _ / 25XL _ / 25A _ / 25AL _ / 25XL _ / 25A _ / 25AL _ / 25B _ / 25BL _ / 25A _ / 25B _ / 25BL _ / 25A _ / 25B _ / 25BL _ / 25C _ / 25CL _ / 25A _ / 25B _ / 25BL _ / 25C _ / 25CL _ / 25B _ / 25C _ / 25CL _ / 25B _ / 25C _ / 25CL _ / 25D _ / 25C _ / 25D _ / 25DL _ / 25C _ / 25D _ / 25DL _ / 25D _ / 25H _ / 25D _ / 25DL _ / 25H _ / 25H _ / 25H _ / 25Z _ / 25Z _ (17 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.6 0.6 0.6 0.8 0.8 0.8 0.8 0.8 1.2 1.2 1.2 1.2 1.2 1.7 1.7 1.7 2.5 2.5 2.5 2.5 3.8 3.8 3.8 5.5 5.5 5.5 8.3 8.3 11.8 11.8 11.8 17.0 25.0 25.0 37.5 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 10 8 10 ESR @ 100kHz max. (Ω) 24.0 21.0 17.0 14.0 15.0 10.0 13.0 8.0 8.0 8.0 7.5 5.4 5.0 5.0 7.0 4.5 4.5 3.7 3.5 3.5 2.8 1.6 3.1 1.5 3.1 2.4 1.2 2.8 2.0 2.0 2.5 1.8 1.8 1.2 1.6 1.0 1.0 1.4 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.9 0.3 0.4 0.4 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS RATINGS AND PART NUMBER REFERENCE 35 V DC @ 85°C Capacitance (μF) 0.10 0.10 0.10 0.15 0.15 0.15 0.22 0.22 0.22 0.33 0.33 0.33 0.47 0.47 0.47 0.47 0.47 0.68 0.68 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 1.5 2.2 2.2 2.2 2.2 3.3 3.3 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 10.0 10.0 15.0 15.0 15.0 22.0 22.0 22.0 33.0 33.0 33.0 47.0 47.0 68.0 Case Size A AL XL A AL XL A AL XL A AL XL A AL B BL XL A AL B BL A AL B BL A B BL C A B BL C B C CL D B C D C D DL C D DL H C D DL D DL H D H Z H Z Z Nemco Part No. PCT.1 PCT.1 PCT.1 PCT.15 PCT.15 PCT.15 PCT.22 PCT.22 PCT.22 PCT.33 PCT.33 PCT.33 PCT.47 PCT.47 PCT.47 PCT.47 PCT.47 PCT.68 PCT.68 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT10 PCT10 PCT15 PCT15 PCT15 PCT22 PCT22 PCT22 PCT33 PCT33 PCT33 PCT47 PCT47 PCT68 / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35XL _ / 35A _ / 35AL _ / 35B _ / 35BL _ / 35XL _ / 35A _ / 35AL _ / 35B _ / 35BL _ / 35A _ / 35AL _ / 35B _ / 35BL _ / 35A _ / 35B _ / 35BL _ / 35C _ / 35A _ / 35B _ / 35BL _ / 35C _ / 35B _ / 35C _ / 35CL _ / 35D _ / 35B _ / 35C _ / 35D _ / 35C _ / 35D _ / 35DL _ / 35C _ / 35D _ / 35DL _ / 35H _ / 35C _ / 35D _ / 35DL _ / 35D _ / 35DL _ / 35H _ / 35D _ / 35H _ / 35Z _ / 35H _ / 35Z _ / 35Z _ 50 V DC @ 85°C (23 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.8 0.8 0.8 0.8 1.2 1.2 1.2 1.2 1.2 1.6 1.6 2.4 2.4 2.3 3.5 3.5 3.5 3.5 5.3 5.3 5.3 7.7 7.7 7.7 11.6 11.6 11.6 16.5 16.5 23.8 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 6 ESR @ 100kHz max. (Ω) 24.0 24.0 29.0 21.0 21.0 24.0 18.0 18.0 21.0 15.0 15.0 17.0 12.0 12.0 10.0 10.0 15.0 8.0 8.0 8.0 8.0 7.5 7.5 6.5 6.5 7.5 5.2 5.2 4.5 4.5 4.2 4.2 3.5 3.5 2.5 1.6 2.5 3.1 2.2 1.5 1.8 1.3 0.9 1.6 1.0 1.0 0.9 1.4 0.9 0.6 0.9 0.5 0.5 0.9 0.9 0.5 0.9 0.4 0.5 Capacitance (μF) 0.10 0.10 0.15 0.15 0.15 0.22 0.22 0.22 0.33 0.33 0.33 0.47 0.47 0.47 0.47 0.47 0.68 0.68 0.68 1.0 1.0 1.0 1.0 1.5 1.5 1.5 2.2 2.2 2.2 3.3 3.3 3.3 4.7 4.7 4.7 6.8 6.8 6.8 10.0 10.0 15.0 15.0 22.0 Case Size A AL A AL B A AL B B AL BL A AL B BL C A B C A B C CL B C D B C D C D DL C D DL C D DL D H D H Z Nemco Part No. PCT.1 PCT.1 PCT.15 PCT.15 PCT.15 PCT.22 PCT.22 PCT.22 PCT.33 PCT.33 PCT.33 PCT.47 PCT.47 PCT.47 PCT.47 PCT.47 PCT.68 PCT.68 PCT.68 PCT1 PCT1 PCT1 PCT1 PCT1.5 PCT1.5 PCT1.5 PCT2.2 PCT2.2 PCT2.2 PCT3.3 PCT3.3 PCT3.3 PCT4.7 PCT4.7 PCT4.7 PCT6.8 PCT6.8 PCT6.8 PCT10 PCT10 PCT15 PCT15 PCT22 / 50A _ / 50AL _ / 50A _ / 50AL _ / 50B _ / 50A _ / 50AL _ / 50B _ / 50B _ / 50AL _ / 50BL _ / 50A _ / 50AL _ / 50B _ / 50BL _ / 50C _ / 50A _ / 50B _ / 50C _ / 50A _ / 50B _ / 50C _ / 50CL _ / 50B _ / 50C _ / 50D _ / 50B _ / 50C _ / 50D _ / 50C _ / 50D _ / 50DL _ / 50C _ / 50D _ / 50DL _ / 50C _ / 50D _ / 50DL _ / 50D _ / 50H _ / 50D _ / 50H _ / 50Z _ (33 V DC @ 125°C) DCL (μA) max 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.7 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.5 0.8 0.8 0.8 1.1 1.1 1.1 1.6 1.7 1.7 0.5 2.4 2.4 3.4 3.4 3.4 5.0 5.0 7.5 7.5 11.0 tan δ max. (%) 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 4 6 8 6 6 8 8 6 6 6 4 4 6 6 6 6 6 6 6 4 6 8 ESR @ 100kHz max. (Ω) 22.0 19.0 15.0 16.0 17.0 18.0 13.0 14.0 12.0 11.0 11.0 9.5 9.5 9.5 9.5 8.0 7.9 8.0 7.0 6.6 7.0 5.5 4.4 5.4 4.5 4.0 4.5 2.5 2.5 2.5 2.0 1.7 1.4 1.4 1.2 1.0 1.0 0.9 0.8 1.0 0.6 0.6 0.6 _ Insert tolerance M(±20%) or K(±10%) to complete the Nemco part number NEMCO reserves the right to supply a higher voltage rating, tighter tolerance and/or lower ESR in the same case size, to the same reliability standards. 142 Technology Dr., Suite 150 Irvine, CA 92618 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 Telephone • 949.783.7300 Facsimile • 949.783.7301 PCT SERIES STANDARD AND EXTENDED RANGE TANTALUM CAPACITORS PACKAGING REFERENCE CASE SIZE NEMCO A B C D H Z Low Profile Sizes XL AL BL CL DL 142 Technology Dr., Suite 150 Irvine, CA 92618 CASE SIZE STANDARD PACKAGING AVAILABLE EIA IECQ 7” Reel Quantity 3216-18 3528-21 6032-28 7343-31 7343-43 7361-37 2000 2000 500 500 400 400 8000 8000 3000 2500 1500 1500 2012-12 3216-12 3528-12 6032-15 7343-20 2500 2500 2500 1000 1000 10000 10000 10000 5000 5000 www.suntsu.com SPECIFICATIONS SUBJECT TO CHANGE WITHOUT NOTICE REV. 10/19/20 13” Reel Quantity Telephone • 949.783.7300 Facsimile • 949.783.7301
PCT.33/6AK 价格&库存
很抱歉,暂时无法提供与“PCT.33/6AK”相匹配的价格&库存,您可以联系我们找货
