BX301N
BX301N
    BENCENT(槟城)
    SMD
    陶瓷气体放电管(GDT) SMD
BX301N 数据手册
BX301N Order Code: BX301N Version: A0 2016-9-6 Gas Discharge Tube Exterior Features Small Size Design 4.2×3.5×3.5mm Current Handling Capability 3,000A @ 8/20μs Low Capacitance and Insertion Loss Fast Response and Long Service Life Moisture sensitivity level:Level 1 SMD Application Information Package (Top View) Internet ` 1 Agency Approvals 2 Schematic Symbol Icon Description Compliance with 2011/65/EU 2 1 Compliance with IEC61249-2-21:2003 Mean lead free Electrical Parameter DC Breakdown Voltage 1)2) 100V/s Impulse Spark-over Voltage Impulse Discharge Current 3) Impulse Discharge Voltage 3) 210~390 V At 1kV/μs for 99 % of measured values  850 V At 1kV/μs Typical values of distribution 750 V 8/20μs 10 operations [5x (+) & 5x (-)] 10/700μs 10 operations [5x (+) & 5x (-)] 3,000 A 6,000 V AC Discharge Current 50Hz, 1S, 10times 3 A Arc Voltage At 1A ~10 V Insulation Resistance DC=100V ≥1 GΩ Capacitance at 1MHz VDC=0.5V ≤0.6 pF ~0.23 g -40-90 ℃ Weight Operating And Storage Temperature Marking Without 1) At delivery AQL 0.65 level II ISO 2859 2) In ionized mode 3) Terms and waveforms in accordance with ITU-T Rec. K. 12; IEC 61643-21 1/3 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BX301N Order Code: BX301N Version: A0 2016-9-6 Gas Discharge Tube Product Characteristics Part Numbering System BX 301 (1) (2) N (3) (1)Bencent Gas Discharge Tube (2) Series: DC Breakdown Voltage, e.g.:301=30×101=300V (3) Tolerance of DC Breakdown Voltage, M=+-20%, Lead Material Copper or iron nickel alloy Body Material Ceramics Terminal Finish 100% Matte-Tin Plated N=+-30%,the Specific tolerance is decided by the table of“Electrical Parameter” Environmental Reliability Characteristics Testing items Technical standards Temperature: 90℃ Time:2H Temperature: -40℃ Time:2H Frequency:10-500Hz Amplitude:0.15mm Time:45min Temperature: 260±5℃ Time of dip soldering:10s,1time High Temperature Storage Test Low Temperature Storage Test Vibration Resistance of soldering heat Note: Up-screen program can be specified by customer’s request via contacting Bencent service Solderability Test Solderability Solder Pot Temperature: 245℃±5℃ Solder Dwell Time: 4-6 seconds Product Dimensions D A C REF mm inch A 0.5±0.1 0.020±0.004 B 4.2±0.3 0.165±0.012 C 3.5±0.2 0.138±0.006 D 3.5±0.2 0.138±0.006 REF mm inch A 4.95 0.195 B 3.0 0.118 C 4.2 0.165 B Recommended Soldering Pad A B 2/3 www.bencent.com.cn Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications BX301N C Order Code: BX301N Version: A0 2016-9-6 Gas Discharge Tube Reflow Profile Reflow Condition Heat Temperature Min 150°C Temperature Max 200°C Time (min to max) 60 – 180 secs Average ramp up rate(Liquids)Tamp (TL) to peal TS(max) to TL - Ramp-up Rate 3°C/second max (Liquids) - Temperature (TL) Peak Temperature (TP) 217°C 60 – 150 seconds TL TS(max) Ramp-down Preheat TS(min) tS 260+0/-5 °C Time within 5°C of actual peak ~10 seconds Temperature (tp) Critical Zone TL to TP Ramp-up TL 3°C/second max - Temperature (TL) Reflow tP TP Temperature Pre Pb-Free assembly 25 Ramp-down Rate 6°C/second max Time 25°C to peak Temperature (TP) 8 minutes Max. Do not exceed 260°C Time time to peak temper ature Package Reel Information 3/3 REF mm inch A 3.8±0.1 0.150±0.004 B 4.5±0.2 0.177±0.008 d Φ1.5±0.1 Φ0.059±0.004 P0 4.0±0.1 0.157±0.004 P1 2.0±0.1 0.079±0.004 P 8.0±0.1 0.315±0.004 E 1.75±0.1 0.069±0.004 F 5.0±0.1 0.197±0.004 W 12.0±0.3 0.472±0.012 D Φ330.0 Φ13.0 D1 Φ50Min Φ1.97Min D2 Φ13±0.15 0.512±0.006 W1 16.8±2.0 0.661±0.079 Outline Reel (PCS) Per Carton (PCS) Reel Diameter (mm) TAPING 2,000 32,000 330 www.bencent.com.cn Carton Size(mm) L W H 360 360 385 Specifications are subject to change without notice. Customers should verify actual device performance in their specific applications
BX301N 价格&库存
很抱歉,暂时无法提供与“BX301N”相匹配的价格&库存,您可以联系我们找货
