10D561K
10D561K
    SURGING(绍鑫)
    插件,P=7.5mm
    压敏电阻 插件,P=7.5mm 压敏电压:504V~616V
10D561K 数据手册
Voltage Dependent Resistor 压敏电阻 10D Series http://www.szshaoxin.com/ 绍 鑫 实 业 Metal Oxide Varistors - 10D Series Features 1. Wide operating voltage (V1mA) range from 8V to 1800V. 2. Fast responding to transient over-voltage. 3. Large absorbing transient energy capability. 4. Low clamping ratio and no following-on current. General Information The MOV-07DxxxK Series of 7 mm radial leaded varistor devices protects against overvoltage transients such as lightning, power contact and power induction. The metal oxide varistors offer a choice of varistor voltages from 18 V to 820 V and Vrms voltages from 11 V to 510 V. The devices have a high current handling, high energy absorption capability and fast response times to protect against transient faults up to rated limits. General Characteristics No Radioactive Material Storage Temperature: -55ºC to +125ºC Operating Temperature: -55ºC to +85ºC Body: Nickel Plated Leads: Surface-mount, Axial Devices: Tin Plated Devices with No Leads: Nickel Plated Product Name 1 0 D 4 7 1 Disc Diameter Type Nominal Varistor Voltage 10=10MM D: Disk 1 471=47*10 V K Varistor Voltage Tolerance K = 10 % S: Square http://www.szshaoxin.com/ 绍 鑫 实 业 Metal Oxide Varistors - 10D Series Electriacl Characteristics Type Number Maximum Allowable Voltage Varistor Voltage Maximum Clamping Voltage VAC(V) VDC(V) V1mA(V) IP(A) VC(V) Withstanding Surge Current High Surge Standard High Surge (J) (W) @1KHz(pf) 36 500 1000 2.1 3.0 0.05 5600 43 500 1000 2.5 5.0 0.05 4500 5 53 500 1000 3.0 6.0 0.05 3700 5 66 500 1000 4.0 7.0 0.05 3000 39(35~43) 5 77 500 1000 4.6 9.0 0.05 2400 47(42~54) 5 93 500 1000 5.5 11.0 0.05 2100 45 56(50~62) 5 100 500 1000 7.0 13.0 0.05 1800 56 68(61~75) 5 135 500 1000 8.2 15.0 0.05 1500 65 82(74~90) 25 135 2500 3500 12.0 17.0 0.4 1200 85 100(90~110) 25 165 2500 3500 15.0 18.0 0.4 1000 100 120(108~132) 25 200 2500 3500 18.0 21.0 0.4 830 125 150(135~165) 25 250 2500 3500 22.0 25.0 0.4 670 150 180(162~198) 25 300 2500 3500 27.0 30.0 0.4 560 130 170 200(180~220) 25 340 2500 3500 30.0 35.0 0.4 500 140 180 220(198~242) 25 360 2500 3500 32.0 39.0 0.4 450 10D241KJ 150 200 240(216~264) 25 395 2500 3500 35.0 42.0 0.4 420 10D271KJ 175 225 270(243~297) 25 455 2500 3500 40.0 49.0 0.4 370 10D301K 10D301KJ 190 250 300(270~330) 25 500 2500 3500 40.0 54.0 0.4 330 10D331K 10D331KJ 210 275 330(297~363) 25 550 2500 3500 40.0 58.0 0.4 300 10D361K 10D361KJ 230 300 360(324~396) 25 595 2500 3500 43.0 65.0 0.4 280 10D391K 10D391KJ 250 320 390(351~429) 25 650 2500 3500 47.0 70.0 0.4 260 10D431K 10D431KJ 275 350 430(387~473) 25 710 2500 3500 60.0 80.0 0.4 230 10D471K 10D471KJ 300 385 470(423~517) 25 775 2500 3500 65.0 85.0 0.4 210 10D511K 10D511KJ 320 415 510(459~561) 25 845 2500 3500 70.0 90.0 0.4 200 10D561K 10D561KJ 350 460 560(504~616) 25 925 2500 3500 70.0 92.0 0.4 180 10D621K 10D621KJ 385 505 620(558~682) 25 1025 2500 3500 70.0 95.0 0.4 160 10D681K 10D681KJ 420 560 680(612~748) 25 1120 2500 3500 70.0 98.0 0.4 150 10D751K 10D751KJ 460 615 750(675~825) 25 1240 2500 3500 70.0 100.0 0.4 130 High Surge 10D180K 10D180KJ 11 14 18(15~21.6) 5 10D220K 10D220KJ 14 18 22(19.5~26) 5 10D270K 10D270KJ 17 22 27(24~30) 10K330K 10K330KJ 20 26 33(29.5~36.5) 10D390K 10D390KJ 25 31 10D470K 10D470KJ 30 38 10D560K 10D560KJ 35 10D680K 10D680KJ 40 10D820K 10D820KJ 50 10D101K 10D101KJ 60 10D121K 10D121KJ 75 10D151K 10D151KJ 95 10D181K 10D181KJ 115 10D201K 10D201KJ 10D221K 10D221KJ 10D241K 10D271K I(A) (J) Typical Capacitance (Reference) Standard Standard I(A) Maximum Energy Rated (10/1000μs) Power 10D781K 10D781KJ 485 640 780(702~858) 25 1290 2500 3500 80.0 105.0 0.4 130 10D821K 10D821KJ 510 670 820(738~902) 25 1355 2500 3500 85.0 110.0 0.4 120 10D911K 10D911KJ 550 745 910(819~1001) 25 1500 2500 3500 93.0 130.0 0.4 110 10D102K 10D102KJ 625 825 1000(900~1100) 25 1650 2500 3500 102.0 140.0 0.4 100 10D112K 10D112KJ 680 895 1100(990~1210) 25 1815 2500 3500 115.0 155.0 0.4 90 10D182K 10D182KJ 1000 1465 1800(1620~1980) 25 2970 2500 3500 133.0 250.0 0.4 70 http://www.szshaoxin.com/ 绍 鑫 实 业 Metal Oxide Varistors - 10D Series Electrical Rating ltem Varistor Voltage Test Condition / Description Requirement The voltage between two terminals with the specified measuring current 1mA. DC applied is call Vb. Maximum Allowable The recommended maximum sine wave voltage (RMS) or the maximum DC Voltage voltage can be applied continuously. Rated Wattaget IEnergy The maximum average power that can be applied within the specified ambient temperature. To meet the specified value The maximum energy within the varistor voltage change of ±10% when one impulse of10/1000μsec. or 2 msec. is applied. Withstanding Surge The maximum current within the varistor voltage change of ±10% with the standard Current impulse current (8/20μsec.) applied one time. The change of Vb shall be measured after the impulse listed below is applied 10,000 times continuously with the interval of ten seconds at room temperature. 180K to 680K 10A (8/20μsec.) 820K to 751K 20A (8/20μsec.) 180K to 680K 25A (8/20μsec.) 820K to 821K 50A (8/20μsec.) 180K to 680K 50A (8/20μsec.) 820K to 182K 100A (8/20μsec.) 180K to 680K 75A (8/20μsec.) 820K to 182K 150A (8/20μsec.) 180K to 680K 100A (8/20μsec.) 820K to 182K 200A (8/20μsec.) 5D series 7Dseries Surge Life Vb Vb _
10D561K 价格&库存
很抱歉,暂时无法提供与“10D561K”相匹配的价格&库存,您可以联系我们找货
