SI2302ADS-T1-GE3
www.VBsemi.com
N-Channel 20 V (D-S) MOSFET
FEATURES
PRODUCT SUMMARY
VDS (V)
ID (A)e
RDS(on) (Ω)
0.028 at VGS = 4.5 V
6a
0.042 at VGS = 2.5 V
6a
0.050 at VGS = 1.8 V
5.6
• Halogen-free According to IEC 61249-2-21
Definition
• TrenchFET® Power MOSFET
• 100 % Rg Tested
• Compliant to RoHS Directive 2002/95/EC
Qg (Typ.)
8.8 nC
APPLICATIONS
• DC/DC Converters
• Load Switch for Portable Applications
SOT-23
G
1
3
S
D
2
Top View
ABSOLUTE MAXIMUM RATINGS TA = 25 °C, unless otherwise noted
Parameter
Drain-Source Voltage
Gate-Source Voltage
Symbol
VDS
VGS
TC = 25 °C
TC = 70 °C
TA = 25 °C
Continuous Drain Current (TJ = 150 °C)
Limit
± 12
ID
5b, c
4b, c
IDM
TC = 25 °C
TA = 25 °C
TC = 25 °C
TC = 70 °C
TA = 25 °C
Continuous Source-Drain Diode Current
Maximum Power Dissipation
TA = 70 °C
Operating Junction and Storage Temperature Range
V
6a
5.1
TA = 70 °C
Pulsed Drain Current
Unit
IS
A
1.04b, c
2.1
1.3
PD
W
1.25b, c
0.8b, c
- 55 to 150
260
TJ, Tstg
Soldering Recommendations (Peak Temperature)
°C
THERMAL RESISTANCE RATINGS
Parameter
Maximum Junction-to-Ambientb, d
Maximum Junction-to-Foot (Drain)
t≤5s
Symbol
RthJA
Typical
80
Maximum
100
Steady State
RthJF
40
60
Unit
°C/W
Notes:
a. Package limited
b. Surface Mounted on 1" x 1" FR4 board.
c. t = 5 s.
d. Maximum under steady state conditions is 125 °C/W.
e. Based on TC = 25 °C.
服务热线:400-655-8788
1
SI2302ADS-T1-GE3
www.VBsemi.com
SPECIFICATIONS TJ = 25 °C, unless otherwise noted
Parameter
Symbol
Test Conditions
Min.
VDS
VGS = 0 V, ID = 250 µA
Typ.
Max.
Unit
Static
Drain-Source Breakdown Voltage
VDS Temperature Coefficient
ΔVDS/TJ
V
25
ID = 250 µA
mV/°C
VGS(th) Temperature Coefficient
ΔVGS(th)/TJ
Gate-Source Threshold Voltage
VGS(th)
VDS = VGS , ID = 250 µA
1.0
V
IGSS
VDS = 0 V, VGS = ± 8 V
± 100
nA
VDS = 20 V, VGS = 0 V
1
VDS = 20 V, VGS = 0 V, TJ = 70 °C
10
Gate-Source Leakage
Zero Gate Voltage Drain Current
IDSS
On-State Drain Currenta
ID(on)
Drain-Source On-State Resistancea
Forward Transconductancea
RDS(on)
gfs
VDS ≤ 5 V, VGS = 4.5 V
- 2.6
0.45
µA
A
VGS = 4.5 V, ID = 5.0 A
0.028
VGS = 2.5 V, ID = 4.7 A
0.042
VGS = 1.8 V, ID = 4.3 A
0.050
VDS = 10 V, ID = 5.0 A
24
Ω
S
b
Dynamic
Input Capacitance
Ciss
Output Capacitance
Coss
Reverse Transfer Capacitance
Crss
Total Gate Charge
Qg
Gate-Source Charge
Qgs
Gate-Drain Charge
Qgd
Gate Resistance
Rg
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
Turn-On Delay Time
Rise Time
Turn-Off Delay Time
Fall Time
865
VDS = 10 V, VGS = 0 V, f = 1 MHz
td(off)
pF
55
VDS = 10 V, VGS = 5 V, ID = 5.0 A
12
18
8.8
14
1.1
VDS = 10 V, VGS = 4.5 V, ID = 5.0 A
VDD = 10 V, RL = 2.2 Ω
ID ≅ 4 A, VGEN = 4.5 V, Rg = 1 Ω
0.5
2.4
4.8
8
16
17
26
31
47
tf
8
16
td(on)
5
10
13
32
6
12
tr
td(off)
nC
0.7
f = 1 MHz
td(on)
tr
105
ID ≅ 4 A, VGEN = 5 V, Rg = 1 Ω
tf
Ω
ns
Drain-Source Body Diode Characteristics
IS
Pulse Diode Forward Current
ISM
Body Diode Voltage
VSD
TC = 25 °C
1.75
IS = 4 A, VGS = 0 V
A
0.75
1.2
Body Diode Reverse Recovery Time
trr
12
ns
Body Diode Reverse Recovery Charge
Qrr
5
10
nC
Reverse Recovery Fall Time
ta
Reverse Recovery Rise Time
tb
IF = 4 A, dI/dt = 100 A/µs, TJ = 25 °C
7
5
V
ns
Notes:
a. Pulse test; pulse width ≤ 300 µs, duty cycle ≤ 2 %
b. Guaranteed by design, not subject to production testing.
Stresses beyond those listed under “Absolute Maximum Ratings” may cause permanent damage to the device. These are stress ratings only, and functional operation
of the device at these or any other conditions beyond those indicated in the operational sections of the specifications is not implied. Exposure to absolute maximum
rating conditions for extended periods may affect device reliability.
服务热线:400-655-8788
2
SI2302ADS-T1-GE3
www.VBsemi.com
TYPICAL CHARACTERISTICS 25 °C, unless otherwise noted
5
V GS = 1 0 V t h r u 3 V
4
V GS = 2 . 5 V
I D - Drain Current (A)
15
10
3
2
T C = 25 °C
5
1
T C = 125 °C
V GS = 1 V
0.5
1.0
1.5
T C = - 55 °C
2.0
0.3
V DS - Drain-to-Source Voltage (V)
1.2
1.5
Transfer Characteristics
Output Characteristics
1200
0.045
V GS = 1.8 V
0.040
Ciss
900
0.035
C - Capacitance (pF)
R DS(on) - On-Resistance (Ω)
0.9
0.6
V GS - Gate-to-Source Voltage (V)
V GS = 2.5 V
0.030
V GS = 4.5 V
600
300
0.025
Coss
Crss
10
15
10
15
ID - Drain Current (A)
On-Resistance vs. Drain Current and Gate Voltage
Capacitance
5
4
V DS = 10 V
3
V DS = 5 V
2
V DS = 16 V
V GS = 2.5 V, I D = 4.7 A
1.45
(Normalized)
VGS - Gate-to-Source Voltage (V)
ID = 5 A
1.20
V GS = 4.5 V, I D = 5 A
0.95
1
4
6
Qg - Total Gate Charge (nC)
Gate Charge
服务热线:400-655-8788
8
10
0.70
- 50
- 25
50
75
100
125
150
T J - Junction Temperature (°C)
On-Resistance vs. Junction Temperature
3
SI2302ADS-T1-GE3
www.VBsemi.com
100
0.06
I S - Source Current (A)
ID = 5 A
T J = 150 °C
10
T J = 25 °C
1
0.05
0.04
T J = 125 °C
0.03
T J = 25 °C
0.02
0.1
0.0
0.3
0.6
0.9
1.2
4
6
8
V SD - Source-to-Drain Voltage (V)
On-Resistance vs. Gate-to-Source Voltage
Source-Drain Diode Forward Voltage
32
0.9
0.7
24
Power (W)
VGS(th) (V)
ID = 250 μA
0.5
0.3
0.1
- 50
16
8
- 25
50
75
100
125
150
0.01
0.1
1
10
100
Time (s)
T J - Temperature (°C)
Single Pulse Power (Junction-to-Ambient)
Threshold Voltage
100
Limited by R DS(on)*
10
100 μs
1 ms
1
10 ms
TA = 25 °C
Single Pulse
100 ms
0.1
1 s, 10 s
DC
BVDSS Limited
0.01
0.1
1
10
100
* V GS > minimum VGS at which RDS(on) is specified
Safe Operating Area, Junction-to-Ambient
服务热线:400-655-8788
4
SI2302ADS-T1-GE3
www.VBsemi.com
7.5
6.0
Package Limited
4.5
3.0
1.5
0.0
50
75
100
125
150
T C - Case Temperature (°C)
Current Derating*
2.5
1.2
2.0
1.5
Power (W)
Power (W)
0.9
1.0
0.6
0.3
0.5
0.0
0.0
50
75
100
125
150
50
75
100
125
TA - Ambient Temperature (°C)
Power Derating, Junction-to-Foot
Power Derating, Junction-to-Ambient
150
* The power dissipation PD is based on TJ(max.) = 150 °C, using junction-to-case thermal resistance, and is more useful in settling the upper
dissipation limit for cases where additional heatsinking is used. It is used to determine the current rating, when this rating falls below the package
limit.
服务热线:400-655-8788
5
SI2302ADS-T1-GE3
www.VBsemi.com
1
Normalized Effective Transient
Thermal Impedance
Duty Cycle = 0.5
0.2
0.1
Notes:
0.05
PDM
0.1
t1
0.02
t2
1. Duty Cycle, D =
t1
t2
2. Per Unit Base = R thJA = 125 °C/W
3. T JM - TA = PDMZthJA(t)
Single Pulse
0.01
10 -4
4. Surface Mounted
10 -3
10 -2
10 -1
1
10
100
1000
10 000
Square Wave Pulse Duration (s)
Normalized Thermal Transient Impedance, Junction-to-Ambient
Thermal Impedance
1
Duty Cycle = 0.5
0.2
0.1
0.02
Single Pulse
0.05
0.1
10 -4
10 -3
10 -2
10 -1
1
10
Normalized Thermal Transient Impedance, Junction-to-Foot
服务热线:400-655-8788
6
SI2302ADS-T1-GE3
www.VBsemi.com
SOT-23 (TO-236): 3-LEAD
b
3
E1
1
E
2
e
S
e1
D
0.10 mm
C
0.004"
A2
A
C
q
Gauge Plane
Seating Plane
Seating Plane
C
A1
Dim
0.25 mm
L
L1
MILLIMETERS
INCHES
Min
Max
Min
Max
A
0.89
1.12
0.035
0.044
A1
0.01
0.10
0.0004
0.004
A2
0.88
1.02
0.0346
0.040
b
0.35
0.50
0.014
0.020
c
0.085
0.18
0.003
0.007
D
2.80
3.04
0.110
0.120
E
2.10
2.64
0.083
0.104
E1
1.20
1.40
0.047
e
0.95 BSC
e1
L
1.90 BSC
0.40
L1
q
0.0748 Ref
0.60
0.016
0.64 Ref
S
0.024
0.025 Ref
0.50 Ref
3°
0.055
0.0374 Ref
0.020 Ref
8°
3°
8°
ECN: S-03946-Rev. K, 09-Jul-01
DWG: 5479
服务热线:400-655-8788
7
SI2302ADS-T1-GE3
www.VBsemi.com
0.049
(1.245)
0.029
0.022
(0.559)
(0.724)
0.037
(0.950)
(2.692)
0.106
RECOMMENDED MINIMUM PADS FOR SOT-23
0.053
(1.341)
0.097
(2.459)
Recommended Minimum Pads
Dimensions in Inches/(mm)
Return to Index
服务热线:400-655-8788
8
SI2302ADS-T1-GE3
www.VBsemi.com
Disclaimer
All products due to improve reliability, function or design or for other reasons, product specifications and
data are subject to change without notice.
Taiwan VBsemi Electronics Co., Ltd., branches, agents, employees, and all persons acting on its or their
representatives (collectively, the "Taiwan VBsemi"), assumes no responsibility for any errors, inaccuracies or
incomplete data contained in the table or any other any disclosure of any information related to the
product.(www.VBsemi.com)
Taiwan VBsemi makes no guarantee, representation or warranty on the product for any particular purpose of
any goods or continuous production. To the maximum extent permitted by applicable law on Taiwan VBsemi
relinquished: (1) any application and all liability arising out of or use of any products; (2) any and all liability,
including but not limited to special, consequential damages or incidental ; (3) any and all implied warranties,
including a particular purpose, non-infringement and merchantability guarantee.
Statement on certain types of applications are based on knowledge of the product is often used in a typical
application of the general product VBsemi Taiwan demand that the Taiwan VBsemi of. Statement on whether the
product is suitable for a particular application is non-binding. It is the customer's responsibility to verify specific
product features in the products described in the specification is appropriate for use in a particular application.
Parameter data sheets and technical specifications can be provided may vary depending on the application and
performance over time. All operating parameters, including typical parameters must be made by customer's
technical experts validated for each customer application. Product specifications do not expand or modify Taiwan
VBsemi purchasing terms and conditions, including but not limited to warranty herein.
Unless expressly stated in writing, Taiwan VBsemi products are not intended for use in medical, life saving,
or life sustaining applications or any other application. Wherein VBsemi product failure could lead to personal
injury or death, use or sale of products used in Taiwan VBsemi such applications using client did not express their
own risk. Contact your authorized Taiwan VBsemi people who are related to product design applications and
other terms and conditions in writing.
The information provided in this document and the company's products without a license, express or implied,
by estoppel or otherwise, to any intellectual property rights granted to the VBsemi act or document. Product
names and trademarks referred to herein are trademarks of their respective representatives will be all.
Material Category Policy
Taiwan VBsemi Electronics Co., Ltd., hereby certify that all of the products are determined to be
oHS compliant and meets the definition of restrictions under Directive of the European Parliament
2011/65 / EU, 2011 Nian. 6. 8 Ri Yue restrict the use of certain hazardous substances in electrical and
electronic equipment (EEE) - modification, unless otherwise specified as inconsistent.(www.VBsemi.com)
Please note that some documents may still refer to Taiwan VBsemi RoHS Directive 2002/95 / EC. We
confirm that all products identified as consistent with the Directive 2002/95 / EC European Directive
2011/65 /.
Taiwan VBsemi Electronics Co., Ltd. hereby certify that all of its products comply identified as
halogen-free halogen-free standards required by the JEDEC JS709A. Please note that some Taiwanese
VBsemi documents still refer to the definition of IEC 61249-2-21, and we are sure that all products
conform to confirm compliance with IEC 61249-2-21 standard level JS709A.
