TEVC3R0V05B1X
TEVC3R0V05B1X
    TOP-EMC(韬略)
    SOD523
    ESD抑制器/TVS二极管 SOD-523 双向
TEVC3R0V05B1X 数据手册
TEVC3R0V05B1X ESD SUPPRESSOR Mechanical Characteristics Features 44W Peak Pulse Power Per Line(8/20us) 5V Working Peak Reverse Voltage Maximum Reverse Peak Pulse Current:4A ESD per IEC 61000-4-2(Contact):20KV ESD per IEC 61000-4-2(Air):30KV Clamping Voltage @IPP=1A:8V Junction Capacitance:3PF Package:SOD-523(0603) Polarity: Bidrectional Mechanical Characteristics Lead Finish: NiPdAu Case Material: “Green” Molding Compound. UL Flammability Classification Rating 94V-0 Moisture Sensitivity: Level 3 per J-STD-020 Terminal Connections: See Diagram Below Marking Information: See Below z z z z z z z 择 z z z z z z z z z 最 佳 选 Schematic And Configuration 的 Ordering Information Packaging Reel Size TEVC3R0V05B1X Tape&Reel 7inch MC 方 案 Part Number -E Absolute Maximum Ratings(Ta=25℃,RH=45%-75%,unless otherwise noted) Symbol 技 Parameter -55 ̄+125 ℃ Tstg -55 ̄+150 ℃ 科 韬 略 Unit Tj Operating Temperature Range Storage Temperature Range Value Electrical Characteristics (Ta=25℃) Parameter Parameter Symbol Symbol Reverse Working Voltage Vrwm Breakdown Voltage Vbr Reverse Leakage Current Ir Clamping Voltage Vc Juntion Capacitance Cj Min Min Typ Type Max Max Unit Unit 5 V TestCondition Condition Test V It=1mA 0.1 uA Vrwm=5V 8 9.8 V Ipp=1A(8×20us pulse) 3 4.5 pF Vr=0V,f=1MHz 6.8 1/4 www.topleve.com G TEVC3R0V05B1X 韬 略 科 技 -E MC 方 案 的 最 佳 选 择 Typical Performance Characteristics (Ta=25℃,unless otherwise noted) 2/4 www.topleve.com TEVC3R0V05B1X Soldering Parameters Reflow Condition Pre Heat Pb-Free Assembly Pb-Free assembly (see bellow) (see asas bellow) Reflow Condition -Temperature Min (Ts(min)) +150℃ -Temperature Max(Ts(max)) +200℃ -Time (Min to Max) (ts) 60-180 secs. Average ramp up rate (Liquid us Temp (TL) to peak) 3℃/sec. Max Ts(max) to TL - Ramp-up Rate 3℃/sec. Max -Temperature(TL) (Liquid us) +217℃ -Temperature(tL) 60-150 secs. 择 Reflow +260(+0/-5)℃ 选 Peak Temp (Tp) Time within 5℃ of actual Peak Temp (tp) 佳 30 secs. Max 最 Ramp-down Rate 案 的 Time 25℃ to Peak Temp (TP) 8 min. Max +260℃ 韬 略 科 技 -E MC 方 Do not exceed 6℃/sec. Max 3/4 www.topleve.com TEVC3R0V05B1X Package Mechanical Data DIMENSIONS A MILLIMETERS MIN NOM MAX 0.51 0.77 INCHES MIN NOM MAX 0.020 0.031 A1 0.50 - 0.70 0.020 - 0.028 b 0.25 - 0.35 0.010 - 0.014 c 0.08 - 0.15 0.003 - 0.006 D 0.75 - 0.85 0.030 - 0.033 E 1.10 - 1.30 0.043 - 0.051 E1 1.50 - 1.70 0.059 - 0.067 SYM 0.20REF L 0.01 - 0.008REF 0.07 择 E2 0.001 7°REF - 0.003 7°REF 最 佳 选 Φ 韬 略 科 技 -E MC 方 案 的 Suggested Land Pattern Contact Information SHENZHEN TECHNOLOGY CO.,LTD ContactTOP-FLIGHT Information 4th Floor, C Building, Quansen Industrial Park , Bulong Road, Longhua New District, Shenzhen Tel: 86-755-82908191 Fax: 86-755-82908701 Email:kang@topleve.com Website: http ://www.topleve .com www.topleve.com 4/4
TEVC3R0V05B1X 价格&库存
很抱歉,暂时无法提供与“TEVC3R0V05B1X”相匹配的价格&库存,您可以联系我们找货
