ES1AL THRU ES1JL
HD FL 50
SOD-1 23FL Plastic-Encapsulate Diodes
Super Fast Recovery Rectifier Diode
Features
●Io
1A
SOD-1 23FL
●VRRM
50V-600V
●High surge current capability
●Glass passivated chip
● Polarity: Color band denotes cathode
Applications
● Rectifier
Marking
● ES1AL-ES1DL : ESL
● ES1EL-ES1GL : ESM
● ES1JL : ESH
Item
Symbol Unit
ES1
Test Conditions
AL BL CL
DL
EL
GL
JL
Repetitive Peak Reverse Voltage
VRRM
Maximum RMS Voltage
VRMS
Average Forward Current
IF(AV)
A
Surge(Non-repetitive)Forward
Current
IFSM
A
TJ
-55~+150
TSTG
-55 ~ +150
Junction Temperature
Storage Temperature
V
50
100
150 200
300
400
600
35
70
105 140
210
280
420
1.0
90
60Hz Half-sine wave ,1 cycle ,
Ta =25℃
30
Electrical Characteristics (T=25℃ Unless otherwise specified)
Item
Symbol
Unit
Peak Forward Voltage
VF
V
Maximum reverse recovery
time
trr
ns
Peak Reverse Current
Thermal
Resistance(Typical)
IRRM1
I
μA
RθJ-A
Test Condition
IF =1.0A
ES1
AL BL CL
EL
0.95
IF=0.5A,IR=1.0A,Irr=0.25A
GL
1.25
JL
1.70
35
Ta =25℃
5
Ta =125℃
100
Between junction and ambient
70
Between junction and terminal
25
VRM=VRRM
℃/W
RθJ-L
DL
1)
1)
Notes:
(1)
Thermal resistance between junction and ambient and between junction and lead mounted on P.C.B with 3mm*3mm
copper pad areas.
High Diode Semiconductor
1
Typical Characteristics
FIG.2: MAXIMUM NON-REPETITIVE FORWARD URGE CURRENT
IFSM(A)
IO(A)
FIG.1: FORWARD CURRENT DERATING CURVE
1.0
0.8
30
24
8.3ms Single Half Sine Wave
JEDEC Method
0.6
18
0.4
12
0.2
6
Single Phase
Half Wave 60Hz
Resistive Load
150
Ta(℃)
100
1
2
Number of Cycles
FIG.4:TYPICAL REVERSE CHARACTERISTICS
IR(uA)
FIG.3: TYPICAL FORWARD CHARACTERISTICS
IF(A)
10
100
TJ=25℃
Pulse width=300us
1% Duty Cycle
1000
Tj=150℃
ES1AL-ES1DL
10
100
Tj=125℃
ES1EL-ES1GL
1.0
10
ES1JL
0.1
1.0
Tj=25℃
0.01
0.4
0.1
0.6
0.8
1.0
1.2
1.4
1.6
VF(V)
60
80
100
Voltage(%)
FIG.5: Diagram of circuit and Testing wave form of reverse recovery time
I
D
trr
IF
VR
IF
RL
t
IRR
IR
2
SOD-1 23FL
1.8± 0.1
1.0 ±0.15
Cathode Band
Top View
1.3± 0.1
0.12-0.20
2.8 ±0.15
0.8±0.1
3.7 ±0.15
Dimensions in millimeters
SOD-1 23FL
1.4
2.85
1.2
JSHD
JSHD
3
Reel Taping Specifications For Surface Mount Devices-SOD-123FL
SOD-123FL
50
1.969
4
很抱歉,暂时无法提供与“ES1JL”相匹配的价格&库存,您可以联系我们找货
