BT137
FSSeries
8.0A 4Quadrants TRIACs
Product Summary
Symbol
Value
Unit
IT(RMS)
8.0
A
VDRM VRRM
600 / 800
V
VTM
1.55
V
Feature
Application
With high ability to withstand the shock loading of
large current,With high commutation performances,
4 quadrants products especially recommended for
use on inductive load.
Washing machine, vacuums, massager, solid state
relay, AC Motor speed regulation and so on.
Package
Circuit diagram
TO-220C
Marking
BT137
600E
XXXX
www.fuxinsemi.com
Page 1
Ver2.1
BT137
FSSeries
Absolute maximum ratings (Ta=25℃ unless otherwise noted)
Parameter
Symbol
Value
Unit
Repetitive peak off-state voltage
VDRM
600 / 800
V
Repetitive peak reverse voltage
VRRM
600 / 800
V
RMS on-state current
IT(RMS)
8
A
ITSM
65
A
I2t
21
A2s
Non repetitive surge peak on-state current
(full cycle, F=50Hz)
I2t value for fusing (tp=10ms)
Critical rate of rise of on-state current (IG =2×IGT)
Peak gate current
dIT/dt
Ⅰ-Ⅱ-Ⅲ
50
Ⅳ
10
A/μs
IGM
2
A
PG(AV)
0.5
W
Junction Temperature
TJ
-40 ~ +125
Storage Temperature
TSTG
-40 ~ +150
Average gate power dissipation
Electrical characteristics (TA=25 oC, unless otherwise noted)
Parameter
Symbol
Test Condition
Gate trigger current
IGT
Gate trigger voltage
VGT
Gate non-trigger voltage
VGD
VD =VDRM Tj =125℃
latching current
IL
VD =12V IGT = 0.1A
Holding current
IH
Critical-rate of rise
of commutation voltage
dVD/dt
VD =12V IT = 0.1A
Tj =25℃
Value
Ⅰ-Ⅱ-Ⅲ
Ⅳ
Ⅰ-Ⅱ-Ⅲ-Ⅳ
Tj =25℃
Ⅰ-Ⅲ-Ⅳ
Ⅱ
MAX.
Unit
10
25
mA
MAX.
1.3
V
MIN.
0.2
V
MAX.
25
35
mA
MAX.
mA
VD=2/3VDRM Gate Open Tj =125℃
MIN.
V/μs
ITM =10A tp=380μs
MAX.
1.55
V
Tj=25℃
MAX.
5
μA
Tj=125℃
MAX.
1
mA
Ⅰ-Ⅱ-Ⅲ-Ⅳ
STATIC CHARACTERISTICS
Forward "on" voltage
VTM
Repetitive Peak Off-State Current
IDRM
Repetitive Peak Reverse Current
IRRM
VD =VDRM VR =VRRM
THERMAL RESISTANCES
Thermal resistance
www.fuxinsemi.com
Rth(j-c)
Junction to case(AC)
TYP.
1.6
℃/W
Rth(j-a)
Junction to ambient
TYP.
60
℃/W
Page 2
Ver2.1
BT137
FSSeries
Typical Characteristics
FIG.2: RMS on-state current versus case temperature
(full cycle)
12
I T(RMS) (A)
P(W)
FIG.1: Maximum power dissipation versus RMS
on-state current (full cycle)
10
8
9
8
7
6
5
6
4
4
3
2
2
1
4
6
8
I T(RMS) (A)
100
Tc
150
FIG.4: On-state characteristics (maximum values)
FIG.3: Surge peak on-state current versus number of cycles
I TMS (A)
I TM (A)
70
60
25
Tj=125ºC
15
40
30
10
Tj=25ºC
5
10
100
Number of cycles
0.5
1.0
FIG.5: Non-repetitive surge peak on-state current for
a sinusoidal pulse with width tp < 10ms
1.5
2.0
2.5
3.0
V TM (V)
FIG.6: Relative variations of gate trigger current, holding
current and latching current versus junction
temperature (typical values)
3.0
I GT,I H,I L(T) / I GT,I H,I L(T=25
I TMS (A)
1000
2.5
2.0
100
1.5
IH
IGT
IL
1.0
0.5
10
0.01
www.fuxinsemi.com
Tj(ºC)
0.1
1
10
tp(ms)
0.0
-40
-20
60
80
100
120
140
Tj
Page 3
Ver2.1
BT137
FSSeries
Ordering Information
BT 137
_
600
E
Triacs
E:I GT1-3 ≤10mA I GT4 ≤25mA
IT(RMS): 8A
600:VDRM /VRRM≥600V
800:VDRM /VRRM≥800V
TO-220C Package Information
Symbol
A
A1
b
b1
c
c1
D
e
www.fuxinsemi.com
Page 4
Dimensions In Millimeters
Min.
Max.
9.700
10.300
2.150
2.550
0.710
0.910
1.170
1.370
0.350
0.650
1.200
1.400
25.100
27.100
2.540 TYP.
Ver2.1
很抱歉,暂时无法提供与“BT137-600E”相匹配的价格&库存,您可以联系我们找货
