LM321MFX
3
LOW POW ER SINGLE OPERATIONAL AMPLIFIER
www.sot23.com.tw
GENERAL DESCRIPTION
These devices consist of two independent, high gain, internally
frequency-compensated operational amplifiers designed operate from a single supply over
a wide range of voltages. Operation from split supplies also is possible if the difference
between the two supplies is 3V to 36V, and VCC is at least 1.5V more positive than the
input common-mode voltage, the low supply-current drain is independent of the magnitude
of the power supply voltage.
Applications
One internally compensated OP amps
Wide power supply range: 3V to 36V
Large output voltage swing: 0V to Vcc-1.5V
Low input bias current
Low input offset voltage and offset current
Internally frequency compensated for unity gain
Short Circuit Protected Outputs
Input common-mode voltage range includes ground
SOT-23-5L package
s
电
子
Features
2021.6.15
(TOP VIEW)
+IN
1
-VS
2
-IN
3
5
+VS
4
OUT
台
舟
Pin Assignments
_
SOT-23-5
1
Multivibrators
Oscillators
Switcching Telephone
Portable Systems
LM321MFX
3
www.sot23.com.tw
Absolute Maximum Ratings
Symbol
Rating
Unit
Power Supply Voltage (Single Supply)
VCC
40
V
Power Supply Voltage (Split Supplies)
Vcc, Vss
±20
V
Input Differential Voltage Range
VIDR
±20
V
Input Common Mode Voltage Range
VICR
-0.3 to VCC
V
Output Short Circuit Duration
TSC
Continuous
PD
500
mW
TST
-55 to +165
°C
TOPJ
-40 to +125
°C
TJ
150
°C
θJC
110
°C/W
θJA
250
°C/W
子
Characteristics
Power Dissipation
Storage Temperature Range
Operating Junction Temperature
Junction Temperature Range
Thermal Resistance from Junction to case
台
舟
电
Thermal Resistance from Junction to ambient
2021.6.15
2
LM321MFX
3
www.sot23.com.tw
Electrical Characteristics
(VCC = 5V, TA=25°C, unless otherwise specified)
Typ Max Units
Symbol
Conditions (Note1)
Min
Input offset voltage(Note2)
VIO
VCC=5V to Max, VIC=VICR
min, VO=1.4V
1
5
Average temperature coefficient
of input offset voltage
αVIO
7
VO=1.4V
2
IIN+ or IIN-
子
Characteristics
Input offset current
IIO
of input offset current
αIIO
Input bias current
IIB
Common-mode input voltage
range
Low-level output voltage
Large-signal differential voltage
amplification
Common-mode rejection ratio
VOL
Crosstalk attenuation
台
Output current
Short-circuit output current
Supply current
2021.6.15
-20 -250 nA
VCC=Max, RL≧10KΩ
27
28
5
KSVR VCC=5V to Max
VOUT F=1KHz to 20KHz
ICC
- pA/°C
26
VCC=15V, VO=1V to 11V,
RL≧2KΩ
CMRR VCC=5V to Max,
VIC=VICR min.
IOS
10
VCC=Max, RL=2KΩ
RL≧10KΩ
nA
AVD
IO
50
舟
Supply voltage rejection ratio
(△VCC/△VIO)
VOH
mV
- uV/°C
0 to
VCC-1.5
VCC=5V to Max
电
High-level output voltage
VICR
11
V
V
mV
25
100 -
V/mV
65
80
dB
65
100 -
dB
120 -
dB
VCC=15V, VID=1V,
VO=0V
-20
VCC=15V, VID= -1V,
VO=2V
10
VID= -1V, VO=200mV
12
30
uA
VCC =15V, VO=0V
40
mA
VO-2.5V, No Load
0.7 1.2
VCC=Max, VO=0.5VCC,
No Load
3
-30
mA
1
2
mA
LM321MFX
3
www.sot23.com.tw
APPLICATION CIRCUIT
Non Inverting DC Amplifier
Volgate Follower
VIN
子
VO
VO
VIN
R2
R1
AV=1+R1/R2
Square-wave Oscillator
DC Summing Amplifier
电
V1
R
V2
VO
R
V3
VO
R
V4
VIN
VO=V1+V2-V3-V4
Where (V1+V2)≧(V3+V4)
To Keep VO≧0V
R
R
R
DC Coupled Low-Pass RC Active Filter
Pulse Generator
舟
C
R
VIN
R
R
C
VO
R
VO
C
R
R
2021.6.15
R
R
R
台
F0=1KHz, Q=1, AV=2
VIN
4
LM321MFX
3
www.sot23.com.tw
TypicalwPerformancewcharacteristics
Temperature vs. Input Offset Voltage
VCC vs. Input Offset Voltage
3
8
7
6
5
4
3
2
1
-20
60
80
100
0.9
0.8
0.7
0.6
10
15
30
35
40
35
40
VCC (V)
VCC vs. Input Bias Current
舟
0.5
5
10
15
台
Icc (mA)
0.5
5
Intput Bias Current (nA)
1
0.3
1
0.4
1.5
电
1.2
2
Temperature (℃)
VCC vs. Icc
2.5
子
9
Input Offset Voltage (mV)
10
VCC (V)
30
35
-5
-10
-15
-20
Iib1
Iib2
-25
40
5
10
15
VCC (V)
30
LM321MFX
3
www.sot23.com.tw
Package Information
SOT-23-5
1.90
D
E1
电
子
e1
2.59
E
0.99
b
e
0.69
0.95
RECOMMENDED LAND PATTERN (Unit: mm)
L
A
A1
θ
舟
A2
台
Symbol
Dimensions
In Millimeters
MIN
MAX
0.2
Dimensions
In Inches
MIN
MAX
A
1.050
1.250
0.041
0.049
A1
0.000
0.100
0.000
0.004
A2
1.050
1.150
0.041
0.045
b
0.300
0.500
0.012
0.020
c
0.100
0.200
0.004
0.008
D
2.820
3.020
0.111
0.119
E
1.500
1.700
0.059
0.067
E1
2.650
2.950
0.104
0.116
e
0.950 BSC
0.037 BSC
e1
1.900 BSC
0.075 BSC
L
0.300
0.600
0.012
0.024
θ
0°
8°
0°
8°
5
c
很抱歉,暂时无法提供与“LM321MFX”相匹配的价格&库存,您可以联系我们找货
