RSS series
METAL OXIDE FILM RESISTORS, FLAMEPROOF (SMALL TYPE)
Features
1. High power, Small body size.
2. Electrical and mechanical stability and high reliability.
3. Nonflame painting, Solvent proof, resistant to heat &
humidity.
4. Annual shift is low for the strengthened metal oxide film.
5. Low noise can produce high resistance values which
wire wound resistors can not reach.
1.
2.
3.
4.
5.
ELECTRICAL AND MECHANICAL PERFORMANCE
Characteristics
Resistance Tolerance
Resistance Temp. Coeff.
Power Rating Load
Short Time Overload
Dielectric Withstanding Voltage
Insulation Resistance
Terminal Strength
Test Methods
Standards
5% ( J ) or
2% ( G)
300 ppm /
-55
Surface temp. 275 Max.
275 , R/R
1%
~ 155
Rated voltage for 30 minutes
/ 30
2.5 times of rated voltage
for 5 seconds.
2.5
/5
2%
No evidence of mechanical damage
or insulation breakdown.
1,000MÙ
Max. Working Voltage for 1 min.
1
DC100V or 500V megger
No evidence of mechanical damage.
Minimum 95% coverage
95%
Resistance to Soldering Heat
, R/R
1%
Solder-ability
< 1/2W
1 kg
> 1W
2.5 kg
235 5
for 2 seconds
270 5 for 10 1 seconds
350 10 for 3.5 0.5 seconds
ENVIRONMENTAL CHARACTERISTICS
Characteristics
Standards
Temp. Cycle
R/R
1%
Load Life
R/R
5%
Moisture-proof Load Life
R/R
5%
Nonflammability
Reference Standards
IEC 60115-4
JIS C 5201-4
not flamed
25
Test Methods
-55 ( 30 min.)
Room Temp.( 3 min.)
+155 ( 30 min.)
Room Temp.( 3 min.) / ( 5 cycles)
Rated power load 90 minutes ON
30 minutes OFF
70 1000 hours
30 minutes OFF
40 95% RH 500 hours
16 times of rated wattage for 5 min.
RSS series
Dimensions
Unit mm
Rated
Wattage D 1
H
L
H
D
H 3
Max.
Working
Voltage
Max.
Overload
Voltage
2.6 0.5
6.8
28
0.6
0.22~33K
250V
400V
1W
3.5
9
28
0.65 0.22~50K
350V
600V
2W
4.5
11
28
0.8
0.22~50K
350V
600V
3W
5.0
15
28
0.8
0.22~50K
350V
600V
5W
8.5
24
38
0.8
0.22~100K
500V
800V
6W
8.5
32
33
0.8
0.22~150K
500V
800V
7W
8.5
41
38
0.8
0.22~200K
750V
1000V
10W
8.5
53
38
0.8
0.22~200K
800V
1500V
1/2W
d
L 1
Resistance
d 0.1
(Ù)
Note: 1. Too low or too high ohmic values can be supplied only case by case.
2. If high resistance values are required, we suggest using RDN series.
3. 0.22 ~ 9.1Ù are using alloy film.
Rate Continuous Working Voltage ( RCWV ) shall be determined
Rated Power X Resistance Value or Max. Working Voltage listed above,
whichever less.
Derating Curve
Surface Temperature Rise
For resistors operated in ambient temperatures above 70 ,
power rating must be derated in accordance with the curve
below.
-55
70
(OC)
100
Rated Load
80
60
40
100
155
150
200
250
300
10W
5~7W
200
3W
2W
1W
100
1/2W
275
Ambient Temp.
(OC)
60
80
100
Rated Load
How to order
It is composed by Type, Rated Wattage, Nominal Resistance, Tolerance and Package. e.g.
RSS
a.
1W
b.
10R
c.
J
d.
T/B
e.
a. Type(
): Metal Oxide Film Resistors, Flameproof (Small Type) are called "RSS".
b. Rated Wattage(
) : Shown by "W", such as 1/2W, 1W, 2W, 3W, 5W, 6W,
7W, 10W.
c. Nominal Resistance(
) : 10Ù.
d. Tolerance(
): G
2% , J
5% .
e. Package (
T/R tape & reel (
); T/B tape in box(
); Nil Bulk(
26
很抱歉,暂时无法提供与“RSS 2W 300R J T/B”相匹配的价格&库存,您可以联系我们找货
