SF28G
SF28G
    DY(迪一电子)
    DO-15(DO-204AC)
    直流反向耐压(Vr):600V;平均整流电流(Io):2A;正向压降(Vf):1.7V;反向恢复时间(trr):35ns;
SF28G 数据手册
SF21G THRU SF28G 2.0 AMP. G lass Passiv ated Sup er Fast Rectiers Features ·Low forward voltage drop Case: DO-15 ·High current capability ·High reliability ·High surge current capability MIN. DIA. Mechanical Data · Case: Molded plastic DO-15 · Terminals: Plated leads solderable per MIL-STD-202,Method 208 guaranteed DIA. · Polarity: Color band dentes cathode end MIN. · Mounting Position: Any · Making: Type Number · Lead Free: For RoHS/Lead Free Version Dimensions in inches and (millimeters) Maximum Ratings and Electrical Characteristics Rating at 25℃ ambient temperature unless otherwise specified Single phase,half wave,60Hz,resistive or inductive load For capacitive load derate current by 20% Type Number SYMBOL SF21G SF22G SF23G SF24G SF25G SF26G SF28G Unit Maximum Recurrent Peak Reverse Voltage VRM 50 100 150 200 300 400 600 V Maximum RMS Voltage VRMS 35 70 105 140 210 280 420 V Maximum DC Blocking Voltage VDC 50 100 150 200 300 400 600 V Average Rectified Output Current (Note 1) @TL =100 ℃ Peak Forward Surge Current 8.3ms Single half sine-wave superimposed on rated load (JEDEC Method) I2t Rating for Fusing (t < 8.3ms) Forward Voltage @IF=2.0A Peak Reverse Current @TA=25℃ At Rated DC Blocking Voltage @TA=125℃ Maximum Reverse Recovery Time (Note2 ) Typical Junction Capacitance (Note 3) Typical Thermal Resistance Junction to Ambient (Note 4) Operating Temperature Range Storage Temperature Range IF(AV) 2.0 A IFSM 50 A 10.375 A2s V I 2t VFM 0.95 1.3 5.0 IR 100 uA TRR 35 nS Cj 25 pF RθJA 25 ℃/W Tj -55 to + 150 ℃ TSTG -55 to + 150 ℃ Note: 1. Leads maintained at ambient temperature at a distance of 9.5mm from the case 2.Reverse Recovery Test Conditions: IF=0.5A, IR=1.0A, IRR=0.25A 3. Measured at 1.0 MHz and Applied reverse Voltage of 4.0V D.C 4.Thermal Resistance from Junction to Ambient at 0.375(9.5mm) lead length. version:05 1.7 1 of 3 SF21G THRU SF28G 2.0 AMP. G lass Passiv ated Sup er Fast Rectiers FIG.2-TYPICAL FORWARD CHARACTERISTICS 100 1.5 1.0 0.5 0 25 50 75 100 125 150 175 INSTANTANEOUS FORWARD CURRENT (A) AVERAGE FORWARD CURRENT AMPERES (A) 2.0 LEAD TEMPERATURE, ℃ SF21G-SF24G 10 SF25G-SF26G SF28G 1.0 T A = 25°C PULSE WIDTH 300us 0.1 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 INSTANTANEOUS FORWARD VOLTAGE V ) FIG.4 – TYPICAL JUNCTION CAPACITANCE 100 80 60 CAPACITANCE, (pF) SF21G-SF24G 40 20 PULSE WIDTH 8.3ms SINGLE HALF-SINE-WAVE (JEDEC METHOD) SF25G -SF28G 10 0 1 2 5 10 20 50 T A = 25°C 100 f = 1 MHz NUMBER OF CYCLES AT 60Hz 1 1 4 100 10 REVERSE VOLTAGE V ) 2 of 3 ( PEAK FORWARD SURGE CURRENT, AMPERES (A) FIG. 3 – MAXIMUM NON-REPETITIVE SURGE CURRENT version:05 2.0 ( FIG. 1 – FORWARD CURRENT DERATING CURVE 2.5 SF21G THRU SF28G 2.0 AMP. G lass Passiv ated Sup er Fast Rectiers Important Notice and Disclaimer •Reproducing and modifying information of the document is prohibited without permission from XINNUO. •XINNUO reserves the right to make changes to this document and its products and specifications • XINNUO disclaims any and all liability arising out of the application or use of any product including damages incidentally and consequentially occurred. •XINNUO does not assume any and all implied warranties, including warranties of fitness for particular purpose, non-infringement and merchantability. Applications shown on the here in document are examples of standard use and • operation. Customers are responsible in comprehending the suitable use in particular applications. XINNUO makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. •The products shown here in are not designed and authorized for equipments requiring high level of reliability or relating to human life and for any applications concerning life-saving or life-sustaining, such as medical instruments, transportation equipment, aerospace machinery et cetera. Customers using or selling these products for use in such applications do so at their own ris k andagree to fully indemnify XINNUO for any damages resulting from such improper use or sale. •Since XINNUO uses lot number as the tracking base, please provide the lot number for tracking when complaining. version:05 3 of 3
SF28G 价格&库存
很抱歉,暂时无法提供与“SF28G”相匹配的价格&库存,您可以联系我们找货
SF28G
  • 20+0.15323
  • 200+0.12203
  • 600+0.10470
  • 3000+0.09014
  • 9000+0.08112
  • 21000+0.07627
库存:112
