HT4580A
DUAL OPERATIONAL AMPLIFIER
■ GENERAL DESCRIPTION
HT4580A is the dual operational amplifier, specially designed for improving the tone control,
which is most suitable for the audio application.Featuring noiseless, higher gain bandwidth, high
output current and low distortion ratio, and it is most suitable not only for acoustic electronic parts of
audio pre-amp and active filter, but also for the industrial measurement tools. It is also suitable for the
head phone amp at higher output current, and further more, it can be applied for the handy type
set operational amplifier of general purpose in application of low voltage single supply type which is
properly biased of the low voltage source.
■ FEATURES
● Operating Voltage
● Low Input Noise Voltage
● Wide Gain Bandwidth Product
● Low Distortion
● Slew Rate
● Bipolar Technology
( ±2V~±18V )
( 0.8µVrms typ. )
( 15MHz typ. )
( 0.0005 typ. )
( 5V/µs typ. )
DIP8 N
SUFFIX
HT4580ANZ
8
1
DIP8 U
SUFFIX
HT4580AUZ
8
1
SOP8 R
SUFFIX
HT4580ARZ
■ PIN CONFIGURATION
8
1
PIN FUNCTION
1.A OUTPUT
2.A –INPUT
3.A +INPUT
4.V
5.B +INPUT
6.B –INPUT
7.B OUTPUT
SOP8 M
SUFFIX
HT4580ARMZ
NOTE: If you need to customize the packaging
shape, please contact the manufacturer.
■ EQUIVALENT CIRCUIT ( 1/2 Shown )
Rev. 01
HT4580A
■ ABSOLUTE MAXIMUM RATINGS
( Ta=25˚C )
PARAMETER
SYMBOL
RATINGS
UNIT
+ V /V
Supply Voltage
± 18
V
Input Voltage
VIC
± 15 ( Note )
V
Differential Input Voltage
VID
± 30
V
Output Current
IO
± 50
mA
Operating Temperature Range
Topr
-40~+85
˚C
Storage Temperature Range
Tstg
-40~+125
˚C
(Note) For supply voltage less than ±15V, the absolute maximum rating is equal to the supply voltage.
■ ELECTRICAL CHARACTERISTICS
( Ta=25˚C,V /V =±15V )
PARAMETER
Input Offset Voltage
Input Offset Current
Input Bias Current
Large Signal Voltage Gain
Output Voltage Swing
Input Common Mode Voltage Range
Common Mode Rejection Ratio
Supply Voltage Rejection Ratio
Operating Current
Slew Rate
Total Harmonic Distortion
Input Noise Voltage
SYMBOL
VIO
IIO
IB
AV
VOM
VICM
CMR
SVR
ICC
SR
GB
THD
VNI
TEST CONDITION
RS≤10kΩ
RL≥2kΩ,VO=±10V
RL≥2kΩ
RS≤10kΩ
RS≤10kΩ
RL≥2kΩ
f=10kHz
AV=20dB,VO=5V,RL=2kΩ,f=1kHz
RIAA,RS=2.2kΩ,30kHz LPF
MIN.
90
± 12
± 12
80
80
TYP.
0.5
5
100
110
± 13.5
± 13.5
110
110
6
5
15
0.0005
0.8
MAX.
3
200
500
9
UNIT
mV
nA
nA
dB
V
V
dB
dB
mA
V/µs
MHz
µVrms
Rev. 01
HT4580A
■ TYPICAL CHARACTERISTICS
Rev. 01
HT4580A
Rev. 01
HT4580A
SOP8
5.00 (0.1968)
4.80 (0.1890)
8
4.00 (0.1574)
3.80 (0.1497)
5
1
4
1.27 (0.0500)
BSC
0.25 (0.0098)
0.10 (0.0040)
CHTLANARITY
0.10
SEATING
PLANE
6.20 (0.2441)
5.80 (0.2284)
1.75 (0.0688)
1.35 (0.0532)
0.51 (0.0201)
0.31 (0.0122)
0.50 (0.0196)
0.25 (0.0099)
45°
8°
0°
0.25 (0.0098)
0.17 (0.0067)
1.27 (0.0500)
0.40 (0.0157)
SOP14
8.75 (0.3445)
8.55 (0.3366)
4.00 (0.1575)
3.80 (0.1496)
8
14
1
7
1.27 (0.0500)
0.50 (0.0197)
BSC
0.25 (0.0098)
0.25 (0.0098)
0.10 (0.0039)
CHTLANARITY
0.10
6.2 0(0.2441)
5.80 (0.2283)
0.51 (0.0201)
0.31 (0.0122)
1.75 (0.0689)
1.35 (0.0531)
SEATING
PLANE
45°
8°
0°
0.25 (0.0098)
0.17 (0.0067)
1.27 (0.0500)
0.40 (0.0157)
Rev. 01
HT4580A
MSOP8
3.20
3.00
2.80
8
3.20
3.00
2.80
1
5.15
4.90
4.65
5
4
PIN 1
IDENTIFIER
0.65 BSC
0.95
0.85
0.75
15°MAX
1.10 MAX
0.15
0.05
CHTLANARITY
0.10
6°
0°
0.40
0.25
0.23
0.09
0.80
0.55
0.40
TSSOP14
5.10
5.00
4.90
14
8
4.50
4.40
4.30
6.40
BSC
1
7
PIN 1
0.65 BSC
1.05
1.00
1.20
MAX
0.80
0.15
0.05
CHTLANARITY
0.10
0.20
0.09
0.30
0.19
SEATING
PLANE
8°
0°
0.75
0.60
0.45
Rev. 01
很抱歉,暂时无法提供与“HT4580ARMZ”相匹配的价格&库存,您可以联系我们找货
