Data Sheet
PW063xxVBBN
Page 1/5
P/N
315241xx
xx=number of poles
2014/01/28
Illustration
see enlarged drawing at the end of the document
Product specification
• pin header, THR solderable
• centerline 3.50 mm, direction of connection vertical 0°
• closed ends
• color black
• Tape & Reel packaging
• with alternative face, codeable
• Connection data
V / A 300 / 10
10 A / 130 V / 2.5 kV / 3 / IEC 61984
Page 2/5
P/N
315241xx
xx=number of poles
2014/01/28
Data Sheet
PW063xxVBBN
Technical Data
General Data
Solder pin length
min. number of poles
max. number of poles
Insulating material class
clearance/creepage dist.
protection category
Overvoltage category
Pollution degree
Rated voltage
Rated test voltage
3.2 mm
2
24
CTI 400
2.48 mm
IP 10
III
3
160 V
2.5 kV
III
2
320 V
2.5 kV
Connection data
V/A
300 / 10
Material
insulating material
flammability class
contact pin material
contact pin surface
PA46
V0
CuMg
Cu + Sn
Climatic properties
upper limit temperature
lower limit temperature
105 °C
-40 °C
General
solderability
Tolerance
Acc. to IPC/JEDEC J-STD-020D-MSL 1
ISO 2768 -mH
II
2
320 V
2.5 kV
Page 3/5
P/N
315241xx
xx=number of poles
2014/01/28
Data Sheet
PW063xxVBBN
Matching Part to
P/N
315131
315141
FW143XXVBFC
SW063XXVBNN
Product name
RW043xxHBLD Typ 513
RW043xxHBLC Typ 514
FW143xxVBFC
SW063xxVBNN
Accessories
P/N
700268-01-0 (on request)
700268-0132 (on request)
700268-0194 (on request)
Product name
F_Kodier sw
F_Kodier sw
F_Kodier sw
Data Sheet
PW063xxVBBN
Illustration
Drawing
L=(pole size - 1) x centerline + 4.9 [0.193]
Page 4/5
P/N
315241xx
xx=number of poles
2014/01/28
Data Sheet
PW063xxVBBN
PCB Layout
Powered by TCPDF (www.tcpdf.org)
Page 5/5
P/N
315241xx
xx=number of poles
2014/01/28
很抱歉,暂时无法提供与“31524102”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 100+2.96805100+0.36031
- 400+2.95418400+0.35863
- 1000+2.954111000+0.35862
- 2500+2.954042500+0.35861
- 4000+2.953984000+0.35860
