S EM ICOND UCTOR
500 mW LL-34 Hermetically
Sealed Glass Zener Voltage
Regulators
SURFACE MOUNT
LL34
Absolute Maximum Ratings
TA = 25°C unless otherwise noted
Parameter
Power Dissipation
Storage Temperature Range
Operating Junction Temperature
Value
Units
500
mW
-65 to +175
°C
+175
°C
DEVICE MARKING DIAGRAM
These ratings are limiting values above which the serviceability of the diode may be impaired.
Cathode Band Color : Blue
Specification Features:
Zener Voltage Range 2.4 to 75 Volts
TCZMxxxB
- VZ tolerance ± 2%
TCZMxxxC
- VZ tolerance ± 5%
Cathode
LL-34 (Mini-MELF) Package
Anode
Surface Device Type Mounting
Hermetically Sealed Glass
ELECTRICAL SYMBOL
Compression Bonded Construction
All External Surfaces Are Corrosion Resistant And Terminals Are Readily Solderable
RoHS Compliant
Matte Tin (Sn) Terminal Finish
Color band Indicates Negative Polarity
Electrical Characteristics
Device Type
TCZM2V4B
TCZM2V7B
TCZM3V0B
TCZM3V3B
TCZM3V6B
TCZM3V9B
TCZM4V3B
TCZM4V7B
TCZM5V1B
TCZM5V6B
TCZM6V2B
TCZM6V8B
TCZM7V5B
TCZM8V2B
TCZM9V1B
TCZM10B
TCZM11B
TCZM12B
TCZM13B
Min
2.35
2.65
2.94
3.23
3.53
3.82
4.21
4.61
5.00
5.49
6.08
6.66
7.33
8.04
8.92
9.80
10.78
11.76
12.74
V Z @ IZT
ZZT @ IZT
IZT
(Volts)
(mA)
Max
Nom
Max
2.4
2.45
5
94
2.7
2.75
5
94
3.0
3.06
5
89
3.3
3.37
5
89
3.6
3.67
5
84
3.9
3.98
5
84
4.3
4.39
5
84
4.7
4.79
5
75
5.1
5.20
5
56
5.6
5.71
5
37
6.2
6.32
5
9
6.8
6.94
5
14
7.5
7.63
5
14
8.2
8.36
5
14
9.1
9.28
5
14
10
10.20
5
18
11
11.22
5
18
12
12.24
5
23
13
13.26
5
28
IZK
(mA)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
ZZK @ IZK
Max
564
564
564
564
564
564
564
470
451
376
141
75
75
75
94
141
141
141
160
IR @ V R
(A)
Max
45
18
9
4.5
4.5
2.7
2.7
2.7
1.8
0.9
2.7
1.8
0.9
0.63
0.45
0.18
0.09
0.09
0.09
VR
(Volts)
1
1
1
1
1
1
1
2
2
2
4
4
5
5
6
7
8
8
8
Number: DB-064
Jan.2011 / D
Page 1
TCZM2V4B through TCZM75B/
TCZM2V4C through TCZM75C
TAK CHEONG
TAK CHEONG
S EM ICOND UCTOR
Device Type
Min
TCZM15B
TCZM16B
TCZM18B
TCZM20B
TCZM22B
TCZM24B
TCZM27B
TCZM30B
TCZM33B
TCZM36B
TCZM39B
TCZM43B
TCZM47B
TCZM51B
TCZM56B
TCZM62B
TCZM68B
TCZM75B
14.70
15.68
17.64
19.60
21.56
23.52
26.46
29.40
32.34
35.28
38.22
42.14
46.06
49.98
54.88
60.76
66.64
73.50
V Z @ IZT
Z ZT @ IZT
IZT
(Volts)
(mA)
Max
Nom
Max
15
16
18
24
27
30
33
36
39
43
47
51
56
62
68
75
15.30
16.32
18.36
20.40
22.44
24.48
27.54
30.60
33.66
36.72
39.78
43.86
47.94
52.02
57.12
63.24
69.36
76.50
5
5
5
5
5
5
2
2
2
2
2
2
2
2
2
2
2
2
28
37
42
51
51
65
75
75
75
84
122
141
160
169
188
202
226
240
IZK
(mA)
ZZK @ IZK
Max
IR @ V R
(A)
Max
VR
(Volts)
1
1
1
1
1
1
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
0.5
188
188
212
212
235
235
282
282
306
329
329
353
353
376
400
423
447
470
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
10.5
11.2
12.6
14.0
15.4
16.8
18.9
21.0
23.0
25.2
27.3
30.1
33.0
35.7
39.2
43.4
47.6
52.5
IZK
(mA)
ZZK @ IZK
Max
IR @ V R
(A)
Max
VR
(Volts)
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
1
0.5
0.5
0.5
0.5
0.5
0.5
564
564
564
564
564
564
564
470
451
376
141
75
75
75
94
141
141
141
160
188
188
212
212
235
235
282
282
306
329
329
353
45
18
9
4.5
4.5
2.7
2.7
2.7
1.8
0.9
2.7
1.8
0.9
0.63
0.45
0.18
0.09
0.09
0.09
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
0.045
1
1
1
1
1
1
1
2
2
2
4
4
5
5
6
7
8
8
8
10.5
11.2
12.6
14.0
15.4
16.8
18.9
21.0
23.0
25.2
27.3
30.1
VF Forward Voltage = 1 V Maximum @ IF = 100 mA for all types
Device Type
TCZM2V4C
TCZM2V7C
TCZM3V0C
TCZM3V3C
TCZM3V6C
TCZM3V9C
TCZM4V3C
TCZM4V7C
TCZM5V1C
TCZM5V6C
TCZM6V2C
TCZM6V8C
TCZM7V5C
TCZM8V2C
TCZM9V1C
TCZM10C
TCZM11C
TCZM12C
TCZM13C
TCZM15C
TCZM16C
TCZM18C
TCZM20C
TCZM22C
TCZM24C
TCZM27C
TCZM30C
TCZM33C
TCZM36C
TCZM39C
TCZM43C
Min
2.28
2.57
2.85
3.14
3.42
3.71
4.09
4.47
4.85
5.32
5.89
6.46
7.11
7.79
8.65
9.50
10.45
11.40
12.35
14.25
15.20
17.10
19.00
20.90
22.80
25.65
28.50
31.35
34.20
37.05
40.85
V Z @ IZT
ZZT @ IZT
IZT
(Volts)
(mA)
Max
Nom
Max
2.4
2.52
5
94
2.7
2.84
5
94
3.0
3.15
5
89
3.3
3.47
5
89
3.6
3.78
5
84
3.9
4.10
5
84
4.3
4.52
5
84
4.7
4.94
5
75
5.1
5.36
5
56
5.6
5.88
5
37
6.2
6.51
5
9
6.8
7.14
5
14
7.5
7.86
5
14
8.2
8.61
5
14
9.1
9.56
5
14
10
10.50
5
18
11
11.55
5
18
12
12.60
5
23
13
13.65
5
28
15
15.75
5
28
16
16.80
5
37
18
18.90
5
42
5
51
22
23.10
5
51
24
25.20
5
65
27
28.35
2
75
30
31.50
2
75
33
34.65
2
75
36
37.80
2
84
39
40.95
2
122
43
45.15
2
141
Number: DB-064
Jan.2011 / D
Page 2
TAK CHEONG
S EM ICOND UCTOR
Device Type
Min
TCZM47C
TCZM51C
TCZM56C
TCZM62C
TCZM68C
TCZM75C
Notes:
1.
2.
VZ @ IZT
Z ZT @ IZT
(Volts)
IZT
(mA)
Max
Nom
Max
44.65
47
49.35
2
48.45
51
53.55
2
53.20
56
58.80
2
58.90
62
65.10
2
64.60
68
71.40
2
71.25
75
78.75
2
160
169
188
202
226
240
IZK
(mA)
ZZK @ IZK
Max
IR @ VR
(A)
Max
VR
(Volts)
0.5
0.5
0.5
0.5
0.5
0.5
353
376
400
423
447
470
0.045
0.045
0.045
0.045
0.045
0.045
33.0
35.7
39.2
43.4
47.6
52.5
For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter
voltage tolerances, contact your nearest Tak Cheong Electronics representative.
The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to
10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK.
Number: DB-064
Jan.2011 / D
Page 3
TAK CHEONG
S EM ICOND UCTOR
Typical Characteristics
1000
Total Capacitance [pF]
PD-Power Passipation [mW]
600
500
400
300
200
f = 1MHz
Ta = 25℃
VR = 0V
100
VR = 2V
100
VR = 30V
1
80
120
160
VZ - Reverse Voltage [V]
Temperature [℃ ]
Figure 1. Power Dissipation vs Ambient Temperature
60
80
Figure 2. Total Capacitance
Valid provided leads at a distance of 0.8mm from case are kept at
ambient temperature
1000
1000
Iz=1mA
Ta = 25℃
Ta = 25℃
Iz=2mA
100
Forward Current [mA]
Differential Zener Impedance [Ω]
VR = 20V
10
Iz=5mA
Iz=10mA
10
1
100
10
1
0.1
0.1
1
10
0.2
0.4
0.6
0.8
VF - Forw ard Voltage [mV]
1
1.2
Figure 4. Forward Current vs. Forward Voltage
Figure 3. Differential Impedance vs. Zener Voltage
300
100
PD = 500mW
Ta = 25℃
Reverse Current [mA]
PD = 500mW
Ta = 25℃
250
VR = 5V
200
150
100
50
10
1
0.1
0.01
4
6
8
Figure 5. Reverse Current vs. Reverse Voltage
10
15
25
35
45
55
65
75
Figure 6. Reverse Current vs. Reverse Voltage
Number: DB-064
Jan.2011 / D
Page 4
TAK CHEONG
S EM ICOND UCTOR
Package Outline
Package
Case Outline
B
LL-34
DIM
C
Inches
Min
Max
Min
Max
A
3.30
3.60
0.130
0.142
B
1.40
1.50
0.055
0.059
C
0.35
0.50
0.014
0.020
A
LL34
Millimeters
Notes:
1.
2.
All dimensions are within DO213AC JEDEC standard.
LL-34 polarity denoted by cathode band.
Number: DB-064
Jan.2011 / D
Page 5
TAK CHEONG
DISC LA I MER NOTIC E
NOTICE
The information presented in this document is for reference only. Tak Cheong reserves the right to make
changes without notice for the specification of the products displayed herein.
The product listed herein is designed to be used with ordinary electronic equipment or devices, and not
designed to be used with equipment or devices which require high level of reliability and the malfunction of with
would directly endanger human life (such as medical instruments, transportation equipment, aerospace
machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Tak Cheong Semiconductor
Co., Ltd., or anyone on its behalf, assumes no responsibility or liability for any damagers resulting from such
improper use of sale.
This publication supersedes & replaces all information reviously supplied. For additional information, please visit
our website http://www.takcheong.com, or consult your nearest Tak Cheong’s sales office for further assistance.
Number: DB-100
April 14, 2008 / A
很抱歉,暂时无法提供与“TCZM4V7BTR”相匹配的价格&库存,您可以联系我们找货
