TCLLZ3V6TR
TCLLZ3V6TR
    TC(同创科技)
    LL-34(SOD-80)
    二极管配置:独立式;稳压值(标称值):3.6V;精度:±5%;功率:500mW;反向电流(Ir):10uA@1V;阻抗(Zzt):100Ω;
TCLLZ3V6TR 数据手册
® S EM ICOND UCTOR 500 mW LL-34 Hermetically Sealed Glass Zener Voltage Regulators SURFACE MOUNT LL34 Absolute Maximum Ratings TA = 25°C unless otherwise noted Parameter Power Dissipation Storage Temperature Range Operating Junction Temperature Value Units 500 mW -65 to +175 °C +175 °C DEVICE MARKING DIAGRAM Cathode Band Color : Blue These ratings are limiting values above which the serviceability of the diode may be impaired. Specification Features:          Zener Voltage Range 2.0 to 75 Volts LL-34 (Mini-MELF) Package Surface Device Type Mounting Hermetically Sealed Glass Cathode Compression Bonded Construction Anode All External Surfaces Are Corrosion Resistant And Terminals Are Readily Solderable RoHS Compliant ELECTRICAL SYMBOL Matte Tin (Sn) Terminal Finish Color band Indicates Negative Polarity Electrical Characteristics TA = 25°C unless otherwise noted Device Type V Z @ IZT (Volts) Nominal IZT (mA) ZZT @ IZT () Max IR @ V R (A) Max VR (Volts) TCLLZ2V0 TCLLZ2V2 TCLLZ2V4 TCLLZ2V7 TCLLZ3V0 TCLLZ3V3 TCLLZ3V6 TCLLZ3V9 TCLLZ4V3 TCLLZ4V7 TCLLZ5V1 TCLLZ5V6 TCLLZ6V2 TCLLZ6V8 TCLLZ7V5 TCLLZ8V2 TCLLZ9V1 TCLLZ10V TCLLZ11V TCLLZ12V 2.0 2.2 2.4 2.7 3.0 3.3 3.6 3.9 4.3 4.7 5.1 5.6 6.2 6.8 7.5 8.2 9.1 10 11 12 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 5 100 100 100 110 120 120 100 100 100 80 80 60 60 20 20 20 25 30 30 30 120 120 120 100 50 20 10 5 5 5 5 5 5 2 0.5 0.5 0.5 0.2 0.2 0.2 0.5 0.7 1 1 1 1 1 1 1 1 1.5 2.5 3 3.5 4 5 6 7 8 9 Number: DB-059 Jan.2011/ F Page 1 TCLLZ2V0 through TCLLZ75V TAK CHEONG TAK CHEONG ® S EM ICOND UCTOR Electrical Characteristics Device Type V Z @ IZT (Volts) Nominal TA = 25°C unless otherwise noted IZT (mA) TCLLZ13V 13 5 TCLLZ15V 15 5 TCLLZ16V 16 5 TCLLZ18V 18 5 TCLLZ20V 20 5 TCLLZ22V 22 5 TCLLZ24V 24 5 TCLLZ27V 27 2 TCLLZ30V 30 2 TCLLZ33V 33 2 TCLLZ36V 36 2 TCLLZ39V 39 2 TCLLZ43V 43 2 TCLLZ47V 47 2 TCLLZ51V 51 2 TCLLZ56V 56 2 TCLLZ62V 62 2 TCLLZ68V 68 2 TCLLZ75V 75 2 VF Forward Voltage = 1.2 V Maximum @ IF = 200 mA for all types Notes: 1. 2. 3. ZZT @ IZT () Max IR @ V R (A) Max VR (Volts) 35 40 40 45 45 30 35 45 55 65 75 85 90 90 110 110 201 230 240 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 0.2 10 11 12 13 15 17 19 21 23 25 27 30 33 36 39 43 47 51 56 The type numbers listed have zener voltage min/max limits as shown and have a standard tolerance on the nominal zener voltage of 5%. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Tak Cheong Electronics representative. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an rms value equal to 10% of the dc zener current (IZT or IZK) is superimposed to IZT or IZK. Number: DB-059 Jan.2011/ F Page 2 TAK CHEONG ® S EM ICOND UCTOR Typical Characteristics 1000 Total Capacitance [pF] PD-Power Passipation [mW] 600 500 400 300 200 f = 1MHz Ta = 25℃ VR = 0V 100 VR = 2V 100 VR = 30V 1 0 40 80 120 160 0 200 20 40 VZ - Reverse Voltage [V] Temperature [℃ ] Figure 1. Power Dissipation vs Ambient Temperature 60 80 Figure 2. Total Capacitance Valid provided leads at a distance of 0.8mm from case are kept at ambient temperature 1000 1000 Iz=1mA Ta = 25℃ Ta = 25℃ Iz=2mA 100 Forward Current [mA] Differential Zener Impedance [Ω] VR = 20V 10 0 Iz=5mA Iz=10mA 10 1 100 10 1 0.1 0.1 1 10 VZ - Reverse Voltage [V] 0 100 0.2 0.4 0.6 0.8 VF - Forw ard Voltage [mV] 1 1.2 Figure 4. Forward Current vs. Forward Voltage Figure 3. Differential Impedance vs. Zener Voltage 300 100 PD = 500mW Ta = 25℃ Reverse Current [mA] PD = 500mW Ta = 25℃ 250 Reverse Current [mA] VR = 5V 200 150 100 50 10 1 0.1 0.01 0 0 2 4 6 VZ - Reverse Voltage [V] 8 Figure 5. Reverse Current vs. Reverse Voltage 10 15 25 35 45 55 65 VZ - Reverse Voltage [V] 75 Figure 6. Reverse Current vs. Reverse Voltage Number: DB-059 Jan.2011/ F Page 3 TAK CHEONG ® S EM ICOND UCTOR Package Outline Package Case Outline B LL-34 DIM Inches Min Max Min Max A 3.30 3.60 0.130 0.142 B 1.40 1.50 0.055 0.059 C 0.35 0.50 0.014 0.020 A LL34 Millimeters C Notes: 1. 2. All dimensions are within DO213AC JEDEC standard. LL-34 polarity denoted by cathode band. Number: DB-059 Jan.2011/ F Page 4 TAK CHEONG ® DISC LA I MER NOTIC E NOTICE The information presented in this document is for reference only. Tak Cheong reserves the right to make changes without notice for the specification of the products displayed herein. The product listed herein is designed to be used with ordinary electronic equipment or devices, and not designed to be used with equipment or devices which require high level of reliability and the malfunction of with would directly endanger human life (such as medical instruments, transportation equipment, aerospace machinery, nuclear-reactor controllers, fuel controllers and other safety devices), Tak Cheong Semiconductor Co., Ltd., or anyone on its behalf, assumes no responsibility or liability for any damagers resulting from such improper use of sale. This publication supersedes & replaces all information reviously supplied. For additional information, please visit our website http://www.takcheong.com, or consult your nearest Tak Cheong’s sales office for further assistance. Number: DB-100 April 14, 2008 / A
TCLLZ3V6TR 价格&库存
很抱歉,暂时无法提供与“TCLLZ3V6TR”相匹配的价格&库存,您可以联系我们找货
