SPSEMI
SMBJ(600W) Series
Surface Mount Transient Voltage Suppressor
Stand-Off Voltage - 5.0 to 440 Volts
600 Watt Peak Pulse Power
Features
For surface mounted applications in order to optimize board space
Low profile package
Built-in strain relief
Glass passivated junction
Low inductance
Excellent clamping capability
Repetition Rate (duty cycle):0.01%
Fast response time: typically less than 1.0ps from 0 Volts to V(BR)
for unidirectional types
Typical IR less than 1µA above 10V
High Temperature solderting: 260°C/10 seconds at terminals
Plastic package has Underwriters Laboratory Flammability 94V-O
Pb-free plated
AEC-Q101
Mechanical Data
Case: JEDEC DO-214AA. Molded plastic over glass passivated junction
Terminals: Solderable per MIL-STD-750,Method 2026
Polarity: Color band denoted positive end (cathode) except Bidirectional
Standard Packaging: 12mm tape (EIA STD RS-481)
Devices For Bipolar Application
For Bidirectional use C or CA Suffix for types SMBJ5.0 thru types SMBJ170 (e.g. SMBJ5.0C , SMBJ170CA)
Electrical characteristics apply in both directions
Maximum Ratings And Characteristics
Ratings at 25 ℃ ambient temperature unless otherwise specified.
RATING
Peak Pulse Power Dissipation on 10/1000µs waveform
SYMBOL
VALUE
P PPM
600
(Note 1,2 ,FIG.1)
Peak Pulse Current of on 10/1000µs waveform (Note 1,FIG.3)
Peak Forward Surge Current,8.3ms Single Half Sine-Wave
Superimposed on Rated Load,(JEDEC Method) (Note2,3)
Operating junction and Storage Temperature Range
I PPM
I FSM
T J , T STG
SEE
UNITS
Watts
Amps
TABLE 1
100
Amps
- 55 to
+150
Notes :
1.Non-repetitive current pulse , per Fig. 3 and derated above TA = 25 ℃ per Fig. 2 .
2.Mounted on 5.0mm x 5.0mm (0.03mm thick) Copper Pads to each terminal
3.8.3ms single half sine-wave , or equivalent square wave, Duty cycle = 4 pulses per minutes maximum.
REV . 2021 . 02 . 01
www.spsemi.cn
Page 1 of 5
SPSEMI
SMBJ(600W) Series
Dimensions (DO-214AA)
DO-214AA(SMB J-Bend)
Cathode Band
0.086 ( 2.20 )
0.071 ( 1.80 )
0.012 ( 0.305 )
0.006 ( 0.152 )
0.108(2.75)
0.083(2.10)
0.155(3.94)
0.130(3.30)
0.060 ( 1.52 )
0.030 ( 0.76 )
0.193(4.90)
0.160(4.05)
0.012(0.3)MAX.
0.223 ( 5.65 )
0.200 ( 5.08 )
Dimensions in inches and(millimeters)
Electrical Characteristics
TABLE1
“ * ”Stand for commonly used models
SMBJ
Part Number
UNI-Polar
BI-Polar
Maximum
Clamping Peak Pulse
Current
Voltage
@Ipp
Device
Marking Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@I T
Breakdown
Voltage
@IT
Test
Current
UNI
BI
V RWM (V)
V BR (V)Min.
V BR (V)Max.
IT(mA)
Vc(V)
Ipp(A)
I R ( A)
Reverse
Leakage
@V RWM
* SMBJ5.0A
* SMBJ5.0CA
KE
AE
5.0
6.40
7.00
10
9.2
65.3
500
SMBJ6.0A
* SMBJ6.0CA
KG
AG
6.0
6.67
7.37
10
10.3
58.3
500
SMBJ6.5A
* SMBJ6.5CA
KK
AK
6.5
7.22
7.98
10
11.2
53.6
300
SMBJ7.0A
SMBJ7.0CA
KM
AM
7.0
7.78
8.60
10
12.0
50.0
200
SMBJ7.5A
SMBJ7.5CA
KP
AP
7.5
8.33
9.21
1
12.9
46.6
100
SMBJ8.0A
* SMBJ8.0CA
KR
AR
8.0
8.89
9.83
1
13.6
44.2
50
SMBJ8.5A
SMBJ8.5CA
KT
AT
8.5
9.44
10.40
1
14.4
41.7
SMBJ9.0A
SMBJ9.0CA
KV
AV
9.0
10.00
11.10
1
15.4
39.0
10
SMBJ10A
* SMBJ10CA
KX
AX
10.0
11.10
12.30
1
17.0
35.3
5
SMBJ11A
SMBJ11CA
KZ
AZ
11.0
12.20
13.50
1
18.2
33.0
1
SMBJ12A
* SMBJ12CA
LE
BE
12.0
13.30
14.70
1
19.9
30.2
1
SMBJ13A
SMBJ13CA
LG
BG
13.0
14.40
15.90
1
21.5
28.0
1
SMBJ14A
SMBJ14CA
LK
BK
14.0
15.60
17.20
1
23.2
25.9
1
* SMBJ15A
SMBJ15CA
LM
BM
15.0
16.70
18.50
1
24.4
24.6
1
SMBJ16A
SMBJ16CA
LP
BP
16.0
17.80
19.70
1
26.0
23.1
1
SMBJ17A
SMBJ17CA
LR
BR
17.0
18.90
20.90
1
27.6
21.8
1
SMBJ18A
SMBJ18CA
LT
BT
18.0
20.00
22.10
1
29.2
20.6
1
SMBJ20A
* SMBJ20CA
LV
BV
20.0
22.20
24.50
1
32.4
18.6
1
SMBJ22A
SMBJ22CA
LX
BX
22.0
24.40
26.90
1
35.5
16.9
1
SMBJ24A
* SMBJ24CA
LZ
BZ
24.0
26.70
29.50
1
38.9
15.5
1
* SMBJ26A
SMBJ26CA
ME
CE
26.0
28.90
31.90
1
42.1
14.3
1
SMBJ28A
SMBJ28CA
MG
CG
28.0
31.10
34.40
1
45.4
13.3
1
Notes :
1.For bidirectional type having V RWM of 10 volts and less, the I R limit is double
2. For parts with A , the V BR is ± 5%
www.spsemi.cn
Page 2 of 5
SPSEMI
SMBJ(600W) Series
TABLE1
SMBJ
Part Number
Device
Marking Code
Reverse
Stand-Off
Voltage
Breakdown
Voltage
@I T
Breakdown
Voltage
@IT
Test
Current
Maximum
Clamping Peak Pulse
Current
Voltage
@Ipp
Reverse
Leakage
@V RWM
UNI-Polar
BI-Polar
UNI
BI
V RWM (V)
V BR (V)Min.
V BR (V)Max.
IT(mA)
Vc(V)
Ipp(A)
I R ( A)
SMBJ30A
SMBJ30CA
MK
CK
30.0
33.30
36.80
1
48.4
12.4
1
SMBJ33A
SMBJ33CA
MM
CM
33.0
36.70
40.60
1
53.3
11.3
1
SMBJ36A
* SMBJ36CA
MP
CP
36.0
40.00
44.20
1
58.1
10.4
1
* SMBJ40A
SMBJ40CA
MR
CR
40.0
44.40
49.10
1
64.5
9.3
1
SMBJ43A
SMBJ43CA
MT
CT
43.0
47.80
52.80
1
69.4
8.7
1
SMBJ45A
SMBJ45CA
MV
CV
45.0
50.00
55.30
1
72.7
8.3
1
SMBJ48A
SMBJ48CA
MX
CX
48.0
53.30
58.90
1
77.4
7.8
1
SMBJ51A
* SMBJ51CA
MZ
CZ
51.0
56.70
62.70
1
82.4
7.3
1
SMBJ54A
SMBJ54CA
NE
DE
54.0
60.00
66.30
1
87.1
6.9
1
SMBJ58A
SMBJ58CA
NG
DG
58.0
64.40
71.20
1
93.6
6.5
1
SMBJ60A
SMBJ60CA
NK
DK
60.0
66.70
73.70
1
96.8
6.2
1
SMBJ64A
SMBJ64CA
NM
DM
64.0
71.10
78.60
1
103.0
5.9
1
SMBJ70A
SMBJ70CA
NP
DP
70.0
77.80
86.00
1
113.0
5.3
1
SMBJ75A
SMBJ75CA
NR
DR
75.0
83.30
92.10
1
121.0
5.0
1
SMBJ78A
SMBJ78CA
NT
DT
78.0
86.70
95.80
1
126.0
4.8
1
SMBJ85A
SMBJ85CA
NV
DV
85.0
94.40
104.00
1
137.0
4.4
1
SMBJ90A
SMBJ90CA
NX
DX
90.0
100.00
111.00
1
146.0
4.1
1
SMBJ100A
SMBJ100CA
NZ
DZ
100.0
111.00
123.00
1
162.0
3.7
1
SMBJ110A
SMBJ110CA
PE
EE
110.0
122.00
135.00
1
177.0
3.4
1
* SMBJ120A
SMBJ120CA
PG
EG
120.0
133.00
147.00
1
193.0
3.1
1
SMBJ130A
SMBJ130CA
PK
EK
130.0
144.00
159.00
1
209.0
2.9
1
* SMBJ150A
SMBJ150CA
PM
EM
150.0
167.00
185.00
1
243.0
2.5
1
SMBJ160A
SMBJ160CA
PP
EP
160.0
178.00
197.00
1
259.0
2.3
1
* SMBJ170A
SMBJ170CA
PR
ER
170.0
189.00
209.00
1
275.0
2.2
1
SMBJ180A
SMBJ180CA
PT
ET
180.0
201.00
222.00
1
292.0
2.1
1
SMBJ200A
SMBJ200CA
PV
EV
200.0
224.00
247.00
1
324.0
1.9
1
SMBJ220A
SMBJ220CA
PX
EX
220.0
246.00
272.00
1
356.0
1.7
1
SMBJ250A
SMBJ250CA
PZ
EZ
250.0
279.00
309.00
1
405.0
1.5
1
SMBJ300A
SMBJ300CA
QE
FE
300.0
335.00
371.00
1
486.0
1.3
1
SMBJ350A
SMBJ350CA
QG
FG
350.0
391.00
432.00
1
567.0
1.1
1
SMBJ400A
*SMBJ400CA
QK
FK
400.0
447.00
494.00
1
648.0
0.9
1
SMBJ440A
SMBJ440CA
QM
FM
440.0
492.00
543.00
1
713.0
0.9
1
Notes :
www.spsemi.cn
Page 3 of 5
SPSEMI
SMBJ(600W) Series
Characteristic Curves (TA=25 ℃ unless otherwise noted)
Fig.1 Peak Pulse Power Rating
Non-repetitive pulse
waveform shown in
Fig.3 TA = 25°C
10
1
0.1
0.1μs
10μs 100μs 1.0ms
1.0μs
td - Pulse Width (sec.)
10ms
Peak Pulse Power(P PP ) or Current(I PPM )
Derating in Percentage,%
P PPM -Peak Pulse Power (kW)
100
Fig.2 Pulse Derating Cruve
Fig.3 Pulse Waveform
tr=10uS
Peak Value
I PPM
100
50
I PPM
2
10/1000μsec . Waveform
as defined by R.E.A
td
00
1.0
2.0
t-Time(mS)
3.0
25 50 75 100 125 150 175 200
T A -Ambient Temperature(℃)
V R ,Measured at
Stand-Off
Voltage,V WM
100
Uni-Directional
Bi-Directional
10 1
TJ=25℃
f=1.0MH Z
Vsig=50mVp-p
100 200
10
V WM -Reverse Stand-off Voltage(V)
Fig.6 Maximum Non-Repetitive Peak
Forward Surge Current Uni-Directional Only
200
Peak Forward Surge Current(A)
Transient Thermal Impedance(C/W)
100
10
1.0
25
Measured at
Zero Bias
4.0
Fig.5 Typ.Transient Thermal Impedance
0.1
1
10
100
0.001 0.01 0.1
tp-Pulse Duration(sec)
50
6000
T J =25℃
Pulse width(td) is defined
ad the Point where the Peak
Current Decays to 50% of I PPM
Half Value
75
Fig.4 Typical Junction Capacitance
C J -Junction Capacitance(pF)
I PPM -Peak Pulse Current(%)
150
100
1000
www.spsemi.cn
8.3mS single half sine-wave
(JEDEC Method)
Unidirectional Only
100
10
1
10
Number of Cycles at 60H Z
100
Page 4 of 5
SPSEMI
SMBJ(600W) Series
Recommended Soldering Conditions
Recommended Conditions
Pb-Free assembly
(see Fig.1)
+150℃
-Temperature Max(T s(max) )
+200℃
-Time(Min to Max)(t s )
60-180secs
Critical Zone
T L to T P
Ramp-up
TL
Average ramp up rate
(Liquidus Temp(T L ) to peak)
3℃/sec.Max.
T s(max) to T L -Ramp-up Rate
3℃/sec.Max.
Re”ow
tP
TP
-Temperature Min(T s(min) )
-Temperature(T L )(Liquidus)
+217℃
-Temperature(t L )
60-150secs
Peak Temp(T P )
+260(+0/-5)℃
Time within 5℃ of actual Peak Temp(t P )
Ramp-down Rate
30 secs.Max.
Time 25℃ to Peak Temp(T P )
8 min.Max.
Do not exceed
+260℃
tL
Temperature
Re”ow Condition
Pre Heat
Reflow Soldering
T s (max)
Ramp-down
Preheat
T s (min)
ts
25
time to peak temperature
(t 25℃ to peak)
6℃/sec.Max.
Time
Marking Code
Cathode Band
AE
KE
Logo
Serial number
Serial number
Logo
Marking Code
Marking Code
Tape And Reel Specification
Symbol
Ea Per Reel
REEL DIA
(mm)
Industry Standard
SMBJ***
500/3000
178/330
EIA RS-481
0.157
(4.0)
0.47
(12.0)
0.314
(8.0)
13.0(330)
0.49
(12.0)
www.spsemi.cn
Page 5 of 5
很抱歉,暂时无法提供与“SMBJ5.0CA”相匹配的价格&库存,您可以联系我们找货
