2D Drawing
IGES
STEP
3D PDF
Solder Profile
CofC RoHS Compliant
CofC REACH Compliant
UL Plastic File
Certificate of Origin
Check Stock
Request a Sample
Send Us An Email
Generated Part Number
GM67X-CBL-152-P
Part Number Builder
LR78160
GM67X-CBL
152
P
Series
Cable
Length
Plug
Option
IP67 Connectors: GM67X-CBL Series
Box Side, IP67 Panel Mount Jack with Cable and Plug
(Must Be Used with GM67X Series Cable Side Part)
Product Features
Series
GM67X-CBL - Panel Mount IP67 Modular Jack with Cable and plug
Cable Length
152 - 152mm
304 - 304mm
IP67
Panel Mount
Cable and Plug Termination
Cat. 5 Cable UTP
Optional Cap Available
Plug Option
P - Plug
Performance Specifications
Plating Option
Blank - Gold Flash
50 - 50µ" Gold Plating
Materials and Finish
Housing Material
Polycarbonate, UL 94V-0 Rated, Black Color
Contact Material
Phosphor Bronze
Nut Material
Gasket Material
Silicone, UL 94HB Rated, Red Color
Contact Kycon For Other Option
GM67X-CBL Series
Dimensions in mm
GM67X-CBL-xxx-P
Electrical Characteristics
Insulation Resistance
500 Megohms Min.
Dielectric Withstanding Voltage
1000V AC RMS for 1 Minute
Contact Resistance
50 milliohms Max.
Current Rating
1.5A
Voltage Rating
125V DC
Durability
1000 Mating Cycles Min.
Operating Temperature
-40°C to +80°C
Note
Plating
Option
*Must be used with GM67X series cable side part
*Kycon can provide custom cable assemblies (mins will apply)
Nut
Gasket
*Kit includes cable, nut, and gasket
Recommended Nut Torque: 12 Kgf-cm
Click here for our assembly videos
Phone: +1.408.494.0330 l Fax: +1.408.494.0325 l WWW.KYCON.COM l 0915
很抱歉,暂时无法提供与“GM67X-CBL-152-P”相匹配的价格&库存,您可以联系我们找货
