4
3
2
1
Part Number:
DRAWN
SM150506-2
4/25/2017
CJ
CHECKED
4/28/2017
P.D.
Description:
D
APPROVED
Dynamic Speaker
4/28/2017
C.E.
This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written
permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com
Top View
Side View
D
Bottom View
11.0 ± 0.2
2.5 ± 0.2
9.6 ± 0.2
Positive (+)
Negative (-)
8.5 ± 0.2
15.0 ± 0.2
C
13.6 ± 0.2
C
B
B
4.5 ± 0.2
A
Items
Specifications
Conditions
Sound Pressure Level
92 ± 3
dB (@ 10cm)
Resonant Frequency
550
Hz
Frequency Range
550 ~ 20,000
Hz
Nominal Power
0.7
W
Max. Power
1
W
Ω
Impedance
6
Cone Material
Mylar
REVISION HISTORY
REV
1
DESCRIPTION
DATE
Released from Engineering
4/28/2015
J.S.
Updated to new template
4/28/2017
C.E.
NOTES
1) All dimensions are in mm unless otherwise noted
Mount Type
Flush Mount
Storage Temperature
-20 ~ +70
°C
3) All parts meet RoHS
Operating Temperature
-20 ~ +70
4) Subject to change or redrawn without notice
Weight
1.6
°C
g
4
APPROVED
2) All tolerances are ± 0.3 mm unless otherwise noted
3
2
1
Additional considerations can be found at www.dbunlimitedco.com/technical-articles.
A
很抱歉,暂时无法提供与“SM150506-2”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+75.21302
- 10+58.53802
- 100+47.83092
