SM160508-1
SM160508-1
    DBUNLIMITED
    DYNAMIC SURFACE MOUNT MICRO SPEA
SM160508-1 数据手册
4 3 2 1 Part Number: DRAWN SM160508-1 11/24/2015 CJ CHECKED 12/9/2015 P.D Description: APPROVED Dynamic Speaker 12/9/2015 J.S D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com 2 - 0.50 3.00 0.20 8.40 0.15 0.20 12.00 C XX X 1.40 7.25 0.20 16.00 13.00 0.20 C 0.40 (Free Position) 2.00 6.00 4.40 2 - 3.50 0.20 0.30 (Working Position) Side View (2) 3.50 9.00 Bottom View Side View (1) Top View 0.20 Date Code Marking "14 K" 14=2014 K=Nov. 2.50 4 - R2.00 B A B Items Specifications Conditions Sound Pressure Level 87 dB (@ 10cm) Resonant Frequency 550 Hz Frequency Range 550 ~ 20,000 Hz Nominal Power 0.5 W Max. Power 1 W Impedance 8 NOTES Cone Material Polyester 1) All dimensions are in mm unless otherwise noted Mount Type Flush Mount Storage Temperature -20 ~ +70 C 3) All parts meet RoHS Operating Temperature -20 ~ +70 4) Subject to change or redrawn without notice Weight 1 C g 4 REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 11/12/2014 J.S. Updated to new template 12/9/2015 J.S. 2) All tolerances are 3 2 0.5 mm unless otherwise noted 1 A
SM160508-1 价格&库存
很抱歉,暂时无法提供与“SM160508-1”相匹配的价格&库存,您可以联系我们找货
SM160508-1
    • 250+48.88761
