SM160508-2
SM160508-2
    DBUNLIMITED
    DYNAMIC MICRO SPEAKER
SM160508-2 数据手册
4 3 2 1 Part Number: DRAWN SM160508-2 8/10/2015 CJ CHECKED 1/7/2016 P.D Description: APPROVED Dynamic Speaker 1/7/2016 J.S D D This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Bottom View Side View (1) Top View 9.00 3.00 6.00 2.00 R2.00 1.00 0.50 16.00 12.30 C 13.00 C 3.40 Text B B A 2.45 0.20 Side View (2) Items Specifications Conditions Sound Pressure Level 80 dBA Resonant Frequency 500 Hz Frequency Range 500 ~ 20,000 Hz Nominal Power 0.7 W Max. Power 1 W Impedance 8 NOTES Cone Material Mylar 1) All dimensions are in mm unless otherwise noted Mount Type Flush Mount Storage Temperature -20 ~ +70 C 3) All parts meet RoHS Operating Temperature -20 ~ +70 4) Subject to change or redrawn without notice Weight 1.1 C g 4 REVISION HISTORY REV 1 DESCRIPTION DATE APPROVED Released from Engineering 2/18/2015 J.S. Updated to new template 1/7/2016 J.S. 2) All tolerances are 3 2 0.5 mm unless otherwise noted 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SM160508-2 价格&库存
很抱歉,暂时无法提供与“SM160508-2”相匹配的价格&库存,您可以联系我们找货
SM160508-2
    • 250+39.93223
