SM500408-2
SM500408-2
    DBUNLIMITED
    DYNAMIC SPEAKER
SM500408-2 数据手册
4 3 2 1 Part Number: DRAWN SM500408-2 6/1/2018 CJ CHECKED 6/1/2018 C.H. Description: D APPROVED Dynamic Speaker 6/1/2018 C.E. This document contains data proprietary to DB Unlimited. Any use or reproduction, in any form, without prior written permission of DB Unlimited is prohibited. All terms and conditions can be found at www.dbunlimitedco.com Top View Side View D Bottom View 8.0 Ø50 C C Max. Vibration 1.0mm 16.8 8Ω XX X Date Code Marking "18 F" 18=2018, F=Jun. B A B Items Specifications Conditions Sound Pressure Level 92 dB (@ 10cm), Avg. Resonant Frequency 400 Hz Frequency Range 400 ~ 5,000 Hz Nominal Power 0.5 W Max. Power 0.8 W NOTES Impedance 8 Ω 1) All dimensions are in mm unless otherwise noted Cone Material Mylar Mount Type Flush Mount Storage Temperature -30 ~ +70 Operating Temperature -20 ~ +60 4 REVISION HISTORY REV DESCRIPTION DATE APPROVED Released from Engineering 6/1/2018 C.E. 2) All tolerances are ± 0.3 mm unless otherwise noted 3) All parts meet RoHS 4) Subject to change or redrawn without notice °C °C 3 2 1 Additional considerations can be found at www.dbunlimitedco.com/technical-articles. A
SM500408-2 价格&库存
很抱歉,暂时无法提供与“SM500408-2”相匹配的价格&库存,您可以联系我们找货
