ETA-USA
The Power Professionals
WRM-00X-O
15W AC/DC Triple Output
Features
• Universal Input
• Compact design with
inrush current protection
• Triple Output
-WRM01X-O: 5, 12, -12 VDC
-WRM04X-O: 5, 15, -15 VDC
• 2 year Warranty
RoHS
MODEL/CHANNEL
OUTPUT Nominal Voltage
Current
Line Regulations
Load Regulations
Ripple
Ripple and Noise
Temperature Drift
V
A
mVp-p
mV
120
75
mV
mV
mVp-p
mS
Hold Up Time
mS
MODEL/CHANNEL
25
50
80
12
0.3
120
120
120
150
180
67
WRM04X-O
12
5
0.2
0.1~2
150
180
120
75
120
120
120
25
50
80
800 max [AC IN 110V Io=100%]
15
15
0.7
0.2
150
225
150
225
150
150
120
150
150
120
67
16 typ [AC IN 110V,Io=100%]
Individual Ground
Unit
INPUT Nominal Voltage
V
AC100V-240V (AC85V~264V or DC125V~ 370V), 50/60Hz (47~440Hz) Universal Input Voltage
Current Typ.
A
0.4A at 110V; 0.25A at 220V (Io=100%)
Inrush Current
A
20A typ (AC IN 110V, Io=100%), 40A typ (AC IN 220V, Io=100%) at cold start
Leakage
Function Overcurrent Protection
A
Over Voltage Protection
Input-Output
Environment
5
0.1~2
Efficiency Typ.
Rise Time
Grounding
WRM01X-O
Unit
Input-F.G.
Output-F.G.
Operating temp. & Hum.
Storage temp. & Hum.
Vibration
Impact
Dimension Size(WxLxH) / Weight
Safety
0.75
Works at 115~140% of rating
Works at 110% over rated current and recovers automatically
AC 3,000V 1minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity)
AC 2,000V 1minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity)
mm/g
AC 500V 1 minute current 100mA, DC 500V 100MΩ (At room temperature & Humidity
-10 ~ +70°C, 20~90% RH(Non condensing)
-20 ~ +75°C, 20~90% RH(Non condensing)
10~55Hz at 1G, 3 minutes period, 30 minutes along X, Y and Z axis
10G for 20ms once on each X, Y and Z axis
82 x 31.5 x 84 (99) / 210
CE/CB IEC 60950-1, EN60950-1, Line Con RF Voltage EN55022-A
ETA-USA
16170 Vineyard Blvd. Suite 180 Morgan Hill, CA 95037 http://www.eta-usa.com
Toll-free (US only): 800-ETA-POWR (800-382-7697) Telephone: 408 778-2793 FAX: 408-779-2753
©2014 ETA-USA All Rights Reserved
ETA-USA reserves the right to make changes to the products and specifications without prior notice. Please contact the factory for latest information.
ETA-USA
Mounting Diagram
Derataing Curve
ETA-USA
ETA-USA
Dimensional Drawing
Block Diagram
ETA-USA
很抱歉,暂时无法提供与“WRM04X-O”相匹配的价格&库存,您可以联系我们找货
