WRB23FWX-O
WRB23FWX-O
    ETA-USA
    UNIVERSAL, DUAL OUTPUT, ENCLOSED
WRB23FWX-O 数据手册
WRB**FWX-O 50 Watt AC/DC Dual Output Universal Input Compact design with Inrush current protection Dual Output -WRB21FWX-O: 5V, 24V - WRB24FWX-O:5V, 12V -WRB22FWX-O: 12V, 12V - WRB25FWX-O:5V, 15V -WRB23FWX-O: 15V, 15V 2 year Warranty RoHS UNIT INPUT Voltage/Freq Current Typ. V A AC100V - 240V (AC85V ~ 264V or DC125V~ 370V), 50 / 60Hz (47 ~ 440Hz) Universal Input voltage 1.2A at 110V; .7A at 220V (I =100%) Power Factor Inrush Current Leakage A mA -20A typ (AC IN 110V, I =100%), 40A typ (AC IN 220V, I =100%) at cold start 0.75 UNIT OUTPUT VDC Efficiency typ Current Line Regulation Load Regulation Ripple Ripple Noise maximum Temperature Drift [0-+50C] Rise Time Hold up Time Grounding % A mV (max) mV(max) mVp-p mVp-p 0.5~5 50 100 80 120 mV 75 mS mS 1000 max [AC IN 110V/220V I =100%] 17 typ [AC IN 110V/220V,I =100%] Protection Isolation Environment Safety Size WRB24FWX-O WRB21FWX-O WRB25FWX-O WRB22FWX-O WRB23FWX-O Nominal Voltage 5 75 12 5 2 120 240 120 150 0.5~5 50 100 80 120 180 75 77 24 5 1 240 480 150 250 0.5~5 50 100 80 120 360 75 76 15 12 12 1.7 150 210 120 150 0.1~2.5 120 240 120 150 77 1.5 120 240 120 150 225 180 180 15 .1~2 150 300 120 150 225 Individual Ground Over Voltage Over Current Input-Output Input-F.G Output-F.G Operating temp/hum Storage temp/hum Vibration Impact CE/ CB Works at 115~140% of rating Works at 105% over rated current and recovers automatically AC 3,000V 1 minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity) AC 2,000V 1 minute current 20mA, DC 500V 100MΩ (At room temperature & Humidity) AC 500V 1 minute current 100mA, DC 500V 100MΩ (At room temperature & Humidity ) -10 ~ +70 , 20 ~ 90% RH(Non condensing) -20 ~ +75 , 20 ~ 90% RH(Non condensing) 10 ~ 55Hz at 1G, 3 minutes period, 30 minutes along X, Y and Z axis 10G for 20ms once on each X, Y and Z axis IEC 60950-1, EN60950-1 Line Con RF Voltage MM/G EN55022-A 82 x 35.5 x 135 (150) / 360 15 77 1.5 150 300 120 150 225 BLOCK DIAGRAM WRB22FWX-O WRB23FWX-O WRB25FWX-O WRB24FWX-O WRB21FWX-O DIMENSIONAL DRAWING (mm) WRB21FWX-O Mark L N NC +V1 -V1 +V2 -V2 WRB22FWX-O WRB23FWX-O WRB24FWX-O WRB25FWX-O Pin Connection AC input line AC input neutral AC Chassis Ground DC V1 Output DC V1 Ground DC V2 Output DC V2 Ground DERATING CURVE AND RECCOMENDED MOUNTING DIAGRAM
WRB23FWX-O 价格&库存
很抱歉,暂时无法提供与“WRB23FWX-O”相匹配的价格&库存,您可以联系我们找货
