OEJ05SC1224I
OEJ05SC1224I
    ETA-USA
    DIP4
    DC DC CONVERTER 5V 1.5W
OEJ05SC1224I 数据手册
OEJ05SC1224I 1.5 Watt DC/DC Power Supply FEATURES Wide input 4:1 Low noise Tight regulation ±0.5% MAX High Isolation Voltage *Image for marketing purposes only-unit may differ UNIT INPUT OUTPUT Nom Voltage (Range) V Current Typ. mA Start-up Time ms OEJ05SC1224I 24VDC 8~32 Vdc 12mA Typ At no load 10 ms UNIT OEJ05SC1224I Nominal Voltage VDC 5 VDC OUTPUT VDC ACCURACY % 2% Current mA 300 Total Pwr Efficiency W % 1.5 83 TYP @ Vin=24Vdc Line Regulation Load Regulation % ±0.5% MAX At LL TO HL, Full Load % ±0.5% MAX At 25%FL TO 100%FL Startup Time Ripple Noise ms mVp-p Temp Coefficient Short circuit protect Cooling Type 10 ms 100mVp-p MAX 0.03%/°C MAX Continuous/ Autorecovery Convection @4.9~5.1Vdc @Vin=8~32Vdc ISOLATION Voltage Resistance 1500Vdc for 1 minute Min. 100 MΩ @ 500 Vdc -20°C ~ +71°C Operating temp Environment Storage Vibration -20°C ~ +85°C Mil-STD 202G Humidity Dimension WxL/weight 90 % m/gm DIMENSIONS AND PINOUT 32x20 /4.5
OEJ05SC1224I 价格&库存
很抱歉,暂时无法提供与“OEJ05SC1224I”相匹配的价格&库存,您可以联系我们找货
