MAKERSSLIM12
MAKERSSLIM12
    MAKERSLED
    12 IN SLIM T-SLOT LED HEAT SINK
MAKERSSLIM12 数据手册
MakersSLIM TM LED t-Slot Mounting Heatsink The MakersSLIM Heatsink Features: • 1.5 inches thick, 6.2 inches wide • up to 33W per foot cooling (up to 85W per fot with not-included fan) • thermally optimized, 392 square inches total surface area per foot • 6063 heatsink grade aluminum • tempered for durability • anodized for improved heat radiation • 7 lanes of LED mounting area Included: • cut to length heat sink housing - up to 3ft • 1/16” [1.5mm] clear acrylic splash guard • two plastic end caps [injection moulded ABS plastic] • stainless steel assembly hardware [on exposed parts] Integrated t-Slots allow easy mounting • 4-40 screws and nuts, enough for 25 LED’s [per 12”]* of Star LEDs. No glue, drilling, or tapping! • nylon washers, enough for 25 LED’s [per 12”]* 48V Terminal Block Available at: www.digikey.com MakersLED tm © MakersLED | www.MakersLED.com MakersDRIVER and MakersCONTROLLER are trademarks of MakersLED. Specifications are subject to change without notice.
MAKERSSLIM12 价格&库存
很抱歉,暂时无法提供与“MAKERSSLIM12”相匹配的价格&库存,您可以联系我们找货
