NJM2535
3-INPUT 1-OUTPUT VIDEO SWITCH
■ GENERAL DESCRIPTION
The NJM2535 is a video switch for VCR, TV and others.
It contains three cramp-type inputs and one buffer-type output.
■ FEATURES
• Operating Voltage
• Low Operating Current
• Crosstalk
• 3-Input, 1-Output
• Bipolar Technology
• Package Outline
(+4.5V to +13V)
(4.6mA MAX)
(-70dB)
DIP8, DMP8, SIP8, SSOP8
■ PACKAGE OUTLINE
NJM2535D
NJM2535L
NJM2535M
NJM2535V
■ PIN CONFIGURATION
NJM2535D
NJM2535M
NJM2535V
NJM2535L
Ver.2013-08-20
-1-
NJM2535
■ ABSOLUTE MAXIMUM RATINGS
PARAMETER
(Ta = 25ºC)
SYMBOL
RATINGS
UNIT
V+
+15
V
Power Dissipation
PD
(DIP-8) 500
(DMP-8) 300
(SIP-8) 800
(SSOP-8) 250
mW
Operating Temperature Range
Topr
-40 to +85
ºC
Storage Temperature Range
Tstg
-40 to +125
ºC
Supply Voltage
(V+ = 5V, Ta = 25°C)
■ ELECTRICAL CHARACTERISTICS
PARAMETER
SYMBOL
TEST CONDITIONS
MIN.
TYP.
MAX.
UNIT
Supply Voltage
V
+4.5
+13.0
V
Supply Current
ICC
3.6
4.6
mA
Frequency Characteristics
Gf
VIN = 2VPP, VO = 10MHz/100kHz
-1.0
dB
Voltage Gain
Gv
VIN = 2VPP, 100kHz
-0.5
dB
Differential Gain
DG
VIN = 2VPP, Standard staircase signal, APL = 50%
0.2
3.0
Differential Phase
DP
0.2
3.0
deg
-30
mV
-70
-60
dB
Output Offset Voltage
Voff
Crosstalk
CT
VIN = 2VPP, 4.3MHz
VCH
2.4
V
VCL
0.8
V
Output Impedance
RO
25
Ω
Input Clamp Voltage
VIN
1.5
V
Switching Voltage
■ INPUT CONTROL SIGNAL-OUTPUT SIGNAL
-2-
SW1
SW2
OUTPUT SIGNAL
L
L
VIN1
H
L
VIN2
L/H
H
VIN3
Ver.2013-08-20
NJM2535
■ TEST CIRCUIT
100
220
Vcon=5V
Terminal DC voltage at test circuit (Ta=25°C)
Terminal name
Vin1
Vin2
DC voltage (V)
(3*V+)/10
(3*V+)/10
Ver.2013-08-20
Vin3
(3*V+)/10
Vout
(3*V+)/10 - 0.7
-3-
NJM2535
■ APPLICATION
This IC requires 1MΩ resistance between INPUT and GND pin for clamp type input since the minute current causes
an unstable pin voltage.
This IC requires 0.1µF capacitor between INPUT and GND, 1MΩ resistance between INPUT and GND for clamp
type input at mute mode.
[CAUTION]
The specifications on this databook are only
given for information , without any guarantee
as regards either mistakes or omissions. The
application circuits in this databook are
described only to show representative usages
of the product and not intended for the
guarantee or permission of any right including
the industrial rights.
-4-
Ver.2013-08-20
很抱歉,暂时无法提供与“NJM2535D#”相匹配的价格&库存,您可以联系我们找货
