ACL 450CPS
Charged Plate System for the ACL 450
Low cost way to test air ionizer performance
Easy to Use:
While away from ionized airflow, turn the ACL 450
fieldmeter on and check “zero” reading. Slide the
plate assembly onto the 450 fieldmeter. Select
charger polarity by grounding the opposite terminal. (Ground “-” to select “+”). To charge the plate
adapter, place it in contact with the appropriate
charger terminal. Position the fieldmeter with the
plate adapter in the ionizer airflow. The meter
should rapidly drop from 1100 V to zero.
To test the decay rate, connect the fieldmeter to a
chart recorder or use a stopwatch to measure the
time required for the voltage to decay from
±1.00kV to ±0.10kV.
Increase the utility of your ACL 450 Electrostatic Fieldmeter
for ionized environments by adding the 450CPS Charged
Plate System. The 450CPS Charged Plate System will allow
the 450 fieldmeter to test and monitor the effectiveness and
balance of air ionization devices. The 450CPS includes a
charge plate attachment for the ACL 450 fieldmeter and a
charging source to charge the plate attachment. The fieldmeter then measures the plate voltage during balance and decay
tests. This low-cost system, designed to meet ESDA Standard
DSP3.3 Periodic Verification of Air Ionizers, correlates closely
to tests results from table-top charged-plate monitors.
Performing both positive and negative decay tests, the HOLD
feature on the meter permits balance measurements to be
taken in areas inaccessible with standard charged plate monitors. The analog output provides 1 volt output corresponding
to a 10kV reading on the display.
Plate Assembly Specifications:
Plate Capacitance: 12 picofarads ± 2 picofarads
Range: 0 ± 2 kV
Grounding:Connection through ACL 450 conductive case
Weight: 1.5 ounces
To check balance, attach plate adapter to fieldmeter and point it into the ionizer airflow. Check for
an average reading of zero. An offset reading indicates an unbalanced ionizer.
Charger Specifications:
Note: All tests should be performed while wearing
a wrist strap to ensure proper grounding.
Power Supply: 9-volt alkaline battery
Product # ACL 450 includes carrying case, 9-volt
battery, and NIST-traceable calibration certificate.
Temperature Range: 10° to 30° C (50° to 86°F)
Product # ACL 450CPS includes charge plate
monitor and carrying case.
Size: 3.75” x 2.88” x 1.00” (9.53 x 7.32 x 2.54 cm)
Output: 1100 VDC normal, < 1μA max.
Output Terminals: Two acorn buttons labeled (+) and (-).
To select, ground opposite terminal.
Relative Humidity: 10% to 80% non-condensing
Weight: 2.8 ounces
840 W. 49th Place · Chicago, IL 60609
800.782.8420 · 847.981.9212 · fax 847.981.9278
info@aclstaticide.com · www.aclstaticide.com
ACL Inc. registered to
ISO-9001 : 2008
Certificate No. 10002746
Rev. Jan. 02,2013 MKB
很抱歉,暂时无法提供与“ACL 450CPS”相匹配的价格&库存,您可以联系我们找货
