IC series
Pushbutton switches for harsh environments - short case - bushing Ø 12 mm - momentary
Distinctive features and specifications
❑ Momentary with short case, reduced behind-panel depth
❑ Tactile feedback
❑ Flat round actuator for optional marking
❑ Glossy actuator option (round curved only)
❑ Sealed to IP67
ENVIRONMENTAL SPECIFICATIONS
GENERAL SPECIFICATIONS
• Front panel sealing : IP67 according to IEC 60529
• Shock resistance : 100 g according to IEC 512-4, test 6c
• Vibration resistance : 10-500Hz - 10 g according to IEC 512-4, test 6d
• Salt spray : IEC 512-6, test 11f
• Robustness : IK06 according to EN 50102 (1 joule)
• Operating temperature : -40°C to +85°C
• Panel thickness : 1,5 mm (.059) min.
4 mm (.157 max.)
• Total travel : 1,7 mm (.067)+/- 0,3 mm
• Typical operating force : 4N +/- 2N
• Mechanical life : 1.000.000 cycles
• Torque : 1,5 Nm max. applied to nut
• Soldering : 320°C max. for 3 sec.
ELECTRICAL SPECIFICATIONS
MATERIALS
• Max. current/voltage rating with resistive load :
0,2A 48VDC, 500.000 cycles
0,5A 48VAC, 500.000 cycles
• Initial contact resistance : 50 mΩ max.
• Insulation resistance : 1 GΩ min. at 500VDC
• Dielectric strength : 1.500 Vrms 50 HZ between terminals
• Case : thermoplastic UL94-V0
• Actuator : polyamide 6/6
• Bushing/bezel : zinc die-cast
(zamac), black painted
• Contacts : brass, gold plated
• Multi-wire lead AWG20,
section 0,6 mm2
• Terminal seal : epoxy
MOUNTING
Matrix mounting
1.50min-4Max
(.059 min-.157max)
Panel cut-out
12.90
(.507)
Ø13.60
(.535DIA)
➀ O-ring
APEM
20.00
(.787)
20.00
(.787)
1
20.00
(.787)
Back of panel space requirement
Ø13.50
(.531DIA)
www.apem.com
1
IC series
Overview
IC
Electrical function
Actuator shape
SERIES
Square
Round, curved
Round, flat
Round curved
with gloss finish
C
R
P
B
3
Normally open
(NO)
Actuator colour
1
2
3
4
5
6
7/1
8
9
A
B
Blue
Black
Green
Grey
Yellow
Red
White
Bright chrome
Orange
Satin chrome
Dark blue
Terminals
S
F
P
Z1
Solder lugs
Flying leads
Straight PC
Quick-connect
Contacts
CD Brass, gold
plated
Options
100
101
104
Satin chrome
bezel
Bright chrome
bezel
High actuator
(round
models only)
ABOUT THIS SERIES
On the following pages, you will find successively :
model structure of switches and options in the same order as in above chart
Dimensions : first dimensions are in mm while inches are shown as bracketed numbers.
NOTICE : please note that not all combinations of above numbers are available.
Refer to the following pages for further information.
A sealing boot is available to protect the switches against frost and sand. It is presented at the end of this catalogue.
Mounting accessories : Standard hardware supplied : 1 hex nut 14 mm (.551) across flats and 1 O-ring.
Hex nut part number U166.
Packaging unit : 25 pieces
2
www.apem.com
APEM
IC series
Square
Quick-connect Z1
1.00
(.039)
MODEL
STRUCTURE
3.40
(.133)
8.40
(.330)
2.40
(.094)
Straight P
1.20
(.047)
2.80
(.110)
CISCOSP
ECH: 0.9
5-05-03
➞ Flat
Solder lug terminals
CISCOSZ-A
DESSIN ECH 0.9
5-05-03
ICC3SCD
Normally Open
Also available with straight PC terminals : ICC3PAD
and quick-connect terminals : ICC3Z1AD
➞ Flat
Sealed flying lead terminals
ICC3FCD
Normally Open
Wire colours (NC/NO) : black : NO, blue : NC
ACTUATOR COLOUR
1 : blue - 2 : black - 3 : green - 4 : grey - 5 : yellow - 6 : red - 7/1 : white - 8 : bright chrome - 9 : orange
A : satin chrome - B : dark blue
OPTIONS
100 : Satin chrome bezel
101 : Bright chrome bezel
APEM
www.apem.com
3
IC series
Round
Straight P
Quick-connect Z1
MODEL
STRUCTURE
1.20
(.047)
3.40
(.133)
1.00
(.039)
8.40
(.330)
2.40
(.094)
• Gloss actuator finish
Curved actuator also available with
gloss finish - replace ICR by ICB in the
part numbers below.
2.80
(.110)
CISCOSP
ECH: 0.9
Actuator marking available on ICP models (symbol
10 mm max.). On request.
5-05-03
➞ Flat
CISCOSZ-A
DESSIN ECH 0.9
Curved actuator
ICR3SCD
5-05-03
Flat actuator
ICP3SCD
Also available with straight PC terminals : IC•3PAD
and quick-connect terminals : IC•3Z1AD
➞ Flat
Curved actuator
ICR3FCD
Flat actuator
ICP3FCD
ACTUATOR COLOUR
OPTIONS
A : satin chrome - B : dark blue -
104 : High actuator
4
www.apem.com
ICR
104
IC1201-A-prelim.
104
Ø12.00
(.472DIA)
4.70
(.185)
Ø12.00
(.472DIA)
4.70
(.185)
ICP
APEM
很抱歉,暂时无法提供与“ICC3FAD2101”相匹配的价格&库存,您可以联系我们找货
