F310R-12LB
F310R-12LB
    NIDEC(尼得科)
    FAN AXIAL 30X10MM 12VDC WIRE
F310R-12LB 数据手册
COPAL ELECTRONICS F310R BRUSHLESS DC FANS ■ FEATURES RoHS compliant ● Low noise, 13 dB (A) ● Light weight (approx. 8 g) ■ STRUCTURE ● Frame and impeller ABS/PBT alloy ● Bearing B type : 1 ball bearing and 1 sleeve bearing C type : 1 sleeve bearing ■ PART NUMBER DESIGNATION F310R - 12 L B Series name Bearing B : 1 ball bearing and 1 sleeve bearing C : 1 sleeve bearing Power supply 05 : DC5 V 12 : DC12 V Air flow L : 0.09 m3/min LL : 0.06 m3/min ■ LIST OF PART NUMBERS 1 ball bearing and 1 sleeve bearing 1 sleeve bearing Power supply Air flow 0.09 m3/min Air flow 0.09 m3/min Air flow 0.06 m3/min DC5 V F310R-05LB F310R-05LC F310R-05LLC DC12 V F310R-12LB F310R-12LC F310R-12LLC ❈ : Verify the above part numbers when placing orders. ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request. Oct, 2005 COPAL ELECTRONICS F310R BRUSHLESS DC FANS ■ STANDARD SPECIFICATIONS Item F310R-05LB -05LC F310R-05LLC F310R-12LB -12LC F310R-12LLC Rated voltage DC5 V DC12 V Voltage range 4.5 ~ 5.7 V 10.2 ~ 13.8 V Rated current 0.05 A 0.07 A 0.025 A 0.04 A Rotating speed 5500 min-1 7000 min-1 5500 min-1 7000 min-1 0.06 m3/min 0.09 m3/min 0.06 m3/min 0.09 m3/min 14 Pa 23 Pa 14 Pa 23 Pa 13 dB (A) 17 dB (A) 13 dB (A) 17 dB (A) Air flow Static pressure Noise Approx. 8 g Net weight ❈ : Figures in the table are typical values under rated operating condition. ■ AIR FLOW PERFORMANCE CURVES 30 Static pressure (Pa) 25 F310R-05LB -05LC -12LB -12LC 20 15 10 F310R-05LLC -12LLC 5 0 0 0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.1 3 Air flow (m /min) ■ OUTLINE DIMENSIONS (Unit: mm) 150±20 Lead wire : UL 1061 AWG28 Red : B Rated voltage Black : 0 V Dimension of mounting hole for recommendation 10±0.5 φ 28.6 24±0.5 □ 4 – C2.3 24±0.5 24±0.5 24±0.5 4 – φ 3.2 Air flow 4 – φ 3.2 30±0.5 ■ Specifications are subject to change without notice. Specifications in this catalog are for reference. The formal specification sheets will be submitted upon request. Oct, 2005
F310R-12LB 价格&库存
很抱歉,暂时无法提供与“F310R-12LB”相匹配的价格&库存,您可以联系我们找货
