1.75mm PLA (1kg) – Wood
SKU:FIT0361
1KG of 1.75mm PLA filament in light cherry color. Allows you to give your prints a
fantastic wood texture. Works fantastically with artworks. Its unique texture
and fragrance appeals to almost everyone.
Polylactic acid or polylactide (PLA) is an environmentally friendly material available for
3d printers, derived from renewable resources such as corn starch, tapioca roots, chips
and sugarcane, it decomposes easily and it comes in a wide range of colors.
You can print the filament in a range from 200°C to 220°C. Please make the appropriate
adjustments to temperature before you print with PLA, some testing might be needed to
find your optimal print settings.
SPECIFICATION
Plate Size: 200X200X64mm(7.87x7.87x2.52")
Diameters: 1.75mm
Net Weight: 1kg
PLA Parameter:
Print temperature: 200°C ~ 220°C
Density: 1.05~1.18g/cm3
Flow density(230Ԩ): 1.08~1.12g/cm3
Tg: 55~60Ԩ
Tm: 145~155Ԩ
MFR(210Ԩ): 5~18 g/10min
Tensile strength: 55MPa
Flexural Strength: 90MPa
Notched lzod lmpact: 0.1J/m2
SHIPPING LIST
1.75mm PLA (1kg) ‐ Wood x1
https://www.dfrobot.com/product‐1093.html 4‐26‐18
很抱歉,暂时无法提供与“FIT0361”相匹配的价格&库存,您可以联系我们找货
