EBH509
EBH509
    MENDA
    LONG CHISEL TIP 2.0MM
EBH509 数据手册
Desoldering Braid & Desoldering Wick | Quick Braid, Sea Braid, One-Step Home About MSDS FEATURED PRODUCTS CROSS REFERENCE PRODUCT OVERVIEW Compliance Documents Distributors Sales Reps Request a Sample Request a Quote Page 1 of 3 Contact News REPLACEMENT SOLDERING TIPS & SOLDERING STATIONS SOLDER/REWORK STATION DESOLDERING BRAID STENCIL ROLLS SOLDER SOAKERS REPLACEMENT SOLDERING TIPS & SOLDERING STATIONS SWABS FUME EXTRACTION SYSTEMS VISUAL INSPECTION SYSTEMS PARMI SOLDER PASTE INSPECTION BGA/PCB Inspection Endoscope Lens BGA Software Optical Inspection Standards The EB9000S Soldering/Rework Station, using Curie Heat Technology, will provide years of reliable performance. With this very precise and self-regulating technology, temperature calibration is not required. Included in the EB9000S are a 13.56 MHz Power Supply, detachable soldering iron stand with sponge and brass curl, tip removal pad, and the EBM8CH176 Solder Tip cartridge. Soldering Station Technical Specifications REPLACEMENT SOLDERING TIPS PROVIDE IMPROVED POWER, PERFORMANCE AND RELIABILITY z Increased plating results in longer service life and cost savings z Better connectivity through the use of gold plated connectors z Faster point to point soldering z Stable tip temperature Large PCBs Optical Inspections vs. X-Ray http://www.easybraidco.com/replacementsoldering.htm 11/12/2012 Desoldering Braid & Desoldering Wick | Quick Braid, Sea Braid, One-Step EASY BRAID PART # 600° Tips EASY BRAID EASY BRAID PART # PART # 700° Tips 800° Tips SIMILAR METCAL® Part # Page 2 of 3 DESCRIPTION EBM6CH175 EBM7CH175 EBM8CH175 STTC-X36 CHISEL 30° TIP 2.5mm EBM6CH176 EBM7CH176 EBM8CH176 STTC-X37 CHISEL 30° TIP 1.78mm EBM6CH177 EBM7CH177 EBM8CH177 STTC-X38 CHISEL 30° TIP 1.5mm EBM6CH178 EBM7CH178 EBM8CH178 STTC-X25 CHISEL 30° TIP 1.0mm EBM6CH179 EBM7CH179 EBM8CH179 STTC-X25P CHISEL 30° EXTRA CAPACITY TIP 1.0mm EBM6CH181 EBM7CH181 EBM8CH181 STTC-X13 CHISEL 90° TIP 3.0mm EBM6CH250 EBM7CH250 EBM8CH250 STTC-X17 Chisel Extra Large Tip 5.0mm (0.20") EBM6CP200 EBM7CP200 EBM8CP200 STTC-X36P CHISEL 30° EXTRA CAPACITY TIP 2.5mm EBM6CP201 EBM7CP201 EBM8CP201 STTC-X37P CHISEL 30° EXTRA CAPACITY TIP 1.8mm EBM6CB225 EBM7CB225 EBM8CB225 STTC-X98 CHISEL BENT 30° TIP 1.78mm EBM6CB226 EBM7CB226 EBM8CB226 STTC-X99 CHISEL BENT 30° TIP 1.5mm EBM6LC650 EBM7LC650 EBM8LC650 STTC-X65 CHISEL 5.0mm EBM6LR403 EBM7LR403 EBM8LR403 STTC-X42 CHISEL LONG REACH 60° TIP 1.78mm EBM6CS150 EBM7CS150 EBM8CS150 STTC-X06 CONICAL SHARP TIP 0.4mm (13.0mm tip length) EBM6CS151 EBM7CS151 EBM8CS151 STTC-X01 CONICAL SHARP TIP 1.0mm (13.4mm tip length) EBM6CS152 EBM7CS152 EBM8CS152 STTC-X22 CONICAL SHARP TIP 0.4mm (8.5mm tip length) EBM6CS154 EBM7CS154 EBM8CS154 STTC-X07 CONICAL SHARP TIP 1.0mm (16.4mm tip length) EBM6CS155 EBM7CS155 EBM8CS155 STTC-X43 CONICAL SHARP TIP 0.5mm EBM6C300 EBM7C300 EBM8C300 STTC-X45 CONICAL TIP 0.4mm EBM6C301 EBM7C301 EBM8C301 STTC-X16 CONICAL TIP 0.5mm EBM6CP302 EBM7CP302 EBM8CP302 STTC-X45P CONICAL EXTRA CAPACITY TIP 0.4mm EBM6CP303 EBM7CP303 EBM8CP303 STTC-X01P CONICAL EXTRA CAPACITY TIP 1.0mm EBM6SB275 EBM7SB275 EBM8SB275 STTC-X26 SHARP BENT 30° TIP 0.4mm (8.4mm tip length) EBM6SB276 EBM7SB276 EBM8SB276 STTC-X44 SHARP BENT 30° TIP 0.5mm EBM6B325 EBM7B325 EBM8B325 STTC-X40 SHARP BENT 30° TIP 0.4mm (16.0mm tip length) EBM6BV350 EBM7BV350 EBM8BV350 STTC-X47 BEVEL 60° TIP 1.78mm EBM6BS602 EBM7BS602 EBM8BS602 STTC-X47P BEVEL 60° TIP 1.8mm EBM6K100 EBM7K100 EBM8K100 SMTC-X161 KNIFE 45° 2.03mm EBM6DS526 EBM7DS526 EBM8DS526 SMTC-X173 KNIFE 45° 5.84mm EBM6MD575 EBM7MD575 EBM8MD575 SMTC-X172 CONICAL FINE TIP 30° 0.51mm EBM6DS525 EBM7DS525 EBM8DS525 SMTC-X147 HOOF 3.3mm EBM6DS529 EBM7DS529 EBM8DS529 SMTC-X167 MINI-HOOF 1.5mm EBM6LB125 EBM7LB125 EBM8LB125 SMTC-X60 LONG BLADE 10.41mm EBM6LB126 EBM7LB126 EBM8LB126 SMTC-X61 LONG BLADE 15.75mm EBM6LB127 EBM7LB127 EBM8LB127 SMTC-X62 LONG BLADE 22. 1mm EBM6MF375 EBM7MF375 EBM8MF375 STTC-X90 Micro Fine Tip 0.25mm (0.01") HAKKO® http://www.easybraidco.com/replacementsoldering.htm 11/12/2012 Desoldering Braid & Desoldering Wick | Quick Braid, Sea Braid, One-Step Part Number EBH500 EBH501 EBH502 EBH503 EBH504 EBH505 EBH506 EBH507 EBH508 EBH509 EBH510 EBH511 EBH512 EBH513 EBH514 EBH515 EBH516 EBH517 Page 3 of 3 CROSS FOR HAKKO 900MT05C 900MT08D 900MT12D 900MT12LD 900MT16D 900MT18H 900MT1C 900MT24D 900MT2C 900MT2LD 900MT32D 900MT32LD 900MT3C 900MT4C 900MTB 900MTI 900MK 900MTLB WELLER® Part Number EBW600 EBW601 EBW602 EBW603 EBW604 EBW605 EBW606 EBW607 EBW608 EBW609 EBW610 EBW611 EBW612 EBW613 EBW614 EBW615 EBW616 EBW617 EBW618 EBW619 EBW620 CROSS FOR WELLER LHT5C LHTC3.2 LHTD 45°5.0 LHTD5.0 LHTE7.0 LHTDX5.0 LHTF9.3 LHTFX9.0 LHTKN LHTO 2.0 LT1 0.25 LT18XL LT1L 0.25 LT1S 0.2 LT1SLX 0.4 LT1X 0.4 LT20 2.0 LT22S LT4 1.2 LT4CP 1.2 LTALF 1.6 SOLDERING STATIONS Part Number EB9000S EB9000PS EBSPG5 EBMSPG50 EBRMP-1 EBSHP-1 EBSHH-1 EBSG-1-GR EBSG-1-GY EBBC-10 Description Soldering Station Soldering System Power Supply Sponge Sponge Tip Removal Pad Hand Piece Workstand Grip - Green Grip - Gray Copper Curls Standard Package 1 1 5 50 1 1 1 1 1 1 Featured Product Cross Reference Product Overview Desoldering Braid Stencil Rolls Solder Soakers Replacement Soldering Tips & Soldering Stations Swabs Fume Extraction Systems Optical Inspection Systems BGA/PCB Inspection BGA Software Endoscope Lens Standards Large PCBs Optical vs. X-Ray Site Map ©2012 EasyBraid Co. 11543 K-Tel Drive Minneapolis, Minnesota 55343 Phone: 1-952-929-3040 Fax: 1-952-929-2765 Contact Us Site Map http://www.easybraidco.com/replacementsoldering.htm 11/12/2012
EBH509 价格&库存
很抱歉,暂时无法提供与“EBH509”相匹配的价格&库存,您可以联系我们找货
