XT06AAQ5ENJD270
XT06AAQ5ENJD270
    II-VI
XT06AAQ5ENJD270 数据手册
PRODUCT BRIEF Pluggable XFP-RF Transmitter Key Features for Hybrid Fiber Coaxial (HFC) Applications  DOCSIS 3.1 compatible: AllDigital QAM loading from 50 MHz to 1.2 GHz  Wavelength can be tuned across the entire C-band at 100GHz ITU DWDM spacings  Packaged in standard XFP pluggable optical module  Built-in digital diagnostic functions  Link distance up to 60 Wavelength tunable, 1.2 GHz pluggable optical transmitter module Overview Finisar’s XFP-RF transmitter is a small form factor hot-pluggable optical module that is compliant with interface specifications developed by the Society of Cable Telecommunications Engineers (SCTE). It can be fully loaded with digital QAM channels from 50 MHz to 1218 MHz to enable cable operators to more effectively segment their serving groups and offer more services to their subscribers. The small XFP module kilometers without any significantly reduces power consumption and increases density for downstream dispersion compensation transmitters. These modules can be integrated into today’s Hybrid-Fiber Coaxial (HFC)  LC Angled-Physical Contact optical broadband platforms and tomorrow’s converged access platforms (CCAP). (APC) optical connection for The transmitter wavelength can be tuned up to any of the 43 different Dense Wavelength low reflection Division Multiplexing (DWDM) wavelengths across the entire C-band in 500 ms. This  Low power consumption increases operational efficiencies in deploying DWDM networks and reduces inventory of  Compliant with SCTE 195 2013: transmitters at different fixed wavelengths. Wavelength tunability also opens the possibility Interface Specifications for an of novel HFC architectures that can dynamically route services and increase bandwidth RF-Modulated Small Form Factor capacity in the cable operator’s access network. Pluggable Optical Module  Mechanical dimensions Key Advantages compliant with 10 Gigabit Small  2x to 4x density improvement over current transmitter solutions Form Factor Pluggable Module  At least 50% less power consumption per transmitter (XFP) Multi-Source Agreement  Enables future HFC architectures to route services dynamically by changing the (INF-8077i, Rev. 4.5) Applications  1550nm Broadcast with DWDM Narrowcast Overlay architectures  All-Digital QAM networks  RF-over-Glass (RFoG) wavelength of the transmitter  Enables pluggable optics to be utilized directly in next-generation Cable Modem Termination Systems and QAM modulators Pluggable XFP-RF HFC Transmitter Specifications Parameter Value Optical Output Power +5 dBm or +6 dBm minimum (see product selection table below) Optical Wavelengths ITU DWDM Channels 18 to 60 (1528.77 nm to 1529.55 nm) Center Wavelength Spacing 100 GHz Wavelength Tuning Time 0.5 seconds typical Optical Connection LC/APC receptacle (angled physical contact) Optical Fiber Distance 0 km to 60 km Fiber Dispersion Compensation, Internal or External Not applicable SBS Suppression +13 dBm typical (higher SBS suppression available) 41 dB, Minimum (64 channels of 256 QAM, link distance of 50km) Modulation Error Ratio (MER) 37 dB, Minimum (154 channels of 256 QAM, link distance of 50km) RF Bandwidth 50 MHz to 1218 MHz RF Input Level Dependent on host module (+3 dBm composite typical into XFP-RF) RF Impedance Dependent on host module (100 Ω differential into XFP-RF) 1.0 dB max, peak to peak, 50 MHz to 1003 MHz RF Flatness 1.5 dB max, peak to peak, 50 MHz to 1218 MHz 16 dB min, 52 MHz to 1218 MHz RF Input Return Loss 78 mm (L ) X 18.35 mm (W) X 8.5 mm (H) Dimensions 3.0 in (L) X 0.7 in (W) X 0.3 in (H) Mounting XFP cage assembly on host module Operating Temperature Range 0˚C to 70˚C Storage Temperature Range -40˚C to 85˚C Power Consumption 3 Watts typical Data/Control Digital diagnostic functions via two-wire serial interface Product Selection Part Number Output Power Wavelength Control Wavelength Range XT05AAQTENJD1860 + 5 dBm Wavelength-Tunable 43 channels from ITU 18 to 60 XT05AAQ5ENJDxxx + 5 dBm Fixed Wavelength Single-channel between ITU 18 to 60 XT06AAQTENJD2035 + 6 dBm Wavelength-Tunable 16 channels from ITU 20 to 35 XT06AAQ5ENJDxxx + 6 dBm Fixed Wavelength Single-channel between ITU 20 to 35 xxx – fixed wavelength designated with ITU DWDM channel number (e.g. "210" for ITU channel 21) 1389 Moffett Park Drive Sunnyvale, CA 94089-1133 www.finisar.com Phone: +1-408-548-1000 Sales: +1-408-541-5690 Email: sales@finisar.com © 2015 Finisar Corporation. All rights reserved. Finisar is a registered trademark of Finisar Corporation. Features and specifications are subject to change without notice. 09/15 Visit Our Website
XT06AAQ5ENJD270 价格&库存
很抱歉,暂时无法提供与“XT06AAQ5ENJD270”相匹配的价格&库存,您可以联系我们找货
