SOMXAM3517-10-1780FJCR
    BEACONEMBEDDEDWORKS
SOMXAM3517-10-1780FJCR 数据手册
AM35x SOM-M2 Hardware Specification Hardware Documentation Logic PD // Products Published: November 2009 Last revised: July 2010 This document contains valuable proprietary and confidential information and the attached file contains source code, ideas, and techniques that are owned by Logic Product Development Company (collectively “Logic PD’s Proprietary Information”). Logic PD’s Proprietary Information may not be used by or disclosed to any third party except under written license from Logic Product Development Company. Logic Product Development Company makes no representation or warranties of any nature or kind regarding Logic PD’s Proprietary Information or any products offered by Logic Product Development Company. Logic PD’s Proprietary Information is disclosed herein pursuant and subject to the terms and conditions of a duly executed license or agreement to purchase or lease equipment. The only warranties made by Logic Product Development Company, if any, with respect to any products described in this document are set forth in such license or agreement. Logic Product Development Company shall have no liability of any kind, express or implied, arising out of the use of the Information in this document, including direct, indirect, special or consequential damages. Logic Product Development Company may have patents, patent applications, trademarks, copyrights, trade secrets, or other intellectual property rights pertaining to Logic PD’s Proprietary Information and products described in this document (collectively “Logic PD’s Intellectual Property”). Except as expressly provided in any written license or agreement from Logic Product Development Company, this document and the information contained therein does not create any license to Logic PD’s Intellectual Property. The Information contained herein is subject to change without notice. Revisions may be issued regarding changes and/or additions. © Copyright 2010, Logic Product Development Company. All Rights Reserved. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved i AM35x SOM-M2 Hardware Specification Revision History REV 1 2 3 4 5 A REVISION DESCRIPTION Schematic PN & REV APPROVAL DATE Initial Release 1013603 Rev B JCA 10/04/09 JCA Beta Release 1013603 Rev B JCA 11/04/09 CM -Section 3.2: Updated DC Main Battery Active Current measurement and clarified note explaining the conditions of that measurement; Added note 4 regarding the 802.11 measurements; -Section 6.3: Changed J3.36 to RFU from NAND_nCS; Changed voltages for J3.35 and J3.37 to 1.8V from 3.3V or 1.8V; Changed J3.39 to UART_DBG from RFU; Changed J3.41 to BT_DBG from RFU; Changed J3.46 to NAND_SEL from RFU -Minor grammatical edits throughout 1014320 Rev A NJK 02/18/10 JCA -Added Sections 2.3.4 & 2.3.5 to point to the Appendices for mechanical drawings -Added Example Retention Methods mechanical drawings -Section 3.10.2: Corrected number of McBSPs available on the SOM to 1014320 four since McBSP5 is used by the uP_HSBUSB signal. Rev A JCA 04/02/10 JCA -Section 3.6 & 3.7: Updated MAC address sticker information; -Section 3.7.1: Added note about FM interface; -Section 4.5.1.1: Corrected supported voltage range for MAIN_BATT_IN input; -Section 6.2 pins J2.49–52: Updated voltage and signal descriptions for 1014320 MAIN_BATT_IN Rev A CM 05/27/10 JCA, NJK Official Release -Added FCC Certification language throughout; -Added 802.11n protocol throughout; -Changed AM3517 microprocessor core to 600 MHz per TI spec; -Section 2.3.1: Updated height for wireless configuration; Updated weight for standard configuration SOM; -Section 2.3.3: Added antenna note pertaining to FCC guidelines; -Section 2.4: Added Industrial Temp range and note that Industrial Temp models do not include Wi-Fi/BT; -Section 3.1: Added USB0 and USB1 voltage parameters; -Section 3.2: Updated Note 3 to indicate the Main Battery Active Current was measured using a fully-populated SOM and the LCD current was not included in the measurement; Added USB0 and USB1 voltage parameters; Added 802.11n parameters. -Added Section 3.7.1: 2.4GHz Antenna Information; -Added Section 3.7.2: Wireless Software Requirements; -Section 3.11: Updated USB information to reflect what is available on the SOM, not the microprocessor; -Section 4.2: Corrected typo in reset signal names; -Section 6.1: Throughout, updates to clarify signal descriptions; J1.37 added microprocessor name and voltage; J1.85 specified signal as Input and 5V, was N/A; Specified or changed IO direction on J1.70, 89, 91; Added clarification to Note 1 that all IO pins must be set to same voltage; -Section 6.2: Throughout, updates to clarify signal descriptions; J2.57 &J2.63 signal descriptions were reversed for Ethernet activity and speed LEDs, this has been corrected; J2.84 description mistakenly called out McBSP1 instead of McBSP2; Specified or changed IO direction on J2.17, 34, 36, 38, 40, 42, 44, 46, 72, 78, 81, 82, 84-86, 88; Added clarification to Note 1 that all IO pins must be set to same voltage; -Section 6.3: Throughout, updates to clarify signal descriptions; J3.16 changed direction to Input and updated description; J3.26 description mistakenly called out McBSP4 instead of McBSP3; J3.47 changed direction to Output, voltage to 3.3V, and updated description; Specified or changed IO direction on J3.1-5, 7-13, 15, 23-29, 77, 85-88; Added clarification to Note 1 that all IO pins must be set to same voltage; 1015592 -Added mechanical drawing for AM35x SOM-M2 with wireless Rev A NJK 07/22/10 EDITOR CM Please check www.logicpd.com for the latest revision of this specification and other documents. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved ii AM35x SOM-M2 Hardware Specification FCC Certification This device complies with part 15 of the FCC Rules. Operation is subject to the following two conditions: (1) This device may not cause harmful interference, and (2) this device must accept any interference received, including interference that may cause undesired operation. Any changes or modifications not expressly approved by Logic PD could void the user's authority to use this device. See Application Note 447 for FCC guidelines pertaining to use of this device in end products. NOTE: This equipment has been tested and found to comply with the limits for a Class B digital device, pursuant to part 15 of the FCC Rules. These limits are designed t o provide reasonable protection against harmful interference in a residential installation. This equipment generates, uses and can radiate radio frequency energy and, if not installed and used in accordance with the instructions, may cause harmful interference to radio communications. However, there is no guarantee that interference will not occur in a particular installation. If this equipment does cause harmful interference to radio or television reception, which can be determined by turning the equipment off and on, the user is encouraged to try to correct the interference by one or more of the following measures: —Reorient or relocate the receiving antenna. —Increase the separation between the equipment and receiver. —Connect the equipment into an outlet on a circuit different from that to which the receiver is connected. —Consult the dealer or an experienced radio/TV technician for help. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved iii AM35x SOM-M2 Hardware Specification Table of Contents 1 Introduction ........................................................................................................................................... 1 1.1 Product Overview ............................................................................................................................. 1 1.2 Abbreviations, Acronyms, & Definitions ........................................................................................... 1 1.3 Nomenclature ................................................................................................................................... 2 1.4 Scope of Document.......................................................................................................................... 2 1.5 Additional Documentation Resources .............................................................................................. 2 2 Functional Specification ...................................................................................................................... 4 2.1 Microprocessor ................................................................................................................................. 4 2.1.1 AM35x Microprocessor .............................................................................................................. 4 2.1.2 AM35x Microprocessor Block Diagram ..................................................................................... 5 2.2 SOM Interface .................................................................................................................................. 5 2.2.1 AM35x SOM-M2 Block Diagram................................................................................................ 6 2.3 Mechanical Specifications ................................................................................................................ 6 2.3.1 Mechanical Characteristics of SOM-M2 .................................................................................... 6 2.3.2 Interface Connectors ................................................................................................................. 7 2.3.3 Wireless Antenna Connection ................................................................................................... 7 2.3.4 AM35x SOM-M2 Mechanical Drawings ..................................................................................... 7 2.3.5 Example AM35x SOM-M2 Retention Methods .......................................................................... 7 2.4 Temperature Specifications ............................................................................................................. 7 3 Electrical Specification ........................................................................................................................ 8 3.1 Absolute Power Maximum Ratings .................................................................................................. 8 3.2 Recommended Power Operating Conditions................................................................................... 8 3.3 Clocks............................................................................................................................................... 8 3.4 Memory ............................................................................................................................................ 9 3.4.1 Memory Management Unit (MMU) ............................................................................................ 9 3.4.2 DDR ........................................................................................................................................... 9 3.4.3 NAND Flash ............................................................................................................................... 9 3.4.4 MMC/SD Support .................................................................................................................... 10 3.5 DMA ............................................................................................................................................... 10 3.6 10/100 Ethernet PHY ..................................................................................................................... 10 3.7 802.11 Wireless Ethernet + Bluetooth ........................................................................................... 10 3.7.1 2.4 GHz Antenna Information .................................................................................................. 11 3.7.2 Software Requirements ........................................................................................................... 11 3.7.3 FM Interface............................................................................................................................. 11 3.8 Display Interface ............................................................................................................................ 11 3.9 Video Processing Front End .......................................................................................................... 12 3.9.1 TV_OUT................................................................................................................................... 12 3.10 Serial Interfaces ............................................................................................................................. 12 3.10.1 CAN Controller......................................................................................................................... 12 3.10.2 McBSP ..................................................................................................................................... 13 3.10.3 UARTs ..................................................................................................................................... 13 3.10.4 McSPI ...................................................................................................................................... 13 3.10.5 I2C ........................................................................................................................................... 13 3.10.5.1 I2C1 ................................................................................................................................... 14 3.11 USB Interface ................................................................................................................................. 14 3.12 ADC/Touch Interface...................................................................................................................... 15 3.13 Real Time Clock (RTC) .................................................................................................................. 15 3.14 General Purpose I/O (GPIO) .......................................................................................................... 15 3.15 Sysboot I/O .................................................................................................................................... 15 3.16 Expansion/Feature Options ........................................................................................................... 15 4 System Integration ............................................................................................................................. 17 4.1 Custom Configuration .................................................................................................................... 17 4.2 Resets ............................................................................................................................................ 17 PN 1014249 Rev A Logic Product Development Company, All Rights Reserved iv AM35x SOM-M2 Hardware Specification 4.2.1 Master Reset (RESPWRONn)—Reset Input .......................................................................... 17 4.2.2 SOM-M2 Reset (RESOUTn)—Reset Output .......................................................................... 17 4.2.3 SOM-M2 Reset (uP_RESWARMn)—Reset Input/Output ....................................................... 18 4.3 Interrupts ........................................................................................................................................ 18 4.4 JTAG Debugger Interface .............................................................................................................. 18 4.5 Power Management ....................................................................................................................... 18 4.5.1 System Power Supplies ........................................................................................................... 18 4.5.1.1 MAIN_BATT_IN ................................................................................................................ 18 4.5.1.2 VRTC_IN ........................................................................................................................... 19 4.5.2 Dual Voltage I/O ...................................................................................................................... 19 4.5.3 System Power Management ................................................................................................... 19 4.5.4 System Power Sequencing ..................................................................................................... 19 4.6 ESD Considerations ....................................................................................................................... 19 5 Memory & I/O Mapping ....................................................................................................................... 21 6 Pin Descriptions & Functions ........................................................................................................... 22 6.1 J1 Connector 100-Pin Descriptions ............................................................................................... 22 6.2 J2 Connector 100-Pin Descriptions ............................................................................................... 26 6.3 J3 Connector 100-Pin Descriptions ............................................................................................... 30 Appendix A: AM35x SOM-M2 Mechanical Drawing (with Wireless)..................................................... 37 Appendix B: AM35x SOM-M2 Mechanical Drawing (without Wireless) ............................................... 39 Appendix C: Example AM35x SOM-M2 Retention Methods ................................................................. 41 PN 1014249 Rev A Logic Product Development Company, All Rights Reserved v AM35x SOM-M2 Hardware Specification Table of Figures Figure 2.1: AM35x Microprocessor Block Diagram ...................................................................................... 5 Figure 2.2: AM35x SOM-M2 Block Diagram ................................................................................................. 6 Table 2.1: Board-to-Board Socket Connectors Manufacturer Information ................................................... 7 Table 2.2: Wireless Antenna Cable Manufacturer Information ..................................................................... 7 Table 3.1: AM3517Microprocessor Clocks ................................................................................................... 9 Table 3.2: I2C1 Bus Devices & Addresses ................................................................................................. 14 Table 3.3: Boot Strap Options ..................................................................................................................... 15 Table 5.1: Chip Select Signals .................................................................................................................... 21 PN 1014249 Rev A Logic Product Development Company, All Rights Reserved vi AM35x SOM-M2 Hardware Specification 1 Introduction 1.1 Product Overview The AM35x System on Module (SOM) is a compact, product-ready hardware and software solution that fast forwards embedded designs. Based on Texas Instruments’ Sitara AM35x microprocessor and designed in the SOM-M2 form factor, the AM35x SOM-M2 offers essential features for handheld and embedded networking applications. The SOM-M2 is an off-the-shelf solution that allows customers to focus on their high-value core technologies. The standard SOM-M2 form factor allows developers to reuse existing baseboard designs when upgrading to new AM processors, which extends roadmap possibilities for their end-product. By starting with the corresponding AM3517 EVM or eXperimenter Development Kit, engineers can write application software on the same hardware that will be used in the final product. The AM35x SOM-M2 is ideal for medical patient monitoring wearables and other portable instrumentation applications. The AM3517 includes an SGX530 graphics accelerator and multiple communication ports, including Bluetooth, wireless 802.11b/g/n, and wired 10/100 Ethernet. For commercial signage, medical imaging, avionics, and industrial displays, the AM3517 SOM-M2 allows for powerful versatility, long-life, and greener products. 1.2 Abbreviations, Acronyms, & Definitions ADC BSP BTB DDR DMA ESD FIFO GPIO GPMC GPO HECC I2C I2S IDC IC I/O IRQ LCD LDO McBSP OTG PCB PCMCIA PHY PLL PWM RTC SCC SDIO PN 1014249 Rev A Analog to Digital Converter Board Support Package Board-to-Board Double Data Rate (RAM) Direct Memory Access Electrostatic Discharge First In First Out General Purpose Input Output General Purpose Memory Controller General Purpose Output High End CAN Controller Inter-Integrated Circuit Inter-Integrated Circuit Sound Insulation Displacement Connector Integrated Circuit Input/Output Interrupt Request Liquid Crystal Display Low Dropout (Regulator) Multi-channel Buffered Serial Port On-the-Go (USB) Printed Circuit Board Personal Computer Memory Card International Association (PC Cards) Physical Layer Phase Lock Loop Pulse Width Modulation Real Time Clock Standard CAN Controller Secure Digital Input Output Logic Product Development Company, All Rights Reserved 1 AM35x SOM-M2 Hardware Specification SDRAM SCCB SOM SOM-M2 SSP SPI STN TFT TI TLB TSC TTL UART 1.3 1.4 Nomenclature ■ The terms “SOM” and “SOM-M2” are used interchangeably throughout this document and can be assumed to mean the same thing within this text. The SOM-M2 is a specific form factor type of Logic PD’s SOM. ■ Within this document, AM35x is used to denote the AM3505 and AM3517 microprocessors; where differences between microprocessor features occur, the specific microprocessor name is used. Scope of Document ■ 1.5 Synchronous Dynamic Random Access Memory Serial Camera Control Bus System on Module SOM form factor type Synchronous Serial Port Standard Programming Interface Super-Twisted Nematic (LCD) Thin Film Transistor (LCD) Texas Instruments Translation Look-Aside Buffer Touch Screen Controller Transistor-Transistor Logic Universal Asynchronous Receive Transmit This Hardware Specification is unique to the design and use of the AM3517 SOM-M2 as designed by Logic PD and does not intend to include information outside of that scope. Detailed information about the Texas Instruments (TI) AM3517 microprocessor or any other device component on the SOM can be found in their respective manuals and specification documents; please see Section 1.5 for additional resources. Additional Documentation Resources The following documents or documentation resources are referenced within this Hardware Specification. ■ TI’s AM3517/05 ARM Microprocessor Datasheet, Technical Reference Manual, User Guides, Application Notes, White Papers, and Errata http://www.ti.com/am3517 ■ TI’s TPS65023 Datasheet http://focus.ti.com/docs/prod/folders/print/tps65023.html ■ TI’s TSC2004 Datasheet http://focus.ti.com/docs/prod/folders/print/tsc2004.html ■ ARM Cortex-A8 Technical Reference Manual http://infocenter.arm.com/help/index.jsp. ■ USB 2.0 Specification, available from USB.org http://www.usb.org/developers/docs/ ■ U-Boot documentation http://www.denx.de/wiki/U-Boot/WebHome ■ Logic PD AM3517 SOM-M2 BOM, Schematic, and Layout http://support.logicpd.com/downloads/1238/ PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 2 AM35x SOM-M2 Hardware Specification ■ Logic PD AM3517 eXperimenter Baseboard BOM, Schematic, and Layout http://support.logicpd.com/downloads/1239/ ■ Logic PD AM3517 Application Board BOM, Schematic, and Layout http://support.logicpd.com/downloads/1240/ PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 3 AM35x SOM-M2 Hardware Specification 2 Functional Specification 2.1 Microprocessor 2.1.1 AM35x Microprocessor The AM35x SOM-M2 uses TI’s high-performance Sitara AM35x microprocessor. This device features the Superscalar ARM® Cortex™-A8 RISC core and provides many integrated on-chip peripherals, including: ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ ■ Superscalar ARM® Cortex™-A8 RISC core □ Vector floating point unit □ 16 Kbytes instruction L1 cache □ 16 Kbytes data L1 cache □ 256 Kbyte L2 cache □ 64 Kbyte RAM □ 112 Kbyte ROM Integrated display sub-system □ Parallel HD at 24 bit color, plus NTSC, Composite Video Processing Front End POWERVR™ SGX530 graphics accelerator from Imagination Technologies (AM3517 only) SDRAM Memory controller with EMIF4 and 1GByte address space GPMC memory controller with 16 bit bus, 8 chip selects, and NOR/NAND support Four UARTs Five multi-channel buffered serial ports (McBSP) Four McSPI CAN controller Three MMC/SD interfaces One 1-wire interface Three I2C interfaces 10/100 MBit Ethernet MAC with RMII interface High/Full/Low speed USB 2.0 On-the-Go (OTG) interface with integrated PHY High speed USB 2.0 Host interfaces Many general purpose I/O (GPIO) signals Programmable timers Watchdog timers Low power modes IMPORTANT NOTE: The AM35x microprocessor is heavily multiplexed; using one peripheral may preclude the use of another. Users should carefully review the microprocessor pinout, SOM pinout, and AM35x multiplexing table. See TI’s AM35x ARM Microprocessor Technical Reference Manual and Data Sheet for additional information; the documents are available from TI’s website. IMPORTANT NOTE: Please visit TI’s website for errata on the AM35x. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 4 AM35x SOM-M2 Hardware Specification 2.1.2 AM35x Microprocessor Block Diagram Figure 2.1: AM35x Microprocessor Block Diagram NOTE: The block diagram pictured above comes from TI’s AM3517/05 ARM Microprocessor Datasheet (document number SPRS550–OCTOBER 2009). 2.2 SOM Interface Logic PD’s common SOM interface allows for easy migration to new microprocessors and technology. Logic PD is constantly researching and developing new technologies to improve performance, lower cost, and increase feature capabilities. By using the common SOM footprint, it is possible to take advantage of Logic PD’s work without having to re-spin the old design in certain cases dependent upon peripheral usage. Please contact Logic PD for more information. In fact, encapsulating a significant amount of your design onto the SOM reduces any long-term risk of obsolescence. If a component on the SOM design becomes obsolete, Logic PD will simply PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 5 AM35x SOM-M2 Hardware Specification design for an alternative part that is transparent to your product. Furthermore, Logic PD tests all SOMs prior to delivery, decreasing time-to-market and ensuring a simpler and less costly manufacturing process. 2.2.1 AM35x SOM-M2 Block Diagram Figure 2.2: AM35x SOM-M2 Block Diagram 2.3 Mechanical Specifications 2.3.1 Mechanical Characteristics of SOM-M2 Parameter Min Typical Max Unit Dimensions (without wireless) — 40.9 x 51.2 x 4.4 — mm Notes Dimensions (with wireless) — 40.9 x 51.2 x 5.4 — mm Weight — 11.0 — Grams 1 Connector Insertion/Removal — 30 — Cycles NOTES: 1. May vary depending on SOM configuration. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 6 AM35x SOM-M2 Hardware Specification 2.3.2 Interface Connectors The AM35x SOM-M2 connects to a PCB baseboard through three 100-pin board-to-board (BTB) socket connectors. Table 2.1: Board-to-Board Socket Connectors Manufacturer Information 2.3.3 Ref Designator Manufacturer SOM-M2 Connector P/N Mating Connector P/N J1:3 Hirose DF40C-100DP-0.4V(51) DF40C-100DS-0.4V(51) Wireless Antenna Connection The mechanical drawing in Appendix A shows the location of the 802.11b/g/n Ethernet and Bluetooth antenna connector (J4) on the top side of the PCB. Table 2.2 contains the manufacturer information for the cables that Logic PD provides in the AM3517 EVM Development Kit. NOTE: To comply with FCC certification already completed on the AM35x SOM-M2, the antenna selected for an end product must meet FCC guidelines as described in Section 3.7.1. Table 2.2: Wireless Antenna Cable Manufacturer Information 2.3.4 Ref Designator Manufacturer P/N J4 Hirose U.FL Coax cable Sunridge Corp. MCBG-RH-54-080-SMAJB281 AM35x SOM-M2 Mechanical Drawings Please see Appendix A for mechanical drawings of the AM35x SOM-M2 and recommended baseboard footprint layout. 2.3.5 Example AM35x SOM-M2 Retention Methods Please see Appendix B for mechanical drawings demonstrating three possible retention methods for the AM35x SOM-M2. These drawings are only meant to serve as possible solutions and should not be considered final designs for retention. 2.4 Temperature Specifications Parameter Min Typical Max 0 25 70 °C Industrial Operating Temperature -40 25 85 °C Storage Temperature -40 25 85 °C Commercial Operating Temperature Unit Notes 1 NOTES: 1. Industrial temperature model will be available in the second half of 2010. Industrial temperature model does not include Wi-Fi/Bluetooth module. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 7 AM35x SOM-M2 Hardware Specification 3 Electrical Specification 3.1 Absolute Power Maximum Ratings Parameter Symbol Rating Unit DC Main Battery Input Voltage MAIN_BATT_IN 0.0 to 7.0 V RTC Backup Battery Voltage VRTC_IN 0.0 to 5 V USB0 VBUS Voltage USB0_VBUS 0.0 to 5.5 V USB1 VBUS Voltage USB1_VBUS 0.0 to 6.0 V NOTE: These stress ratings are only for transient conditions. Operation at, or beyond, absolute maximum rating conditions may affect reliability and cause permanent damage to the SOM-M2 and its components. 3.2 Recommended Power Operating Conditions Parameter Min Typical Max Unit DC Main Battery Input Voltage 3.5 5 6 V DC Main Battery Active Current — 302 — mA DC RTC Backup Battery Voltage 1.8 3.2 5 V DC USB0_VBUS Voltage — 5 — V Notes 3 DC USB1_VBUS Voltage 0 5 5.5 V 802.11b Transmit Power +16 +18 +20 dBm 4 802.11b Receive Sensitivity 802.11g Transmit Power 802.11g Receive Sensitivity 802.11n Transmit Power 802.11n Receive Sensitivity BT Transmit Power BT Receive Sensitivity — -87 -76 dBm 4 +11 +13 +15 dBm 4 — -73 -68 dBm 4 +10 +12 +14 dBm 4 -64 dBm 4 dBm 4 dBm 4 V 2 0.35 x VREF V 2 — -67 +4.5 +8.0 — -90 -70 Input Signal High Voltage 0.65 x VREF — VREF Input Signal Low Voltage -0.3 — Output Signal High Voltage -- — VREF V Output Signal Low Voltage GND — 0.2 V 2 NOTES: 1. 2. 3. 4. 3.3 General note: CPU power rails are sequenced on the module. VREF represents the peripheral I/O supply reference for the specific CPU voltage rail. Measured across R178 with 4.2V input. Fully populated SOM running Demo application on U-Boot/Linux version 2009.08. 4.3” display attached (but current from the display is not included in the measurement); no other peripherals attached. Wireless numbers taken from the Murata LBEH19XMMC Module Datasheet (Rev. I). Logic PD is working to verify these numbers on the SOM application. Clocks The AM35x requires an oscillator to enable proper internal timing. A 26.000 MHz oscillator is used to generate many of the microprocessor’s internal clocks via a series of Phase Lock Loops (PLLs) and signal dividers. To generate the core CPU clock, the 26.000 MHz signal is run through PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 8 AM35x SOM-M2 Hardware Specification a Digital PLL controlled by the PRCM registers. Divisors are used to divide down the internal bus frequency to set the LCD, memory controller, camera interface, etc. IMPORTANT NOTE: Please see TI’s AM35x ARM Microprocessor Technical Reference Manual for additional information about microprocessor clocking. The second required clock runs at 32.768 kHz and is connected directly to the AM35x. The 32.768 kHz clock is used for CPU start up and reference. The CPU’s core clock speed is initialized by software on the SOM-M2. The SDRAM bus speed is set at 166 MHz in U-Boot. Other clock speeds, such as core speed and specific serial baud rates, can be supported and modified in software for specific user applications. The SOM-M2 provides an external bus clock, uP_OBSCLK. This clock is driven by the SYS_CLKOUT1 pin. Table 3.1: AM3517Microprocessor Clocks AM35x Microprocessor Signal Name SOM-M2 Net Name Default Software Value in U-Boot CORE N/A Up to 600 MHz SDRC_CLK uP_DDR_CLK 166 MHz SYSCLKOUT1 uP_OBSCLK 26MHz 3.4 Memory 3.4.1 Memory Management Unit (MMU) The AM35x SOM has one MMU for the microprocessor unit (MPU). The MPU MMU is described in the ARM Cortex-A8 Technical Reference Manual, available at http://infocenter.arm.com/help/index.jsp. 3.4.2 DDR The AM35x SOM uses a 32-bit memory bus to interface to two 16-bit DDR2 SDRAM memories. The memory on the SOM-M2 included in the AM3517 EVM Development Kit is 256 MB DDR2, organized as 64 Meg x 32. Other memory densities may be available for SOMs in production volumes. Please contact Logic PD about custom configurations if your design requires different memory densities from Logic PD’s standard SOM configurations. 3.4.3 NAND Flash The SOM-M2 uses the 16-bit GPMC memory bus to interface to a single 512 MB NAND flash memory chip. It is possible to expand the system’s non-volatile storage capability by adding external flash ICs, SD memory, NOR, or NAND flash on the user application board. See the AM3517 EVM Development Kit for reference designs or contact Logic PD for other possible peripheral designs. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 9 AM35x SOM-M2 Hardware Specification 3.4.4 MMC/SD Support The SOM-M2 directly supports a single SD/MMC slot. The SOM-M2 routes the signals for MMC1 to the baseboard connectors, allowing connections on a user design to a socket where a card can be mounted. MMC1 supports up to 8 data bits. The AM35x microprocessor has functionality for two more MMC peripherals: MMC2 is used for the Murata Wi-Fi/Bluetooth module on the SOM. It has functionality on the upper 4 data bits to support direction control for an SD/MMC buffer. MMC3 is an alternate pin mapping for other peripherals used elsewhere on the SOM. The AM3517 eXperimenter Board reference design includes a single SD/MMC connector. Please contact Logic PD for more information on implementing additional slots. 3.5 DMA The AM35x has several DMA controllers: ■ SDMA – data transfers from the microprocessor to peripherals ■ Display DMA ■ USB High Speed (HS) DMA The SDMA controller (DMA4) has the following features: ■ 32 channels (independent, concurrent, variable data size, burst/chain, endian conversion) ■ Memory to memory, memory to peripheral ■ Interrupts ■ 256 32-bit FIFOs 3.6 10/100 Ethernet PHY The AM35x SOM-M2 uses an SMSC LAN8710 Ethernet PHY to provide an easy-to-use networking interface. The four analog PHY interface signals (transmit/receive) each require an external impedance matching circuit to operate properly. Logic PD provides an example circuit schematic in the AM35x eXperimenter Board Schematics. Please note the TX+/- and RX+/- pairs must be routed as differential pairs (at 100 ohms) on the baseboard PCB. The 10/100 Ethernet MAC address can be found in two ways. One, the MAC address is printed on a sticker affixed to the top side of the SOM and is the address that does not follow this convention: 00:08:EE:xx:xx:xx. Two, the 10/100 Ethernet MAC address is stored within the AM35x microprocessor and can be obtained using software; please refer to TI’s AM35x ARM Microprocessor Technical Reference Manual for this procedure. 3.7 802.11 Wireless Ethernet + Bluetooth The SOM-M2 uses a Murata LBEH19XMMC 802.11b/g/n + Bluetooth 2.1 Wireless IC to provide an easy-to-use wireless networking interface. The LBEH19XMMC is connected to the AM35x through a combination of MMC, SDIO, and GPIO. The RF connector is located on the SOM at reference designator J4; J4 is shared between 802.11 and Bluetooth. The MAC address for 802.11b/g/n is printed on a sticker affixed to the top side of the SOM. The 802.11b/g/n MAC address follows this convention: 00:08:EE:xx:xx:xx NOTE: Transmit power (VBAT) comes from U22, which converts the incoming voltage (MAIN_BATT_IN) to ~3.5V. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 10 AM35x SOM-M2 Hardware Specification NOTE: See Application Note 447 for FCC guidelines pertaining to use of the AM35x SOM-M2 in end products. 3.7.1 2.4 GHz Antenna Information The AM35x SOM-M2 has been qualified to use a Pulse W1038, 4.9 dBi Omni-directional antenna. Use of this antenna will satisfy FCC regulations. A different Omni-directional antenna with a peak gain of 4.9 dBi or less may be substituted and still satisfy FCC regulations. If an antenna with higher gain or of a different type is to be used, the end product must be put through intentional radiation testing at a qualified test lab. Please refer to FCC rules 47 CFR § 15.204 for more information. 3.7.2 Software Requirements In order to be FCC compliant with the 802.11b/g/n and Bluetooth devices, the following software must be used: ■ ■ 802.11b/g/n: Bluetooth: Firmware Version: Rev 6.1.0.0.313 Firmware Version: 7.2.31; initialization script TI_P31.91 Any other version of the firmware must be approved by the FCC. If another version of the firmware is desired, please contact Logic PD for assistance with certification. 3.7.3 FM Interface The Murata module on the SOM-M2 has FM capabilities. FM signals are routed to the baseboard connectors (see Section 6) for connection to audio processing and antenna. NOTE: The FM interface is untested and not supported with software. IMPORTANT NOTE: The FCC certification for the AM35x SOM-M2 does not cover FM signals; therefore, use of FM signals will require independent FCC testing and certification. 3.8 Display Interface The AM35x has a built-in graphics controller supporting up to 24-bit parallel RGB (pixel rates up to 74.25 MHz enabling HD resolutions) along with two 10-bit Digital-to-Analog Converters (DAC) supporting composite NTSC/PAL video and Luma/Chroma Separate Video (S-Video). Image rotation, resizing, color space conversion, and 8-bit alpha blending functions are built in. See TI’s AM35x Technical Reference Manual for further information on the integrated LCD controller. The signals from the AM35x LCD controller are organized by bit and color and can be interfaced through the SOM-M2 expansion connectors. The signals from the SOM-M2 are driven from the 3.3V_or_1.8V rail. Logic PD has written drivers for panels of different types and sizes. Please contact Logic PD before selecting a display for your application. NOTE: In 3.3V IO mode, an LCD can be driven directly from the AM3517. NOTE: The eXperimenter Baseboard uses the standard Logic PD 16-bit LCD interface as well as a 24-bit HDMI transceiver. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 11 AM35x SOM-M2 Hardware Specification IMPORTANT NOTE: Using the internal graphics controller may affect microprocessor performance. Selecting display resolutions and color bits per pixel will vary microprocessor busload. 3.9 Video Processing Front End The AM35x has a built-in 16-bit video input port supporting RAW data interface, up 75 MHz pixel clock, REC656/CCIR656, YCbCr422 format (8- and 16-bit), black clamping signal generation, 10-bit to 8-bit A-law compression, and up to 16K pixels in horizontal and vertical directions. The signal input to the VPFE is through the CCDC bus connections. The SOM-M2 supports an 8-bit video input interface with control lines on the CCDC bus (see Section 6). See TI’s AM35x Technical Reference Manual and Logic PD’s AM3517 Application Board Schematics for connection details. 3.9.1 TV_OUT The AM35x supports S-Video on the TV_OUT signals (see Section 6 for details). Note that the TV_OUT signals need to be routed at 75 ohms single ended. There are optional noise-filtering component locations on the SOM-M2 for the TV_OUT signals. 3.10 Serial Interfaces The SOM-M2 comes with the following serial channels: high end CAN controller, multichannel buffered serial ports (McBSPs), four McSPI ports, up to four UARTS, and three I2C ports. If additional serial channels are required, please contact Logic PD for reference designs. Please see TI’s AM35x Technical Reference Manual for further information regarding serial communications. 3.10.1 CAN Controller The AM3517 has a high performance CAN 2.0B controller. It includes a CAN Protocol Kernel, a Standard CAN Controller (SCC), and a High End CAN Controller (HECC). The SCC supports 16 receive/transmit message objects, while the HECC supports 32 receive/transmit message objects. The HECC also supports 32 receive-identifier masks. Other features of the CAN controller include: ■ ■ ■ ■ ■ ■ ■ ■ 1 Mbps data rate Programmable sampling rate Selectable edge for synchronization Automatic re-transmission Bus failure diagnostic Self test Wake-up on bus activity Auto reply The signals from the SOM-M2 are driven from the 3.3V_or_1.8V rail. The end-product design must provide an external CAN transceiver. Logic PD has provided an example reference design with the AM3517 Application Board Schematics. When choosing a CAN transceiver, the designer should keep in mind bus loading, availability, ESD protection, and data rates. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 12 AM35x SOM-M2 Hardware Specification 3.10.2 McBSP The SOM-M2 provides access to four multi-channel buffered serial ports (McBSP) with the following capabilities: ■ ■ ■ ■ ■ ■ Full-duplex and multi-drop 512B FIFO on McBSP1, 3, 4; 5KB FIFO on McBSP2 Max data rate of 48 Mbps I2S, PCM, and TDMI support Support for external clocks and frame sync Sidetone support on McBSP2/3 (requires channels are looped back) The signals from the SOM-M2 are scaled to IO voltage levels (3.3V_or_1.8V), not RS232 level signals. NOTE: McBSP5 is an alternate pin mapping of the HSUSB bus. On the AM35x SOM-M2, uP_HSUSB is used for the USB host port and McBSP5 is not available. 3.10.3 UARTs The AM35x microprocessor has up to four asynchronous serial ports with the following capabilities: ■ ■ ■ ■ ■ 16C750-compatible. IrDA and CIR support (UART3 only) 64 byte FIFO on receive and transmit Hardware or software flow control Baud rates to 3686400 bps The signals from the SOM-M2 are TTL level signals (3.3V_or_1.8V), not RS232 level signals. NOTE: UART4 is an alternate pin function of GPMC_WAIT1/2. 3.10.4 McSPI The SOM-M2 makes McSPI ports 1 and 2 available. They have the following characteristics: ■ ■ ■ ■ ■ ■ ■ Four channels / chip selects (McSPI1) Two channels / chip selects (McSPI2) Programmable frequency, polarity, and phase for each channel SPI word lengths ranging from 4 bits to 32 bits Up to four master channels or single channel in slave mode Master multichannel mode with either full duplex or half duplex 64 byte FIFO Please see TI’s AM35xx Technical Reference Manual for further information. The signals from the SOM-M2 are TTL level signals (3.3V or 1.8V), not RS232 level signals. Note that McSPI3 is an alternate function of MMC2, which is used for the on-board Murata WiFi module. 3.10.5 I2C The AM35x microprocessor has three I2C ports with the following characteristics: ■ ■ ■ Slave or master mode Serial camera control bus (SCCB) mode Compliant with I2C version 2.1 PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 13 AM35x SOM-M2 Hardware Specification ■ ■ ■ ■ Standard (100Kbps) and fast mode (400Kbps) High-speed mode up to 3.4Mbps 7- and 10-bit addressing 8 byte (I2C1, I2C2) and 64 byte (I2C3) FIFOs Please see TI’s AM35x ARM Microprocessor Technical Reference Manual for further information. The signals from the SOM-M2 are TTL level signals (3.3V or 1.8V), not RS232 level signals. 3.10.5.1 I2C1 Table 3.2 lists the devices that are connected to the SOM-M2 I2C1 bus. IMPORTANT NOTE: the INA219 Power Measurement ICs are only populated on the AM3517 SOM-M2 included with the AM3517 EVM Development Kit; they are connected to I2C1 only when resistors R200 and R201 are populated. Table 3.2: I2C1 Bus Devices & Addresses 3.11 Device Hex Address S35390 0x30 Binary Address Function 0b0110000 RTC on I2C1 TPS65023 0x48 0b1001000 PMIC on I2C1 TSC2004 0x4B 0b1001011 Touch on I2C1 INA219 0x40 0b1000000 5V power measure on PM/I2C1 INA219 0x41 0b1000001 1.2V power measure on PM/I2C1 INA219 0x42 0b1000010 VIO power measure on PM/I2C1 INA219 0x43 0b1000011 1.8V power measure on PM/I2C1 USB Interface The AM35x SOM-M2 supports one USB 2.0 high-speed host port and one USB 2.0 OTG port; the USB PHY for the OTG port (USB0) is internal to the AM35x microprocessor. The SOM-M2 adds an external SMSC USB3320 PHY connected to the HSUSB bus to implement a high-speed host port (USB1). All ports can operate at up to 480 Mbit/sec. NOTE: The host port (USB1) does not support full- or low-speed; to use full- or low-speed peripherals, an external hub is required. A second host port can be implemented by connecting to the ETK bus (labeled uP_HSUSB1) on connector J3. The third host port is an alternate pin function of other interfaces. Refer to the AM3517 Application Board Schematics for example circuitry. For more information on pin-mapping and using both USB host and OTG interfaces, please see TI’s AM35xx Technical Reference Manual. IMPORTANT NOTE: In order to correctly implement USB on the SOM-M2, additional impedance matching circuitry may be required on the USBx_D+ and USBx_D- signals before they can be used. USB 2.0 requirements specify the signals must be routed as differential pairs with a 90 ohm differential impedance. Refer to the USB 2.0 Specification for detailed information. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 14 AM35x SOM-M2 Hardware Specification 3.12 ADC/Touch Interface The SOM-M2 uses TI’s TSC2004 touch screen controller (TSC). The controller includes a 12-bit analog-to-digital converter (ADC). This TSC is used to support standard 4-wire resistive touch panels and one auxiliary A/D signal. The device is connected to the CPU by the I2C1 interface. Please see TI’s TSC2004 Datasheet for more information. 3.13 Real Time Clock (RTC) The SOM-M2 has a Seiko S35390 real time clock connected to I2C1. Note that the RTC requires an additional voltage (VRTC_IN) to operate and to perform timekeeping when MAIN_BATT_IN is not present. The voltage for the RTC comes from VRTC_IN (see Section 6). The AM3517 EVM Development Kit reference design includes example circuitry to power VRTC_IN from either the power supply or backup battery. 3.14 General Purpose I/O (GPIO) Logic PD designed the SOM-M2 to be flexible and provide multiple options for analog and digital GPIO. There are numerous digital GPIO pins on the SOM-M2 that interface to the AM35x. See Section 6 of this document for more information. If certain peripherals are not desired, such as the LCD controller, chip selects, or UARTs, then more GPIO pins become available. 3.15 Sysboot I/O The AM35x has eight lines dedicated for Sysboot functionality. Two of these are pulled down on the SOM and not connected externally (uP_SYSBOOT7:8); the remainder are routed to the baseboard connectors. Default resistors on the SOM-M2 set a boot order of: NAND, EMAC, USB, MMC1. Changes to the boot order can be made with baseboard circuitry; however, four of the Sysboot lines (Sysboot1,3,4,6) are used as GPIO on the SOM-M2 after boot. IMPORTANT NOTE: When using the Sysboot pins as IO, be aware that they cannot be driven during reset. Table 3.3: Boot Strap Options 3.16 BOOT[8:0] Boot Order [BOOT5 = 0 default] Boot Order [BOOT5 = 1] 0b0 01X0 1100 (Default) NAND, EMAC, USB, MMC1 EMAC, USB, MMC1, NAND 0b0 01X0 1101 XIP, USB, UART, MMC1 USB, UART, MMC1, XIP 0b0 01X0 1000 XDOC, EMAC, USB, EMAC USB, XDOC 0b0 01X0 1001 MMC2, EMAC, USB, EMAC USB, MMC2 Expansion/Feature Options The SOM was designed for expansion and a variable feature set, providing all the necessary control signals and bus signals to expand the user’s design. Some of these signals are buffered and brought out to the expansion connectors. It is possible for a user to expand the SOM’s functionality even further by adding host bus or ISA bus devices. Some features that are PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 15 AM35x SOM-M2 Hardware Specification implemented on the AM35x microprocessor, but are not discussed herein, include: pulse width modulation (PWM), Secure Digital, MMC cards, SDIO cards, 1wire interface, watchdog timers, or the debug module. See TI’s AM35xx Technical Reference Manual and Logic PD’s AM3517 SOMM2 Schematics for more details. Logic PD has experience implementing additional options, including other audio codecs, Ethernet ICs, co-processors, and components on SOMs. Please contact Logic PD for potential reference designs before selecting your peripherals. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 16 AM35x SOM-M2 Hardware Specification 4 System Integration 4.1 Custom Configuration The AM3517 SOM-M2 was designed to meet multiple applications for users with specific design and budget requirements. As a result, this SOM supports a variety of embedded operating systems, flexible DDR and flash memory footprints, and other hardware configurations. If your application needs require unique hardware or software configurations, please contact Logic PD about custom SOMs available in production volumes. 4.2 Resets The SOM-M2 has a reset input (RESPWRONn) and a reset output (RESOUTn). External devices should use RESPWRONn to assert reset to the product. The SOM-M2 uses RESOUTn to indicate to other devices that the SOM-M2 is in reset. 4.2.1 Master Reset (RESPWRONn)—Reset Input Logic PD suggests that custom designs implementing the AM35x SOM-M2 use the RESPWRONn signal as the “pin-hole” reset used in commercial embedded systems. The RESPWRONn triggers a power-on-reset event to the AM35x microprocessor via the TPS65023 PMIC and resets the entire CPU. IMPORTANT NOTE: Any custom reset circuit design should guard the assertion of the reset lines during a low power state so as to prevent power-up in a low or bad power condition. (Powering up in a low or bad power condition will cause data corruption and, possibly, temporary system lock. Either one of the following two conditions will cause a system-wide reset: power on the RESPWRONn signal or a low pulse on the RESPWRONn signal. Low Pulse on RESPWRONn Signal A low pulse on the RESPWRONn signal for longer than 30mS—asserted by an external source (for example, the reset button on the custom design application)—will bring RESOUTn low for 100mS after the assertion source is de-asserted. Logic PD suggests that for any external assertion source that triggers the RESPWRONn signal, analog or digital, de-bouncing should be used to generate a clean, one-shot reset signal. 4.2.2 SOM-M2 Reset (RESOUTn)—Reset Output All hardware peripherals should connect their hardware-reset pin to the RESOUTn signal on the expansion connector. Internally, all SOM-M2 peripheral hardware reset pins are connected to the RESOUTn net. If the reset circuit is asserted (active low), the user can expect to lose information stored in RAM. The data loss occurs because the CPU is reset to its reset defaults. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 17 AM35x SOM-M2 Hardware Specification 4.2.3 SOM-M2 Reset (uP_RESWARMn)—Reset Input/Output uP_RESWARMn is the raw AM35x reset I/O. As such, it is sensitive to external loading and no devices with active pull-ups should be added to this line. It is permissible to have active low circuitry on this line. 4.3 Interrupts The AM35x incorporates the ARM Cortex-A8 interrupt controller which provides many inter-system interrupt sources and destinations. Most external GPIO signals can also be configured as interrupt inputs by configuring their pin control registers. Logic PD BSPs setup and process all SOM-M2 interrupt sources, onboard and external. Refer to TI’s AM35xx Reference Manual for further information on using interrupts. IRQn is routed to the baseboard, see Section 6 for details. 4.4 JTAG Debugger Interface The JTAG connection on the AM35x allows recovery of corrupted flash memory, and real-time application debug. There are several third-party JTAG debuggers available for TI microprocessors. The following signals make up the JTAG interface to the AM35x microprocessor: TDI, TMS, TCK, TDO, nTRST, RTCK, EMU0, EMU1, and RESOUTn (RESOUTn is only required for some JTAG tools; see the JTAG tool documentation for exact pinout). These signals should interface directly to a 20-pin 0.1” through-hole connector, as shown on the AM3517 eXperimenter Baseboard Schematics. IMPORTANT NOTE: When laying out the 20-pin connector, realize that it may not be numbered as a standard 20-pin 0.1” insulation displacement connector (IDC) through-hole connector. See the EVM Development Kit reference design for further details. Each JTAG tool vendor may define the 20-pin IDC connector pin-out differently. 4.5 Power Management 4.5.1 System Power Supplies In order to ensure a flexible design, the SOM-M2 has the following power inputs: MAIN_BATT_IN and VRTC. MAIN_BATT_IN is the power input to the SOM-M2 PMIC (TPS65023). The TPS65023 generates the on-board voltages for the AM35x and associated peripherals. Note that 3.3V_or_1.8V is an output of the SOM PMIC, and is the selectable IO voltage rail. The setting is determined by the baseboard design by using signal IO_VOLTAGE_SEL (see Section 6 for details). IMPORTANT NOTE: 3.3V_or_1.8V is an output from the SOM-M2, and should only be used as a reference voltage input to level shifting devices on baseboard designs. 4.5.1.1 MAIN_BATT_IN The MAIN_BATT_IN input is the main source of power for the SOM-M2. In normal configuration, this input expects a voltage from 3.5V to 5V. The TPS65023 power management controller takes the MAIN_BATT_IN rail input and creates all onboard voltages. If the design is required to maintain RAM contents in a critical power situation (e.g., low battery, loss of power), the PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 18 AM35x SOM-M2 Hardware Specification MAIN_BATT_IN supply should be maintained above the minimum level at all costs (see Section 2). 4.5.1.2 VRTC_IN VRTC_IN is used to power the real time clock, U35. Always power this rail to maintain the clock and power state of the product. A lithium-ion coin cell typically supplies power to this rail. See the AM3517 eXperimenter Baseboard Schematic for details on powering VRTC_IN. 4.5.2 Dual Voltage I/O The AM35x microprocessor and SOM-M2 uniquely support dual-voltage I/O. The user may select an operating voltage of either 1.8V or 3.3V through “IO_VOLTAGE_SEL” J1.37. For 3.3V operation, J1.37 should be left unconnected. For 1.8V operation, J1.37 should be tied directly to GND. IMPORTANT NOTE: The IO_VOLTAGE_SEL line should only be changed with the SOM powered off. 4.5.3 System Power Management Good power management design is important in any system development and embedded system design is no exception. In embedded system design, power management is typically one of the most complicated areas due to the dramatic effect it has on product cost, performance, usability, and overall customer satisfaction. Many factors affect a power-efficient hardware design: power supply selection (efficiency), clocking design, IC and component selection, etc. The SOM was designed with these aspects in mind while also providing maximum flexibility in software and system integration. On the AM35x there are many different software configurations that drastically affect power consumption: microprocessor core clock frequency, bus clock frequency, peripheral clocks, bus modes, power management states; peripheral power states and modes; product user scenarios; interrupt handling; and display settings (resolution, backlight, refresh, bits per pixel, etc). These settings are typically initialized in the startup software routines and may be modified later in the operating system and application software. Information for these items can be found in the appropriate documents such as the U-Boot User’s Manual or the specific BSP manual. 4.5.4 System Power Sequencing Power sequencing for the AM35x is handled by the TPS65023 PMIC. IMPORTANT NOTE: External circuitry should guarantee that any voltages applied to SOM pins are present only after the SOM-M2 has completed its power up sequence. Failure to do so may result in erratic SOM-M2 operation or device damage. One way to ensure this is to use the external reset (RESOUTn) as a gating signal for all external power supplies. 4.6 ESD Considerations The SOM was designed to interface to a customer’s peripheral board, while remaining low cost and adaptable to many different applications. The SOM does not provide any onboard ESD protection circuitry—this must be provided by the product it is used in. Logic PD has extensive PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 19 AM35x SOM-M2 Hardware Specification experience in designing products with ESD requirements. Please contact Logic PD if you need any assistance in ESD design considerations. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 20 AM35x SOM-M2 Hardware Specification 5 Memory & I/O Mapping On the AM35x microprocessor, all address mapping for the GPMC chip select signals is listed below. Mapped “Chip Select” signals for the AM35x are available as outputs from the microprocessor and are assigned as described in Table 5.1. Table 5.1: Chip Select Signals Chip Select Device/Feature Notes nCS0 NAND / boot NOR Boot chip select for NAND device or external NOR (when configured on AM3517 Application Board) nCS1 External CS Available for use by an off-board external device nCS2 External CS Available for use by an off-board external device nCS3 External CS Available for use by an off-board external device nCS4:7 Used as GPIO See Section 6 for details PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 21 AM35x SOM-M2 Hardware Specification 6 Pin Descriptions & Functions SOM Net Name: This is the name used in Logic PD’s AM3517 SOM-M2 Schematics. Microprocessor Name: This is the name used TI’s AM35x ARM Microprocessor Datasheet. I/O: This indicates the default pin usage. Most pins can be configured as either input or output. Consult Logic PD’s AM3517 SOM-M2 Schematics and TI’s AM35x ARM Microprocessor Datasheet for more information. IMPORTANT NOTE: All IO is run at either 3.3V or 1.8V; there is no individual pin selection of IO voltages. Description: If a pull-up or pull-down resistor is present on the AM3517 SOM-M2, it will be noted here. Special usage tips and cautions will be noted here. Consult Logic PD’s AM3517 SOM-M2 Schematics and TI’s AM35x ARM Microprocessor Datasheet for more information. 6.1 J1 Connector 100-Pin Descriptions J1 Pin# SOM Net Name 1 uP_DSS_DOUT8 2 uP_DSS_DOUT0 3 uP_DSS_DOUT9 4 uP_DSS_DOUT1 5 uP_DSS_DOUT10 6 uP_DSS_DOUT2 7 uP_DSS_DOUT11 8 uP_DSS_DOUT3 9 uP_DSS_DOUT12 10 uP_DSS_DOUT4 11 uP_DSS_DOUT13 12 uP_DSS_DOUT5 13 uP_DSS_DOUT14 PN 1014249 Rev A Microprocessor Name I/O Voltage Description DSS_DATA8/GPIO 3.3V or 1.8V LCD G3 data bit when operating in 16 bpp _78/HW_DBG16 O (see Note 1) 5:6:5 color mode. DSS_DATA0/UAR T1_CTS/DSSVEN 3.3V or 1.8V LCD B1 data bit when operating in 16 bpp C656_DATA0/GPI O_70 O (see Note 1) 5:6:5 color mode. DSS_DATA9/GPIO 3.3V or 1.8V LCD_G4 data bit when operating in 16 bpp _79/HW_DBG17 O (see Note 1) 5:6:5 color mode. DSS_DATA1/UAR T1_RTS/DSSVEN 3.3V or 1.8V LCD_B2 data bit when operating in 16 bpp C656_DATA1/GPI O_71 O (see Note 1) 5:6:5 color mode. DSS_DATA10/GPI 3.3V or 1.8V LCD_G5 data bit when operating in 16 bpp O_80 O (see Note 1) 5:6:5 color mode. DSS_DATA2/DSS VENC656_DATA2/ 3.3V or 1.8V LCD_B3 data bit when operating in 16 bpp GPIO_72 O (see Note 1) 5:6:5 color mode. DSS_DATA11/GPI 3.3V or 1.8V LCD_R1 data bit when operating in 16 bpp O_81 O (see Note 1) 5:6:5 color mode. DSS_DATA3/DSS VENC656_DATA3/ 3.3V or 1.8V LCD_B4 data bit when operating in 16 bpp GPIO_73 O (see Note 1) 5:6:5 color mode. DSS_DATA12/GPI 3.3V or 1.8V LCD_R2 data bit when operating in 16 bpp O_82 O (see Note 1) 5:6:5 color mode. LCD_B5 data bit when operating in 16 bpp DSS_DATA4/UAR 5:6:5 color mode. Notice that LCD_B0 is T3_RX_IRRX/DSS omitted; LCD_B5 (Blue MSB) is also 3.3V or 1.8V connected to LCD_B0 (Blue LSB) when VENC656_DATA4/ GPIO_74 O (see Note 1) driving an 18 bit display with 16 bits. DSS_DATA13/GPI 3.3V or 1.8V LCD_R3 data bit when operating in 16 bpp O_83 O (see Note 1) 5:6:5 color mode. DSS_DATA5/UAR T3_TX_IRTX/DSS 3.3V or 1.8V LCD_G0 data bit when operating in 16 bpp VENC656_DATA5/ GPIO_75 O (see Note 1) 5:6:5 color mode. DSS_DATA14/GPI 3.3V or 1.8V LCD_R4 data bit when operating in 16 bpp O_84 O (see Note 1) 5:6:5 color mode. Logic Product Development Company, All Rights Reserved 22 AM35x SOM-M2 Hardware Specification Microprocessor Name DSS_DATA6/UAR T1_TX/DSSVENC 656_DATA6/GPIO _76/HW_DBG14 J1 Pin# SOM Net Name 14 uP_DSS_DOUT6 15 uP_DSS_DOUT15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 I/O Voltage O Description 3.3V or 1.8V LCD_G1 data bit when operating in 16 bpp (see Note 1) 5:6:5 color mode. LCD_R5 data bit when operating in 16 bpp 5:6:5 color mode. Notice that LCD_R0 is omitted; LCD_R5 (Red MSB) is also 3.3V or 1.8V connected to LCD_R0 (Red LSB) when (see Note 1) driving an 18 bit display with 16 bits. DSS_DATA15/GPI O_85 O DSS_DATA7/UAR T1_RX/DSSVENC 3.3V or 1.8V LCD_G2 data bit when operating in 16 bpp 656_DATA7/GPIO uP_DSS_DOUT7 _77/HW_DBG15 O (see Note 1) 5:6:5 color mode. DSS_HSYNC/GPI 3.3V or 1.8V uP_DSS_HSYNC O_67/HW_DBG13 O (see Note 1) LCD Horizontal Sync signal. DSS_PCLK/GPIO_ 3.3V or 1.8V LCD Pixel Clock signal. This signal has a uP_DSS_PCLK 66/HW_DBG12 O (see Note 1) 22 ohm series resistor on the SOM. DGND VSS I GND Ground. Connect to digital ground. DGND VSS I GND Ground. Connect to digital ground. DSS_VSYNC/GPI 3.3V or 1.8V uP_DSS_VSYNC O_68 O (see Note 1) LCD Vertical Sync signal. RFU — NA NA Reserved for future use. Do not connect. 3.3V or 1.8V LCD AC bias control (STN) or pixel data DSS_ACBIAS/GPI uP_DSS_ACBIAS O_69 O (see Note 1) enable (TFT) signal. CCDC_PCLK/GPI 3.3V or 1.8V CCDC_PCLK O_94/HW_DBG0 I (see Note 1) Video Processor Pixel Clock signal. USB0_DRVVBUS/ UART3_TX_IRTX/ 3.3V or 1.8V Power enable for external USB0 power uP_USB0_DRVVBUS GPIO_125 O (see Note 1) switch. CCDC_HD/UART4 3.3V or 1.8V CCDC_HD _RTS/GPIO_96 I (see Note 1) Video Processor Horizontal Sync signal. FM_AINR — I Analog input to FM on Murata module. CCDC_VD/UART4 3.3V or 1.8V _CTS/GPIO_97/H CCDC_VD W_DBG2 I (see Note 1) Video Processor Vertical Sync signal. Active low. External reset input to the SOM-M2. This signal should be used to reset all devices on the SOM-M2 including TPS65023 MAIN_BATT_ the CPU. 4.7k pull-up on SOM to RESPWRONn HOT_RESET I IN MAIN_BATT_IN. CCDC_WEN/CCD C_DATA9/UART4_ 3.3V or 1.8V Video Processor Memory Write Enable RX/GPIO_98/HW_ CCDC_WEN DBG3 I (see Note 1) signal. Active low. Software can use as a SYS_NIRQ/GPIO_ 3.3V or 1.8V hardware interrupt. This signal has a 4.7k IRQn 0 I (see Note 1) pull-up on the SOM. CCDC_FIELD/CC DC_DATA8/UART 3.3V or 1.8V 4_TX/I2C3_SCL/G CCDC_FLD PIO_95/HW_DBG1 I (see Note 1) Video Processor Field ID signal. RFU — NA NA Reserved for future use. Do not connect. CCDC_DATA7/GP 3.3V or 1.8V CCDC_D7 IO_106 I (see Note 1) Video Processor data bit 7. RFU — NA NA Reserved for future use. Do not connect. CCDC_DATA6/GP 3.3V or 1.8V CCDC_D6 IO_105 I (see Note 1) Video Processor data bit 6. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 23 AM35x SOM-M2 Hardware Specification Microprocessor Name J1 Pin# SOM Net Name 37 IO_VOLTAGE_SEL 38 39 CCDC_D5 FM_AOUTR 40 41 CCDC_D4 FM_AOUTL 42 43 CCDC_D3 DGND 44 45 UART1_TX FM_RXI 46 47 UART1_CTS DGND 48 UART1_RTS 49 CAN_RX 50 UART1_RX 51 CAN_TX 52 53 UART3_RTS DGND 54 55 UART3_CTS FM_TXO 56 57 MMC1_D6 FM_AINL 58 MMC1_D7 59 MMC1_D0 60 MMC2_D0 61 MMC1_D1 62 MMC2_D1 63 MMC1_D2 64 MMC2_D2 PN 1014249 Rev A TPS65023 DEFDCDC2 CCDC_DATA5/GP IO_104/HW_DBG7 -CCDC_DATA4/GP IO_103/HW_DBG6 -CCDC_DATA3/GP IO_102/HW_DBG5 — UART1_TX/GPIO_ 148 -UART1_CTS/GPIO _150 — UART1_RTS/GPIO _149 HECC1_RXD/UAR T3_RTS_SD/GPIO _131 UART1_RX/MCBS P1_CLKR/MCSPI4 _CLK/GPIO_151 HECC1_TXD/UAR T3_RX_IRRX/GPI O_130 UART3_RTS_SD/ GPIO_164 — UART3_CTS_RCT X/GPIO_163 -MMC1_DAT6/GPI O_128 -MMC1_DAT7/GPI O_129 MMC1_DAT0/MCS PI2_CLK/GPIO_12 2 MMC2_DAT0/MCS PI3_SOMI/UART4 _TX/GPIO_132 MMC1_DAT1/MCS PI2_SIMO/GPIO_1 23 MMC2_DAT1/UAR T4_RX/GPIO_133 MMC1_DAT2/MCS PI2_SOMI/GPIO_1 24 MMC2_DAT2/MCS PI3_CS1/GPIO_13 4 I/O Voltage O Description Input to TPS65023 PMIC. This signal has a MAIN_BATT_ 4.7k pull-up resistor. See Section 4.5.2 for IN more information. 3.3V or 1.8V (see Note 1) Video Processor data bit 5. -Connected to FM output of Murata module. 3.3V or 1.8V (see Note 1) Video Processor data bit 4. Connected to FM output of Murata module. 3.3V or 1.8V (see Note 1) Video Processor data bit 3. GND Ground. Connect to digital ground. 3.3V or 1.8V (see Note 1) UART1 Transmit signal. — RX input of Murata module 3.3V or 1.8V (see Note 1) UART1 Clear To Send signal. GND Ground. Connect to digital ground. 3.3V or 1.8V (see Note 1) UART1 Ready To Send signal. I 3.3V or 1.8V HECC Receive input. Connect to CAN (see Note 1) transceiver on baseboard. I 3.3V or 1.8V (see Note 1) UART1 Receive signal. I I O I O I I O I I I 3.3V or 1.8V (see Note 1) 3.3V or 1.8V O (see Note 1) I GND 3.3V or 1.8V I (see Note 1) O — 3.3V or 1.8V I/O (see Note 1) I — 3.3V or 1.8V I/O (see Note 1) O HECC Transmit output. Connect to CAN transceiver on baseboard. UART3 Ready To Send signal. Ground. Connect to digital ground. UART3 Clear To Send signal. Connected to FM output of Murata module. — Analog input to FM on Murata module. MMC1 Data bit 7. 3.3V or 1.8V I/O (see Note 1) MMC1 Data bit 0. 3.3V or 1.8V I/O (see Note 1) MMC2 Data bit 0. 3.3V or 1.8V I/O (see Note 1) MMC1 Data bit 1. 3.3V or 1.8V I/O (see Note 1) MMC2 Data bit 1. 3.3V or 1.8V I/O (see Note 1) MMC1 Data bit 2. 3.3V or 1.8V I/O (see Note 1) MMC2 Data bit 2. Logic Product Development Company, All Rights Reserved 24 AM35x SOM-M2 Hardware Specification J1 Pin# SOM Net Name 65 3.3V_or_1.8V 66 MMC2_D3 67 68 3.3V_or_1.8V TOUCH_X1 69 70 MMC1_D3 TOUCH_X2 71 72 MMC1_D4 TOUCH_Y1 73 74 MMC1_D5 TOUCH_Y2 75 MMC1_CMD 76 MMC2_CMD 77 MMC1_CLK 78 79 80 MMC2_CLK DGND DGND 81 uP_USB1_DM 82 uP_USB0_DM 83 uP_USB1_DP 84 uP_USB0_DP 85 86 87 88 USB1_VBUS uP_USB0_ID USB0_VBUS USB0_VBUS 89 90 UART2_CTS 5V_IN 91 92 UART2_RTS 5V_IN PN 1014249 Rev A Microprocessor Name I/O Voltage Description I/O Voltage Output from SOM. Do not use 3.3V or 1.8V this as a general purpose power source. (see Note 1) Use this pin to power level shifters etc. VDDSHV O MMC2_DAT3/MCS PI3_CS0/GPIO_13 3.3V or 1.8V 5 I/O (see Note 1) MMC2 Data bit 3. I/O Voltage Output from SOM. Do not use 3.3V or 1.8V this as a general purpose power source. VDDSHV O (see Note 1) Use this pin to power level shifters etc. — I 1.8V Touch Left (X+) Input to TSC2004. MMC1_DAT3/MCS PI2_CS0/GPIO_12 3.3V or 1.8V 5 I/O (see Note 1) MMC1 Data bit 3. — I 1.8V Touch Left (X-) Input to TSC2004. MMC1_DAT4/GPI 3.3V or 1.8V O_126 I/O (see Note 1) MMC1 Data bit 4. — I 1.8V Touch Left (Y+) Input to TSC2004. MMC1_DAT5/GPI 3.3V or 1.8V O_127 I/O (see Note 1) MMC1 Data bit 5. — I 1.8V Touch Left (Y-) Input to TSC2004. MMC1_CMD/GPIO 3.3V or 1.8V _121 I/O (see Note 1) MMC1 Command signal. MMC2_CMD/MCS PI3_SIMO/UART4 3.3V or 1.8V _RTS/GPIO_131 I/O (see Note 1) MMC2 Command signal. MMC1_CLK/GPIO 3.3V or 1.8V MMC1 Clock signal. This signal has a 47 _120 O (see Note 1) ohm series resistor on the SOM. MMC2_CLK/MCSP I3_CLK/UART4_C 3.3V or 1.8V MMC2 Clock signal. This signal has a 47 TS/GPIO_130 O (see Note 1) ohm series resistor on SOM. — I GND Ground. Connect to digital ground. — I GND Ground. Connect to digital ground. USB1 Data Minus (see Note 4). Connects -I/O (see Note 3) to USB3320 on the SOM. USB0_DM/UART3 _RX_IRRX I/O (see Note 3) USB0 Data Minus (see Note 4). USB1 Data Plus (see Note 4). Connects to -I/O (see Note 3) USB3320 on the SOM. USB0_DP/UART3 _TX_IRTX I/O (see Note 3) USB0 Data Plus (see Note 4). USB1 VBus. This signal is used by the USB3320 to determine when a device is — I 5V connected/disconnected. USB0_ID I (see Note 3) USB0 ID signal. USB0_VBUS I 5V or GND USB0 VBus. USB0_VBUS I 5V or GND USB0 VBus. UART2_CTS/MCB SP3_DX/GPT9_P 3.3V or 1.8V WM_EVT/GPIO_1 44 I (see Note 1) UART2 Clear To Send signal. — I 5V Not used on SOM-M2. Do not connect. UART2_RTS/MCB SP3_DR/GPT10_P 3.3V or 1.8V WM_EVT/GPIO_1 45 O (see Note 1) UART2 Ready To Send signal. — I 5V Not used on SOM-M2. Do not connect. Logic Product Development Company, All Rights Reserved 25 AM35x SOM-M2 Hardware Specification 93 94 UART2_TX DGND 95 96 UART2_RX 5V_IN Microprocessor Name UART2_TX/MCBS P3_CLKX/GPT11_ PWM_EVT/GPIO_ 146 VSS UART2_RX/MCBS P3_FSX/GPT8_P WM_EVT/GPIO_1 47 — 97 98 UART3_TX 5V_IN UART3_TX_IRTX — O I 99 100 UART3_RX DGND UART3_RX_IRRX VSS I I J1 Pin# SOM Net Name I/O Voltage O I O I Description 3.3V or 1.8V (see Note 1) UART2 Transmit signal. GND Ground. Connect to digital ground. 3.3V or 1.8V (see Note 1) 5V 3.3V or 1.8V (see Note 1) 5V 3.3V or 1.8V (see Note 1) GND UART2 Receive signal. Not used on SOM-M2. Do not connect. UART3 Transmit signal. Not used on SOM-M2. Do not connect. UART3 Receive signal. Ground. Connect to digital ground. NOTE 1: Most AM3517 SOM-M2 I/O pins are dual-voltage capable; that is, the SOM I/O pins may be configured to operate at 3.3V or 1.8V; however, all IO pins must be set to the same voltage. The desired I/O voltage is set via J1.37. See Section 4.5.2 for more information. NOTE 2: At startup, the boot mode is determined by sampling uP_SYS_BOOT [0:6]. Resistors on the SOM pull these pins to a default value. User boards may select alternate boot modes by pulling selected pins opposite their default value; to do this, the user board must use resistors of much lower impedance than those used on the SOM. User boards must ensure that other circuits do not drive or load down these pins at startup. Driving/loading these pins at startup may cause the AM3517 microprocessor to latch an incorrect boot mode. NOTE 3: USB voltage levels follow the USB specification and depend on the USB operating speed. Please see the USB 2.0 Specification for more information. NOTE 4: Route USB signals as 45 ohms single ended, 90 ohm differential. 6.2 J2 Connector 100-Pin Descriptions J2 Pin# SOM Net Name 1 GPMC_D7 2 ENET_INTn 3 GPMC_D8 4 GPMC_WAIT1 5 GPMC_D9 6 GPMC_WAIT2 7 GPMC_D10 8 GPMC_NBE1 PN 1014249 Rev A Microprocessor Name I/O Voltage Description 3.3V or 1.8V I/O (see Note 1) GPMC Bus Data Bit 7. GPMC_D7 GPMC_NCS7/GP MC_IO_DIR/0/GPT 3.3V or 1.8V Interrupt for Ethernet PHY (LAN9710). 4.7K 8_PWM_EVT/GPI O_58 I (see Note 1) pull-up on SOM. GPMC_D8/GPIO_ 3.3V or 1.8V 44 I/O (see Note 1) GPMC Bus Data Bit 8. GPMC_WAIT1/UA 3.3V or 1.8V RT4_TX/GPIO_63 I (see Note 1) WAIT1 signal for GPMC interface. GPMC_D9/GPIO_ 3.3V or 1.8V 45 I/O (see Note 1) GPMC Bus Data Bit 9. GPMC_WAIT2/UA 3.3V or 1.8V RT4_RX/GPIO_64 I (see Note 1) WAIT2 signal for GPMC interface. GPMC_D10/GPIO 3.3V or 1.8V _46 I/O (see Note 1) GPMC Bus Data Bit 10. GPMC_NBE1/GPI 3.3V or 1.8V O_61 O (see Note 1) BYTE Enable 1 for GPMC Interface. Logic Product Development Company, All Rights Reserved 26 AM35x SOM-M2 Hardware Specification J2 Pin# SOM Net Name 9 GPMC_D11 10 GPMC_NBE0_CLE 11 GPMC_D12 12 GPMC_WEn 13 GPMC_D13 14 GPMC_OEn 15 GPMC_D14 16 GPMC_NADV_ALE 17 GPMC_D15 18 19 20 21 GPMC_CLK DGND DGND RFU 22 GPMC_nCS5 23 GPMC_A1 24 RTCINTn 25 GPMC_A2 26 GPMC_nCS3 27 GPMC_A3 28 GPMC_nCS2 29 GPMC_A4 30 GPMC_nCS1 31 GPMC_A5 32 GPMC_nCS0 33 GPMC_A6 34 GPMC_D0 35 GPMC_A7 PN 1014249 Rev A Microprocessor Name GPMC_D11/GPIO _47 GPMC_NBE0_CL E/GPIO_60 GPMC_D11/GPIO _48 GPMC_NWE GPMC_D11/GPIO _49 GPMC_NOE GPMC_D11/GPIO _50 GPMC_NADV_AL E GPMC_D11/GPIO _51 GPMC_CLK/GPIO _59 VSS VSS — GPMC_NCS5/SYS _NDMAREQ2/0/G PT10_PWM_EVT/ GPIO_56 GPMC_A1/GPIO_ 34 GPMC_NCS4/SYS _NDMAREQ1/GPT 9_PWM_EVT/GPI O_55 GPMC_A2/GPIO_ 35 GPMC_NCS3/SYS _NDMAREQ0/GPT 10_PWM_EVT/GPI O_54 GPMC_A3/GPIO_ 36 GPMC_NCS2/GPT 9_PWM_EVT/GPI O_53 GPMC_A4/GPIO_ 37 GPMC_NCS1/GPI O_52 GPMC_A5/GPIO_ 38 GPMC_nCS0 GPMC_A6/GPIO_ 39 GPMC_D0 GPMC_A7/GPIO_ 40 I/O Voltage 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) I GND I GND NA NA O O O O O O GPMC Bus Data Bit 11. BYTE Enable 0 for GPMC Interface. GPMC Bus Data Bit 12. GPMC Bus Write Enable. GPMC Bus Data Bit 13. GPMC Bus Output Enable. GPMC Bus Data Bit 14. GPMC Bus Address Latch Enable. GPMC Bus Data Bit 15. GPMC Bus Clock. Ground. Connect to digital ground. Ground. Connect to digital ground. Reserved for future use. Do not connect. 3.3V or 1.8V (see Note 1) GPMC Bus Chip Select 5. 3.3V or 1.8V (see Note 1) GPMC Bus Address Bit 1. 3.3V or 1.8V Active low. Real Time Clock Interrupt. This (see Note 1) signal has a 4.7k pull-up. 3.3V or 1.8V (see Note 1) GPMC Bus Address Bit 2. 3.3V or 1.8V (see Note 1) GPMC Bus Chip Select 3. 3.3V or 1.8V (see Note 1) GPMC Bus Address Bit 3. 3.3V or 1.8V (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) O Description GPMC Bus Chip Select 2. GPMC Bus Address Bit 4. GPMC Bus Chip Select 1. GPMC Bus Address Bit 5. GPMC Bus Chip Select 0. GPMC Bus Address Bit 6. GPMC Bus Data Bit 0. GPMC Bus Address Bit 7. Logic Product Development Company, All Rights Reserved 27 AM35x SOM-M2 Hardware Specification Microprocessor Name J2 Pin# SOM Net Name 36 GPMC_D1 37 GPMC_A8 38 GPMC_D2 39 GPMC_A9 40 GPMC_D3 41 GPMC_A10 GPMC_D3 GPMC_A10/SYS_ NDMAREQ3/GPIO _43 42 43 GPMC_D4 RFU GPMC_D4 — I/O NA 44 45 GPMC_D5 RFU GPMC_D5 — I/O NA 46 47 48 GPMC_D6 DGND DGND GPMC_D6 VSS VSS I/O I I 49 MAIN_BATT_IN — I max 6V 50 MAIN_BATT_IN — I max 6V 51 MAIN_BATT_IN — I max 6V 52 53 54 55 56 MAIN_BATT_IN DGND DGND RFU TV_OUT1 ETHER_LINK_ACT_L EDn TV_OUT2 — VSS VSS — TV_OUT1 I I I NA O max 6V GND GND NA — 57 58 59 60 61 62 63 GPMC_D1 GPMC_A8/GPIO_ 41 I/O Voltage 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) 3.3V or 1.8V I/O (see Note 1) GPMC_D2 GPMC_A9/SYS_N DMAREQ2/GPIO_ 42 Description GPMC Bus Data Bit 1. GPMC Bus Address Bit 8. GPMC Bus Data Bit 2. 3.3V or 1.8V (see Note 1) GPMC Bus Address Bit 9. 3.3V or 1.8V I/O (see Note 1) GPMC Bus Data Bit 3. O O 3.3V or 1.8V (see Note 1) 3.3V or 1.8V (see Note 1) NA 3.3V or 1.8V (see Note 1) NA 3.3V or 1.8V (see Note 1) GND GND GPMC Bus Address Bit 10. GPMC Bus Data Bit 4. Reserved for future use. Do not connect. GPMC Bus Data Bit 5. Reserved for future use. Do not connect. GPMC Bus Data Bit 6. Ground. Connect to digital ground. Ground. Connect to digital ground. External power source input. This signal should be driven directly by a single cell lithium-ion battery or a fixed regulated power source. See Sections 3.2 & 4.5.1.1. External power source input. This signal should be driven directly by a single cell lithium-ion battery or a fixed regulated power source. See Sections 3.2 & 4.5.1.1. External power source input. This signal should be driven directly by a single cell lithium-ion battery or a fixed regulated power source. See Sections 3.2 & 4.5.1.1.. External power source input. This signal should be driven directly by a single cell lithium-ion battery or a fixed regulated power source. See Sections 3.2 & 4.5.1.1. Ground. Connect to digital ground. Ground. Connect to digital ground. Reserved for future use. Do not connect. Composite/Luma S-Video (See Note 4). — O — Connect to anode of Ethernet Activity LED. TV_OUT2 O Chroma S-Video (See Note 4). I2C3_SDA/GPIO_1 3.3V or 1.8V uP_I2C3_SDA 85 I/O (see Note 1) I2C3 Serial Data. I2C2_SDA/GPIO_1 3.3V or 1.8V uP_I2C2_SDA 83 I/O (see Note 1) I2C2 Serial Data. I2C3_SCL/GPIO_1 3.3V or 1.8V uP_I2C3_SCL 84 O (see Note 1) I2C3 Serial Clock. I2C2_SDA/GPIO_1 3.3V or 1.8V uP_I2C2_SCL 68 O (see Note 1) I2C2 Serial Clock. Connect to cathode of Ethernet Speed ETHER_SPEED_LED — O — LED. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 28 AM35x SOM-M2 Hardware Specification Microprocessor Name — J2 Pin# SOM Net Name 64 VRTC_IN 65 3.3V_or_1.8V 66 uP_McBSP1_CLKR VDDSHV MCBSP1_CLKR/M CSPI4_CLK/GPIO _156 67 3.3V_or_1.8V VDDSHV 68 69 uP_McBSP_CLKS RFU McBSP_CLKS — 70 uP_MCBSP1_FSX MCBSP1_FSX 71 ETHER_TX+ — 72 uP_MCBSP1_DR MCBSP1_DR 73 ETHER_TX- — 74 uP_MCBSP1_DX MCBSP1_DX 75 ETHER_RX+ — 76 uP_MCBSP1_FSR MCBSP1_FSR 77 ETHER_RX- 78 79 80 uP_MCBSP1_CLKX DGND DGND 81 uP_SPI1_CLK 82 uP_MCBSP2_CLKX 83 uP_SPI1_SOMI 84 uP_MCBSP2_FSX 85 uP_SPI1_SIMO 86 uP_MCBSP2_DX 87 uP_SPI1_SCSn0 88 uP_MCBSP2_DR — MCBSP1_CLKX/M CBSP3_CLKX/GPI O_162 — — MCSPI1_CLK/MM C2_DAT4/GPIO_1 71 MCBSP2_CLKX/G PIO_117 MCSPI1_SOMI/M MC2_DAT6/GPIO_ 173 MCBSP2_FSX/GPI O_116 MCSPI1_SIMO/M MC2_DAT5/GPIO_ 172 MCBSP2_DX/GPI O_119 MCSPI1_CS0/MM C2_DAT7/GPIO_1 74 MCBSP2_DR/GPI O_118 PN 1014249 Rev A I/O Voltage I 2V-5V O Description Voltage for Real Time Clock on the SOM. I/O Voltage Output from SOM. Do not use 3.3V or 1.8V this as a general purpose power source. (see Note 1) Use this pin to power level shifters etc. 3.3V or 1.8V McBSP1 Receive Clock. This signal has a (see Note 1) 22 ohm series resistor on the SOM. I/O Voltage Output from SOM. Do not use 3.3V or 1.8V this as a general purpose power source. O (see Note 1) Use this pin to power level shifters etc. 3.3V or 1.8V McBSP Shared Clock. This signal has a 22 O (see Note 1) ohm series resistor on the SOM. NA NA Reserved for future use. Do not connect. 3.3V or 1.8V O (see Note 1) McBSP1 Transmit Frame Sync signal. Ethernet Transmit plus (+). This signal has a 49.9 ohm pull-up on the SOM. See Note O — 2. 3.3V or 1.8V I (see Note 1) McBSP1 Receive Data signal. Ethernet Transmit minus (-). This signal has a 49.9 ohm pull-up on the SOM. See O — Note 2. 3.3V or 1.8V O (see Note 1) McBSP1 Transmit Data signal. Ethernet Receive plus (+). This signal has a 49.9 ohm pull-up on the SOM. See Note I — 2 3.3V or 1.8V I (see Note 1) McBSP1 Receive Frame Synch signal. Ethernet Receive minus (-). This signal has a 49.9 ohm pull-up on the SOM. See Note I — 2. O O I I O O I O O O O I 3.3V or 1.8V (see Note 1) GND GND McBSP1 Transmit Clock. This signal has a 22 ohm series resistor on the SOM. Ground. Connect to digital ground. Ground. Connect to digital ground. 3.3V or 1.8V (see Note 1) 3.3V or 1.8V (see Note 1) SPI1 clock signal. This signal has a 22 ohm series resistor on the SOM. McBSP2 Transmit Clock. This signal has a 22 ohm series resistor on the SOM. 3.3V or 1.8V (see Note 1) SPI1 Slave Out, Master In signal. 3.3V or 1.8V (see Note 1) McBSP2 Transmit Frame Sync signal. 3.3V or 1.8V (see Note 1) SPI1 Slave In, Master Out signal. 3.3V or 1.8V (see Note 1) McBSP2 Transmit Data signal. 3.3V or 1.8V (see Note 1) Chip Select 0 for SPI1. 3.3V or 1.8V (see Note 1) McBSP2 Receive Data. Logic Product Development Company, All Rights Reserved 29 AM35x SOM-M2 Hardware Specification Microprocessor Name MCSPI1_CS1/ADP LLV2D_DITHERIN G_EN2/MMC3_CM D/GPIO_175 — MCSPI1_CS2/MM C3_CLK/GPIO_17 6 — MCSPI1_CS3/HSU SB2_TLL_DATA2/ HSUSB2_DATA2/ GPIO_177/MM_FS USB2_TXDAT — — MCSPI2_CLK/HSU SB2_TLL_DATA7/ HSUSB2_DATA7/ GPIO_178 MCSPI2_CS1/GPT 8_PWM_EVT/HSU SB2_TLL_DATA3/ HSUSB2_DATA3/ GPIO_182/MM_FS USB2_TXEN_N MCSPI2_SOMI/GP T10_PWM_EVT/H SUSB2_TLL_DAT A5/HSUSB2_DAT A5/GPIO_180 MCSPI2_CS0/GPT 11_PWM_EVT/HS USB2_TLL_DATA 6/HSUSB2_DATA6 /GPIO_181 MCSPI2_SIMO/GP T9_PWM_EVT/HS USB2_TLL_DATA 4/HSUSB2_DATA4 /GPIO_179 J2 Pin# SOM Net Name 89 90 uP_SPI1_SCSn1 RFU 91 92 uP_SPI1_SCSn2 RFU 93 94 95 uP_SPI1_SCSn3 RFU RFU 96 uP_SPI2_CLK 97 uP_SPI2_SCSn1 98 uP_SPI2_SOMI 99 uP_SPI2_SCSn0 100 uP_SPI2_SIMO I/O Voltage Description 3.3V or 1.8V O (see Note 1) Chip Select 1 for SPI1. NA NA Reserved for future use. Do not connect. 3.3V or 1.8V Chip Select 2 for SPI1. This signal has a 47 O (see Note 1) ohm series resistor on the SOM. NA NA Reserved for future use. Do not connect. 3.3V or 1.8V O (see Note 1) Chip Select 3 for SPI1. NA NA Reserved for future use. Do not connect. NA NA Reserved for future use. Do not connect. O 3.3V or 1.8V SPI2 Clock signal. This signal has a 22 (see Note 1) ohm series resistor on the SOM. O 3.3V or 1.8V (see Note 1) Chip Select 1 for SPI2. I 3.3V or 1.8V (see Note 1) SPI2 Slave Out, Master In signal. O 3.3V or 1.8V (see Note 1) Chip Select 0 for SPI2. O 3.3V or 1.8V (see Note 1) SPI1 Slave In, Master Out signal. NOTE 1: Most AM3517 SOM-M2 I/O pins are dual-voltage capable; that is, the SOM I/O pins may be configured to operate at 3.3V or 1.8V; however, all IO pins must be set to the same voltage. The desired I/O voltage is set via J1.37. See Section 4.5.2 for more information. NOTE 2: Route Ethernet signals as 50 ohms single ended, 100 ohm differential. 6.3 J3 Connector 100-Pin Descriptions J3 Pin# SOM Net Name 1 up_DSS_DOUT16 PN 1014249 Rev A Microprocessor Name DSS_DATA16/GPI O_86 I/O Voltage Description 3.3V or 1.8V O (see Note 1) DSS bus data bit 16. Logic Product Development Company, All Rights Reserved 30 AM35x SOM-M2 Hardware Specification Microprocessor Name J3 Pin# SOM Net Name 2 up_SYS_BOOT2 3 up_DSS_DOUT17 4 up_SYS_BOOT5 5 up_DSS_DOUT18 6 HDQ_SIO 7 8 up_DSS_DOUT19 PM_I2C_SCL 9 10 up_DSS_DOUT20 PM_I2C_SDA 11 up_DSS_DOUT21 12 up_SYS_BOOT0 13 14 up_DSS_DOUT22 RFU 15 up_DSS_DOUT23 16 17 SYS_CLKREQ RFU 18 19 20 uP_OBSCLK DGND DGND PN 1014249 Rev A SYS_BOOT2/GPI O_4 DSS_DATA17/GPI O_87 I/O Voltage I O Description Boot Select 2. This signal may be used as a GPIO after the boot process is complete. This signal must not have a load during boot so the boot sequence is 3.3V or 1.8V not disrupted. This signal has a 4.7k pull(see Note 1) up. 3.3V or 1.8V (see Note 1) DSS bus data bit 17. Boot Select 5. This signal may be used as a GPIO after the boot process is complete. This signal must not have a load during boot so the boot sequence is 3.3V or 1.8V not disrupted. This signal has a 4.7k pull(see Note 1) down. SYS_BOOT5/MMC 2_DIR_DAT3/GPI O_7 I DSS_DATA18/MC 3.3V or 1.8V SPI3_CLK/DSS_D ATA4/GPIO_88 O (see Note 1) DSS bus data bit 18. HDQ_SIO/SYS_AL TCLK/I2C2_SCCB E/I2C3_SCCBE/G 3.3V or 1.8V PIO_170 I/O (see Note 1) One wire interface signal. DSS_DATA19/MC 3.3V or 1.8V SPI3_SIMO/DSS_ DATA3/GPIO_89 O (see Note 1) DSS bus data bit 19. NA I — Power measurement I2C clock signal. DSS_DATA20/MC SPI3_SOMI/DSS_ 3.3V or 1.8V DATA2/GPIO_90 O (see Note 1) DSS bus data bit 20. NA I/O — Power measurement I2C data signal. DSS_DATA21/MC SPI3_CS0/DSS_D 3.3V or 1.8V ATA1/GPIO_91 O (see Note 1) DSS bus data bit 21. Boot Select 0. This signal may be used as a GPIO after the boot process is complete. This signal must not have a load during boot so the boot sequence is SYS_BOOT2/GPI 3.3V or 1.8V not disrupted. This signal has a 4.7k pullO_2 I (see Note 1) down. DSS_DATA22/MC 3.3V or 1.8V SPI3_CS1/DSS_D ATA0/GPIO_92 O (see Note 1) DSS bus data bit 22. — NA N/A Reserved for future use. Do not connect. DSS_DATA23/DS S_DATA5/GPIO_9 3.3V or 1.8V O (see Note 1) DSS bus data bit 23. 3 Active high. SYS_CLKREQ is connected to the enable of the 26MHz main clock oscillator. This signal may be driven high when the SOM is in sleep state to drive SYS_CLKOUT1 (uP_OBSCLK) out without waking the AM3517. Please see SYS_CLKREQ/GP 3.3V or 1.8V TI’s AM35xx Reference Manual for more IO_1 I (see Note 1) information. — NA NA Reserved for future use. Do not connect. SYS_CLKOUT1/G 3.3V or 1.8V AM35x output clock (26MHz). This signal PIO_10 O (see Note 1) has a 22 ohm series resistor on the SOM. VSS I GND Ground. Connect to digital ground. VSS I GND Ground. Connect to digital ground. Logic Product Development Company, All Rights Reserved 31 AM35x SOM-M2 Hardware Specification J3 Pin# SOM Net Name 21 uP_McBSP4_CLKX 22 uP_McBSP3_CLKX 23 uP_McBSP4_DX 24 uP_McBSP3_DX 25 uP_McBSP4_DR 26 uP_McBSP3_DR 27 uP_McBSP4_FSX 28 29 uP_McBSP3_FSX BUFF_DIS 30 31 CCDC_D0 RFU 32 33 CCDC_D1 RFU 34 35 36 37 CCDC_D2 WLAN_RS232_RX RFU WLAN_RS232_TX 38 39 MMC2_D4 UART_DBG 40 41 MMC2_D5 BT_DBG 42 43 MMC2_D6 RFU 44 45 MMC2_D7 RFU PN 1014249 Rev A Microprocessor Name MCBSP4_CLKX/G PIO_152/MM_FSU SB3_TXSE0 MCBSP3_CLKX/U ART2_TX/GPIO_1 42/0 MCBSP4_DX/GPI O_154/0/MM_FSU SB3_TXDAT MCBSP3_DX/UAR T2_CTS/GPIO_14 0/0 MCBSP4_DR/GPI O_153/0/MM_FSU SB3_RXRCV MCBSP3_DR/UAR T2_RTS/GPIO_14 1/0 MCBSP4_FSX/GPI O_155/0/MM_FSU SB3_TXEN_N MCBSP3_FSX/UA RT2_RX/GPIO_14 3/0 — CCDC_DATA0/I2C 3_SDA/GPIO_99 — CCDC_DATA1/GP IO_100 — CCDC_DATA2/GP IO_101/HW_DBG4 NA — NA MMC2_DAT4/MM C2_DIR_DAT0/MM C3_DAT0/GPIO_1 36 — MMC2_DAT5/MM C2_DIR_DAT1/MM C3_DAT1/GPIO_1 37/MM_FSUSB3_ RXDP — MMC2_DAT6/MM C2_DIR_CMD/MM C3_DAT2/GPIO_1 38/0 — MMC2_DAT7/MM C2_CLKIN/MMC3_ DAT3/GPIO_139/0 /MM_FSUSB3_RX DM — I/O Voltage Description O 3.3V or 1.8V (see Note 1) McBSP4 Transmit Clock signal. O 3.3V or 1.8V (see Note 1) McBSP3 Transmit Clock signal. O 3.3V or 1.8V (see Note 1) McBSP4 Transmit Data signal. O 3.3V or 1.8V (see Note 1) McBSP3 Transmit Data signal. I 3.3V or 1.8V (see Note 1) McBSP4 Receive Data signal. I 3.3V or 1.8V (see Note 1) McBSP3 Receive Data signal. O 3.3V or 1.8V (see Note 1) McBSP4 Transmit Sync signal. 3.3V or 1.8V (see Note 1) NA 3.3V or 1.8V I (see Note 1) NA NA 3.3V or 1.8V I (see Note 1) NA NA 3.3V or 1.8V I (see Note 1) I 1.8V NA NA O 1.8V O I McBSP3 Transmit Sync signal. Used for test only. Do not connect. CCDC bus data bit 0. Reserved for future use. Do not connect. CCDC bus data bit 1. Reserved for future use. Do not connect. CCDC bus data bit 2. Used for test only. Do not connect. Reserved for future use. Do not connect. Used for test only. Do not connect. 3.3V or 1.8V I/O (see Note 1) MMC2 data bit 4. O 1.8V Used for test only. Do not connect. 3.3V or 1.8V I/O (see Note 1) MMC2 data bit 5. O 1.8V Used for test only. Do not connect. 3.3V or 1.8V I/O (see Note 1) MMC2 data bit 6. NA NA Reserved for future use. Do not connect. 3.3V or 1.8V I/O (see Note 1) MMC2 data bit 7. NA NA Reserved for future use. Do not connect. Logic Product Development Company, All Rights Reserved 32 AM35x SOM-M2 Hardware Specification J3 Pin# SOM Net Name Microprocessor Name 46 NAND_SEL — I 47 48 49 50 51 USB1_CPEN RFU RFU RFU DGND NA — — — — O NA NA NA I 52 53 uP_RESWARMn RFU SYS_NRESWARM 3.3V or 1.8V I/O (see Note 1) /GPIO_30 — NA NA 54 55 56 57 58 59 RESOUTn RFU RFU RFU RFU RFU NA — — — — — 60 61 uP_I2C1_SCL RFU I2C1_SCL — 62 uP_I2C1_SDA 63 64 ETK_D15 RSRV01 65 66 3.3V_or_1.8V RSRV02 67 68 3.3V_or_1.8V RSRV10 69 ETK_D14 I2C1_SDA ETK_D15/HSUSB2 _DATA1/GPIO_29/ MM_FSUSB2_TXS E0/HSUSB2_TLL_ 3.3V or 1.8V DATA1/HW_DBG1 7 I/O (see Note 1) ETK bus data bit 15. — NA NA Reserved for future use. Do not connect. I/O Voltage Output from SOM. Do not use 3.3V or 1.8V this as a general purpose power source. VDDSHV O (see Note 1) Use this pin to power level shifters etc. — NA NA Reserved for future use. Do not connect. I/O Voltage Output from SOM. Do not use 3.3V or 1.8V this as a general purpose power source. VDDSHV O (see Note 1) Use this pin to power level shifters etc. — NA NA Reserved for future use. Do not connect. ETK_D14/HSUSB2 _DATA0/GPIO_28/ MM_FSUSB2_RX RCV/HSUSB2_TL 3.3V or 1.8V L_DATA0/HW_DB G16 I/O (see Note 1) ETK bus data bit 14. PN 1014249 Rev A I/O Voltage 3.3V or 1.8V (See Note 1) 3.3V NA NA NA GND Description Select line to choose between GPMC_nCS0 and GPMC_nCS2 for NAND. NAND_SEL high (default) will send GPMC_nCS0 to NAND; NAND_SEL low will send GPMC_nCS2 to NAND. Please refer to the Application Board schematics for an example of external chip select usage. External VBUS power supply control for USB1. Please see the SMSC USB3320 Datasheet for more information. Reserved for future use. Do not connect. Reserved for future use. Do not connect. Reserved for future use. Do not connect. Ground. Connect to digital ground. Active low. Reset output from the AM3517 microprocessor. This signal is open collector only. There should be no pull-ups on this line. Use RESOUTn to drive external device reset lines. Reserved for future use. Do not connect. Active low. Buffered reset output from the AM3517 microprocessor that drives all onboard reset inputs. This signal should be used to drive reset inputs on external chips that require similar timing to the onboard devices. Reserved for future use. Do not connect. Reserved for future use. Do not connect. Reserved for future use. Do not connect. Reserved for future use. Do not connect. Reserved for future use. Do not connect. 3.3V or 1.8V (see Note 1) NA NA NA NA NA 3.3V or 1.8V O (see Note 1) I2C1 clock signal. NA NA Reserved for future use. Do not connect. 3.3V or 1.8V I/O (see Note 1) I2C1 data signal. O NA NA NA NA NA Logic Product Development Company, All Rights Reserved 33 AM35x SOM-M2 Hardware Specification 71 72 ETK_D13 RSRV12 73 74 ETK_D12 RSRV13 75 76 uP_HSUSB1_CLK RSRV14 77 78 79 80 uP_HSUSB1_STP RSRV15 DGND DGND 81 ETK_D11 Microprocessor Name — ETK_D13/HSUSB2 _NXT/GPIO_27/M M_FSUSB2_RXD M/HSUSB2_TLL_ NXT/HW_DBG15 — ETK_D12/HSUSB2 _DIR/GPIO_26/HS USB2_TLL_DIR/H W_DBG14 — ETK_CTL/MMC3_ CMD/HSUSB1_CL K/GPIO_13/MM_F SUSB1_RXDP/HS USB1_TLL_CLK/H W_DBG1 — ETK_CLK/MCBSP 5_CLKX/MMC3_C LK/HSUSB1_STP/ GPIO_12/HSUSB1 _TLL_STP/HW_D BG0 — — — ETK_D11/MCSPI3 _CLK/HSUSB2_ST P/GPIO_25/MM_F SUSB2_RXDP/HS USB2_TLL_STP/H W_DBG13 82 uP_TCK TCK 83 ETK_D10 — 84 uP_RTCK 85 uP_HSUSB1_NXT RTCK/ GP8[0] ETK_D9/SYS_SE CURE_INDICATO R/MMC3_DAT5/H SUSB1_NXT/GPIO _23/MM_FSUSB1_ RXDM/HSUSB1_T LL_NXT/HW_DBG 11 86 uP_EMU1 87 uP_HSUSB1_DIR J3 Pin# SOM Net Name 70 RSRV11 PN 1014249 Rev A EMU1 ETK_D8/SYS_DR M_MSECURE/MM C3_DAT6/HSUSB 1_DIR/GPIO_22/H SUSB1_TLL_DIR/ HW_DBG10 I/O Voltage NA NA Description Reserved for future use. Do not connect. 3.3V or 1.8V I/O (see Note 1) ETK bus data bit 13. NA NA Reserved for future use. Do not connect. 3.3V or 1.8V I/O (see Note 1) ETK bus data bit 12. NA NA Reserved for future use. Do not connect. 3.3V or 1.8V O (see Note 1) Not connected on the SOM (R1 absent). NA NA Reserved for future use. Do not connect. O NA I I 3.3V or 1.8V (see Note 1) NA GND GND 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V I (see Note 1) 3.3V or 1.8V I/O (see Note 1) 3.3V or 1.8V O (see Note 1) High speed USB1 bus STOP signal. Reserved for future use. Do not connect. Ground. Connect to digital ground. Ground. Connect to digital ground. ETK bus data bit 11. JTAG TCK signal. ETK bus data bit 10. JTAG RTCK signal. I 3.3V or 1.8V (see Note 1) High speed USB1 bus NEXT signal. uP_EMU1 is part of the JTAG interface. Please reference TI’s AM35xx Reference 3.3V or 1.8V Manual for more information. This signal (see Note 1) has a 4.7k pull-up on the SOM. O 3.3V or 1.8V (see Note 1) High speed USB1 bus direction. O Logic Product Development Company, All Rights Reserved 34 AM35x SOM-M2 Hardware Specification J3 Pin# SOM Net Name 88 uP_EMU0 89 uP_HSUSB1_D3 90 uP_TDO 91 uP_HSUSB1_D6 92 uP_TDI 93 uP_HSUSB1_D5 94 uP_TMS 95 uP_HSUSB1_D4 96 uP_TRSTn 97 uP_HSUSB1_D7 98 uP_HSUSB1_D0 99 uP_HSUSB1_D2 PN 1014249 Rev A Microprocessor Name I/O Voltage Description uP_EMU0 is part of the JTAG interface. Please reference TI’s AM35xx Reference 3.3V or 1.8V Manual for more information. This signal (see Note 1) has a 4.7k pull-up on the SOM. EMU0 I ETK_D3/MCSPI3_ CLK/MMC3_DAT3/ HSUSB1_DATA7/ GPIO_17/HSUSB1 3.3V or 1.8V _TLL_DATA7/HW_ I/O (see Note 1) DBG5 3.3V or 1.8V TDO O (see Note 1) ETK_D6/MCBSP5 _DX/MMC3_DAT2/ HSUSB1_DATA6/ GPIO_20/HSUSB1 3.3V or 1.8V _TLL_DATA6/HW_ I/O (see Note 1) DBG8 3.3V or 1.8V TDI I (see Note 1) ETK_D5/MCBSP5 _FSX/MMC3_DAT 1/HSUSB1_DATA5 /GPIO_19/HSUSB 3.3V or 1.8V 1_TLL_DATA5/HW I/O (see Note 1) _DBG7 3.3V or 1.8V TMS I (see Note 1) ETK_D4/MCBSP5 _DR/MMC3_DAT0/ HSUSB1_DATA4/ GPIO_18/HSUSB1 3.3V or 1.8V _TLL_DATA4/HW_ I/O (see Note 1) DBG6 3.3V or 1.8V TRST I (see Note 1) ETK_D3/MCSPI3_ CLK/MMC3_DAT3/ HSUSB1_DATA7/ GPIO_17/HSUSB1 3.3V or 1.8V _TLL_DATA7/HW_ I/O (see Note 1) DBG5 ETK_D0/MCSPI3_ SIMO/MMC3_DAT 4/HSUSB1_DATA0 /GPIO_14/MM_FS USB1_RXRCV/HS 3.3V or 1.8V USB1_TLL_DATA I/O (see Note 1) 0/HW_DBG2 ETK_D2/MCSPI3_ CS0/HSUSB1_DA TA2/GPIO_16/MM _FSUSB1_TXDAT/ 3.3V or 1.8V HSUSB1_TLL_DA I/O (see Note 1) TA2/HW_DBG4 High speed USB1 bus data bit 3. JTAG TDO signal. High speed USB1 bus data bit 6. JTAG TDI signal. High speed USB1 bus data bit 5. JTAG TMS signal. High speed USB1 bus data bit 4. JTAG TRSTn signal. High speed USB1 bus data bit 7. High speed USB1 bus data bit 0. High speed USB1 bus data bit 2. Logic Product Development Company, All Rights Reserved 35 AM35x SOM-M2 Hardware Specification J3 Pin# SOM Net Name 100 uP_HSUSB1_D1 Microprocessor Name I/O Voltage Description ETK_D1/MCSPI3_ SOMI/HSUSB1_D ATA1/GPIO_15/M M_FSUSB1_TXSE 3.3V or 1.8V 0/HSUSB1_TLL_D I/O (see Note 1) High speed USB1 bus data bit 1. ATA1/HW_DBG3 NOTE 1: Most AM3517 SOM-M2 I/O pins are dual-voltage capable; that is, the SOM I/O pins may be configured to operate at 3.3V or 1.8V; however, all IO pins must be set to the same voltage. The desired I/O voltage is set via J1.37. See Section 4.5.2 for more information. PN 1014249 Rev A Logic Product Development Company, All Rights Reserved 36 8 7 6 4 5 1 2 3 REV. A Appendix A: AM35x SOM-M2 Mechanical Drawing (with Wireless) REVISIONS DESCRIPTION INITIAL ENGINEERING RELEASE ECO NUMBER C029634 DATE 07.21.10 51.2 (REF) F F NOTES: 36.1 40.9 (REF) E 1 DO NOT PLACE ANY COMPONENTS WITHIN LAYOUT AREA OF SOM 2 BASEBOARD CONNECTOR SPECIFICATION: HIROSE DF40C-100DS-0.4V 3 MACHINE PLACEMENT OF J1,J2, AND J3 IS HIGHLY RECOMMENDED 4 ALL ALIGNED COMPONENTS TO BE WITHIN .075 5. DO NOT SCALE DRAWING E J4 1.9 D 2x R1.2 TOP D 2.7 (MAX) 0 1.6 2.7 C C B B THIS DRAWING PREPARED IN ACCORDANCE WITH ASME Y14.5-2000 ALL DIMENSIONS ARE IN MILLIMETERS UNLESS OTHERWISE SPECIFIED TOLERANCES UNLESS OTHERWISE SPECIFIED X ± 0.5 X.X ± 0.2 X.XX ± 0.1 X° ± 1° BOTTOM A THIRD ANGLE PROJECTION ENG 5 4 REV 07.21.10 C AM35X SOM-M2 WITH WIRELESS 07.21.10 A SCALE DWG NO SHEET 3:1 1016392 1 OF 2 PMH MANF 6 TITLE KAG MGR 7 SIZE 07.21.10 CHECK 8 DATE NWR DATE DATE DATE 3 2 1 A 8 7 6 4 5 1 2 3 F F E E D D BOTTOM 40.7 35.560 .075 30.988 .075 0 10.5 TOP PIN LOCATIONS ISOMETRIC VIEWS FOR REFERENCE ONLY 13.9 C 1 2 1 1 4 B 1 C 2 3 J1 0 2 J3 99 100 J2 99 100 2 2 B 99 100 2 27 RECOMMENDED BASEBOARD FOOTPRINT A A 8 7 6 5 4 3 2 SIZE TITLE REV A C AM35X SOM-M2 WITH WIRELESS SCALE DWG NO SHEET 3:1 1016392 2 OF 2 1 8 7 6 4 5 1 2 3 Appendix B: AM35x SOM-M2 Mechanical Drawing (without Wireless) REV. A ECO NUMBER C06984 REVISIONS DESCRIPTION INITIAL ENGINEERING RELEASE DATE 10.30.09 B C029634 UPDATED PIN LOCATIONS ON BASEBOARD FOOTPRINT 07.21.10 51.2 (REF) F F NOTES: 36.1 40.9 (REF) E 1 DO NOT PLACE ANY COMPONENTS WITHIN LAYOUT AREA OF SOM 2 BASEBOARD CONNECTOR SPECIFICATION: HIROSE DF40C-100DS-0.4V 3 MACHINE PLACEMENT OF J1,J2, AND J3 IS HIGHLY RECOMMENDED 4 ALL ALIGNED COMPONENTS TO BE WITHIN .075 5. DO NOT SCALE DRAWING E J4 1.9 D 2x R1.2 TOP D 1.7 (MAX) 0 1.6 2.7 C C B B THIS DRAWING PREPARED IN ACCORDANCE WITH ASME Y14.5-2000 ALL DIMENSIONS ARE IN MILLIMETERS UNLESS OTHERWISE SPECIFIED TOLERANCES UNLESS OTHERWISE SPECIFIED X ± 0.5 X.X ± 0.2 X.XX ± 0.1 X° ± 1° BOTTOM A THIRD ANGLE PROJECTION ENG 5 4 REV 10.30.09 C AM35X SOM-M2 10.30.09 B SCALE DWG NO SHEET 3:1 1014529 1 OF 2 PMH MANF 6 TITLE KAG MGR 7 SIZE 10.30.09 CHECK 8 DATE MHC DATE DATE DATE 3 2 1 A 8 7 6 4 5 1 2 3 F F E E D D BOTTOM 40.7 35.560 .075 30.988 .075 0 10.5 TOP PIN LOCATIONS ISOMETRIC VIEWS FOR REFERENCE ONLY 13.9 C 1 2 1 1 4 B 1 C 2 3 J1 0 2 J3 99 100 J2 99 100 2 2 B 99 100 2 27 RECOMMENDED BASEBOARD FOOTPRINT A A 8 7 6 5 4 3 2 SIZE TITLE REV B C AM35X SOM-M2 SCALE DWG NO SHEET 3:1 1014529 2 OF 2 1 Appendix C: Example Retention Methods REV. A ECO NUMBER - REVISIONS DESCRIPTION INITIAL RELEASE DATE 02.12.10 NOTES: 1. BASED ON TESTING A LIMITED NUMBER OF SAMPLES, THE AM3517 SOM-M2 REQUIRES 10 LBS OF EXTRACTION FORCE AFTER ONE INSERTION CYCLE. AFTER 30 INSERTION AND EXTRACTION CYCLES, THIS IS REDUCED TO 7 LBS. THIS INFORMATION IS PROVIDED FOR REFERENCE ONLY. THIS DRAWING PREPARED IN ACCORDANCE WITH ASME Y14.5-2000 ALL DIMENSIONS ARE IN MILLIMETERS UNLESS OTHERWISE SPECIFIED TOLERANCES UNLESS OTHERWISE SPECIFIED X ± 0.5 X.X ± 0.2 X.XX ± 0.1 X° ± 1° THIRD ANGLE PROJECTION ENG DATE NWR 02.04.10 CHECK DATE KAG 02.04.10 MGR DATE PMH 02.12.10 MANF DATE SIZE TITLE REV A AM3517 SOM-M2 Retention System- None A SCALE DWG NO SHEET 1015273 1 OF 1 REV. ECO NUMBER A - REVISIONS DESCRIPTION DATE INITIAL RELEASE 02.12.10 NOTES: 1. THIS IS AN EXAMPLE RETENTION METHOD USING A CLIP. THIS DRAWING PREPARED IN ACCORDANCE WITH ASME Y14.5-2000 ALL DIMENSIONS ARE IN MILLIMETERS SPECIFIED TOLERANCES UNLESS OTHERWISE SPECIFIED X ± 0.5 X.X ± 0.2 X.XX ± 0.1 X° ± 1° THIRD ANGLE PROJECTION ENG DATE NWR 02.04.10 CHECK DATE KAG 02.04.10 MGR DATE PMH 02.12.10 MANF DATE SIZE TITLE REV A AM3517 SOM-M2 Retention System - Clip A SCALE DWG NO SHEET 1015274 1 OF 1 REV. ECO NUMBER A - REVISIONS DESCRIPTION DATE INITIAL RELEASE 02.12.10 NOTES: 1. THE AM3517 SOM-M2 CAN BE RETAINED IN PLACE BY THE SURROUNDING ENCLOSURE. 2. REPRESENTATIVE ENCLOSURE 2 THIS DRAWING PREPARED IN ACCORDANCE WITH ASME Y14.5-2000 ALL DIMENSIONS ARE IN MILLIMETERS UNLESS OTHERWISE SPECIFIED TOLERANCES UNLESS OTHERWISE SPECIFIED X ± 0.5 X.X ± 0.2 X.XX ± 0.1 X° ± 1° THIRD ANGLE PROJECTION ENG DATE NWR 02.04.10 CHECK DATE KAG 02.04.10 MGR DATE PMH 02.12.10 MANF DATE SIZE TITLE REV A AM3517 SOM-M2 Retention System - Housing A SCALE DWG NO SHEET 1015275 1 OF 1
SOMXAM3517-10-1780FJCR 价格&库存
很抱歉,暂时无法提供与“SOMXAM3517-10-1780FJCR”相匹配的价格&库存,您可以联系我们找货
