Premium 3D Printer Filament—PLA
PLA
Description
The Premium 3D Printer Filament—PLA is made of high purity polylactic acid (PLA) pellets with a tight
diameter tolerance.
Applications & Usages
The PLA filament is the optimal choice for use in homes, schools, and hobbyists. A heated print bed is not
required and when properly utilized, faster print speeds and lower layer heights can be achieved.
Benefits and Features
1.75 mm and 3.00 mm diameters
Low diameter variance
Vivid and unique colors such as Skin, Gold, Silver, Glow in the Dark, and so on
3D-Filament Processing Parameters
Working Temperature
Bed Temperature
Temperature a)
210—220 °C [410–428 °F]
Not Required
a) Values may vary depending on the printer type, environmental conditions, and color of filament.
Adjust print temperatures by 5 °C until ideal flow and bed adhesion is obtained.
3D-Filament Properties
Quality Control
Density
Method
ASTM D 1505
Value
1.24 g/cm3
Physical Properties
Tensile Strength
% Elongation
Young’s Modulus
Elmendorf Tear
Optical, Haze
Optical, Gloss 20°
Method
ASTM D 882, Machine Direction
ASTM D 1922, Machine Direction
ASTM D 1003
ASTM D 1003
Value
100 N/mm2
[15 000 lb/in2]
180%
3 500 N/mm2 [500 000 lb/in2]
670 g/mm
[17 g/mil]
2.1%
90%
Thermal Properties
Melting Point
Method
ASTM D 3418
Value
115—170 °C [239–338 °F]
Date: 06 January 2016 / Ver. 1.02
Page 1 of 4
PLA
Storage and Shelf Life
Store between 18 to 27 °C [65–80 °F] and protect from direct heat or sunlight. Keep sealed in an air tight
container, away from humidity.
Shelf Life
Unopened package
Opened package
Value
1 y from date of purchase
Variable depending on storage conditions
Health and Safety
Please see the Premium 3D Printer Filament-PLA Safety Data Sheet (SDS) for more details on
transportation, storage, handling and other security guidelines.
Environmental Impact: This product doesn’t have any known environmental toxicity.
This product meets the European Directive
2011/65/EU Annex II (ROHS);
recasting 2002/95/EC.
Health and Safety: This product is not considered to be hazardous for human health under normal use.
It is widely used in the packing and food industry.
HMIS® RATING
NFPA® 704 CODES
HEALTH:
FLAMMABILITY:
1
PHYSICAL HAZARD:
PERSONAL PROTECTION:
Approximate HMIS and NFPA Risk Ratings Legend:
0 (Low or none); 1 (Slight); 2 (Moderate); 3 (Serious); 4 (Severe)
Page 2 of 4
PLA
Packaging and Supporting Products
Available Colors
Translucent
White
Black
Red
Yellow
Green
Blue
Orange
Purple
Grey
Pink
Brown
Gold
Silver
Glow in the Dark
Skin
Navy
Lime
Available Sizes
Diameter
Filament Length
0.25 kg
spools
0.50 kg
spools
1.0 kg
spools
1.75 mm
3.00 mm
85 m
28.8 m
170 m
57.5 m
340 m
115 m
Spool Weight
Dimensions
Inner
diameter
Outer
diameter
Width
0.25 kg
0.50 kg
1.00 kg
32 mm
32 mm
57 mm
160 mm
160 mm
180 mm
57 mm
57 mm
92 mm
Diameter
Spool Weight
kg
Net Volume
L
qt
Net Weight
kg
lb
1.75 mm or 3.00 mm
0.25
0.50
1.0
0.202
0.403
0.806
0.213
0.426
0.852
0.25
0.50
1.0
0.55
1.1
2.2
Note: Some colors are not available in all sizes. Use the 3D filament Part Selection Tool for PLA on the
MG Chemical web site or click here.
Page 3 of 4
PLA
Supporting Products
3D Printing Masking Tape, Cat. No. MAS100-15, MAS200-15
3D Printing Polyimide Tape, Cat. No. POL100, POL200
Acetone, Cat. No. 434-1L, 434-4L
d-Limonene, Pure Grade: Cat. No. 433-1L, 433-4L
Technical Support
Contact us regarding any questions, improvement suggestions, or problems with this product. Application
notes, instructions, and FAQs are located at www.mgchemicals.com.
Email: support@mgchemicals.com
Phone: +1-800-340-0772 (Canada, Mexico & USA)
+1-905-331-1396 (International)
Fax: +1-905-331-2862 or +1-800-340-0773
Mailing address:
Manufacturing & Support
1210 Corporate Drive
Burlington, Ontario, Canada
L7L 5R6
Head Office
9347–193rd Street
Surrey, British Columbia, Canada
V4N 4E7
Warranty
M.G. Chemicals Ltd. warranties this product for 12 months from the date of purchase by the end user.
M.G. Chemicals Ltd. makes no claims as to shelf life of this product for the warranty. The liability of M.G.
Chemicals Ltd. whether based on its warranty, contracts, or otherwise shall in no case include incidental or
consequential damage.
Disclaimer
This information is believed to be accurate. It is intended for professional end users having the skills to
evaluate and use the data properly. M.G. Chemicals Ltd. does not guarantee the accuracy of the data and
assumes no liability in connection with damages incurred while using it.
Page 4 of 4
很抱歉,暂时无法提供与“PLA30TL1”相匹配的价格&库存,您可以联系我们找货
